AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon AVR-4310CI Thread
Denon AVR-4310CI Thread - Page 101
post #3001 of 5208
Originally Posted by jimbotron View Post
I notice that the trouble starts (AV dropping out when changing inputs) when the audio has been muted anytime the unit has been on.
Anyone else have the same thing?
(It would be nice if someone, anyone, replied to my 4310 problems...)
When I switch inputs, I have to turn off the unit and then turn it back on or else I get nothing.
post #3002 of 5208
Originally Posted by -dase- View Post
Sooo pissed...
It's been problem free...
now all the symptoms are there...
no network, no usb.... just hangs forever and freezes during "connecting"...
arrggghhhhhhhhhhhh network card dead...
That blows...
Here's a thought: I wonder, since it has been reported here recently that you can easily "replace" your network card, if you REMOVED the network card - would you get all functionality back, except for (of course) network features?
post #3003 of 5208
Originally Posted by kc8apf View Post
this is really annoying and rather unnecessary. No one is answering your question since the sound of a receiver will be colored heavily by the room, speakers, sources, etc. The best thing is to try one in your home with your equipment and see if it is to your liking.
+1
post #3004 of 5208
Mine was also doing this. The "network reset" described on the last page fixed this, but I still get no USB functionality, and no network functionality either...
I'll check in after the phone calls if there is anything but frustration to report. Thanks for the suggestions all.
Mine is still under warranty so I won't be fiddling with the card myself.
post #3005 of 5208
I have a AVR-4310ci
I installed a small monitor on another floor of the house, so I used one of those HDMI over internet Cat5 adapters Transmits HDMI audio/video signal via 2 CAT5e/CAT6 cables up to 180 feet
Part #: CB-HM0A12-S1
When plugged into my Direct TV DVR I get sound and picture about 20 feet away via network cable.
When I plug the Denon either to monitor 1 or 2 out I sometimes don't get a picture but never sound. It seems like the Denon does not sense a connection when not directly plugged into the Monitor downstairs.
Does anyone know how to solve this or have experience with this?
Thank you
post #3006 of 5208
This is a bit confusing ... are you saying you never "lose" sound or you never "get" sound? If the latter, and you are trying to send the audio to the downstairs monitor, have you changed the HDMI Audio Out setting to "TV"?
post #3007 of 5208
I have a question that I hope is not completely obvious, because I would feel pretty bad posting it here. Anyway, I run my cable box into the 4310 via HDMI and then run HDMI into the TV. It wall works great.
My question is, how do I go about watching cable TV while listening to either HD radio, or interent radio? I've tried playing with the input opions like auto, hdmi, digital for my cable source, but I don't think that gets me any closer to what I'm looking for.
Will I have to run component cables from the cable box striaght to the TV and then just play the radio out of the 4310?
For anyone wondering what the purpose is, I would like to watch football on the TV and listen to another game that isn't being televised.
post #3008 of 5208
Yep you will need to bypass the 4310 for this. The best is a HDMI switch that has 2 outputs so you can switch into 4310 or direct to TV.
Alternatively you can go with Component cables and standard audio cables as a bypass.
post #3009 of 5208
That's one option, however, this is what the Video Select feature is designed for although it doesn't work with HDMI sources. Therefore you'll need to also run a component cable from the cable box to the 4310 (set to a new source name) and then with the Tuner selected, change the Video Select setting to the new cable box source name.
post #3010 of 5208
** Think your Denon AVR is defective? Try the "Reset the Microprocessor" procedure (back of Owner's Manual)
I have never gotten "sound" via the Denon to the Monitor downstairs via the HDMI extender. I know the HDMI extender works since when I connect it to the DVR (without going thru the Denon) I get sound and picture. I have set the Denon to HDMI and when I run it directly to another monitor YES I get sound and picture. The only time I don't get sound is when I send HDMI from the Denon to the Monitor downstairs VIA the HDMI extender.
Does that make sense?
post #3011 of 5208
Got it ... there's an issue with the TV's EDID being passed from the HDMI extender to the 4310. Give the HDMI reset portion of the below a try.
Regardless of the brand of AVR, HDMI "handshake" issues often exist (video/audio problems) when connecting a cable/sat box to an HDMI repeater (ie. AVR). There are a few solutions that can be used to resolve this issue:
(1) Make sure the firmware on the cable/sat box is up to date
(2) Try the other HDMI jacks on the AVR first to see if the same issue exists
(3) HDMI reset procedure:
a. While the cable/sat box is on, disconnect HDMI cable from TV
b. Turn off power to the all devices (OFF, not in standby)
c. Disconnect HDMI cable from the cable/sat box to AVR at both ends
d. Wait 2 minutes
e. Reconnect all HDMI cables
f. Apply power to TV, then AVR, then cable/sat box
(4) Cable configuration work-around:
a. Connect a component and optical/coax cable from the cable/sat box to the AVR,
or,
b. Connect the HDMI cable from the cable/sat box to the TV and an optical/coax cable from the cable/sat box to the AVR
(5) Replace the cable/sat box with different model/mfr
(6) Sometimes adding an HDMI switch between the AVR and the TV will resolve this issue although will of course require an extra cost for the switch.
post #3012 of 5208
To bbar and jdsmootie: Thanks for the input. I'll give it a shot this weekend.
post #3013 of 5208
Much better!
post #3014 of 5208
Well getting the refurbished unit like everyone else on here. No parts for about 12 weeks in addition to the 3 months my unit has been in the repair shop. I don't know about anyone else but that is pretty unacceptable to me. I will be looking elsewhere for the next unit I buy.
post #3015 of 5208
I have had the network card issue since about March and have been in touch with Denon, but they want me to ship it from California to Factory Service Center PanurgyOEM in New Jersey. I only ever used the network connection for firmware upgrades as I have a HTPC and media server that handle all of my network stuff (internet radio, DVD/BD playback, etc.). I just don't want to be with out the unit for several months so I haven't sent it in. I go back and forth with the idea of sending it in sometimes I think I want a fully functioning unit and other times I am perfectly happy with the unit as is. Like many others here I have owned several Denon's and have been loyal to their Brand for a long time, but based on how they have handled this problem I can say that I will consider other Brands for my next purchase.
post #3016 of 5208
As long as the factory has the NIC in stock there's no reason it should take more than a week or two. Although as it's fairly easy to replace, you might want to find a local repair shop that can replace it for you once they receive it in house, reducing your out of pocket time.
post #3017 of 5208
I initially came to this Forum for information, and assistance on proper set up for my AVR-4310CI, purchased in early July, 2010. I had high expectations for its use as a home entertainment center based on my previous ownership of an AVR-3300 that provided many years of enjoyable, and trouble free service to my family.
I must give AVS Forum stand out member Batpig many thanks for his contributions on many topics and time saving tips pertaining to the Denon AVR.
In the past forty years and starting with kit built amps, preamps, and FM tuners, I have owned many consumer grade and esoteric stereo component systems, including those manufactured by Denon. I currently integrate into my system a Denon DRM-800A cassette tape deck that after twenty years plays flawlessly. I can state that I have never purchased a component, with the exception of an early model Nakamichi cd player, that out of the box or during its long term use exhibited a design or electronic component flaw.
Like many of this forums members coming here for information, I share a problem with my system network card that manifested on initial set up on July, 3, and after performing the early July software update. By dumb luck I worked through the update error and freeze problems, after three hours, and four attempts through a hard wired Ethernet connection to a router configured for DHCP. I successfully installed the updates after rebooting the AVR, DSL modem, and router, and with the exception of the crippled network card issue, have a functioning AVR.
For its intended use and duty as a consumer grade home theater audio, and video processing center it exceeds my expectations. I do have an occasional audio drop out on Sat TV that I attribute to a HDMI handshake issue, somewhere in the system link, even when in the AVR stand by pass through mode. I ran the Audyssess set up program six or seven times based on tips from the Denon and Audyssess forums and am pleased with the settings for 5.1 channel DVD and Blu-Ray playback. Two channel source music from cd's, and tape has lost some impact in bass and low midrange as reported by other forum members. I am benchmarking my speaker sound performance based on my prior AVR-3300 which was amplifier rated at 105 watts per channel, all channels driven. CD, SACD, DVD, and Blue-Ray Video playback is deftly handled by an Oppo 80 Blue-Ray player used as a transport, with all video and audio processed by the AVR with aplomb.
On one key point Denon missed a home run, falling just short of home base, and scoring zero. Frankly, I am deeply concerned about the network issues, and out of the box build quality with this AVR family.
Due to lack of communication and my perceived obfuscation from Denon for the network failure, my quest for information on this concern has taken me to sleuth the local Big Box Denon retail stores, whom appear to have large inventories of refurbished 3310CI and 4310CI units on the shelves, and reading all the threads in the Denon 3310, 3311, 4310, 4311 forums. A 3311 forum member provided a link to an authorized Denon installer's forum which documents his correspondence with a Denon Installers Group representative. In this correspondence the certified installer claims an eighty percent failure rate on new installs of 3310, 3311, 4310, and 4311 models. His major gripe as a professional installer is his loss of reputation to his customers and lost profits due to multiple defective units for a single installation, thus causing further lost work man hours. A forum member recently posted his experience and conversation with his local Denon authorized repair center. He is informed there is an issue with insufficient memory chip capacity integrated into the network card board, and as a repair, he replaces the network card board with a Denon replacement board that incorporates more memory chip capacity.
It is my intuitive opinion, and learned speculation that after a year of reported network problems or failures encompassing an entire years production run for the AVR-3310CI and 4310CI models, and then running into the next model year for the 3311CI and 4311CI, with all sharing the same defect either by lack of quality control or circuit design, to continue sales of known defective units is a deceptive and conscious business decision evidenced by the lack of communication by Denon. This places the consumer in the unfair position of paying for return shipment and loss of use. Due to deception and obfuscation of the known network problem by Denon, installers, and consumers are bearing the burden.
I would further suspect that the high failure rate has placed a burden on available replacement parts inventory, and impacted repair facility repair turn around time. I would further suspect that for Denon to cut losses, and for dealers to maintaining profit margins, the many refurbished units received priority in the repair chain process.
post #3018 of 5208
Hi,
I am new to the forum. I recently bought a 4310ci and have been setting it up over the last few days. When I switch inputs the volume level changes quite a bit across inputs. When I run my DVD player (connected by optical to the receiver) the volume level that is my target loudness is around -18db. When I switch to my cbl/sat box (comcast HD DVR connected by coaxial) I need to turn it up to about 0db to get a similar volume. When I switch to the network input and play internet redio I need to turn it down to around -36db to get a similar level. I don't know if I am missing something obvious in setting the receiver up or not. Any thoughts would be appreciated. Thanks.
post #3019 of 5208
Each input has a Source Level setting (p. 50) that can be adjusted from -12db to +12db.
post #3020 of 5208
Thanks very much I'll try that and see if it solves the problem.
post #3021 of 5208
I must give AVS Forum “stand out” member Batpig many thanks for his contributions on many topics and time saving tips pertaining to the Denon AVR.
For its intended use and duty as a consumer grade home theater audio, and video processing center it exceeds my expectations. I do have an occasional audio drop out on Sat TV that I attribute to a HDMI handshake issue, somewhere in the system link, even when in the AVR stand by pass through mode. I ran the Audyssess set up program six or seven times based on tips from the Denon and Audyssess forums and am pleased with the settings for 5.1 channel DVD and Blu-Ray playback. Two channel source music from cd’s, and tape has lost some impact in bass and low midrange as reported by other forum members. I am benchmarking my speaker sound performance based on my prior AVR-3300 which was amplifier rated at 105 watts per channel, all channels driven. CD, SACD, DVD, and Blue-Ray Video playback is deftly handled by an Oppo 80 Blue-Ray player used as a transport, with all video and audio processed by the AVR with aplomb.
Due to lack of communication and my perceived obfuscation from Denon for the network failure, my quest for information on this concern has taken me to sleuth the local Big Box Denon retail stores, whom appear to have large inventories of refurbished 3310CI and 4310CI units on the shelves, and reading all the threads in the Denon 3310, 3311, 4310, 4311 forums. A 3311 forum member provided a link to an authorized Denon installer’s forum which documents his correspondence with a Denon Installers Group representative. In this correspondence the certified installer claims an eighty percent failure rate on new installs of 3310, 3311, 4310, and 4311 models. His major gripe as a professional installer is his loss of reputation to his customers and lost profits due to multiple defective units for a single installation, thus causing further lost work man hours. A forum member recently posted his experience and conversation with his local Denon authorized repair center. He is informed there is an issue with insufficient memory chip capacity integrated into the network card board, and as a repair, he replaces the network card board with a Denon replacement board that incorporates more memory chip capacity.
It is my intuitive opinion, and learned speculation that after a year of reported network problems or failures “encompassing an entire years production run” for the AVR-3310CI and 4310CI models, and then running into the next model year for the 3311CI and 4311CI, with all sharing the same defect either by lack of quality control or circuit design, to continue sales of known defective units is a deceptive and conscious business decision evidenced by the lack of communication by Denon. This places the consumer in the unfair position of paying for return shipment and loss of use. Due to deception and obfuscation of the known network problem by Denon, installers, and consumers are bearing the burden.
Always hard to tell what is a pattern and what is coincidence. Folks assailed me when I brought up the POD issue with last year's receivers from Denon's sister company Marantz, but time and repeated occurrence demonstrated that there was a very uncomfortable and widespread issue with the compatability of the 5004 and 6004 that even persists with refurbished models.
To me, obfuscation or merely a blind eye is the largest sin - componentry and design can be flawed - but the quality of any company in its products or services is solely underpinned by its honesty and conviction to its customer base.
That said, I own three Denon receivers currently and have owned numerous in the past, and overall, believe them to be high quality products. I did go 0 for 3 on 3310s whose network capability/features worked consistently.
post #3022 of 5208
"I did go 0 for 3 on 3310s whose network capability/features worked consistently."??????
So, you had three failed 3310s or they worked?????
post #3023 of 5208
Why would anyone go through three "good" units? I think you answered your own question...
post #3024 of 5208
It's Winston, He tests a lot of blurays and receivers and posts their results in his blog...
post #3025 of 5208
So, does this say Class Action suit against Denon?
post #3026 of 5208
Doubtful as it only effects "some" of the early releases of last year's 3310 and 4310 as the newer mfr'd units as well as the 3311 and 4311 have the newer NIC installed.
post #3027 of 5208
I have yet to send my 4310 in for repair. Various car problems have kept me sidelined.
Anyway, I tried the network reset that jdsmoothie described earlier (up + down on startup).
Like -dase- described, this fixed the problem of AV dropping out between inputs (which required me turning off and then on to get any functionality). I can now switch between inputs without the unit locking up. But as -dase- described as well, I have no network connection at all and none of the network menu items are selectable (so I cannot manually set the connection).
This is a question for jdsmoothie or someone else intimately familiar with Denon products.
When turning on the unit, there are three distinctive clicks, two of which come immediately, and then a third click just before the sound turns on. (CLICKCLICK..........CLICK) When the 4310 had the problem of AV cutting out between inputs, there were only two clicks; one at startup and then one before the sound comes on (CLICK..............CLICK). Does anyone know what was going on? What is the significance of those initial clicks? After the network reset, the 4310 no longer bricks between inputs, and it's back to having three clicks at startup.
post #3028 of 5208
Can't say for sure, but likely the pattern/number of "clicks" on startup identify whether the AVR's processor is booting up properly just as the pattern/number of "beeps" indicate your PC is booting up properly.
post #3029 of 5208
i have ordered the new nic card from pacparts....149.60 shipped...14 days till dilevery.......
was not gonna wait 12 weeks for repair.........
the nic card is super easy to remove.......im gonna hang on to the old one in case of future warrenty issues...LOL
post #3030 of 5208
Did you order directly from Denon? I would prefer doing this over risking shipping the unit plus waiting the 2 or 3 months turn around. Did they provide you with a part number? I am extremely disgusted with Denon over this and when you call their support they say "what network card problem" which is like rubbing salt in an open wound. I have some friends wanting to put in new surround system and I will not recommend Denon to them.
