Originally Posted by duc135
The Oppo will send both video and audio out all outputs simultaneously with the exception to HDMI 1 which the audio can be muted. So if you have HDMI 1 connected to the Kuro and HDMI 2 connected to the 4310 you will be able to watch from either source.
I have my 93 connected exactly this way. HDMI 1 goes directly to my Kuro while HDMI 2 goes to my 4311 then to another input on the Kuro. For color space I use Video RGB for HDMI 1 direct to the Kuro and 30 bit dithered. For HDMI 2 I use 4:2:2/30 bit since the 4311 can't handle anything above that. One thing to note is that I have not had the time to test these settings using calibration disks yet and am only going by what others have suggested on the Oppo thread. I have HDMI 1 set to the primary display with video only set to on.
Thank you so much for your quick and informative reply. I will give those settings a go on my set-up too. I really recommend the Spears & Munsil calibration disc if you have the time and inclination. Thank you again!
But damn!
Takes SOOOOOOO LOOOOOOOONG to DL?!
