Originally Posted by Splicer010
Flashing on output 1 HDMI, all connected components via HDMI, as well as component to HDMI. Output HDMI 2, zero flashing. Have not tried the Wii (component to HDMI) yet.
Is there a known problem/fix that addresses this problem or is it just me? What is the difference between outout HDMI 1/2? I was under the impression there was no difference?
Do I need to send the 4310 in for repair...again?
Background: Never an issue (no flashing) till an Oppo 93 was connected to the system in a direct replacement of a LG BDP. I am certain it is coincidence and nothing to do with the Oppo itself, however even after returning to the original system configuration, the flashing has increased in frequency it seems. Oh yes, the display is a Mitsubishi 73733. Once switched to output HDMI 2, all flashing has ceased, tho I have read on others it has returned on output HDMI 2 also.
Wow! No one? Really?
, my first question is, did you rerun Audyssey with your new speakers? Beyond that, it becomes a complex discussion. For ex., what exactly do you mean by "Manual EQ"-did you use Base curve copy or have you tweaked the graphic EQ yourself and what are the curves like, are tone controls off, etc. Also of interest is the "at night" remark-if it means lower volume, are you using Audyssey with DEQ on?
Found it, got it, thnx!
