AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › optimizing for front row vs back row: implications on riser
post #1 of 9
I've been fighting the riser height calculator for a few hours now trying to determine how to get the dang thing under 16" or so (which is impractical for all of the obvious reasons).
Bryan Bape and I originally settled on the REAR row to optimize the acoustical design . As a result, the front row is quite close to the screen (1.1x or so), and the rear row gets the sweet spot in sound and field of view.
However, pushing the entire seating area back by about 10 - 12" makes a significant difference with the height of the riser and was a factor I had forgotten about completely. If I pushed the seating area even farther, to make the front row where the rear is now, then I would be able to get even lower on the riser height.
So what did you guys go with? Optimizing the front row, or optimizing the back row?
post #2 of 9
Just one little cheat tip. Put a lifter riser just under the last row seats, like a 2 inch mini riser. Carpet to match and it will disappear. You preserve headroom when standing but get the needed height. Kind of like putting the chair on a thick phone book. Take one of your chairs and put it on blocks. You will find that you don't even notice it getting in and out.
post #3 of 9
Yeah, I look at a ton of risers beforehand. I also toyed with the idea of doing one of the risers that just under the chair, with a step in front, and no riser between the rows. This has a similar advantage but I discarded that idea.
I will likely do the mini-riser regardless of the final height requirements. That is, if I have a 10" riser requirement, I will frame an 8" riser, etc.
In my discussions with Bryan, we chose to an either/or scenario for which row will get the sweet spot in acoustical design, but I may see about compromising all of the seats to get a sub-sweet-spot for two rows.
post #4 of 9
Also: has anyone explored the idea of simply extending the feet of the chairs on the seats, instead of a mini-riser?
I'm thinking a couple of hockey pucks screwed to the underside of the legs of my home theater seats might serve the same booster function.
post #5 of 9
You can modify your chairs any way you want... they even sell higher rise recliners for that purpose. I think what you need to be careful of is the if you raise the seating height then the person's feet may not comfortably reach the floor. You could try it and see.
I used a 3rd row of counter height stools to give me the elevation I needed. My riser is 10" high. My second row of seating is ~15ft from the screen and the bottom of my screen is 24" off the floor. The riser is a few inches lower than the calculator suggested but the sight lines are perfect.
Best of luck.
Bud
2nd Run Cinema - A Fabric Frame Theater
post #6 of 9
Only allow short people to sit in front of you in your first row?
-Suntan
post #7 of 9
-Suntan
Honestly....this type of solution might be the best bet.
The Riser calc gets you to input a worst case scenario...short people in the back and tall people up front.
post #8 of 9
or try and raise the screen a few inches.
post #9 of 9
The calculator is a great tool, but it also makes some assumptions. If people in the front row recline or otherwise do not sit up perfectly straight the calculations are different.
Do your own test and then you will know. That's how I picked counter height stools for my 3rd row rather than the bar stools I thought that I would need.
