AVS › AVS Forum › Video Components › Home Theater Computers › Ever have a ZIF CPU socket break? Is it fixable?
post #1 of 3
Can you fix or replace a Socket 939 ZIF module?
I was working on the daughters computer as it was noisy and BSOD'ing on her. The culprit ended up being the stock AMD CPU fan.
The then went to take off the Heatsink and fan from the CPU (it was partially clogged with dust and was making noise). When I removed the heatsink, it ripped the CPU with it as well. right out of the ZIF socket.
I decided to go forward, clean the heatsink, reinstall the CPU (AMD Athlon 64 3700+ San Diego), add some new arctic 5, upgrade and replace the heatsink (I attached a near silent 80mm fan that I had where the 70mm stock fan was), and start her back up. It worked great.
I put it aside as I was also doing a chinese Hard Drive fire drill between the server and her Computer.
I pulled her computer back up the front of my workbench, plugged it in and it came right on but didn't with a blank screen. I had this happen once before years ago. It generally means the CPU is not installed ... or not in right. I pulled the HEatsink back off andonce again it was stuck to the artic 5.
I took it back off tried again and now it started making a siren noise like a police car.
As far as I can tell, I think the ZIF module is broken and make a "snap" noise when I put the CPU in, and then release it again.
Can these things be replaced repaired. I figure the Motherboard is trashed otherwise so there is no harm in trying.
I bought her a new motherboard, CPU and some ram (her's used DDR). The board (Machspeed Viper Mk8) isn't a bad board. I might use it to upgrade my home media server...
post #2 of 3
Check to see if the pins on the chip aren't bent, or one of them anyhow. Lots of times when you rip the cpu out like that it comes on an angle and when you go to replace it, a pin that's no longer straight enough to enter the socket gets bent when you insert the chip.
Look down each row and column. You'd be surprised how one pin out of place (laying flat) isn't always real obvious on first glance. Also look for a pin missing (still in the socket). That's not so easy to see so you probably want a magnifying glass for that.
I seriously doubt there's any fixing a socket. They can't be desoldered.
I used that artic crap once. Never again. Give me the ole white stuff that stains your clothes any day.
post #3 of 3
Agree with K-Spaz.
I did the same thing once when replacing the CPU cooler. It's scary I used a toothpick to straighten a few CPU pins and it's been running fine since then. Be gentle with the pins, you don't want it to break off completely.
