AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Fringe area question
post #1 of 18
I live 90 miles from Diluth MN in the Superior National Forrest.
I have a very large, complex outdoor antenna with a built in low noise amplifer that gives me "fair to good" analog signals when the weather is right.
What's my chances of receiving digital signals with a converter box?
Which box is the most sensitive?
Any help will be appreciated!
post #2 of 18
Welcome to the forum Seastarbr!
Can you go to tvfool.com, enter your actual address, and post the results back here? Either save the results to your hard drive and post as an attachment or copy the link from the first paragraph on tvfool output to your reply. Tvfool is an excellent tool for diagnosing problems and understanding reception possiblities.
post #3 of 18
You will find that is more difficult to receive digital.
post #4 of 18
I think most of the government-subsidized "coupon boxes" have pretty good tuners. I have the Zenith DTT901 and the Channel Master CM7000, and for me the CM7000 has a slight edge, but not by much. See the Coupon Eligibie Converter Box (CECB) forum for more information and opinion. These boxes don't provide HD, only SD.
If you want HD, your choices are rather slim. The Samsung DTB-H260F has a pretty good tuner, but it's hard to find now. Other recent models are the PrimeDTV PHD-205 and the Centronics ZAT-502 which are apparently available only online. I haven't seen any comparisons of their tuners, but they're recent models so they should be on a par with the Samsung. There are threads about each of these units in this forum.
post #5 of 18
The answer is here:
http://www.tvfool.com/index.php?opti...pper&Itemid=29
Input all the relevant data. The data given is roughly an estimate for about 20' high if you don't enter an antenna height. Change the AGL if needed to reflect your antenna height.
post #6 of 18
i dont know about that...each local area can be different but its been my experience so far that digital tv signals are generally easier to receive well....
90 miles is a long way for local tv signals but if your antenna is working properly i bet u'll do well, seastarbr....especially since you said your analog works fairly well now....
the DTVPal +PLUS box claims to have an enhanced sensitivity tuner >
http://www.dtvpal.com/
give us your zip code for tvfool.com....
post #7 of 18
From what I have seen is that if you can get a snowy but watchable analog picture you can get digital... if the signal strength is equivalent.
Rick R
post #8 of 18
The TV Fool website will not accept my address in the Superior National Forrest.
The zip covers an entire Minnesota county (Lake) where the center is 30 miles from my home so that;s no help.
I think I will rely on the fact that I now get fair analog reception and buy a couple of converters.
Again, what are the most sensitive available????
Bill
post #9 of 18
You can use the coordinates option on tvfool. Use a GPS, or find your house on Google maps. Zoom in, put it your camp the center of the screen, and click on "link" (top right). Click on "Paste link". Your exact location will be embedded in the URL.
Look for numbers like this: 47.6603 -91.3870. The first number is the Latitude. The second is the Longitude. Make sure that you use the - sign on the Longitude.
post #10 of 18
Bill
you can enter your geographical coordinates
post #11 of 18
At 70 miles, my Apex DT502's and Sunkey SK-801ATSC's are much more sensitive then my Insignia -APT (Zenith clone).
NOTE: I'm smack in the middle of three DMA's and have three local tranmitters within 20 miles. Since my reception from those three DMA's are 2-edge, I have severe multi-path and atmospheric propogation issues.
post #12 of 18
The Zenith DTT-900 had the best tuner in it. When LG went to the 901 they lost some sensitivity.
post #13 of 18
You're probably referring to the 900's with the Sanyo tuner, right?
Some 900's didn't have that. I had one that didn't.
post #14 of 18
Didn't the 900's with the Sanyo tuner have the UBA00AL?
If it works that well for fringe, wouldn't the following CECB's
perform similarly for fringe since they also have it?
Sanyo UBA00AL
Artec T3AP
Artec T3Ap Pro
Digital Stream DSP7500T
Digital Stream DTX9900
GE 22729
Goodmind DTA1000
Microprose MPI-500
Microprose MPI-500PT
Zentech DF2000
Zentech DF2000L
I'm not sure what the difference is, but these use the Sanyo UBD00AL below.
Sanyo UBD00AL
Airlink 101 ATVC102
Digital Stream DTX9950
Zinwell-USA ZAT-970A
post #15 of 18
I can confirm that the Digital Stream DTX9950 does not perform as well as the Insignia -APT (Zenith 901 clone).
post #16 of 18
I don't think Sanyo has the stats for either of those tuners posted on their website.
post #17 of 18
I have both the 900 and the 901 and can confirm that the 900 with the Sanyo tuner has a small edge over the 901 in picking up distant signals, enough to make the difference between reception and no reception. I'm about 50 miles from most of my stations.
post #18 of 18
My DTT-900 does great getting stations 90 miles away. It wins hands down over the 901.
