AVS › AVS Forum › Video Components › Home Theater Computers › Freaking HELP computer geeks
post #1 of 9
Figure this is the best place to get an answer on this here. Is there a difference in the size of a jumper that works on a 3.5" HDD and a 2.5" laptop HDD and if so what is it and where the heck can I get the 2.5" jumpers.
post #2 of 9
Jumper?
Are you using SATA or PATA? I don't think SATA drives need jumpers.
post #3 of 9
Yes, IDE 2.5" drives use smaller jumpers. More info here:
http://drivejumper.com/
post #4 of 9
Which do I need?
post #5 of 9
Probably small. If need be, you can probably get a conductive pen and make a trace between the two pins. I doubt much voltage goes through those pins.
post #6 of 9
Um? Yeah my tech level for PC's is pretty low. I am using the HDD in a PS3 actually. I need the Corky answer.
post #7 of 9
Get the small jumper. If you have a fry's in your area, they probably sell them as well.
post #8 of 9
Funniest Thread Title I've seen in a while :-)
post #9 of 9
"corky answer"...thanks for the laugh, that's awesome.
