My dedicated home theater room is in a 'bonus' room above the garage. The good news is that this room has a dedicated HVAC system. The bad news is that the air handler for the HVAC is in a small closet at the back of the room and the noise from the air handler is quite noticeable. Since we live in Central Florida, the AC runs a lot when I'm up in the theater room.
I am looking for advice/recommendations on how to minimize the noise coming from the air handler within the closet. One challenge is going to be that the return duct for the air handler is directly below the air handler 'closet'.
Any advice/tips?
One thing that I plan to do is to add a couple more vents into the room. Currently there are only two AC vents into the room which produce a lot of wind noise because of the amount of air running through them. I assume that adding a couple more vents should reduce the wind noise? Would increasing the size of the current vents help/hurt the noise level?
Any advice/tips?
