Originally Posted by
QQQ
Amir,
The only knowledge we have of the LTS tests are second hand reports from Nin.
Not at all. We have the full copy of the Bryston test report and their methodology. Here it is again:
http://bryston.com/pdfs/07/Swedish14BSSTReview.pdf. And this is what they say to sum up their results up to that point:
“To sum it up, normally there are lots of views, ideas and opinions regarding the character of the tested amplifier after the open listening.
That was not the case this time.
We were sitting in open listening for well over one hour, and no one mentioned a single word about any differences they either imagined or heard. Actually, that’s the first time ever something like that has happened.”Quote:
I find the reports intriguing but do not believe second hand hearsay on an Internet board (Nin), of a magazine printed in another language that we cannot even read (save perhaps Nin and Hevi), whose test methods are unknown to us, whose results have not been peer reviewed, establishes anything.
Well, per above, we have a lot more than that, and it is all in English.
Also, even if just for the sake of discussion we accept that the magazine has established that amps and DAC's "sound different", I am unsure that we have established that they sound different when listening to music. If the differences can only be heard when running special tests/tones on artificial loads, than what that establishes is that the differences can be heard on special tests/tones when running artificial loads.
I have not heard of blind tests using test tones. Such a thing becomes very uncomfortable quickly. Here is what we see in the report above:
“We kept on listening without any changes. We switched between B and A, sometimes rapidly, sometimes with longer intervals. We tried having the music running while switching, and to play shorter loops and switch so
that identical sequence was heard on B and A.”
So we can confirm that they were indeed using music. As for artificial load, I encourage you to read their methodology. While one can argue that it may not be 100% identical to the load in your living room, it is a reasonable approximation (they used a speaker crossover). I will note though, that if you demand 100% identical situation to someone’s living room, then few A/B tests will pass by that standard. And subjectivists can use the same argument against you as we discussed before.
And are those artificial loads realistic or meant to make the components fail?
No. Reading the reports, you see that people criticized them for using to “easy” of a load initially so they made the load harder to drive to represent a speaker that is that way. But in no case is it doing things like having a 1 ohm load.
I do not know but I am sure you can think of any number of ways that a load could be designed to make a component fail or reveal audible differences that would not be detectable under real world operation. I'd think it would be easy to do with amps.
They played music and compared the output of the amp to input. They used real people who I am sure would go deaf if they were listening to test tones designed to make equipment fail.
Lastly as has been pointed out several times I do not believe most of us objectivists have said that all amps and DACs sound the same, in fact we have said several times that of course they do not, there are many poorly designed amps and DAC's out there, some of which are even designed to purposely sound different. I believe what we have said is that a double blind test is the legitimate method to test if they do sound different.
So if I went and organized a double-blind test and found differences, I should be prepared to be told that some of them were poorly designed? Putting aside tube amps, where is the list of poorly designed amps I am supposed to avoid? How about CD players?
Can someone explain the engineering aspect of a poorly designed CD player and amp?
You called out my name so I wanted to give you the courtesy of a response but I hesitate to do so as I do not want to get involved in debating more strawman arguments and logical fallacies which seem to be used so extensively that it makes the debate unproductive.
If asking you to comment on blind-testing of amps with detailed reporting, published for years in papers and magazines is a “strawman argument and logical fallacy,” let’s cut the conversation because I don’t know what else to put in front of you that would be acceptable.
So for example if you were to now say "but you said you believed in double blind tests and now that you have them you come up with a reason to argue against them", that would be an Amir strawman argument
. My position is and has been 100% consistent.
Your position has been consistent. Question is, how do you explain it against facts to the contrary? Either you are wrong, or the facts are. Either way, we need more of an explanation than “what might be” going on with the test and instead, addressing the points precisely as I have done. We have a rare situation here with real data that didn’t come from either one of us. Data that a respected company like Bryston took seriously. I wish you would too
. I know I did…
