AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Home Theater A/C vents question
post #1 of 23
Hi,
I'm building the new home with dedicated home theater room. That room will have two AC vents. Where should I put them?
Thanks so much in advance!
-Mike
post #2 of 23
"Vents"? In the world of HVAC you have supplies and returns. I presume you have two supplies. You're going to need returns in the room as well. You cannot pump cool air into a room without taking air out of the room.
post #3 of 23
I have returns right outside of the room already. It is brand new custom home so I just want to make sure we put the vents where they will not affect the projector.
-Mike
post #4 of 23
Your two supplies won't push much air into your HT with the door closed. If this is still under construction you may want to think about getting a return ran into your space.
Sorry that doesn't answer your question, but it's still something you should think about.
post #5 of 23
I prefer cool air hitting me in the face rather than the back of the neck, put the supplies up front and the return at the back. The projector will give off a lot of heat so a return in that area makes some sense.
post #6 of 23
You need to get a return in the room, unless you want to watch movies with the door open. If you care at all about sound isolation, that return should be a straight run back to the HVAC, not shared through the wall with another return close to the HT.
If you leave the door closed, it's going to get hot. 3-4 people, a projector, blu-ray player, etc. put off quite a bit of heat.
post #7 of 23
This is the approach I took with my room. Two large supplies up front about a foot from the screen and a large return near the projector. Large so air can flow without making any noise.
Dennis, Big, and other have been giving sound advice here for years, 'nuf said!
post #8 of 23
What is more important, heating or cooling? The duct layout can be optimized a little depending on which one is going to get used more.
-Suntan
post #9 of 23
Hmm...how much does a "return" cost? Ballpark.
I'm doing my living room into a home theater. It has a single AC vent. Never been a problem I guess because it has a large opening to the room. But for movies I'll be pulling a curtain across that opening for light control. So I don't know if that constitutes a serious block to the air or not. (Haven't tried it yet). The room is 15' by 13.'
Opinions? Thanks.
post #10 of 23
In Adak, in the winter, in a sound isolated room, cooling is more important.
www.welcometoalaska.com/Communities/adak.htm
post #11 of 23
Thanks y'all!!!
I am worrying about the air flow affecting picture quality when putting them on both side of the screen which I originally did ...
It is kinda vaulted ceiling so I don't think an air return would fit in there but I will rethink about it and get an air return in there for sure ...
:cheers:
-Mike
post #12 of 23
Originally Posted by mikec5vert View Post
Thanks y'all!!!
:cheers:
-Mike
Why would your air flow affect picture quality?
post #13 of 23
You dont need a true return. You can do what alot of builders are doing wich is to have drop that is nothing more than a duct going from in the Theater room to another drop that is outside the room. All you are trying to accomplish is preventing a pressure that prevents air from entering the room.
post #14 of 23
Well, I thought wind may affect the lighting but just remember the speed of light is super fast so there is nothing would affect
I will talk to my A/C guy Monday to see if he got your idea. If he gives me problem, I will change from vaulted ceiling to cake box. For now, the room is got 10ft ceiling and the vaulted to maybe 14ft or 15ft. I think I will just do 11.5 ft cake box.
Thanks so much y'all for the great idea of a return somewhere near the projector to get all the heat out. In my previous 2 theaters from a regular room w/o return, it was so hot there.
-Mike
post #15 of 23
Sorry to tack on a n00b question in here...
The HVAC system in the apartment I am in right now has a return in walk in closet, and many supplies throughout apartment... Closet door is always closed and system works fine...
Am I missing something, or is the return feed being in a room like that really that big of a deal?
Matt
post #16 of 23
If that is the only return you should leave the door open. If there are others the effective size of the return in the closet is the size of the gap under the door. If that is small you should leave the door open.
post #17 of 23
Or get a louvred door.
post #18 of 23
Hi,
I already had 2 return for that unit (I got 2 units for my house). There is one right outside in front of the theater room doors.
I'll ask if he can add 1 more in the theater room.
-Mike
post #19 of 23
That's great, I'll remember that if I ever buy a house in Adak...
-Suntan
post #20 of 23
Same holds true for Whitehorse, Fairbanks and Nome. Good time for house hunting. Deals can be had.
post #21 of 23
Exactly.
If that is a solid door and your return is in a closet...then you're having the system work very hard to pull in air greatly decreasing your efficiency and likely system life.
post #22 of 23
-Mike
No you're right. Two supplies in the path of the projected image could show up as dust floating in the air at times.
Code requirements (at least where i live) require the supplies to be where the greatest heat loss or gain is expected. That would be a window and/or outside walls.
You want the return opposite the supplies so the air is drawn throughout the room.
I'd say, put one close to the window and another on the opposite side for a symmetrical look. The return could be (and is usually) on an interior wall space to draw the supplied air towards the centre of the home/room.
post #23 of 23
Yesterday I did stop by the A/C shop and we came to the final solution. It is not the best but not bad either. I told him I got equipment closet (the 3x2 closet in the picture) which is 10ft tall but I only use up to 7ft so I want the return on top of that.
The A/C vents gotta be in front of that return and flow air away from it. Return should always be behind of the vents.
Remember, this room got vaulted ceiling so not many places got enough room for A/C vents or return .
-Mike
***BTW, my next thing will be moving the sub location to be under the equipment cabinet since currently it is in the same wall with kitchen so I don't want all the dishes fell off the shelves when watching movies :-) Now need to find the way to not vibrate the DVD player in there
