AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Nintendo › Need component cable that's separable
post #1 of 5
I know this is weird, but bear with me!
I have my wii hooked up to my TV and receiver, which are not immediately adjacent to each other. I want to hook up the wii with a component cable instead of the cable it came with, but I need one that will allow the audio and video parts of the cable to separate for at least 5-6 feet. But when I go looking for cables, I find a lot like this one or this one, where audio and video connectors can't be separated my more than a few inches (it looks like, anyway).
Does anyone have an idea of where I could find the kind of cable I need, or what terms I could use to search? ("Detachable" doesn't work, it's some other kind of wii accessory.)
Appreciate any advice!
post #2 of 5
You most likely won't find what you are looking for. Your best bet is to just use the solution I'm using. Just buy a couple rca "barrel" connectors and another set of stereo RCA cables to extend the audio to your receiver. Alternatively you could buy a set of stereo RCA cables that are male on one end and female on the other.
post #3 of 5
Yeah, this is what you want:
31 cents each. Use them with the stereo rca cables of your choice for the audio.
post #4 of 5
Ah, that makes sense. I sure wish they just made these like the old RCA cables that you could split as you needed to.
Thanks for the help
post #5 of 5
Thanks for the help
http://www.monoprice.com/products/se...ponent&x=0&y=0
Don't spend too much on the component cables, either.
  Back to Forum: Nintendo
