This worked on the 80u & 850u sets I have that ended up with duplicate OTA channels after rescanning. Probably works on other Panasonic TV's, too.
1. Disconnect the antenna cable from the back of the set.
2. Go to Menu, Setup, Program channel, Auto (make sure 'ANT in' is Antenna), All channels. (This will blow away all OTA channels.)
3. After this is done, reconnect the antenna and run the scan for all channels again.
4. Edit those you don't want.
I tried this with Digital and Analog only scans and the channels were still there. Only running a scan for all channels without the antenna plugged in removed channels.
