Thanks, Kal. I will go through my local Classe dealer to see if Classe has any more information and will post if so.
Originally Posted by rubyrad
I own a Classe SSP-800 pre-pro and was looking to buy a new multichannel SACD player as my current SACD player (Lexicon RT-10) is now somewhat outdated. As the Sony ES 5400 sends DSD only through HDMI, and the Classe does not decode a DSD data stream directly (as I understand it), are the two units incompatible?
The Sony player will output PCM from SACD over HDMI. I did one test with an early SSP-800 and they failed to communicate but the system was at a local shop and I cannot be certain of the actual setup.
Subsequently, I was successful in getting the XA5400ES to communicate (SACD - PCM) via HDMI to an ARCAM AV888 and the Meridian HD621/861.
Since there are no switches or menus to select PCM output, it would seem that the EDID handshaking is at the core of the issue. I would be surprised if the current SSP-800s would not work with it but, as of this moment, I have no such evidence.
__________________
Kal Rubinson
"Music in the Round"
Contributing Editor, Stereophile
www.stereophile.com/musicintheround/ info and will post if helpful.
__________________
Kal Rubinson
