Originally Posted by
vicra
When the red/yellow/white cables are plugged in I switch to svhs (the only other choice the remote gives me besides regular tv) and I can get sound but no picture.
The reason you get no picture (but you do get sound) is because the CECB has no S-Video output, so there is no input to the TV on the S-Video connection. Like I said above, there must be a way to switch the TV to the input for the yellow video cable, also known as composite video. It may be called Input, or Video, or it could be on channel 95 or 99; but if you have a yellow connector on the TV, there must be a way to switch to it. Also look for an input or source button on the front of the TV.
The red and white audio inputs on the TV will work with either S-Video (which you don't have) or yellow composite video.
With the rf cable I have the tv set to channel 3 and I can get picture but no sound (although I had sound and picture when I first turned on the tv this morning but only for a few minutes then the sound went out).
Like I said above, switch the CECB output to channel 4 and switch the TV to channel 4. That may work.
