AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Sony 40S4100 won't stay on setting Full Pixel for Screen Size
post #1 of 2
Hi, I notice that the setting "Full Pixel" looks better than "normal" for picture. Normal cuts off the top and bottom of the picture. "Full pixel" always looks great. But everytime I change it to "full pixel," it changes back to "normal" after I turn the tv off and back on. How do I get it to stick?
post #2 of 2
The only thing I can think of is you are removing power from the set or it has a setting for low off-state power so that it doesn't go to standby when you turn it off. If it isn't that then you can thank the thoughtless programmer who didn't program the set to remember the zoom settings when the set turns off.
