[US] Daybreakers (Additional Details)
Region Locked (AB) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Lionsgate
UPC: 031398122289
Release Date: 2010-05-11
Aspect Ratio: 2.35:1
English DD 2.0 track is a commentary. Also included on the disc is a two hour production documentary in HD weighing in at ~18GB!
Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
[US] Daybreakers AVC 1:37:48 23,463,585,792 45,650,191,399 31.98 22.07 DTS-HD Master 7.1 5431Kbps (48kHz/24-bit)
Code:
DISC INFO: Disc Title: DAYBREAKERS Disc Size: 45,650,191,399 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.3 PLAYLIST REPORT: Name: 00004.MPLS Length: 1:37:48 (h:m:s) Size: 23,463,585,792 bytes Total Bitrate: 31.98 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 22066 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 MPEG-4 AVC Video 1803 kbps 480p / 23.976 fps / 16:9 / High Profile 3.2 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 5431 kbps 7.1 / 48 kHz / 5431 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio English 256 kbps 2.0 / 48 kHz / 256 kbps / Dolby Surround SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 19.874 kbps Presentation Graphics English 22.220 kbps Presentation Graphics Spanish 20.879 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00391.M2TS 0:00:00.000 1:37:48.696 23,463,585,792 31,985 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:04:39.612 15,911 kbps 31,603 kbps 00:03:23.161 29,374 kbps 00:03:22.160 26,684 kbps 00:03:08.021 82,939 bytes 302,772 bytes 00:00:13.013 2 0:04:39.612 0:03:44.557 22,975 kbps 35,093 kbps 00:06:11.621 32,948 kbps 00:06:10.787 30,573 kbps 00:06:08.618 119,783 bytes 354,060 bytes 00:07:23.401 3 0:08:24.170 0:10:09.400 22,916 kbps 35,072 kbps 00:16:40.791 33,001 kbps 00:14:06.929 30,923 kbps 00:14:15.938 119,471 bytes 399,523 bytes 00:14:47.553 4 0:18:33.570 0:05:33.374 22,593 kbps 34,379 kbps 00:23:22.067 32,518 kbps 00:23:18.355 30,229 kbps 00:23:18.355 117,790 bytes 328,002 bytes 00:19:29.293 5 0:24:06.945 0:09:52.842 24,596 kbps 36,507 kbps 00:31:45.403 34,795 kbps 00:31:45.403 34,553 kbps 00:31:43.443 128,230 bytes 502,571 bytes 00:31:53.411 6 0:33:59.787 0:03:39.510 24,614 kbps 35,786 kbps 00:34:36.824 33,692 kbps 00:34:23.686 32,078 kbps 00:34:19.766 128,328 bytes 431,331 bytes 00:36:34.150 7 0:37:39.298 0:03:03.224 14,488 kbps 25,544 kbps 00:39:52.223 20,665 kbps 00:37:54.605 19,588 kbps 00:38:25.303 75,536 bytes 262,412 bytes 00:39:41.879 8 0:40:42.523 0:06:11.245 26,222 kbps 35,538 kbps 00:46:40.839 34,583 kbps 00:46:01.467 34,462 kbps 00:45:47.661 136,711 bytes 340,831 bytes 00:44:24.328 9 0:46:53.769 0:04:37.277 26,872 kbps 37,118 kbps 00:51:18.200 34,269 kbps 00:48:11.597 33,595 kbps 00:48:11.597 140,097 bytes 377,620 bytes 00:48:49.343 10 0:51:31.046 0:05:43.593 21,846 kbps 35,543 kbps 00:55:58.980 33,554 kbps 00:57:06.214 32,179 kbps 00:57:04.629 113,895 bytes 319,241 bytes 00:55:35.749 11 0:57:14.639 0:03:06.644 25,358 kbps 35,317 kbps 00:59:23.643 31,554 kbps 01:00:09.314 30,695 kbps 01:00:03.766 132,207 bytes 349,203 bytes 00:59:01.246 12 1:00:21.284 0:05:20.445 23,033 kbps 35,507 kbps 01:00:36.591 33,966 kbps 01:00:39.302 32,930 kbps 01:00:36.424 120,081 bytes 385,415 bytes 01:03:09.160 13 1:05:41.729 0:05:02.927 24,162 kbps 36,761 kbps 01:06:16.138 34,633 kbps 01:06:45.126 34,189 kbps 01:06:40.287 125,969 bytes 453,138 bytes 01:06:35.574 14 1:10:44.657 0:03:38.968 23,591 kbps 31,084 kbps 01:13:07.216 29,059 kbps 01:13:07.216 27,853 kbps 01:13:02.961 122,994 bytes 326,218 bytes 01:12:17.958 15 1:14:23.625 0:09:30.278 23,723 kbps 35,261 kbps 01:14:48.108 32,877 kbps 01:14:44.646 30,384 kbps 01:18:13.522 123,681 bytes 321,146 bytes 01:18:04.638 16 1:23:53.903 0:13:54.792 15,495 kbps 36,638 kbps 01:29:50.968 32,515 kbps 01:25:25.370 30,671 kbps 01:24:59.219 80,787 bytes 584,364 bytes 01:36:49.887 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00391.M2TS 4113 (0x1011) 0x1B AVC 5868.529 22,067 16,187,307,622 88,056,600 00391.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5868.529 5,431 3,983,850,568 22,567,580 00391.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 5868.529 640 469,496,320 2,750,955 00391.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 5868.529 256 187,798,528 1,100,382 00391.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5868.529 20 14,578,990 83,962 00391.M2TS 4609 (0x1201) 0x90 PGS eng (English) 5868.529 22 16,300,353 93,924 00391.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 5868.529 21 15,316,705 88,288 00391.M2TS 6912 (0x1B00) 0x1B AVC 5868.529 1,803 1,322,815,295 7,267,856
