Looks fine as well on mine, using IE7. Region codes are formatted using spaces, so it all depends how they're typed.
A B C AB A C BC ABC
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
00002.MPLS VC-1 1:58:56 28,573,224,960 36,599,330,132 32.03 29.45 DD AC3 5.1 640Kbps DD AC3 2.0 224Kbps
DISC INFO: Disc Title: PANS_LABYRINTH Disc Size: 36,599,330,132 bytes Protection: AACS BD-Java: No BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00002.MPLS Size: 28,573,224,960 bytes Length: 1:58:56 (h:m:s) Total Bitrate: 32.03 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 29451 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio Spanish 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Spanish 224 kbps 2.0 / 48 kHz / 224 kbps Dolby Digital Audio Spanish** 224 kbps 2.0 / 48 kHz / 224 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 22.157 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00005.M2TS 0:00:00.000 0:00:05.630 2,064,384 2,933 00006.M2TS 0:00:05.630 1:58:51.124 28,571,160,576 32,052 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:11:19.595 28,698 kbps 54,657 kbps 00:07:45.047 39,501 kbps 00:05:47.055 37,197 kbps 00:05:46.679 149,813 bytes 984,673 bytes 00:09:02.792 2 0:11:19.595 0:06:39.982 28,398 kbps 54,444 kbps 00:13:29.141 38,797 kbps 00:13:29.308 36,363 kbps 00:13:29.016 148,055 bytes 615,588 bytes 00:14:05.511 3 0:17:59.578 0:06:42.068 28,205 kbps 54,001 kbps 00:18:20.599 39,234 kbps 00:24:19.958 35,801 kbps 00:19:20.784 147,050 bytes 704,912 bytes 00:23:29.533 4 0:24:41.646 0:07:05.716 33,176 kbps 53,710 kbps 00:24:43.940 38,914 kbps 00:26:23.248 36,988 kbps 00:28:00.845 172,966 bytes 866,296 bytes 00:29:22.677 5 0:31:47.363 0:06:36.020 32,659 kbps 55,018 kbps 00:33:05.733 39,604 kbps 00:34:15.803 37,211 kbps 00:33:05.733 170,269 bytes 966,007 bytes 00:32:01.711 6 0:38:23.384 0:05:17.775 31,602 kbps 52,123 kbps 00:41:35.367 38,189 kbps 00:42:41.809 36,730 kbps 00:38:30.016 164,759 bytes 812,609 bytes 00:40:41.689 7 0:43:41.160 0:06:45.863 30,865 kbps 52,705 kbps 00:46:12.644 39,045 kbps 00:46:11.685 36,972 kbps 00:46:11.310 160,917 bytes 809,671 bytes 00:46:14.605 8 0:50:27.023 0:05:00.341 28,226 kbps 48,932 kbps 00:53:25.368 36,029 kbps 00:53:27.787 33,761 kbps 00:53:22.782 147,155 bytes 666,491 bytes 00:53:10.061 9 0:55:27.365 0:06:58.417 30,721 kbps 57,925 kbps 00:55:46.926 38,528 kbps 00:55:46.926 36,572 kbps 01:00:59.197 160,164 bytes 932,675 bytes 00:55:47.802 10 1:02:25.783 0:09:27.858 32,396 kbps 51,080 kbps 01:04:14.016 38,158 kbps 01:06:42.623 36,894 kbps 01:11:22.403 168,898 bytes 885,113 bytes 01:02:25.825 11 1:11:53.642 0:11:41.075 29,574 kbps 55,873 kbps 01:18:50.851 39,100 kbps 01:18:08.850 36,904 kbps 01:18:08.850 154,183 bytes 799,831 bytes 01:18:08.892 12 1:23:34.718 0:07:43.171 29,947 kbps 51,341 kbps 01:26:47.619 39,082 kbps 01:24:29.689 36,910 kbps 01:26:47.619 156,130 bytes 757,225 bytes 01:25:01.012 13 1:31:17.889 0:10:21.537 31,659 kbps 53,309 kbps 01:41:37.966 39,079 kbps 01:33:41.532 37,108 kbps 01:34:12.313 165,055 bytes 1,023,267 bytes 01:37:31.971 14 1:41:39.426 0:10:30.212 34,215 kbps 52,955 kbps 01:49:00.992 38,611 kbps 01:42:29.726 36,959 kbps 01:43:07.222 178,383 bytes 820,700 bytes 01:50:30.832 15 1:52:09.639 0:06:47.115 6,836 kbps 18,495 kbps 01:58:23.679 16,354 kbps 01:58:20.635 15,397 kbps 01:58:16.964 35,737 bytes 359,370 bytes 01:58:23.721 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00005.M2TS 4113 (0x1011) 0xEA VC-1 5.506 1,614 1,110,467 6,116 00005.M2TS 4352 (0x1100) 0x81 AC3 spa (Spanish) 5.506 229 157,696 880 00005.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 5.506 655 450,560 2,640 00005.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 5.506 229 157,696 880 00005.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5.506 0 70 7 00006.M2TS 4113 (0x1011) 0xEA VC-1 7130.999 29,473 26,271,879,242 142,885,064 00006.M2TS 4352 (0x1100) 0x81 AC3 spa (Spanish) 7130.999 224 199,671,808 1,114,240 00006.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 7130.999 640 570,490,880 3,342,720 00006.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 7130.999 224 199,671,808 1,114,240 00006.M2TS 4608 (0x1200) 0x90 PGS eng (English) 7130.999 22 19,766,470 112,944
Total Video
00001.MPLS MPEG-2 2:00:14 38,923,431,936 42,615,439,158 43.16 39.66 DD AC3 2.0 192Kbps
DISC INFO: Disc Title: ALL_THE_GOALS Disc Size: 42,615,439,158 bytes Protection: AACS BD-Java: No BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00001.MPLS Size: 38,923,431,936 bytes Length: 2:00:14 (h:m:s) Total Bitrate: 43.16 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-2 Video 39660 kbps 1080i / 25 fps / 16:9 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps Dolby Digital Audio Dutch 192 kbps 2.0 / 48 kHz / 192 kbps Dolby Digital Audio French 192 kbps 2.0 / 48 kHz / 192 kbps Dolby Digital Audio Greek 192 kbps 2.0 / 48 kHz / 192 kbps Dolby Digital Audio Italian 192 kbps 2.0 / 48 kHz / 192 kbps Dolby Digital Audio Portuguese 192 kbps 2.0 / 48 kHz / 192 kbps Dolby Digital Audio Spanish 192 kbps 2.0 / 48 kHz / 192 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics Danish 4.773 kbps Presentation Graphics Finnish 4.916 kbps Presentation Graphics Norwegian 4.553 kbps Presentation Graphics Swedish 4.820 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00003.M2TS 0:00:00.000 1:14:15.000 24,023,119,872 43,139 00004.M2TS 1:14:15.000 0:45:59.960 14,900,312,064 43,190 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:01:18.440 38,708 kbps 43,588 kbps 00:00:03.240 40,523 kbps 00:00:38.039 40,029 kbps 00:00:42.480 193,441 bytes 695,757 bytes 00:00:00.280 2 0:01:18.440 0:11:45.280 39,639 kbps 44,744 kbps 00:05:30.240 40,817 kbps 00:05:26.240 40,323 kbps 00:11:19.800 198,196 bytes 714,789 bytes 00:10:18.880 3 0:13:03.720 0:00:28.000 38,962 kbps 42,642 kbps 00:13:30.720 40,420 kbps 00:13:26.720 40,134 kbps 00:13:21.680 194,811 bytes 695,612 bytes 00:13:08.920 4 0:13:31.720 0:05:15.399 39,739 kbps 44,126 kbps 00:13:47.240 40,535 kbps 00:18:08.640 40,192 kbps 00:13:46.560 198,697 bytes 709,038 bytes 00:15:46.240 5 0:18:47.119 0:00:28.000 38,781 kbps 43,580 kbps 00:18:58.680 40,555 kbps 00:18:58.680 40,234 kbps 00:18:58.680 193,907 bytes 695,713 bytes 00:18:52.359 6 0:19:15.119 0:12:13.080 39,679 kbps 44,100 kbps 00:28:31.200 40,665 kbps 00:28:27.200 40,340 kbps 00:21:59.880 198,397 bytes 730,334 bytes 00:19:38.240 7 0:31:28.200 0:00:28.480 38,827 kbps 42,284 kbps 00:31:39.720 40,272 kbps 00:31:47.160 40,036 kbps 00:31:46.640 194,137 bytes 695,713 bytes 00:31:36.640 8 0:31:56.680 0:07:05.759 39,797 kbps 43,724 kbps 00:31:57.680 40,637 kbps 00:35:26.399 40,244 kbps 00:36:04.200 198,986 bytes 680,730 bytes 00:32:01.120 9 0:39:02.439 0:00:28.039 39,045 kbps 44,010 kbps 00:39:29.479 40,668 kbps 00:39:25.479 40,269 kbps 00:39:20.439 195,226 bytes 695,629 bytes 00:39:07.960 10 0:39:30.479 0:08:28.400 39,668 kbps 44,217 kbps 00:47:45.960 40,593 kbps 00:41:13.279 40,258 kbps 00:44:09.359 198,340 bytes 695,757 bytes 00:43:53.560 11 0:47:58.880 0:00:28.000 38,263 kbps 42,229 kbps 00:48:10.439 39,495 kbps 00:48:17.520 39,162 kbps 00:48:10.439 191,316 bytes 695,713 bytes 00:48:04.120 12 0:48:26.880 0:07:54.599 39,727 kbps 43,508 kbps 00:48:58.200 40,585 kbps 00:49:22.479 40,266 kbps 00:54:37.800 198,634 bytes 695,757 bytes 00:56:16.960 13 0:56:21.479 0:00:28.000 38,961 kbps 42,836 kbps 00:56:45.239 40,271 kbps 00:56:41.239 40,116 kbps 00:56:36.840 194,804 bytes 695,627 bytes 00:56:28.840 14 0:56:49.479 0:05:33.280 39,670 kbps 43,204 kbps 01:01:25.320 40,753 kbps 01:02:17.760 40,221 kbps 01:00:25.680 198,350 bytes 695,757 bytes 00:58:34.000 15 1:02:22.760 0:09:52.279 39,753 kbps 44,711 kbps 01:02:34.320 40,696 kbps 01:02:34.280 40,300 kbps 01:06:12.000 198,767 bytes 721,256 bytes 01:02:37.720 16 1:12:15.040 0:00:28.000 38,667 kbps 42,278 kbps 01:12:42.040 40,663 kbps 01:12:38.040 40,271 kbps 01:12:33.000 193,334 bytes 695,494 bytes 01:12:25.840 17 1:12:43.040 0:15:59.760 39,734 kbps 45,577 kbps 01:18:25.920 40,842 kbps 01:26:20.760 40,335 kbps 01:18:25.920 198,669 bytes 750,144 bytes 01:22:41.320 18 1:28:42.800 0:09:35.319 39,661 kbps 45,209 kbps 01:31:13.640 40,889 kbps 01:31:16.559 40,425 kbps 01:35:31.040 198,304 bytes 703,289 bytes 01:37:00.280 19 1:38:18.120 0:11:13.079 39,781 kbps 44,590 kbps 01:39:04.640 40,781 kbps 01:39:00.640 40,359 kbps 01:38:55.600 198,903 bytes 695,757 bytes 01:38:25.840 20 1:49:31.200 0:10:43.760 39,528 kbps 44,337 kbps 01:56:25.400 40,794 kbps 01:58:25.920 40,327 kbps 01:58:22.560 197,650 bytes 708,181 bytes 01:58:16.840 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00003.M2TS 4113 (0x1011) 0x02 MPEG-2 4454.880 39,641 22,074,516,220 120,034,975 00003.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 4454.880 192 106,920,192 696,095 00003.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 4454.880 192 106,920,192 696,095 00003.M2TS 4354 (0x1102) 0x81 AC3 ita (Italian) 4454.880 192 106,920,192 696,095 00003.M2TS 4355 (0x1103) 0x81 AC3 spa (Spanish) 4454.880 192 106,920,192 696,095 00003.M2TS 4356 (0x1104) 0x81 AC3 por (Portuguese) 4454.880 192 106,920,192 696,095 00003.M2TS 4357 (0x1105) 0x81 AC3 ell (Greek) 4454.880 192 106,920,192 696,095 00003.M2TS 4358 (0x1106) 0x81 AC3 nld (Dutch) 4454.880 192 106,920,192 696,095 00003.M2TS 4608 (0x1200) 0x90 PGS swe (Swedish) 4454.880 5 2,806,981 15,926 00003.M2TS 4609 (0x1201) 0x90 PGS nor (Norwegian) 4454.880 5 2,697,223 15,273 00003.M2TS 4610 (0x1202) 0x90 PGS fin (Finnish) 4454.880 5 2,893,691 16,396 00003.M2TS 4611 (0x1203) 0x90 PGS dan (Danish) 4454.880 5 2,802,050 15,903 00004.M2TS 4113 (0x1011) 0x02 MPEG-2 2759.880 39,693 13,693,420,306 74,460,812 00004.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 2759.880 192 66,239,232 431,245 00004.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 2759.880 192 66,239,232 431,245 00004.M2TS 4354 (0x1102) 0x81 AC3 ita (Italian) 2759.880 192 66,239,232 431,245 00004.M2TS 4355 (0x1103) 0x81 AC3 spa (Spanish) 2759.880 192 66,239,232 431,245 00004.M2TS 4356 (0x1104) 0x81 AC3 por (Portuguese) 2759.880 192 66,239,232 431,245 00004.M2TS 4357 (0x1105) 0x81 AC3 ell (Greek) 2759.880 192 66,239,232 431,245 00004.M2TS 4358 (0x1106) 0x81 AC3 nld (Dutch) 2759.880 192 66,239,232 431,245 00004.M2TS 4608 (0x1200) 0x90 PGS swe (Swedish) 2759.880 4 1,539,814 8,689 00004.M2TS 4609 (0x1201) 0x90 PGS nor (Norwegian) 2759.880 4 1,408,683 7,960 00004.M2TS 4610 (0x1202) 0x90 PGS fin (Finnish) 2759.880 4 1,539,901 8,687 00004.M2TS 4611 (0x1203) 0x90 PGS dan (Danish) 2759.880 4 1,502,690 8,483
Total Video
00001.MPLS AVC 1:42:56 36,109,633,536 40,804,594,163 46.77 35.82 Dolby TrueHD 5.1 3672Kbps (48kHz/24-bit)
DISC INFO: Disc Title: THE_TRUMAN_SHOW_EU Disc Size: 40,804,594,163 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00001.MPLS Size: 36,109,633,536 bytes Length: 1:42:56 (h:m:s) Total Bitrate: 46.77 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 35825 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby TrueHD Audio English 3672 kbps 5.1 / 48 kHz / 3672 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps) Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Spanish 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio German 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Italian 640 kbps 5.1 / 48 kHz / 640 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics Danish 29.212 kbps Presentation Graphics German 31.020 kbps Presentation Graphics English 32.060 kbps Presentation Graphics Spanish 30.986 kbps Presentation Graphics French 25.743 kbps Presentation Graphics Italian 30.002 kbps Presentation Graphics Dutch 26.461 kbps Presentation Graphics Norwegian 28.197 kbps Presentation Graphics Finnish 28.436 kbps Presentation Graphics Swedish 27.315 kbps Presentation Graphics English 35.840 kbps Presentation Graphics German 0.071 kbps Presentation Graphics Spanish 0.140 kbps Presentation Graphics French 0.125 kbps Presentation Graphics Italian 0.119 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00002.M2TS 0:00:00.000 1:42:56.920 36,109,633,536 46,767 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:02:42.537 33,131 kbps 52,365 kbps 00:00:16.349 39,834 kbps 00:00:12.345 38,422 kbps 00:00:07.340 172,686 bytes 540,419 bytes 00:00:17.017 2 0:02:42.537 0:04:06.746 36,326 kbps 39,654 kbps 00:03:46.476 37,570 kbps 00:03:10.315 37,176 kbps 00:03:28.666 189,387 bytes 521,071 bytes 00:03:52.982 3 0:06:49.283 0:02:17.428 36,799 kbps 39,102 kbps 00:06:57.250 37,255 kbps 00:07:37.874 37,081 kbps 00:07:07.593 191,856 bytes 423,834 bytes 00:09:06.712 4 0:09:06.712 0:00:36.745 36,813 kbps 40,157 kbps 00:09:35.950 37,516 kbps 00:09:10.550 37,154 kbps 00:09:08.673 191,927 bytes 581,966 bytes 00:09:15.513 5 0:09:43.457 0:01:47.899 36,406 kbps 39,397 kbps 00:11:19.553 37,413 kbps 00:11:21.972 37,066 kbps 00:11:19.970 189,803 bytes 445,820 bytes 00:11:28.979 6 0:11:31.357 0:05:43.343 36,590 kbps 41,340 kbps 00:12:42.386 37,425 kbps 00:15:28.010 37,145 kbps 00:15:22.963 190,762 bytes 404,414 bytes 00:14:26.949 7 0:17:14.700 0:12:14.525 36,517 kbps 41,313 kbps 00:25:50.423 37,499 kbps 00:25:46.503 37,215 kbps 00:25:41.498 190,381 bytes 388,752 bytes 00:28:27.414 8 0:29:29.225 0:07:28.990 36,413 kbps 41,614 kbps 00:32:56.516 37,331 kbps 00:35:57.613 37,111 kbps 00:31:34.893 189,840 bytes 900,766 bytes 00:29:52.540 9 0:36:58.216 0:05:35.710 36,551 kbps 39,817 kbps 00:39:35.623 37,346 kbps 00:40:38.853 37,101 kbps 00:39:45.549 190,559 bytes 477,069 bytes 00:40:43.023 10 0:42:33.926 0:03:07.186 36,689 kbps 39,626 kbps 00:43:02.830 37,248 kbps 00:43:44.580 37,073 kbps 00:43:49.460 191,281 bytes 385,308 bytes 00:44:27.247 11 0:45:41.113 0:02:02.705 36,713 kbps 39,270 kbps 00:46:51.809 37,338 kbps 00:47:15.749 37,204 kbps 00:47:10.619 191,407 bytes 488,625 bytes 00:45:53.417 12 0:47:43.819 0:03:28.625 36,624 kbps 41,038 kbps 00:50:03.458 37,752 kbps 00:49:59.621 37,383 kbps 00:49:54.616 190,940 bytes 552,773 bytes 00:48:17.352 13 0:51:12.444 0:01:44.187 36,521 kbps 40,332 kbps 00:52:51.042 37,744 kbps 00:52:47.038 37,046 kbps 00:52:44.786 190,402 bytes 389,837 bytes 00:52:09.543 14 0:52:56.631 0:02:26.396 36,615 kbps 39,253 kbps 00:54:07.494 37,329 kbps 00:54:06.618 37,042 kbps 00:53:33.335 190,896 bytes 365,180 bytes 00:53:33.418 15 0:55:23.028 0:05:45.011 36,662 kbps 39,642 kbps 01:00:06.519 37,439 kbps 00:59:20.765 37,087 kbps 01:00:58.029 191,139 bytes 476,623 bytes 00:59:23.893 16 1:01:08.039 0:08:49.946 36,562 kbps 46,748 kbps 01:01:27.725 38,750 kbps 01:01:23.721 37,488 kbps 01:04:31.492 190,617 bytes 480,030 bytes 01:03:53.371 17 1:09:57.985 0:03:22.911 36,700 kbps 41,403 kbps 01:12:29.636 37,738 kbps 01:12:25.591 37,236 kbps 01:12:20.586 191,339 bytes 536,943 bytes 01:13:18.268 18 1:13:20.896 0:07:40.460 36,499 kbps 42,946 kbps 01:19:54.164 37,823 kbps 01:19:50.202 37,365 kbps 01:19:45.113 190,292 bytes 448,846 bytes 01:19:50.827 19 1:21:01.356 0:02:21.391 36,608 kbps 43,148 kbps 01:21:36.224 37,941 kbps 01:21:32.220 37,388 kbps 01:21:27.257 190,859 bytes 388,798 bytes 01:22:05.170 20 1:23:22.747 0:04:21.344 36,210 kbps 40,960 kbps 01:25:38.258 37,597 kbps 01:25:34.254 37,327 kbps 01:25:29.249 188,782 bytes 434,896 bytes 01:27:21.527 21 1:27:44.092 0:04:07.121 36,698 kbps 40,621 kbps 01:27:55.144 37,432 kbps 01:28:54.120 37,197 kbps 01:28:54.495 191,327 bytes 414,203 bytes 01:31:16.512 22 1:31:51.214 0:02:58.094 36,740 kbps 39,247 kbps 01:34:33.501 37,345 kbps 01:34:30.456 37,135 kbps 01:34:28.329 191,544 bytes 419,174 bytes 01:34:34.460 23 1:34:49.308 0:01:11.446 36,318 kbps 38,663 kbps 01:35:42.945 37,218 kbps 01:35:24.135 36,981 kbps 01:35:07.535 189,344 bytes 332,010 bytes 01:35:39.692 24 1:36:00.755 0:06:56.165 27,134 kbps 43,552 kbps 01:42:52.749 37,446 kbps 01:41:35.380 37,171 kbps 01:41:30.375 141,479 bytes 438,460 bytes 01:42:53.500 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00002.M2TS 4113 (0x1011) 0x1B AVC 6176.754 35,826 27,660,819,710 150,417,368 00002.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 6176.754 4,312 3,329,277,000 24,344,024 00002.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 6176.754 640 494,154,240 2,895,435 00002.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 6176.754 640 494,154,240 2,895,435 00002.M2TS 4355 (0x1103) 0x81 AC3 deu (German) 6176.754 640 494,154,240 2,895,435 00002.M2TS 4356 (0x1104) 0x81 AC3 ita (Italian) 6176.754 640 494,154,240 2,895,435 00002.M2TS 4608 (0x1200) 0x90 PGS dan (Danish) 6176.754 29 22,554,854 130,540 00002.M2TS 4609 (0x1201) 0x90 PGS deu (German) 6176.754 31 23,951,171 138,152 00002.M2TS 4610 (0x1202) 0x90 PGS eng (English) 6176.754 32 24,754,045 142,188 00002.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 6176.754 31 23,925,059 137,984 00002.M2TS 4612 (0x1204) 0x90 PGS fra (French) 6176.754 26 19,876,364 116,004 00002.M2TS 4613 (0x1205) 0x90 PGS ita (Italian) 6176.754 30 23,165,345 133,847 00002.M2TS 4614 (0x1206) 0x90 PGS nld (Dutch) 6176.754 26 20,430,663 119,006 00002.M2TS 4615 (0x1207) 0x90 PGS nor (Norwegian) 6176.754 28 21,771,361 126,299 00002.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 6176.754 28 21,955,888 127,294 00002.M2TS 4617 (0x1209) 0x90 PGS swe (Swedish) 6176.754 27 21,090,419 122,606 00002.M2TS 4618 (0x120A) 0x90 PGS eng (English) 6176.754 36 27,672,372 159,209 00002.M2TS 4619 (0x120B) 0x90 PGS deu (German) 6176.754 0 54,790 327 00002.M2TS 4620 (0x120C) 0x90 PGS spa (Spanish) 6176.754 0 108,038 627 00002.M2TS 4621 (0x120D) 0x90 PGS fra (French) 6176.754 0 96,340 559 00002.M2TS 4622 (0x120E) 0x90 PGS ita (Italian) 6176.754 0 92,152 537
Total Video
There are three general classes of entries that I skipped over when I did my first pass through them:
Whenever you can get to it would be great.
There are three general classes of entries that I skipped over when I did my first pass through them:[list=1][*]Entries marked as (EU). I'd prefer to have these mapped to specific a specific country or countries if possible, so if anyone knows what countries those entries are applicable to that would be appreciated.[*]Partial television show entries - usually just the first episode or first disc posted. I was going to leave these out, but I think now perhaps it would be better to put them in after all.
Total Video
00018.MPLS VC-1 1:38:21 13,276,342,272 20,790,383,032 18.00 14.99 DTS 5.1 768Kbps (48kHz/24-bit) DD AC3 5.1 640Kbps
DISC INFO: Disc Title: BDROM Disc Size: 20,790,383,032 bytes Protection: AACS BD-Java: No BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00018.MPLS Size: 13,276,342,272 bytes Length: 1:38:21 (h:m:s) Total Bitrate: 18.00 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 14991 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS Audio English 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / Dolby Surround Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 109.752 kbps Presentation Graphics Spanish 93.778 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00024.M2TS 0:00:00.000 1:38:20.895 13,276,323,840 17,999 00009.M2TS 1:38:20.895 0:00:00.625 18,432 236 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:14:11.016 12,173 kbps 25,009 kbps 00:00:49.966 20,528 kbps 00:00:47.922 19,586 kbps 00:00:41.374 63,459 bytes 299,174 bytes 00:00:40.248 2 0:14:11.016 0:05:43.134 17,206 kbps 32,210 kbps 00:14:34.290 20,804 kbps 00:17:50.319 20,082 kbps 00:18:41.703 89,704 bytes 652,043 bytes 00:14:19.733 3 0:19:54.151 0:06:53.746 18,986 kbps 32,209 kbps 00:25:03.877 23,971 kbps 00:25:07.923 22,779 kbps 00:25:08.215 98,985 bytes 361,085 bytes 00:26:20.662 4 0:26:47.897 0:08:29.926 13,532 kbps 24,264 kbps 00:26:51.318 17,645 kbps 00:34:16.137 16,479 kbps 00:31:35.059 70,547 bytes 268,971 bytes 00:27:55.006 5 0:35:17.824 0:04:46.619 15,724 kbps 25,544 kbps 00:37:41.676 19,741 kbps 00:37:39.257 18,031 kbps 00:37:34.168 81,975 bytes 289,960 bytes 00:36:05.496 6 0:40:04.443 0:04:03.159 16,411 kbps 28,724 kbps 00:40:04.568 22,301 kbps 00:40:13.119 20,372 kbps 00:40:47.570 85,561 bytes 319,192 bytes 00:40:54.618 7 0:44:07.603 0:06:48.449 15,478 kbps 30,985 kbps 00:48:08.510 23,217 kbps 00:48:08.510 22,846 kbps 00:48:08.510 80,695 bytes 435,805 bytes 00:48:08.552 8 0:50:56.053 0:08:27.882 15,742 kbps 22,945 kbps 00:53:27.787 18,672 kbps 00:58:12.155 17,864 kbps 00:50:58.638 82,070 bytes 279,198 bytes 00:51:06.521 9 0:59:23.935 0:18:40.911 14,658 kbps 28,383 kbps 01:00:37.925 21,792 kbps 01:07:11.402 20,048 kbps 01:04:57.268 76,423 bytes 343,172 bytes 01:01:25.348 10 1:18:04.846 0:05:26.326 17,333 kbps 24,542 kbps 01:22:48.838 21,099 kbps 01:19:19.796 20,405 kbps 01:18:12.938 90,365 bytes 256,649 bytes 01:19:53.997 11 1:23:31.172 0:09:54.427 15,470 kbps 28,104 kbps 01:24:24.142 23,333 kbps 01:24:58.593 22,110 kbps 01:24:58.051 80,655 bytes 373,370 bytes 01:27:04.886 12 1:33:25.600 0:04:55.920 11,329 kbps 31,920 kbps 01:33:56.464 24,164 kbps 01:33:56.297 23,082 kbps 01:33:56.464 59,083 bytes 1,009,749 bytes 01:33:53.669 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00024.M2TS 4113 (0x1011) 0xEA VC-1 5900.770 14,993 11,058,508,432 60,185,909 00024.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 5900.770 640 472,153,600 2,766,525 00024.M2TS 4353 (0x1101) 0x82 DTS eng (English) 5900.770 768 566,591,488 3,319,872 00024.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 5900.770 192 141,646,080 922,175 00024.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 5900.770 192 141,646,080 922,175 00024.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5900.770 110 80,963,001 449,079 00024.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 5900.770 94 69,179,312 384,024 00009.M2TS 4113 (0x1011) 0xEA VC-1 0.501 161 10,044 65
Total Video
00021.MPLS AVC 1:22:27 15,893,200,896 19,345,519,028 25.70 23.40 DD AC3 5.1 448Kbps
DISC INFO: Disc Title: AMERICAN CAROL Disc Size: 19,345,519,028 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00021.MPLS Size: 15,893,200,896 bytes Length: 1:22:27 (h:m:s) Total Bitrate: 25.70 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 23398 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio English 448 kbps 5.1 / 48 kHz / 448 kbps Dolby Digital Audio English 384 kbps 2.0 / 48 kHz / 384 kbps / Dolby Surround Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 51.499 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:22:22.938 15,892,586,496 25,722 00025.M2TS 1:22:22.938 0:00:05.004 614,400 982 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:06:33.893 25,190 kbps 50,535 kbps 00:00:58.058 38,734 kbps 00:00:54.554 35,638 kbps 00:05:33.666 131,317 bytes 511,274 bytes 00:03:52.982 2 0:06:33.893 0:06:49.826 24,685 kbps 42,294 kbps 00:09:46.294 33,230 kbps 00:08:21.918 31,886 kbps 00:08:09.864 128,698 bytes 499,296 bytes 00:13:14.251 3 0:13:23.719 0:07:11.222 25,662 kbps 39,086 kbps 00:13:54.708 33,300 kbps 00:17:57.451 30,480 kbps 00:17:57.451 133,791 bytes 528,053 bytes 00:15:40.939 4 0:20:34.942 0:05:33.833 24,773 kbps 42,897 kbps 00:22:59.628 32,661 kbps 00:22:55.624 29,726 kbps 00:24:59.331 129,153 bytes 592,928 bytes 00:23:00.462 5 0:26:08.775 0:07:03.965 25,246 kbps 45,534 kbps 00:26:56.156 37,870 kbps 00:26:56.197 33,894 kbps 00:26:56.197 131,623 bytes 512,760 bytes 00:26:56.239 6 0:33:12.740 0:05:34.834 26,037 kbps 50,817 kbps 00:34:52.173 36,448 kbps 00:35:35.258 33,324 kbps 00:35:10.858 135,744 bytes 510,226 bytes 00:34:52.215 7 0:38:47.575 0:08:57.703 24,519 kbps 44,059 kbps 00:45:11.917 35,423 kbps 00:45:23.720 33,767 kbps 00:45:19.258 127,832 bytes 492,497 bytes 00:45:20.801 8 0:47:45.279 0:06:32.058 24,636 kbps 39,374 kbps 00:54:01.655 32,115 kbps 00:47:52.661 29,751 kbps 00:47:52.578 128,443 bytes 481,380 bytes 00:53:15.442 9 0:54:17.337 0:06:35.561 22,802 kbps 42,087 kbps 00:54:26.221 33,516 kbps 00:54:22.217 30,446 kbps 00:54:19.256 118,880 bytes 510,507 bytes 00:54:26.263 10 1:00:52.899 0:07:08.177 25,656 kbps 41,119 kbps 01:02:35.626 34,467 kbps 01:03:50.535 32,547 kbps 01:03:45.822 133,761 bytes 536,982 bytes 01:04:01.546 11 1:08:01.076 0:07:56.058 25,088 kbps 41,562 kbps 01:10:36.565 32,997 kbps 01:12:26.467 31,332 kbps 01:12:24.089 130,796 bytes 525,379 bytes 01:12:00.816 12 1:15:57.135 0:06:25.760 5,651 kbps 37,178 kbps 01:16:29.251 28,922 kbps 01:16:26.707 28,108 kbps 01:16:22.452 29,464 bytes 457,053 bytes 01:16:29.293 13 1:22:22.896 0:00:05.046 864 kbps 1,241 kbps 01:22:24.939 871 kbps 01:22:22.896 0 kbps 00:00:00.000 4,542 bytes 74,208 bytes 01:22:25.190 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 4942.855 23,421 14,471,014,765 78,716,615 00000.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 4942.855 448 276,804,864 1,544,670 00000.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 4942.855 384 237,261,312 1,390,203 00000.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 4942.855 192 118,630,656 772,335 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 4942.855 52 31,851,872 184,454 00025.M2TS 4113 (0x1011) 0x1B AVC 4.880 894 545,098 3,003
Total Video
00001.MPLS AVC 1:45:16 30,681,366,528 44,993,411,114 38.86 34.56 LPCM 1.0 1152Kbps (48kHz/24-bit) DD AC3 1.0 192Kbps
DISC INFO:
Disc Title: REPULSION
Disc Size: 44,993,411,114 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.2
PLAYLIST REPORT:
Length: 1:45:16 (h:m:s)
Total Bitrate: 38.86 Mbps
Description:
VIDEO:
MPEG-4 AVC Video 34555 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio English 1152 kbps 1.0 / 48 kHz / 1152 kbps / 24-bit
Dolby Digital Audio English 192 kbps 1.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics English 26.966 kbps
FILES:
00257.M2TS 0:00:00.000 1:45:16.643 30,681,366,528 38,858
CHAPTERS:
1 0:00:00.000 0:02:19.639 31,608 kbps 36,941 kbps 00:00:07.340 36,339 kbps 00:00:03.336 36,292 kbps 00:00:02.335 164,738 bytes 212,686 bytes 00:01:28.004
2 0:02:19.639 0:06:18.836 36,064 kbps 38,515 kbps 00:04:34.607 36,704 kbps 00:04:30.603 36,368 kbps 00:04:25.598 188,022 bytes 253,282 bytes 00:08:37.725
3 0:08:38.476 0:10:57.782 35,354 kbps 40,271 kbps 00:14:13.394 37,058 kbps 00:14:09.390 36,658 kbps 00:14:04.385 184,320 bytes 247,667 bytes 00:14:13.936
4 0:19:36.258 0:07:26.904 35,926 kbps 39,158 kbps 00:24:07.070 36,721 kbps 00:24:03.024 36,350 kbps 00:23:58.061 187,300 bytes 227,132 bytes 00:24:07.737
5 0:27:03.163 0:09:04.794 35,588 kbps 38,837 kbps 00:34:24.437 36,776 kbps 00:34:20.433 36,486 kbps 00:34:15.428 185,537 bytes 243,668 bytes 00:34:25.146
6 0:36:07.957 0:06:22.840 33,322 kbps 37,022 kbps 00:41:52.885 36,419 kbps 00:41:48.797 36,338 kbps 00:41:43.792 173,728 bytes 209,451 bytes 00:41:45.836
7 0:42:30.798 0:12:03.305 32,674 kbps 38,084 kbps 00:47:08.784 36,663 kbps 00:47:04.863 36,413 kbps 00:46:59.817 170,346 bytes 243,710 bytes 00:47:09.493
8 0:54:34.104 0:09:14.679 36,097 kbps 37,880 kbps 01:00:14.402 36,518 kbps 00:55:50.472 36,369 kbps 00:57:55.555 188,193 bytes 231,863 bytes 00:58:05.231
9 1:03:48.783 0:08:45.066 35,693 kbps 38,121 kbps 01:12:09.616 36,443 kbps 01:07:14.238 36,329 kbps 01:04:20.731 186,088 bytes 228,077 bytes 01:12:10.075
10 1:12:33.849 0:05:03.011 35,559 kbps 38,101 kbps 01:13:59.852 36,487 kbps 01:16:35.173 36,340 kbps 01:16:30.168 185,390 bytes 229,489 bytes 01:15:56.426
11 1:17:36.860 0:12:19.864 33,875 kbps 38,402 kbps 01:22:20.769 36,663 kbps 01:22:16.765 36,449 kbps 01:22:11.801 176,610 bytes 261,111 bytes 01:22:13.428
12 1:29:56.724 0:05:23.531 34,847 kbps 39,417 kbps 01:33:23.014 36,587 kbps 01:34:57.233 36,384 kbps 01:34:52.228 181,676 bytes 244,758 bytes 01:33:23.514
13 1:35:20.256 0:09:13.344 34,337 kbps 37,987 kbps 01:35:25.970 36,574 kbps 01:35:42.737 36,365 kbps 01:37:45.568 179,018 bytes 228,009 bytes 01:37:37.768
14 1:44:33.600 0:00:43.042 5,393 kbps 10,792 kbps 01:44:51.201 10,153 kbps 01:44:48.490 9,224 kbps 01:44:46.738 28,144 bytes 109,006 bytes 01:44:50.617
STREAM DIAGNOSTICS:
00257.M2TS 4113 (0x1011) 0x1B AVC 6316.477 34,556 27,284,101,050 148,371,906
00257.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 6316.477 2,310 1,824,247,076 10,106,632
00257.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 6316.477 192 151,600,128 986,980
00257.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6316.477 27 21,291,442 121,643
Total Video
00001.MPLS AVC 1:34:43 29,234,737,152 49,237,323,332 41.15 34.62 LPCM 1.0 1152Kbps (48kHz/24-bit) LPCM 1.0 1152Kbps (48kHz/24-bit)
DISC INFO:
Disc Title: MARIENBAD
Disc Size: 49,237,323,332 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.2
PLAYLIST REPORT:
Length: 1:34:43 (h:m:s)
Total Bitrate: 41.15 Mbps
Description:
VIDEO:
MPEG-4 AVC Video 34618 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio French 1152 kbps 1.0 / 48 kHz / 1152 kbps / 24-bit
SUBTITLES:
Presentation Graphics English 35.354 kbps
FILES:
00237.M2TS 0:00:00.000 1:34:43.511 29,234,737,152 41,150
CHAPTERS:
1 0:00:00.000 0:08:38.184 33,361 kbps 39,499 kbps 00:00:31.031 36,608 kbps 00:03:32.170 36,403 kbps 00:03:27.165 173,914 bytes 302,999 bytes 00:00:31.656
2 0:08:38.184 0:03:39.969 35,069 kbps 36,984 kbps 00:11:16.592 36,388 kbps 00:12:03.764 36,289 kbps 00:10:30.379 182,833 bytes 253,822 bytes 00:12:08.519
3 0:12:18.154 0:02:29.607 36,072 kbps 40,092 kbps 00:14:32.580 36,863 kbps 00:14:28.534 36,410 kbps 00:14:23.529 188,061 bytes 707,153 bytes 00:14:33.539
4 0:14:47.761 0:02:49.961 36,159 kbps 39,326 kbps 00:17:32.676 36,865 kbps 00:17:28.672 36,536 kbps 00:17:23.667 188,517 bytes 583,425 bytes 00:17:33.677
5 0:17:37.723 0:02:37.198 36,179 kbps 37,368 kbps 00:18:24.061 36,437 kbps 00:19:58.488 36,334 kbps 00:19:53.442 188,619 bytes 271,187 bytes 00:18:27.815
6 0:20:14.922 0:05:39.172 32,348 kbps 37,195 kbps 00:24:54.534 36,424 kbps 00:23:24.111 36,312 kbps 00:22:32.476 168,650 bytes 258,204 bytes 00:22:46.823
7 0:25:54.094 0:03:24.996 36,198 kbps 37,885 kbps 00:28:36.673 36,583 kbps 00:28:32.669 36,420 kbps 00:28:27.664 188,721 bytes 325,286 bytes 00:28:37.424
8 0:29:19.090 0:03:15.361 36,219 kbps 37,395 kbps 00:32:13.014 36,496 kbps 00:32:09.052 36,358 kbps 00:32:04.047 188,831 bytes 284,533 bytes 00:29:53.708
9 0:32:34.452 0:04:35.817 33,928 kbps 37,496 kbps 00:34:50.630 36,422 kbps 00:34:46.626 36,328 kbps 00:34:41.621 176,885 bytes 426,025 bytes 00:35:17.907
10 0:37:10.269 0:05:19.777 32,415 kbps 38,551 kbps 00:38:20.464 36,495 kbps 00:40:03.025 36,378 kbps 00:39:58.020 168,995 bytes 277,953 bytes 00:38:25.761
11 0:42:30.047 0:04:21.970 36,131 kbps 37,029 kbps 00:46:34.666 36,440 kbps 00:45:49.955 36,354 kbps 00:45:44.950 188,372 bytes 269,124 bytes 00:46:36.627
12 0:46:52.017 0:04:29.394 36,219 kbps 37,365 kbps 00:48:26.028 36,432 kbps 00:48:22.024 36,305 kbps 00:48:17.019 188,827 bytes 272,540 bytes 00:48:40.834
13 0:51:21.411 0:04:56.713 36,223 kbps 36,762 kbps 00:56:09.157 36,329 kbps 00:51:35.550 36,291 kbps 00:52:59.885 188,849 bytes 252,540 bytes 00:51:22.412
14 0:56:18.124 0:04:28.685 35,563 kbps 40,343 kbps 00:56:55.078 37,003 kbps 00:56:51.074 36,614 kbps 00:56:46.069 185,412 bytes 690,085 bytes 00:56:56.079
15 1:00:46.809 0:04:25.974 35,273 kbps 38,092 kbps 01:05:07.111 36,512 kbps 01:05:02.982 36,353 kbps 01:04:08.845 183,899 bytes 286,632 bytes 01:02:25.074
16 1:05:12.783 0:04:33.022 36,192 kbps 37,462 kbps 01:08:53.295 36,468 kbps 01:08:49.291 36,356 kbps 01:08:37.446 188,687 bytes 287,198 bytes 01:07:51.567
17 1:09:45.806 0:04:00.698 36,203 kbps 39,172 kbps 01:09:59.403 36,584 kbps 01:09:55.399 36,369 kbps 01:10:09.205 188,747 bytes 538,487 bytes 01:10:00.404
18 1:13:46.505 0:04:01.324 35,887 kbps 39,253 kbps 01:14:42.352 36,694 kbps 01:14:38.348 36,479 kbps 01:14:33.343 187,096 bytes 605,117 bytes 01:14:43.353
19 1:17:47.829 0:04:06.120 36,039 kbps 37,787 kbps 01:21:49.946 36,463 kbps 01:21:45.775 36,350 kbps 01:20:48.134 187,890 bytes 239,999 bytes 01:21:40.812
20 1:21:53.950 0:05:31.164 33,628 kbps 38,319 kbps 01:27:00.298 36,639 kbps 01:26:56.252 36,450 kbps 01:26:51.247 175,320 bytes 526,359 bytes 01:27:01.257
21 1:27:25.114 0:07:18.396 30,018 kbps 37,432 kbps 01:28:47.447 36,412 kbps 01:28:43.443 36,322 kbps 01:32:54.902 156,517 bytes 315,192 bytes 01:33:19.010
STREAM DIAGNOSTICS:
00237.M2TS 4113 (0x1011) 0x1B AVC 5683.344 34,619 24,593,912,613 133,742,629
00237.M2TS 4352 (0x1100) 0x80 LPCM fra (French) 5683.344 2,310 1,641,399,132 9,093,624
00237.M2TS 4353 (0x1101) 0x80 LPCM fra (French) 5683.344 2,310 1,641,399,132 9,093,624
00237.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5683.344 35 25,116,790 143,976
Total Video
The Towering Inferno AVC 2:44:53 39,291,930,624 48,243,804,187 31.77 24.82 DTS-HD Master 5.1 3555Kbps (48kHz/24-bit) DD AC3 4.0 448Kbps / DD AC3 2.0 224Kbps
DISC INFO: Disc Title: TOWERING_INFERNO Disc Size: 48,243,804,187 bytes Protection: BD+ BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00002.MPLS Size: 39,291,930,624 bytes Length: 2:44:53 (h:m:s) Total Bitrate: 31.77 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 24817 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 3555 kbps 5.1 / 48 kHz / 3555 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 448 kbps 4.0 / 48 kHz / 448 kbps Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / Dolby Surround Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps Dolby Digital Audio Spanish 224 kbps 2.0 / 48 kHz / 224 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 38.058 kbps Presentation Graphics French 33.961 kbps Presentation Graphics Spanish 30.808 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00002.M2TS 0:00:00.000 2:44:53.884 39,291,930,624 31,771 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:03:35.215 30,889 kbps 48,277 kbps 00:00:02.419 34,609 kbps 00:00:30.989 32,982 kbps 00:00:19.853 161,012 bytes 514,847 bytes 00:03:25.246 2 0:03:35.215 0:05:28.703 24,490 kbps 42,529 kbps 00:04:03.993 32,676 kbps 00:04:03.993 31,816 kbps 00:04:03.993 127,681 bytes 590,701 bytes 00:04:04.035 3 0:09:03.918 0:02:24.894 23,931 kbps 34,991 kbps 00:10:06.689 31,524 kbps 00:10:08.649 28,023 kbps 00:10:03.644 124,766 bytes 525,867 bytes 00:11:13.381 4 0:11:28.813 0:02:20.014 23,902 kbps 31,829 kbps 00:11:52.920 29,225 kbps 00:12:34.211 27,339 kbps 00:11:46.122 124,615 bytes 509,746 bytes 00:11:53.921 5 0:13:48.828 0:04:56.004 24,837 kbps 41,200 kbps 00:18:21.225 33,004 kbps 00:18:21.225 31,913 kbps 00:18:21.225 129,491 bytes 599,235 bytes 00:18:21.266 6 0:18:44.832 0:04:09.958 24,095 kbps 34,994 kbps 00:21:07.766 28,864 kbps 00:22:24.259 26,975 kbps 00:20:51.458 125,623 bytes 513,978 bytes 00:20:52.876 7 0:22:54.790 0:05:49.098 24,722 kbps 38,764 kbps 00:28:18.488 33,564 kbps 00:24:45.984 32,271 kbps 00:24:46.276 128,890 bytes 589,400 bytes 00:28:16.069 8 0:28:43.888 0:03:08.938 26,114 kbps 37,280 kbps 00:30:16.022 33,939 kbps 00:30:12.560 31,815 kbps 00:29:05.952 136,148 bytes 501,927 bytes 00:29:14.753 9 0:31:52.827 0:03:51.773 24,609 kbps 32,323 kbps 00:34:03.374 28,033 kbps 00:32:08.468 27,242 kbps 00:33:01.396 128,302 bytes 492,646 bytes 00:32:26.903 10 0:35:44.600 0:05:55.271 24,365 kbps 44,012 kbps 00:40:59.623 34,298 kbps 00:39:25.071 31,461 kbps 00:38:32.727 127,029 bytes 649,462 bytes 00:37:43.928 11 0:41:39.872 0:05:05.179 23,520 kbps 46,361 kbps 00:44:40.427 33,781 kbps 00:44:40.386 32,827 kbps 00:44:40.427 122,623 bytes 683,604 bytes 00:45:05.035 12 0:46:45.052 0:05:22.363 26,007 kbps 42,274 kbps 00:47:44.987 33,870 kbps 00:47:43.610 33,122 kbps 00:47:43.277 135,588 bytes 593,486 bytes 00:50:57.012 13 0:52:07.415 0:03:23.828 24,406 kbps 35,847 kbps 00:54:11.581 29,140 kbps 00:55:14.894 28,131 kbps 00:54:43.238 127,241 bytes 512,820 bytes 00:54:54.040 14 0:55:31.244 0:02:34.445 24,113 kbps 48,990 kbps 00:56:20.794 30,096 kbps 00:56:39.270 28,163 kbps 00:57:16.141 125,715 bytes 543,612 bytes 00:58:05.690 15 0:58:05.690 0:08:26.506 25,914 kbps 43,706 kbps 01:04:35.997 35,103 kbps 01:06:14.887 34,439 kbps 01:06:14.971 135,101 bytes 534,799 bytes 01:06:13.177 16 1:06:32.196 0:03:40.553 29,011 kbps 41,307 kbps 01:08:42.618 34,352 kbps 01:09:36.172 33,529 kbps 01:09:37.423 151,248 bytes 632,865 bytes 01:08:42.660 17 1:10:12.750 0:03:54.943 24,055 kbps 37,635 kbps 01:11:34.999 31,684 kbps 01:11:31.036 30,254 kbps 01:11:29.535 125,411 bytes 483,849 bytes 01:11:41.714 18 1:14:07.693 0:09:25.648 22,983 kbps 32,508 kbps 01:14:56.742 28,447 kbps 01:17:58.757 27,354 kbps 01:20:53.598 119,824 bytes 494,522 bytes 01:18:02.094 19 1:23:33.341 0:04:42.615 22,412 kbps 43,519 kbps 01:23:55.947 27,590 kbps 01:24:16.634 25,791 kbps 01:24:11.796 116,848 bytes 463,494 bytes 01:24:28.730 20 1:28:15.957 0:05:52.351 23,444 kbps 35,966 kbps 01:29:16.851 31,145 kbps 01:33:37.570 29,686 kbps 01:33:40.281 122,224 bytes 605,827 bytes 01:29:17.060 21 1:34:08.309 0:08:58.120 24,323 kbps 38,958 kbps 01:39:09.735 31,844 kbps 01:39:05.731 30,412 kbps 01:42:48.036 126,810 bytes 502,127 bytes 01:34:45.930 22 1:43:06.430 0:03:24.829 26,404 kbps 38,145 kbps 01:45:05.257 31,461 kbps 01:45:01.878 29,365 kbps 01:44:58.417 137,657 bytes 515,731 bytes 01:45:06.091 23 1:46:31.259 0:02:34.445 24,358 kbps 32,989 kbps 01:46:42.854 27,692 kbps 01:46:40.894 27,039 kbps 01:47:43.748 126,990 bytes 499,280 bytes 01:48:03.226 24 1:49:05.705 0:08:51.656 25,700 kbps 49,863 kbps 01:54:58.933 33,096 kbps 01:50:42.927 32,357 kbps 01:56:08.169 133,991 bytes 638,619 bytes 01:54:59.058 25 1:57:57.361 0:02:49.460 24,195 kbps 35,088 kbps 01:58:30.978 27,339 kbps 02:00:22.924 26,831 kbps 02:00:16.000 126,141 bytes 430,331 bytes 01:58:34.649 26 2:00:46.822 0:06:22.632 24,728 kbps 40,555 kbps 02:05:14.882 32,568 kbps 02:05:53.379 31,695 kbps 02:06:30.457 128,921 bytes 574,465 bytes 02:05:53.754 27 2:07:09.455 0:07:25.236 23,007 kbps 43,703 kbps 02:07:37.900 33,574 kbps 02:07:37.900 30,614 kbps 02:08:01.090 119,951 bytes 582,697 bytes 02:07:37.941 28 2:14:34.691 0:07:13.266 23,437 kbps 34,741 kbps 02:21:31.316 31,905 kbps 02:21:27.312 31,515 kbps 02:21:37.947 122,188 bytes 487,517 bytes 02:21:26.352 29 2:21:47.957 0:08:50.363 25,853 kbps 48,386 kbps 02:23:12.333 35,902 kbps 02:23:00.738 33,176 kbps 02:23:00.780 134,787 bytes 597,558 bytes 02:30:38.320 30 2:30:38.320 0:06:11.704 26,723 kbps 45,457 kbps 02:36:44.561 33,514 kbps 02:36:44.603 31,675 kbps 02:34:29.885 139,323 bytes 738,561 bytes 02:36:44.645 31 2:36:50.025 0:04:35.274 26,466 kbps 40,692 kbps 02:37:39.867 33,671 kbps 02:37:35.904 32,409 kbps 02:37:30.941 137,984 bytes 571,440 bytes 02:39:20.217 32 2:41:25.300 0:03:28.583 23,400 kbps 37,011 kbps 02:44:47.711 28,327 kbps 02:41:26.301 27,052 kbps 02:41:26.009 122,048 bytes 502,631 bytes 02:41:29.680 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00002.M2TS 4113 (0x1011) 0x1B AVC 9893.801 24,817 30,692,009,973 166,944,181 00002.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 9893.801 3,555 4,396,816,048 25,438,108 00002.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 9893.801 448 554,057,728 3,091,840 00002.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 9893.801 224 277,028,864 1,545,920 00002.M2TS 4355 (0x1103) 0x81 AC3 spa (Spanish) 9893.801 224 277,028,864 1,545,920 00002.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 9893.801 224 277,028,864 1,545,920 00002.M2TS 4357 (0x1105) 0x81 AC3 eng (English) 9893.801 224 277,028,864 1,545,920 00002.M2TS 4358 (0x1106) 0x81 AC3 eng (English) 9893.801 224 277,028,864 1,545,920 00002.M2TS 4608 (0x1200) 0x90 PGS eng (English) 9893.801 38 47,068,025 266,927 00002.M2TS 4609 (0x1201) 0x90 PGS fra (French) 9893.801 34 42,001,051 237,833 00002.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 9893.801 31 38,101,819 216,592
Total Video
This Is Spinal Tap AVC 1:22:50 24,071,086,080 35,143,834,301 38.74 32.98 DTS-HD Master 5.1 3129Kbps (48kHz/24-bit) DD AC3 2.0 224Kbps
DISC INFO: Disc Title: THIS_IS_SPINAL_TAP Disc Size: 35,143,834,301 bytes Protection: BD+ BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00000.MPLS Size: 24,071,086,080 bytes Length: 1:22:50 (h:m:s) Total Bitrate: 38.74 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 32983 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 3129 kbps 5.1 / 48 kHz / 3129 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / Dolby Surround Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 71.853 kbps Presentation Graphics French 57.495 kbps Presentation Graphics Spanish 57.948 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:22:50.966 24,071,086,080 38,739 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:01:54.447 29,415 kbps 35,560 kbps 00:00:40.498 34,800 kbps 00:01:36.387 34,738 kbps 00:01:36.304 153,299 bytes 260,149 bytes 00:01:32.675 2 0:01:54.447 0:02:16.261 33,185 kbps 38,381 kbps 00:03:53.608 34,824 kbps 00:03:53.733 34,699 kbps 00:03:53.816 173,009 bytes 356,436 bytes 00:03:51.814 3 0:04:10.708 0:02:18.680 34,394 kbps 35,985 kbps 00:05:03.177 34,880 kbps 00:04:12.460 34,787 kbps 00:05:34.834 179,317 bytes 290,896 bytes 00:04:15.713 4 0:06:29.389 0:01:52.612 34,367 kbps 36,688 kbps 00:07:40.585 35,128 kbps 00:07:36.581 34,885 kbps 00:07:31.576 179,175 bytes 377,017 bytes 00:07:41.544 5 0:08:22.001 0:01:42.936 33,378 kbps 36,567 kbps 00:08:45.525 34,743 kbps 00:08:34.555 34,596 kbps 00:08:29.592 174,017 bytes 240,524 bytes 00:09:18.808 6 0:10:04.937 0:02:00.411 30,740 kbps 38,053 kbps 00:11:43.119 33,986 kbps 00:11:43.035 33,041 kbps 00:11:37.655 160,263 bytes 276,405 bytes 00:11:05.498 7 0:12:05.349 0:00:48.173 33,290 kbps 36,006 kbps 00:12:08.811 34,901 kbps 00:12:09.603 34,441 kbps 00:12:07.309 173,557 bytes 327,593 bytes 00:12:25.911 8 0:12:53.522 0:03:59.572 33,268 kbps 37,225 kbps 00:13:03.783 35,171 kbps 00:12:59.737 34,740 kbps 00:14:07.054 173,442 bytes 306,279 bytes 00:13:04.533 9 0:16:53.095 0:01:53.071 33,033 kbps 34,845 kbps 00:17:19.204 34,107 kbps 00:17:16.368 33,876 kbps 00:17:14.491 172,220 bytes 292,357 bytes 00:18:46.166 10 0:18:46.166 0:01:41.643 34,462 kbps 36,475 kbps 00:20:08.498 34,823 kbps 00:19:09.982 34,728 kbps 00:19:41.180 179,671 bytes 270,716 bytes 00:18:47.167 11 0:20:27.809 0:03:26.289 33,561 kbps 36,689 kbps 00:20:47.537 34,864 kbps 00:22:41.651 34,774 kbps 00:22:36.938 174,970 bytes 282,642 bytes 00:21:44.303 12 0:23:54.099 0:03:01.306 32,131 kbps 35,644 kbps 00:25:39.955 34,506 kbps 00:25:36.076 33,577 kbps 00:24:46.526 167,518 bytes 298,459 bytes 00:24:52.741 13 0:26:55.405 0:00:59.225 32,907 kbps 34,951 kbps 00:27:46.289 34,059 kbps 00:27:46.039 33,483 kbps 00:27:44.621 171,564 bytes 266,556 bytes 00:27:51.044 14 0:27:54.631 0:02:08.545 33,370 kbps 35,754 kbps 00:29:44.866 34,815 kbps 00:29:40.862 34,712 kbps 00:29:17.881 173,976 bytes 286,206 bytes 00:30:03.176 15 0:30:03.176 0:01:19.621 33,446 kbps 35,749 kbps 00:30:44.133 34,833 kbps 00:31:07.031 34,749 kbps 00:31:02.151 174,370 bytes 286,360 bytes 00:30:17.649 16 0:31:22.797 0:02:01.204 34,445 kbps 36,259 kbps 00:32:28.196 34,962 kbps 00:32:24.275 34,772 kbps 00:31:33.182 179,580 bytes 277,940 bytes 00:32:38.373 17 0:33:24.002 0:06:11.204 32,350 kbps 36,233 kbps 00:34:17.513 34,928 kbps 00:34:13.509 34,769 kbps 00:33:50.945 168,656 bytes 264,761 bytes 00:34:54.675 18 0:39:35.206 0:01:57.951 32,987 kbps 35,730 kbps 00:39:36.832 34,780 kbps 00:39:51.430 34,716 kbps 00:39:49.678 171,979 bytes 281,894 bytes 00:41:12.011 19 0:41:33.157 0:01:07.067 34,216 kbps 35,440 kbps 00:42:24.625 34,796 kbps 00:42:24.667 34,649 kbps 00:42:24.667 178,389 bytes 260,709 bytes 00:42:19.245 20 0:42:40.224 0:02:43.705 33,290 kbps 36,578 kbps 00:44:57.653 34,780 kbps 00:42:40.849 34,721 kbps 00:42:40.808 173,558 bytes 325,779 bytes 00:44:31.126 21 0:45:23.929 0:02:15.510 33,681 kbps 35,620 kbps 00:47:31.348 34,828 kbps 00:45:28.600 34,669 kbps 00:46:45.594 175,596 bytes 278,973 bytes 00:46:44.510 22 0:47:39.439 0:02:09.546 31,338 kbps 36,799 kbps 00:49:45.816 34,397 kbps 00:47:54.913 33,839 kbps 00:49:17.120 163,382 bytes 266,142 bytes 00:47:46.029 23 0:49:48.986 0:03:03.725 33,578 kbps 36,414 kbps 00:52:39.364 35,010 kbps 00:52:35.360 34,762 kbps 00:52:42.450 175,062 bytes 268,393 bytes 00:52:10.001 24 0:52:52.711 0:00:59.059 29,706 kbps 35,353 kbps 00:53:01.052 34,805 kbps 00:52:57.090 34,680 kbps 00:52:55.589 154,871 bytes 282,189 bytes 00:53:51.770 25 0:53:51.770 0:03:44.182 32,812 kbps 36,519 kbps 00:56:29.385 35,033 kbps 00:56:12.702 34,677 kbps 00:53:52.896 171,067 bytes 285,576 bytes 00:57:31.531 26 0:57:35.952 0:04:33.189 33,581 kbps 35,686 kbps 01:02:00.675 34,855 kbps 01:00:43.306 34,754 kbps 01:00:38.134 175,076 bytes 258,631 bytes 00:57:49.132 27 1:02:09.142 0:01:52.779 32,689 kbps 35,245 kbps 01:03:30.348 34,770 kbps 01:03:30.348 34,218 kbps 01:03:29.222 170,425 bytes 258,555 bytes 01:02:12.520 28 1:04:01.921 0:04:27.266 32,930 kbps 35,641 kbps 01:06:20.643 34,823 kbps 01:04:33.327 34,592 kbps 01:07:14.530 171,681 bytes 284,214 bytes 01:06:05.795 29 1:08:29.188 0:01:48.358 32,959 kbps 35,599 kbps 01:08:39.990 34,816 kbps 01:08:31.482 34,759 kbps 01:08:30.898 171,834 bytes 293,194 bytes 01:09:43.429 30 1:10:17.546 0:01:52.862 33,287 kbps 35,635 kbps 01:11:50.681 34,741 kbps 01:10:20.799 34,661 kbps 01:10:20.799 173,545 bytes 271,305 bytes 01:12:10.409 31 1:12:10.409 0:05:24.532 32,939 kbps 37,683 kbps 01:17:20.886 34,839 kbps 01:12:15.539 34,689 kbps 01:13:18.769 171,731 bytes 287,030 bytes 01:17:16.923 32 1:17:34.941 0:05:16.024 32,991 kbps 36,216 kbps 01:20:09.638 34,900 kbps 01:20:55.517 34,842 kbps 01:20:00.545 172,025 bytes 347,035 bytes 01:21:58.204 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 4970.841 32,983 20,494,398,643 111,452,635 00000.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 4970.841 3,130 1,944,549,820 11,336,086 00000.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 4970.841 224 139,187,328 776,715 00000.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 4970.841 224 139,187,328 776,715 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 4970.841 72 44,647,218 255,289 00000.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 4970.841 58 36,006,997 206,145 00000.M2TS 4610 (0x1202) 0x90 PGS fra (French) 4970.841 57 35,725,619 204,666
Total Video
Jingle All the Way: Extended Director's Cut (seamless) AVC 1:33:44 25,126,115,328 45,176,078,817 35.74 28.21 DTS-HD Master 5.1 4450Kbps (48kHz/24-bit)
DISC INFO: Disc Title: JINGLE_ALL_THE_WAY_US Disc Size: 45,176,078,817 bytes Protection: BD+ BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00002.MPLS Size: 25,126,115,328 bytes Length: 1:33:44 (h:m:s) Total Bitrate: 35.74 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 28209 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4450 kbps 5.1 / 48 kHz / 4450 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio French 448 kbps 5.1 / 48 kHz / 448 kbps Dolby Digital Audio Spanish 448 kbps 5.1 / 48 kHz / 448 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 67.057 kbps Presentation Graphics Chinese 44.666 kbps Presentation Graphics Chinese 47.136 kbps Presentation Graphics French 5.074 kbps Presentation Graphics Korean 38.356 kbps Presentation Graphics Spanish 47.441 kbps Presentation Graphics Spanish 4.138 kbps Presentation Graphics Thai 38.784 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00001.M2TS 0:00:00.000 0:19:56.612 5,345,163,264 35,735 00011.M2TS 0:19:56.612 0:07:43.838 2,117,695,488 36,525 00003.M2TS 0:27:40.450 0:05:27.994 1,639,409,664 39,986 00012.M2TS 0:33:08.444 0:09:09.632 2,701,363,200 39,319 00005.M2TS 0:42:18.077 0:03:04.642 754,225,152 32,678 00013.M2TS 0:45:22.719 0:05:03.845 1,489,618,944 39,220 00007.M2TS 0:50:26.565 0:05:38.546 1,499,547,648 35,435 00014.M2TS 0:56:05.111 0:01:23.416 386,273,280 37,045 00009.M2TS 0:57:28.528 0:23:58.645 6,606,323,712 36,736 00015.M2TS 1:21:27.173 0:12:17.445 2,586,494,976 28,059 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:57.143 29,081 kbps 51,026 kbps 00:00:01.876 38,477 kbps 00:00:26.234 35,723 kbps 00:04:34.732 151,600 bytes 639,077 bytes 00:00:20.937 2 0:07:57.143 0:05:48.097 28,614 kbps 44,067 kbps 00:09:19.433 38,008 kbps 00:09:18.099 35,876 kbps 00:09:31.946 149,183 bytes 512,205 bytes 00:08:21.417 3 0:13:45.241 0:02:35.613 26,956 kbps 41,661 kbps 00:14:55.644 33,849 kbps 00:14:45.551 32,147 kbps 00:13:45.241 140,535 bytes 664,937 bytes 00:14:47.177 4 0:16:20.854 0:02:14.884 24,630 kbps 38,522 kbps 00:16:23.232 34,954 kbps 00:16:21.063 32,442 kbps 00:16:20.854 128,411 bytes 563,184 bytes 00:16:24.149 5 0:18:35.739 0:05:20.403 29,632 kbps 45,767 kbps 00:20:45.702 38,276 kbps 00:18:48.043 35,656 kbps 00:23:16.561 154,487 bytes 576,543 bytes 00:20:46.286 6 0:23:56.143 0:02:08.253 30,345 kbps 41,041 kbps 00:24:55.785 36,757 kbps 00:23:58.520 35,895 kbps 00:23:58.520 158,154 bytes 484,251 bytes 00:24:57.746 7 0:26:04.396 0:02:03.456 27,002 kbps 42,270 kbps 00:27:29.689 31,493 kbps 00:27:17.093 30,053 kbps 00:27:13.965 140,775 bytes 551,990 bytes 00:27:45.747 8 0:28:07.852 0:02:22.058 33,010 kbps 45,811 kbps 00:29:26.973 37,958 kbps 00:29:44.532 36,390 kbps 00:30:16.272 172,148 bytes 493,011 bytes 00:30:21.528 9 0:30:29.911 0:02:15.593 33,326 kbps 43,081 kbps 00:32:01.711 36,893 kbps 00:32:26.611 36,097 kbps 00:32:27.362 173,746 bytes 518,123 bytes 00:31:12.287 10 0:32:45.505 0:06:09.619 31,138 kbps 44,200 kbps 00:35:54.277 38,572 kbps 00:35:50.857 35,116 kbps 00:35:47.770 162,337 bytes 681,228 bytes 00:35:07.980 11 0:38:55.124 0:03:22.952 31,879 kbps 46,180 kbps 00:40:12.368 38,583 kbps 00:40:09.156 36,215 kbps 00:39:48.803 166,203 bytes 584,370 bytes 00:40:13.327 12 0:42:18.077 0:03:04.642 25,660 kbps 41,601 kbps 00:42:33.425 34,760 kbps 00:42:33.425 31,216 kbps 00:42:30.839 133,779 bytes 515,088 bytes 00:42:33.467 13 0:45:22.719 0:03:40.178 31,848 kbps 43,503 kbps 00:47:05.614 37,380 kbps 00:46:28.243 35,794 kbps 00:46:54.478 166,040 bytes 529,773 bytes 00:45:46.869 14 0:49:02.898 0:07:56.726 28,591 kbps 47,931 kbps 00:54:03.531 38,194 kbps 00:54:02.822 34,688 kbps 00:50:03.792 149,061 bytes 593,148 bytes 00:56:59.624 15 0:56:59.624 0:06:44.779 27,515 kbps 50,470 kbps 01:00:27.832 38,720 kbps 01:00:45.850 35,626 kbps 01:00:06.102 143,452 bytes 671,554 bytes 00:57:13.137 16 1:03:44.403 0:02:18.638 29,287 kbps 44,878 kbps 01:04:39.208 38,410 kbps 01:03:53.287 35,137 kbps 01:04:45.881 152,688 bytes 568,844 bytes 01:05:29.925 17 1:06:03.042 0:02:44.247 31,340 kbps 49,262 kbps 01:07:32.923 37,604 kbps 01:07:52.443 36,243 kbps 01:07:55.029 163,391 bytes 602,505 bytes 01:07:33.883 18 1:08:47.289 0:04:19.676 30,035 kbps 49,485 kbps 01:10:46.075 38,352 kbps 01:12:44.735 36,076 kbps 01:10:25.429 156,590 bytes 622,682 bytes 01:11:26.448 19 1:13:06.965 0:01:40.517 26,328 kbps 43,367 kbps 01:14:23.834 33,105 kbps 01:13:19.269 30,202 kbps 01:13:19.269 137,261 bytes 594,243 bytes 01:14:23.876 20 1:14:47.482 0:03:34.547 29,209 kbps 47,372 kbps 01:17:13.670 38,263 kbps 01:17:12.377 35,831 kbps 01:17:10.041 152,284 bytes 597,593 bytes 01:15:25.520 21 1:18:22.030 0:04:11.668 30,654 kbps 46,591 kbps 01:22:10.008 38,893 kbps 01:20:04.716 36,225 kbps 01:22:01.458 159,818 bytes 710,843 bytes 01:22:10.050 22 1:22:33.698 0:02:54.173 26,066 kbps 47,959 kbps 01:25:03.181 38,274 kbps 01:25:03.181 35,576 kbps 01:23:35.093 135,898 bytes 548,293 bytes 01:25:03.890 23 1:25:27.872 0:00:47.130 29,874 kbps 50,128 kbps 01:26:10.999 38,178 kbps 01:25:40.843 34,672 kbps 01:25:40.093 155,748 bytes 473,847 bytes 01:26:11.040 24 1:26:15.003 0:07:28.614 16,286 kbps 37,695 kbps 01:32:45.935 35,967 kbps 01:32:41.889 35,040 kbps 01:32:37.927 84,906 bytes 732,789 bytes 01:32:41.972 25 1:33:43.617 0:00:01.001 103 kbps 0 kbps 00:00:00.000 0 kbps 00:00:00.000 0 kbps 00:00:00.000 561 bytes 785 bytes 01:33:43.909 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00001.M2TS 4113 (0x1011) 0x1B AVC 1196.487 28,351 4,240,236,125 23,061,481 00001.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 1196.487 4,259 636,988,008 3,648,322 00001.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 1196.487 448 67,011,840 373,950 00001.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 1196.487 448 67,011,840 373,950 00001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1196.487 74 11,026,586 62,442 00001.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 1196.487 60 8,904,358 50,673 00001.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 1196.487 1 100,275 585 00001.M2TS 4611 (0x1203) 0x90 PGS fra (French) 1196.487 2 328,050 1,883 00001.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 1196.487 54 8,082,920 46,318 00001.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 1196.487 58 8,630,899 49,487 00001.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 1196.487 46 6,834,367 39,542 00001.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 1196.487 48 7,169,620 41,338 00011.M2TS 4113 (0x1011) 0x1B AVC 463.755 29,097 1,686,742,934 9,173,539 00011.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 463.755 4,266 247,296,692 1,416,828 00011.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 463.755 448 25,976,832 144,960 00011.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 463.755 448 25,976,832 144,960 00011.M2TS 4608 (0x1200) 0x90 PGS eng (English) 463.755 73 4,246,270 24,122 00011.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 463.755 53 3,093,245 17,628 00011.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 463.755 11 665,525 3,857 00011.M2TS 4611 (0x1203) 0x90 PGS fra (French) 463.755 13 770,690 4,429 00011.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 463.755 51 2,962,027 17,054 00011.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 463.755 53 3,085,218 17,768 00011.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 463.755 45 2,592,684 15,024 00011.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 463.755 44 2,560,620 14,845 00003.M2TS 4113 (0x1011) 0x1B AVC 327.869 32,282 1,323,014,283 7,194,877 00003.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 327.869 4,539 186,030,576 1,062,283 00003.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 327.869 448 18,369,792 102,510 00003.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 327.869 448 18,369,792 102,510 00003.M2TS 4608 (0x1200) 0x90 PGS eng (English) 327.869 54 2,232,533 12,685 00003.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 327.869 37 1,495,956 8,534 00003.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 327.869 0 10,286 64 00003.M2TS 4611 (0x1203) 0x90 PGS fra (French) 327.869 1 59,686 350 00003.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 327.869 33 1,335,027 7,748 00003.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 327.869 37 1,506,328 8,663 00003.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 327.869 31 1,251,011 7,266 00003.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 327.869 28 1,136,706 6,599 00012.M2TS 4113 (0x1011) 0x1B AVC 549.549 31,402 2,157,101,471 11,731,010 00012.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 549.549 4,642 318,851,080 1,818,979 00012.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 549.549 448 30,781,184 171,770 00012.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 549.549 448 30,781,184 171,770 00012.M2TS 4608 (0x1200) 0x90 PGS eng (English) 549.549 69 4,763,544 27,027 00012.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 549.549 52 3,572,236 20,372 00012.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 549.549 17 1,141,336 6,567 00012.M2TS 4611 (0x1203) 0x90 PGS fra (French) 549.549 18 1,245,196 7,130 00012.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 549.549 50 3,413,459 19,618 00012.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 549.549 51 3,520,943 20,224 00012.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 549.549 43 2,926,459 16,952 00012.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 549.549 43 2,958,200 17,127 00005.M2TS 4113 (0x1011) 0x1B AVC 184.476 25,681 592,193,921 3,221,012 00005.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 184.476 4,009 92,454,904 531,193 00005.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 184.476 448 10,341,632 57,710 00005.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 184.476 448 10,341,632 57,710 00005.M2TS 4608 (0x1200) 0x90 PGS eng (English) 184.476 73 1,676,913 9,518 00005.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 184.476 64 1,467,595 8,347 00005.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 184.476 0 8,875 56 00005.M2TS 4611 (0x1203) 0x90 PGS fra (French) 184.476 4 92,702 520 00005.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 184.476 55 1,265,068 7,266 00005.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 184.476 60 1,375,219 7,896 00005.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 184.476 48 1,107,154 6,390 00005.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 184.476 52 1,195,240 6,839 00013.M2TS 4113 (0x1011) 0x1B AVC 303.678 31,655 1,201,601,360 6,534,688 00013.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 303.678 4,244 161,111,020 922,752 00013.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 303.678 448 17,016,832 94,960 00013.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 303.678 448 17,016,832 94,960 00013.M2TS 4608 (0x1200) 0x90 PGS eng (English) 303.678 87 3,294,386 18,723 00013.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 303.678 64 2,433,704 13,923 00013.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 303.678 5 201,591 1,156 00013.M2TS 4611 (0x1203) 0x90 PGS fra (French) 303.678 6 236,536 1,343 00013.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 303.678 67 2,547,806 14,693 00013.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 303.678 68 2,590,169 14,903 00013.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 303.678 53 2,007,607 11,684 00013.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 303.678 54 2,060,849 11,958 00007.M2TS 4113 (0x1011) 0x1B AVC 338.380 28,104 1,188,743,618 6,465,293 00007.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 338.380 4,175 176,587,424 1,012,505 00007.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 338.380 448 18,961,152 105,810 00007.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 338.380 448 18,961,152 105,810 00007.M2TS 4608 (0x1200) 0x90 PGS eng (English) 338.380 94 3,976,420 22,459 00007.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 338.380 66 2,788,661 15,822 00007.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 338.380 0 0 0 00007.M2TS 4611 (0x1203) 0x90 PGS fra (French) 338.380 0 0 0 00007.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 338.380 63 2,658,127 15,246 00007.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 338.380 68 2,856,749 16,372 00007.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 338.380 53 2,222,663 12,846 00007.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 338.380 52 2,191,771 12,688 00014.M2TS 4113 (0x1011) 0x1B AVC 83.333 29,556 307,877,414 1,674,422 00014.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 83.333 4,336 45,166,748 258,270 00014.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 83.333 448 4,671,744 26,070 00014.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 83.333 448 4,671,744 26,070 00014.M2TS 4608 (0x1200) 0x90 PGS eng (English) 83.333 60 622,939 3,527 00014.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 83.333 58 608,838 3,459 00014.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 83.333 35 362,474 2,062 00014.M2TS 4611 (0x1203) 0x90 PGS fra (French) 83.333 41 430,463 2,439 00014.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 83.333 44 454,398 2,585 00014.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 83.333 44 456,543 2,597 00014.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 83.333 37 387,344 2,220 00014.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 83.333 31 328,026 1,882 00009.M2TS 4113 (0x1011) 0x1B AVC 1438.562 29,028 5,219,886,614 28,389,123 00009.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 1438.562 4,640 834,278,904 4,758,334 00009.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 1438.562 448 80,566,528 449,590 00009.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 1438.562 448 80,566,528 449,590 00009.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1438.562 59 10,620,613 60,500 00009.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 1438.562 40 7,165,137 40,870 00009.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 1438.562 1 165,336 940 00009.M2TS 4611 (0x1203) 0x90 PGS fra (French) 1438.562 1 135,674 770 00009.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 1438.562 38 6,888,704 39,645 00009.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 1438.562 40 7,204,806 41,578 00009.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 1438.562 33 5,998,245 34,787 00009.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 1438.562 33 6,006,165 34,794 00015.M2TS 4113 (0x1011) 0x1B AVC 737.320 20,789 1,915,977,446 10,423,176 00015.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 737.320 4,665 429,929,780 2,451,459 00015.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 737.320 448 41,298,432 230,460 00015.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 737.320 448 41,298,432 230,460 00015.M2TS 4608 (0x1200) 0x90 PGS eng (English) 737.320 51 4,686,059 26,686 00015.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 737.320 20 1,825,180 10,463 00015.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 737.320 3 253,560 1,452 00015.M2TS 4611 (0x1203) 0x90 PGS fra (French) 737.320 3 268,638 1,534 00015.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 737.320 19 1,796,326 10,388 00015.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 737.320 21 1,913,597 11,009 00015.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 737.320 18 1,639,767 9,523 00015.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 737.320 18 1,660,958 9,646
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
Jingle All the Way: Theatrical Cut (seamless) AVC 1:29:31 23,848,200,192 45,176,078,817 35.52 28.04 DTS-HD Master 5.1 4423Kbps (48kHz/24-bit)
DISC INFO: Disc Title: JINGLE_ALL_THE_WAY_US Disc Size: 45,176,078,817 bytes Protection: BD+ BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00001.MPLS Size: 23,848,200,192 bytes Length: 1:29:31 (h:m:s) Total Bitrate: 35.52 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 28039 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4423 kbps 5.1 / 48 kHz / 4423 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio French 448 kbps 5.1 / 48 kHz / 448 kbps Dolby Digital Audio Spanish 448 kbps 5.1 / 48 kHz / 448 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 67.502 kbps Presentation Graphics Chinese 44.007 kbps Presentation Graphics Chinese 46.621 kbps Presentation Graphics French 1.228 kbps Presentation Graphics Korean 37.737 kbps Presentation Graphics Spanish 47.003 kbps Presentation Graphics Spanish 0.685 kbps Presentation Graphics Thai 38.208 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00001.M2TS 0:00:00.000 0:19:56.612 5,345,163,264 35,735 00002.M2TS 0:19:56.612 0:06:26.928 1,794,619,392 37,105 00003.M2TS 0:26:23.540 0:05:27.994 1,639,409,664 39,986 00004.M2TS 0:31:51.534 0:07:18.187 2,147,887,104 39,214 00005.M2TS 0:39:09.722 0:03:04.642 754,225,152 32,678 00006.M2TS 0:42:14.365 0:04:42.490 1,322,385,408 37,449 00007.M2TS 0:46:56.855 0:05:38.546 1,499,547,648 35,435 00008.M2TS 0:52:35.402 0:00:45.211 189,628,416 33,554 00009.M2TS 0:53:20.613 0:23:58.645 6,606,323,712 36,736 00010.M2TS 1:17:19.259 0:12:11.856 2,549,010,432 27,864 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:57.143 29,081 kbps 51,026 kbps 00:00:01.876 38,477 kbps 00:00:26.234 35,723 kbps 00:04:34.732 151,600 bytes 639,077 bytes 00:00:20.937 2 0:07:57.143 0:05:48.097 28,614 kbps 44,067 kbps 00:09:19.433 38,008 kbps 00:09:18.099 35,876 kbps 00:09:31.946 149,183 bytes 512,205 bytes 00:08:21.417 3 0:13:45.241 0:02:35.613 26,956 kbps 41,661 kbps 00:14:55.644 33,849 kbps 00:14:45.551 32,147 kbps 00:13:45.241 140,535 bytes 664,937 bytes 00:14:47.177 4 0:16:20.854 0:02:14.884 24,630 kbps 38,522 kbps 00:16:23.232 34,954 kbps 00:16:21.063 32,442 kbps 00:16:20.854 128,411 bytes 563,184 bytes 00:16:24.149 5 0:18:35.739 0:04:03.368 30,340 kbps 43,670 kbps 00:20:45.702 38,276 kbps 00:18:48.043 35,573 kbps 00:20:49.289 158,180 bytes 562,801 bytes 00:20:46.286 6 0:22:39.107 0:02:08.378 30,119 kbps 39,929 kbps 00:23:38.750 36,338 kbps 00:22:41.485 35,237 kbps 00:22:41.485 157,026 bytes 513,560 bytes 00:22:40.776 7 0:24:47.485 0:02:03.456 27,616 kbps 41,068 kbps 00:26:12.779 32,596 kbps 00:25:05.629 32,138 kbps 00:25:00.749 143,929 bytes 551,990 bytes 00:26:28.837 8 0:26:50.942 0:02:22.058 33,010 kbps 45,811 kbps 00:28:10.063 37,958 kbps 00:28:27.622 36,390 kbps 00:28:59.362 172,148 bytes 493,011 bytes 00:29:04.617 9 0:29:13.001 0:02:15.593 33,326 kbps 43,081 kbps 00:30:44.801 36,893 kbps 00:31:09.701 36,097 kbps 00:31:10.451 173,746 bytes 518,123 bytes 00:29:55.376 10 0:31:28.595 0:04:30.395 31,647 kbps 43,611 kbps 00:34:09.714 38,034 kbps 00:34:06.294 35,302 kbps 00:34:01.330 164,994 bytes 654,734 bytes 00:33:23.418 11 0:35:58.990 0:03:10.732 31,442 kbps 45,170 kbps 00:38:10.579 37,586 kbps 00:36:56.881 36,132 kbps 00:36:52.668 163,925 bytes 549,013 bytes 00:37:17.193 12 0:39:09.722 0:03:04.642 25,660 kbps 41,601 kbps 00:39:25.070 34,760 kbps 00:39:25.071 31,216 kbps 00:39:22.485 133,778 bytes 515,088 bytes 00:39:25.112 13 0:42:14.365 0:03:18.823 29,875 kbps 42,910 kbps 00:42:36.679 36,726 kbps 00:42:35.844 35,618 kbps 00:43:30.649 155,756 bytes 543,930 bytes 00:43:27.771 14 0:45:33.188 0:07:18.271 28,314 kbps 47,931 kbps 00:50:33.822 38,194 kbps 00:50:33.113 34,537 kbps 00:46:35.626 147,603 bytes 553,383 bytes 00:52:51.459 15 0:52:51.459 0:06:45.029 27,329 kbps 50,470 kbps 00:56:19.918 38,720 kbps 00:56:37.936 35,626 kbps 00:55:58.188 142,498 bytes 620,037 bytes 00:55:10.765 16 0:59:36.489 0:02:18.638 29,287 kbps 44,878 kbps 01:00:31.294 38,410 kbps 00:59:45.373 35,137 kbps 01:00:37.967 152,688 bytes 568,844 bytes 01:01:22.011 17 1:01:55.127 0:02:44.247 31,340 kbps 49,262 kbps 01:03:25.009 37,604 kbps 01:03:44.528 36,243 kbps 01:03:47.114 163,391 bytes 602,505 bytes 01:03:25.968 18 1:04:39.375 0:04:19.676 30,035 kbps 49,485 kbps 01:06:38.160 38,352 kbps 01:08:36.820 36,076 kbps 01:06:17.515 156,590 bytes 622,682 bytes 01:07:18.534 19 1:08:59.051 0:01:40.517 26,328 kbps 43,367 kbps 01:10:15.919 33,105 kbps 01:09:11.355 30,202 kbps 01:09:11.355 137,261 bytes 594,243 bytes 01:10:15.961 20 1:10:39.568 0:03:34.547 29,209 kbps 47,372 kbps 01:13:05.756 38,263 kbps 01:13:04.463 35,831 kbps 01:13:02.127 152,284 bytes 597,593 bytes 01:11:17.606 21 1:14:14.116 0:04:11.668 30,501 kbps 52,104 kbps 01:18:02.093 38,893 kbps 01:15:56.802 36,314 kbps 01:17:53.543 158,994 bytes 776,410 bytes 01:18:02.135 22 1:18:25.784 0:02:54.465 24,910 kbps 48,190 kbps 01:20:55.266 38,319 kbps 01:20:55.266 34,857 kbps 01:20:55.266 129,869 bytes 547,109 bytes 01:20:55.976 23 1:21:20.250 0:07:25.111 16,371 kbps 37,657 kbps 01:27:51.182 35,768 kbps 01:27:47.136 34,857 kbps 01:27:43.174 85,352 bytes 726,263 bytes 01:27:47.220 24 1:28:45.361 0:00:44.753 32,160 kbps 52,874 kbps 01:29:25.902 39,263 kbps 01:28:54.871 36,655 kbps 01:28:53.995 167,670 bytes 456,914 bytes 01:29:25.943 25 1:29:30.114 0:00:01.000 102 kbps 0 kbps 00:00:00.000 0 kbps 00:00:00.000 0 kbps 00:00:00.000 579 bytes 788 bytes 01:29:30.406 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00001.M2TS 4113 (0x1011) 0x1B AVC 1196.487 28,351 4,240,236,125 23,061,481 00001.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 1196.487 4,259 636,988,008 3,648,322 00001.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 1196.487 448 67,011,840 373,950 00001.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 1196.487 448 67,011,840 373,950 00001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1196.487 74 11,026,586 62,442 00001.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 1196.487 60 8,904,358 50,673 00001.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 1196.487 1 100,275 585 00001.M2TS 4611 (0x1203) 0x90 PGS fra (French) 1196.487 2 328,050 1,883 00001.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 1196.487 54 8,082,920 46,318 00001.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 1196.487 58 8,630,899 49,487 00001.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 1196.487 46 6,834,367 39,542 00001.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 1196.487 48 7,169,620 41,338 00002.M2TS 4113 (0x1011) 0x1B AVC 386.845 29,558 1,429,273,667 7,773,219 00002.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 386.845 4,375 211,540,644 1,210,230 00002.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 386.845 448 21,668,864 120,920 00002.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 386.845 448 21,668,864 120,920 00002.M2TS 4608 (0x1200) 0x90 PGS eng (English) 386.845 82 3,974,273 22,584 00002.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 386.845 55 2,659,819 15,124 00002.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 386.845 3 139,453 808 00002.M2TS 4611 (0x1203) 0x90 PGS fra (French) 386.845 3 151,980 875 00002.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 386.845 50 2,435,884 14,022 00002.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 386.845 53 2,566,880 14,780 00002.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 386.845 44 2,151,212 12,452 00002.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 386.845 43 2,092,684 12,136 00003.M2TS 4113 (0x1011) 0x1B AVC 327.869 32,282 1,323,014,283 7,194,877 00003.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 327.869 4,539 186,030,576 1,062,283 00003.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 327.869 448 18,369,792 102,510 00003.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 327.869 448 18,369,792 102,510 00003.M2TS 4608 (0x1200) 0x90 PGS eng (English) 327.869 54 2,232,533 12,685 00003.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 327.869 37 1,495,956 8,534 00003.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 327.869 0 10,286 64 00003.M2TS 4611 (0x1203) 0x90 PGS fra (French) 327.869 1 59,686 350 00003.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 327.869 33 1,335,027 7,748 00003.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 327.869 37 1,506,328 8,663 00003.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 327.869 31 1,251,011 7,266 00003.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 327.869 28 1,136,706 6,599 00004.M2TS 4113 (0x1011) 0x1B AVC 438.104 31,572 1,729,005,805 9,402,938 00004.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 438.104 4,416 241,826,572 1,382,605 00004.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 438.104 448 24,541,440 136,950 00004.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 438.104 448 24,541,440 136,950 00004.M2TS 4608 (0x1200) 0x90 PGS eng (English) 438.104 71 3,886,397 22,044 00004.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 438.104 50 2,736,658 15,591 00004.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 438.104 0 0 0 00004.M2TS 4611 (0x1203) 0x90 PGS fra (French) 438.104 0 0 0 00004.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 438.104 48 2,636,661 15,189 00004.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 438.104 50 2,751,943 15,845 00004.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 438.104 40 2,175,893 12,669 00004.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 438.104 42 2,311,444 13,405 00005.M2TS 4113 (0x1011) 0x1B AVC 184.476 25,681 592,193,921 3,221,012 00005.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 184.476 4,009 92,454,904 531,193 00005.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 184.476 448 10,341,632 57,710 00005.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 184.476 448 10,341,632 57,710 00005.M2TS 4608 (0x1200) 0x90 PGS eng (English) 184.476 73 1,676,913 9,518 00005.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 184.476 64 1,467,595 8,347 00005.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 184.476 0 8,875 56 00005.M2TS 4611 (0x1203) 0x90 PGS fra (French) 184.476 4 92,702 520 00005.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 184.476 55 1,265,068 7,266 00005.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 184.476 60 1,375,219 7,896 00005.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 184.476 48 1,107,154 6,390 00005.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 184.476 52 1,195,240 6,839 00006.M2TS 4113 (0x1011) 0x1B AVC 282.324 30,155 1,064,196,153 5,787,668 00006.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 282.324 4,066 143,495,224 824,008 00006.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 282.324 448 15,821,568 88,290 00006.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 282.324 448 15,821,568 88,290 00006.M2TS 4608 (0x1200) 0x90 PGS eng (English) 282.324 84 2,955,037 16,804 00006.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 282.324 63 2,232,113 12,767 00006.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 282.324 0 0 0 00006.M2TS 4611 (0x1203) 0x90 PGS fra (French) 282.324 0 0 0 00006.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 282.324 66 2,329,758 13,442 00006.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 282.324 67 2,377,117 13,687 00006.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 282.324 52 1,847,648 10,757 00006.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 282.324 52 1,828,743 10,621 00007.M2TS 4113 (0x1011) 0x1B AVC 338.380 28,104 1,188,743,618 6,465,293 00007.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 338.380 4,175 176,587,424 1,012,505 00007.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 338.380 448 18,961,152 105,810 00007.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 338.380 448 18,961,152 105,810 00007.M2TS 4608 (0x1200) 0x90 PGS eng (English) 338.380 94 3,976,420 22,459 00007.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 338.380 66 2,788,661 15,822 00007.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 338.380 0 0 0 00007.M2TS 4611 (0x1203) 0x90 PGS fra (French) 338.380 0 0 0 00007.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 338.380 63 2,658,127 15,246 00007.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 338.380 68 2,856,749 16,372 00007.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 338.380 53 2,222,663 12,846 00007.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 338.380 52 2,191,771 12,688 00008.M2TS 4113 (0x1011) 0x1B AVC 45.128 26,606 150,085,088 816,317 00008.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 45.128 4,123 23,258,164 133,564 00008.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 45.128 449 2,533,888 14,140 00008.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 45.128 449 2,533,888 14,140 00008.M2TS 4608 (0x1200) 0x90 PGS eng (English) 45.128 50 283,951 1,610 00008.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 45.128 50 281,926 1,599 00008.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 45.128 6 35,562 202 00008.M2TS 4611 (0x1203) 0x90 PGS fra (French) 45.128 10 56,670 325 00008.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 45.128 21 117,283 679 00008.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 45.128 21 117,497 680 00008.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 45.128 19 108,477 631 00008.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 45.128 12 64,962 378 00009.M2TS 4113 (0x1011) 0x1B AVC 1438.562 29,028 5,219,886,614 28,389,123 00009.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 1438.562 4,640 834,278,904 4,758,334 00009.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 1438.562 448 80,566,528 449,590 00009.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 1438.562 448 80,566,528 449,590 00009.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1438.562 59 10,620,613 60,500 00009.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 1438.562 40 7,165,137 40,870 00009.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 1438.562 1 165,336 940 00009.M2TS 4611 (0x1203) 0x90 PGS fra (French) 1438.562 1 135,674 770 00009.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 1438.562 38 6,888,704 39,645 00009.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 1438.562 40 7,204,806 41,578 00009.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 1438.562 33 5,998,245 34,787 00009.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 1438.562 33 6,006,165 34,794 00010.M2TS 4113 (0x1011) 0x1B AVC 731.731 20,646 1,888,438,665 10,273,427 00010.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 731.731 4,625 422,992,196 2,412,869 00010.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 731.731 448 40,986,624 228,720 00010.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 731.731 448 40,986,624 228,720 00010.M2TS 4608 (0x1200) 0x90 PGS eng (English) 731.731 51 4,687,360 26,694 00010.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 731.731 20 1,825,180 10,463 00010.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 731.731 0 0 0 00010.M2TS 4611 (0x1203) 0x90 PGS fra (French) 731.731 0 0 0 00010.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 731.731 20 1,796,326 10,388 00010.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 731.731 21 1,913,597 11,009 00010.M2TS 4614 (0x1206) 0x90 PGS kor (Korean) 731.731 18 1,639,767 9,523 00010.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 731.731 18 1,654,856 9,613
Total Video
(JP) Eternal Sunshine of the Spotless Mind AVC 1:47:41 34,929,045,504 38,730,906,428 43.25 37.57 Dolby TrueHD 5.1 1163Kbps (48kHz/16-bit) DD AC3 5.1 448Kbps
DISC INFO: Disc Title: BDROM Disc Size: 38,730,906,428 bytes Protection: AACS BD-Java: No BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00000.MPLS Size: 34,929,045,504 bytes Length: 1:47:41 (h:m:s) Total Bitrate: 43.25 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 37567 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby TrueHD Audio English 1163 kbps 5.1 / 48 kHz / 1163 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps) Dolby Digital Audio English 448 kbps 5.1 / 48 kHz / 448 kbps Dolby Digital Audio Japanese 448 kbps 5.1 / 48 kHz / 448 kbps Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics Japanese 118.504 kbps Presentation Graphics Japanese 1.876 kbps Presentation Graphics Japanese 234.866 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:47:41.455 34,929,045,504 43,246 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:03:42.722 37,911 kbps 43,915 kbps 00:02:08.378 40,311 kbps 00:02:04.415 39,742 kbps 00:01:03.563 197,615 bytes 381,148 bytes 00:02:19.931 2 0:03:42.722 0:06:48.032 39,316 kbps 41,531 kbps 00:09:41.539 39,781 kbps 00:09:22.436 39,670 kbps 00:06:16.626 204,977 bytes 319,027 bytes 00:07:54.098 3 0:10:30.755 0:02:54.090 38,795 kbps 43,063 kbps 00:11:11.212 39,863 kbps 00:11:07.124 39,590 kbps 00:12:24.535 202,259 bytes 297,079 bytes 00:11:11.712 4 0:13:24.845 0:04:12.543 38,761 kbps 42,913 kbps 00:17:34.344 40,174 kbps 00:16:38.831 39,660 kbps 00:16:33.909 202,081 bytes 331,578 bytes 00:16:43.585 5 0:17:37.389 0:01:57.450 38,230 kbps 41,657 kbps 00:18:14.259 39,605 kbps 00:19:17.072 39,582 kbps 00:19:12.192 199,316 bytes 283,167 bytes 00:19:13.110 6 0:19:34.840 0:05:36.461 38,605 kbps 43,831 kbps 00:23:25.987 40,236 kbps 00:20:04.828 39,716 kbps 00:23:16.978 201,268 bytes 365,694 bytes 00:21:02.344 7 0:25:11.301 0:02:49.002 39,176 kbps 43,822 kbps 00:26:24.332 40,190 kbps 00:26:16.449 39,896 kbps 00:26:11.361 204,245 bytes 321,166 bytes 00:26:25.000 8 0:28:00.303 0:07:07.760 39,223 kbps 46,410 kbps 00:29:13.793 40,164 kbps 00:29:01.072 39,729 kbps 00:29:45.283 204,490 bytes 359,285 bytes 00:34:30.485 9 0:35:08.064 0:07:58.019 38,321 kbps 44,415 kbps 00:37:35.503 40,420 kbps 00:37:31.499 39,871 kbps 00:37:26.452 199,788 bytes 309,086 bytes 00:37:00.468 10 0:43:06.083 0:06:22.507 38,328 kbps 41,494 kbps 00:43:15.217 39,729 kbps 00:49:11.657 39,648 kbps 00:49:06.652 199,822 bytes 321,025 bytes 00:47:18.293 11 0:49:28.590 0:02:44.622 38,920 kbps 41,521 kbps 00:49:47.025 39,750 kbps 00:51:23.371 39,608 kbps 00:50:25.022 202,909 bytes 288,275 bytes 00:51:17.157 12 0:52:13.213 0:07:10.763 37,639 kbps 43,460 kbps 00:57:50.300 40,065 kbps 00:57:46.379 39,698 kbps 00:58:10.278 196,234 bytes 459,901 bytes 00:57:50.967 13 0:59:23.977 0:03:28.750 39,317 kbps 43,449 kbps 01:02:23.072 39,974 kbps 01:02:19.068 39,748 kbps 01:02:14.063 204,980 bytes 329,689 bytes 01:02:50.099 14 1:02:52.727 0:12:57.193 38,603 kbps 43,058 kbps 01:05:25.296 40,348 kbps 01:05:21.250 39,791 kbps 01:08:31.190 201,258 bytes 400,428 bytes 01:09:46.682 15 1:15:49.920 0:05:37.879 38,606 kbps 42,780 kbps 01:21:00.522 40,083 kbps 01:18:28.745 39,809 kbps 01:18:23.824 201,276 bytes 291,321 bytes 01:19:39.399 16 1:21:27.799 0:02:54.382 38,312 kbps 41,057 kbps 01:22:22.228 39,714 kbps 01:21:52.574 39,513 kbps 01:22:45.502 199,743 bytes 313,824 bytes 01:23:13.029 17 1:24:22.182 0:07:22.483 37,227 kbps 47,208 kbps 01:31:19.599 40,201 kbps 01:27:44.676 39,716 kbps 01:27:39.796 194,084 bytes 331,873 bytes 01:31:20.433 18 1:31:44.665 0:04:07.080 38,995 kbps 41,640 kbps 01:33:43.284 39,901 kbps 01:33:46.662 39,674 kbps 01:33:22.555 203,304 bytes 307,024 bytes 01:34:22.323 19 1:35:51.746 0:08:13.534 38,743 kbps 44,239 kbps 01:36:35.956 40,358 kbps 01:36:31.952 39,818 kbps 01:40:50.210 201,986 bytes 331,557 bytes 01:38:51.342 20 1:44:05.280 0:03:33.504 9,686 kbps 18,799 kbps 01:46:44.773 17,768 kbps 01:46:43.772 16,561 kbps 01:46:41.019 50,497 bytes 274,312 bytes 01:46:45.440 21 1:47:38.785 0:00:02.669 393 kbps 413 kbps 01:47:39.619 0 kbps 00:00:00.000 0 kbps 00:00:00.000 2,083 bytes 3,413 bytes 01:47:39.786 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 6461.288 37,568 30,342,239,120 164,994,031 00000.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 6461.288 1,611 1,301,428,872 10,048,516 00000.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 6461.288 448 361,842,432 2,019,210 00000.M2TS 4354 (0x1102) 0x81 AC3 jpn (Japanese) 6461.288 448 361,842,432 2,019,210 00000.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 6461.288 192 155,075,328 1,009,605 00000.M2TS 4608 (0x1200) 0x90 PGS jpn (Japanese) 6461.288 119 95,713,629 543,458 00000.M2TS 4609 (0x1201) 0x90 PGS jpn (Japanese) 6461.288 2 1,515,533 8,560 00000.M2TS 4610 (0x1202) 0x90 PGS jpn (Japanese) 6461.288 235 189,697,183 1,063,021
Video Total
Region Year Title Codec Display Aspect Bitrate Length Movie Size Disc Size Bitrate Primary Language Audio
ABC [CZ] 2008 10,000 BC VC-1 1080p24 2.40:1 16.42 1:48:55 21,807,962,112 29,195,609,964 26.70 TrueHD 5.1 48/16 1666
ABC [CZ] 2006 300 VC-1 1080p24 2.40:1 16.58 1:56:38 22,607,075,328 31,757,127,836 25.84 TrueHD 5.1 48/16 1734 / AC3 5.1 48 640
[UK] 2006 FIFA World Cup 2006: All The Goals MPEG-2 1080i50 1.78:1 39.66 2:00:14 38,923,431,936 42,615,439,158 43.16 AC3 2.0 192
ABC [US] 2005 The Amateurs VC-1 1080p24 1.85:1 14.99 1:38:21 13,276,342,272 20,790,383,032 18.00 DTS 5.1 48 768 / AC3 5.1 48 640 / AC3 2.0 48 192
ABC [US] 2008 An American Carol AVC 1080p24 2.35:1 23.40 1:22:27 15,893,200,896 19,345,519,028 25.70 AC3 5.1 48 448 / AC3 2.0 48 384
ABC [US] 1996 The Beast MPEG-2 720p60 1.78:1 15.30 2:53:38 21,245,300,736 21,316,627,764 16.31 AC3 2.0 48 192
ABC [US] 2007 Donkey X AVC 1080p24 2.35:1 19.10 1:27:25 15,711,725,568 17,167,864,148 23.96 DTS-MA 2.0 48/16 1587
ABC [JP] 2004 Eternal Sunshine of the Spotless Mind AVC 1080p24 1.85:1 37.57 1:47:41 34,929,045,504 38,730,906,428 43.25 TrueHD 5.1 48/16 1163 / AC3 5.1 48 448
ABC [US] 2007 The Heartbreak Kid AVC 1080p24 2.35:1 37.55 1:55:33 39,777,447,936 42,900,518,448 45.90 TrueHD 5.1 48/24 2885
BC [CZ] 2007 Hitman AVC 1080p24 2.35:1 15.97 1:34:14 17,420,937,216 24,394,242,396 24.65 DTS-HR 5.1 48/24 3018
A [US] 1996 Jingle All the Way: Extended (seamless) AVC 1080p24 1.85:1 28.21 1:33:44 25,126,115,328 45,176,078,817 35.74 DTS-MA 5.1 48/24 4450
Theatrical (seamless) AVC 1080p24 1.85:1 28.04 1:29:31 23,848,200,192 35.52 DTS-MA 5.1 48/24 4450
A [US] 1980 Kagemusha AVC 1080p24 1.85:1 21.27 3:00:36 34,499,653,632 49,708,896,608 25.47 DTS-MA 4.0 48/24 2586
A [US] 1961 Last Year at Marienbad AVC 1080p24 2.35:1 34.62 1:34:43 29,234,737,152 49,237,323,332 41.15 LPCM 1.0 48/24 1152 / LPCM 1.0 48/24 1152
ABC [UK] 2006 Pan's Labyrinth VC-1 1080p24 1.85:1 29.45 1:58:56 28,573,224,960 36,599,330,132 32.03 AC3 5.1 48 640 / AC3 2.0 48 224
A [US] 1967 Play Time AVC 1080p24 1.85:1 24.49 2:04:34 24,532,033,536 49,161,111,601 26.26 LPCM 2.0 48/24 2304 / AC3 2.0 48 192
A [US] 1965 Repulsion AVC 1080p24 1.66:1 34.56 1:45:16 30,681,366,528 44,993,411,114 38.86 LPCM 1.0 48/24 1152
ABC [UK] 1957 The Seventh Seal AVC 1080p24 1.33:1 21.99 1:36:13 16,988,663,808 16,988,663,808 23.54 AC3 2.0 48 224
A [US] 1984 This Is Spinal Tap AVC 1080p24 1.85:1 32.98 1:22:50 24,071,086,080 35,143,834,301 38.75 DTS-MA 5.1 48/24 3129 / AC3 2.0 48 224
A [US] 1974 The Towering Inferno AVC 1080p24 2.35:1 24.82 2:44:53 39,291,930,624 48,243,804,187 31.77 DTS-MA 5.1 48/24 3555 / AC3 4.0 48 448 / AC3 2.0 48 224
ABC [AU] 1998 The Truman Show AVC 1080p24 1.78:1 35.83 1:42:56 36,109,633,536 40,804,594,163 46.77 TrueHD 5.1 48/24 3672
Total Video
Crash: Director's Cut Edition (2005) MPEG-2 1:55:00 20,942,321,664 21,736,091,712 24.28 20.78 DTS 6.1-ES 1509Kbps (48kHz/24-bit) DD AC3 5.1-EX 640Kbps
DISC INFO: Disc Title: LOGICAL_VOLUME_ID (98828491_CRASH_BD) Disc Size: 21,736,091,712 bytes Protection: AACS BD-Java: No BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00000.MPLS Size: 20,942,321,664 bytes Length: 1:55:00 (h:m:s) Total Bitrate: 24.28 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-2 Video 20778 kbps 1080p / 23.976 fps / 16:9 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-ES Audio English 1509 kbps 6.1-ES / 48 kHz / 1509 kbps / 24-bit Dolby Digital EX Audio English 640 kbps 5.1-EX / 48 kHz / 640 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 38.736 kbps Presentation Graphics Spanish 30.050 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:55:00.894 20,942,321,664 24,278 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:48.342 17,046 kbps 35,615 kbps 00:00:16.307 25,820 kbps 00:00:14.514 24,186 kbps 00:06:33.017 88,863 bytes 572,535 bytes 00:06:03.654 2 0:07:48.342 0:08:28.424 21,884 kbps 32,484 kbps 00:10:23.247 28,369 kbps 00:10:23.164 26,678 kbps 00:10:23.205 114,095 bytes 591,718 bytes 00:15:14.330 3 0:16:16.767 0:08:52.406 22,505 kbps 36,614 kbps 00:17:17.870 28,378 kbps 00:17:17.578 27,090 kbps 00:16:35.244 117,332 bytes 576,320 bytes 00:22:12.998 4 0:25:09.174 0:10:09.775 20,965 kbps 31,943 kbps 00:30:51.474 25,666 kbps 00:33:08.861 24,172 kbps 00:33:03.856 109,304 bytes 568,734 bytes 00:33:10.405 5 0:35:18.950 0:07:39.876 20,846 kbps 33,769 kbps 00:40:05.027 24,793 kbps 00:37:42.093 23,757 kbps 00:42:48.816 108,681 bytes 560,326 bytes 00:36:37.361 6 0:42:58.826 0:06:27.553 20,150 kbps 29,390 kbps 00:46:22.029 25,356 kbps 00:43:45.039 24,368 kbps 00:43:44.204 105,053 bytes 543,499 bytes 00:47:27.761 7 0:49:26.380 0:10:59.909 20,429 kbps 33,870 kbps 00:58:40.141 25,089 kbps 00:50:11.883 24,016 kbps 00:50:10.257 106,509 bytes 589,422 bytes 00:55:16.354 8 1:00:26.289 0:06:05.865 22,186 kbps 39,282 kbps 01:04:48.259 35,018 kbps 01:05:28.674 29,114 kbps 01:05:27.757 115,669 bytes 573,600 bytes 01:03:10.578 9 1:06:32.154 0:09:29.026 21,141 kbps 33,122 kbps 01:15:50.796 27,665 kbps 01:15:48.669 26,922 kbps 01:15:44.414 110,217 bytes 592,909 bytes 01:14:22.374 10 1:16:01.181 0:09:31.570 21,259 kbps 34,536 kbps 01:22:38.286 27,298 kbps 01:23:50.275 25,893 kbps 01:23:48.690 110,835 bytes 587,097 bytes 01:22:59.891 11 1:25:32.752 0:07:51.429 22,703 kbps 30,944 kbps 01:31:13.843 26,968 kbps 01:31:09.839 26,087 kbps 01:29:08.426 118,363 bytes 530,787 bytes 01:33:24.181 12 1:33:24.181 0:07:51.721 20,358 kbps 31,488 kbps 01:34:03.262 24,121 kbps 01:34:21.656 23,383 kbps 01:34:22.448 106,136 bytes 593,450 bytes 01:37:49.530 13 1:41:15.903 0:06:23.299 21,172 kbps 33,956 kbps 01:46:08.987 26,804 kbps 01:45:30.699 25,394 kbps 01:46:08.987 110,379 bytes 542,917 bytes 01:46:13.658 14 1:47:39.202 0:07:20.690 17,956 kbps 29,866 kbps 01:48:21.620 28,366 kbps 01:50:43.637 27,524 kbps 01:50:39.132 93,616 bytes 520,490 bytes 01:49:00.700 15 1:54:59.893 0:00:01.001 737 kbps 0 kbps 00:00:00.000 0 kbps 00:00:00.000 0 kbps 00:00:00.000 4,011 bytes 43,989 bytes 01:55:00.435 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x02 MPEG-2 6900.769 20,778 17,923,281,057 97,505,591 00000.M2TS 4352 (0x1100) 0x82 DTS-ES eng (English) 6900.769 1,509 1,301,681,508 7,763,508 00000.M2TS 4353 (0x1101) 0x81 AC3-EX eng (English) 6900.769 640 552,071,680 3,234,795 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6900.769 39 33,413,769 190,148 00000.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 6900.769 30 25,921,186 149,322
Total Video
(CA) Hostage (1080i60) AVC 1:53:12 17,967,495,168 18,046,318,404 21.16 15.00 DTS-HD Master 5.1 4032Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
DISC INFO: Disc Title: HOSTAGE Disc Size: 18,046,318,404 bytes Protection: AACS BD-Java: No BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00003.MPLS Size: 17,967,495,168 bytes Length: 1:53:12 (h:m:s) Total Bitrate: 21.16 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 15000 kbps 1080i / 29.970 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4032 kbps 5.1 / 48 kHz / 4032 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 448 kbps 5.1 / 48 kHz / 448 kbps Dolby Digital Audio French 448 kbps 5.1 / 48 kHz / 448 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics French 0.119 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00003.M2TS 0:00:00.000 1:53:12.819 17,967,495,168 21,161 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:03:21.167 11,767 kbps 33,847 kbps 00:00:02.135 27,157 kbps 00:00:01.034 22,657 kbps 00:00:23.790 49,069 bytes 296,958 bytes 00:00:04.804 2 0:03:21.167 0:07:28.881 17,775 kbps 33,734 kbps 00:04:38.778 29,254 kbps 00:08:20.766 26,705 kbps 00:07:58.711 74,138 bytes 294,115 bytes 00:08:33.312 3 0:10:50.049 0:07:53.940 17,625 kbps 32,760 kbps 00:10:52.618 28,203 kbps 00:13:34.647 26,856 kbps 00:13:33.245 73,509 bytes 297,802 bytes 00:17:35.354 4 0:18:43.989 0:03:54.033 16,315 kbps 28,999 kbps 00:19:12.384 23,876 kbps 00:19:08.747 21,584 kbps 00:19:06.211 68,045 bytes 290,013 bytes 00:18:47.593 5 0:22:38.023 0:04:20.994 18,332 kbps 33,247 kbps 00:25:38.637 28,890 kbps 00:25:37.536 25,878 kbps 00:25:34.299 76,459 bytes 296,703 bytes 00:26:02.561 6 0:26:59.017 0:03:10.623 13,520 kbps 28,952 kbps 00:27:12.797 23,504 kbps 00:27:08.927 21,764 kbps 00:27:08.927 56,389 bytes 285,248 bytes 00:28:00.645 7 0:30:09.641 0:05:42.542 13,886 kbps 32,957 kbps 00:33:11.622 24,888 kbps 00:33:08.753 19,883 kbps 00:33:03.781 57,915 bytes 299,591 bytes 00:30:17.282 8 0:35:52.183 0:03:43.556 15,598 kbps 29,680 kbps 00:37:57.842 27,518 kbps 00:37:57.241 25,660 kbps 00:37:54.772 65,055 bytes 295,864 bytes 00:39:26.163 9 0:39:35.740 0:07:12.899 15,181 kbps 34,977 kbps 00:41:41.966 33,348 kbps 00:41:40.130 31,949 kbps 00:41:39.964 63,315 bytes 298,217 bytes 00:42:10.661 10 0:46:48.639 0:04:48.621 15,869 kbps 35,568 kbps 00:49:09.813 31,923 kbps 00:49:06.276 25,023 kbps 00:49:02.606 66,186 bytes 298,131 bytes 00:48:43.720 11 0:51:37.260 0:10:21.420 14,846 kbps 32,232 kbps 00:58:31.207 28,227 kbps 00:58:27.203 23,847 kbps 00:58:28.238 61,922 bytes 292,683 bytes 00:56:01.658 12 1:01:58.681 0:04:46.319 12,636 kbps 26,620 kbps 01:03:27.637 19,168 kbps 01:03:38.681 16,661 kbps 01:03:33.609 52,704 bytes 286,559 bytes 01:03:26.469 13 1:06:45.001 0:04:56.195 12,880 kbps 28,176 kbps 01:08:16.692 22,855 kbps 01:08:15.424 20,047 kbps 01:08:13.422 53,720 bytes 270,368 bytes 01:09:34.203 14 1:11:41.196 0:08:24.303 14,627 kbps 27,696 kbps 01:19:00.736 23,662 kbps 01:18:58.100 22,297 kbps 01:18:57.833 61,009 bytes 294,462 bytes 01:14:55.123 15 1:20:05.500 0:07:41.394 13,654 kbps 33,337 kbps 01:25:17.579 23,659 kbps 01:20:13.275 21,342 kbps 01:20:08.703 56,948 bytes 296,758 bytes 01:22:17.399 16 1:27:46.894 0:09:50.323 16,813 kbps 35,926 kbps 01:32:42.557 31,113 kbps 01:37:08.155 28,331 kbps 01:37:03.484 70,125 bytes 295,807 bytes 01:32:43.357 17 1:37:37.218 0:10:04.770 16,037 kbps 34,458 kbps 01:44:14.381 29,262 kbps 01:44:13.547 27,778 kbps 01:44:07.241 66,888 bytes 295,716 bytes 01:44:12.379 18 1:47:41.988 0:05:30.830 8,034 kbps 15,362 kbps 01:52:22.302 14,110 kbps 01:52:20.500 11,952 kbps 01:52:18.031 33,512 bytes 150,937 bytes 01:52:24.137 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00003.M2TS 4113 (0x1011) 0x1B AVC 6792.753 15,000 12,736,408,827 69,440,681 00003.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 6792.753 4,032 3,423,647,748 19,666,303 00003.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 6792.753 448 380,400,384 2,122,770 00003.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 6792.753 448 380,400,384 2,122,770 00003.M2TS 4608 (0x1200) 0x90 PGS fra (French) 6792.753 0 101,368 587
Total Video
Mutant Chronicles VC-1 1:40:49 28,420,159,488 40,422,392,524 37.59 31.20 DTS-HD Master 5.1 4232Kbps (48kHz/24-bit)
DISC INFO: Disc Title: MUTANT_CHRONICLES Disc Size: 40,422,392,524 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00000.MPLS Size: 28,420,159,488 bytes Length: 1:40:49 (h:m:s) Total Bitrate: 37.59 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 31202 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4232 kbps 5.1 / 48 kHz / 4232 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 27.680 kbps Presentation Graphics Spanish 24.947 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:40:49.043 28,420,159,488 37,586 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:15:23.631 33,384 kbps 53,786 kbps 00:13:58.212 42,055 kbps 00:07:17.353 39,826 kbps 00:05:45.386 174,041 bytes 743,217 bytes 00:11:33.567 2 0:15:23.631 0:03:42.513 32,780 kbps 55,670 kbps 00:17:23.459 42,310 kbps 00:18:04.792 39,967 kbps 00:17:32.176 170,900 bytes 696,613 bytes 00:18:09.671 3 0:19:06.145 0:04:56.129 32,161 kbps 52,980 kbps 00:20:37.402 41,439 kbps 00:19:44.266 39,438 kbps 00:21:35.210 167,672 bytes 716,915 bytes 00:23:43.088 4 0:24:02.274 0:06:08.618 32,805 kbps 56,126 kbps 00:26:39.139 40,145 kbps 00:24:22.794 38,706 kbps 00:24:22.377 171,028 bytes 676,219 bytes 00:28:32.001 5 0:30:10.892 0:07:46.257 34,164 kbps 57,094 kbps 00:30:43.716 43,466 kbps 00:31:48.281 41,296 kbps 00:30:48.388 178,118 bytes 715,572 bytes 00:37:17.234 6 0:37:57.149 0:08:33.346 33,509 kbps 57,540 kbps 00:43:08.168 41,742 kbps 00:43:34.403 39,337 kbps 00:43:30.816 174,984 bytes 810,499 bytes 00:44:01.639 7 0:46:30.496 0:06:32.642 33,716 kbps 49,927 kbps 00:51:03.977 41,271 kbps 00:46:46.178 39,324 kbps 00:48:19.688 175,779 bytes 645,696 bytes 00:52:15.590 8 0:53:03.138 0:14:11.100 33,661 kbps 56,903 kbps 01:01:03.326 42,267 kbps 00:59:17.804 40,613 kbps 00:59:14.717 175,493 bytes 620,869 bytes 00:58:19.078 9 1:07:14.238 0:05:27.201 32,128 kbps 59,967 kbps 01:10:32.227 42,212 kbps 01:08:45.663 38,520 kbps 01:08:22.389 167,498 bytes 573,594 bytes 01:09:16.694 10 1:12:41.440 0:11:14.340 32,564 kbps 60,958 kbps 01:12:45.360 42,889 kbps 01:12:41.440 39,517 kbps 01:15:32.110 169,774 bytes 696,903 bytes 01:19:10.245 11 1:23:55.780 0:09:12.802 33,411 kbps 58,486 kbps 01:25:08.728 42,311 kbps 01:32:08.689 39,441 kbps 01:32:07.021 174,520 bytes 676,863 bytes 01:27:06.220 12 1:33:08.583 0:07:39.417 6,609 kbps 14,403 kbps 01:37:28.551 13,979 kbps 01:37:26.131 13,546 kbps 01:37:23.295 35,687 bytes 215,543 bytes 01:40:34.028 13 1:40:48.000 0:00:01.042 200 kbps 209 kbps 01:40:48.000 0 kbps 00:00:00.000 0 kbps 00:00:00.000 2,174 bytes 9,236 bytes 01:40:49.001 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0xEA VC-1 6048.960 31,202 23,592,555,309 128,308,115 00000.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 6048.960 4,232 3,200,216,456 18,337,024 00000.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 6048.960 224 169,372,672 945,160 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6048.960 28 20,929,563 120,542 00000.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 6048.960 25 18,862,955 108,161
Total Video
Race to Witch Mountain AVC 1:38:17 27,729,967,104 36,453,440,969 37.61 28.05 DTS-HD Master 5.1 3903Kbps (48kHz/24-bit)
DISC INFO: Disc Title: WTM1NNE1 Disc Size: 36,453,440,969 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00034.MPLS Size: 27,729,967,104 bytes Length: 1:38:17 (h:m:s) Total Bitrate: 37.61 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 28054 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 3903 kbps 5.1 / 48 kHz / 3903 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio Chinese 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Portuguese 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Spanish 640 kbps 5.1 / 48 kHz / 640 kbps Dolby Digital Audio Thai 640 kbps 5.1 / 48 kHz / 640 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 31.685 kbps Presentation Graphics Chinese 24.274 kbps Presentation Graphics Chinese 23.477 kbps Presentation Graphics Chinese 27.222 kbps Presentation Graphics Chinese 0.721 kbps Presentation Graphics French 29.837 kbps Presentation Graphics French 0.866 kbps Presentation Graphics Indonesian 30.636 kbps Presentation Graphics Korean 18.560 kbps Presentation Graphics Malay 34.703 kbps Presentation Graphics Portuguese 29.378 kbps Presentation Graphics Portuguese 0.856 kbps Presentation Graphics Spanish 27.054 kbps Presentation Graphics Spanish 0.811 kbps Presentation Graphics Thai 23.134 kbps Presentation Graphics Thai 0.421 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00125.M2TS 0:00:00.000 1:38:17.933 27,729,967,104 37,613 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:09:08.548 29,376 kbps 48,603 kbps 00:01:56.324 37,945 kbps 00:08:05.776 37,126 kbps 00:08:00.771 153,142 bytes 711,810 bytes 00:01:46.106 2 0:09:08.548 0:03:58.237 33,072 kbps 41,078 kbps 00:11:53.170 36,489 kbps 00:10:47.104 36,263 kbps 00:10:19.493 172,421 bytes 417,350 bytes 00:13:06.452 3 0:13:06.785 0:04:19.592 31,397 kbps 45,839 kbps 00:16:19.770 36,740 kbps 00:14:48.721 36,473 kbps 00:13:07.036 163,688 bytes 430,778 bytes 00:13:17.046 4 0:17:26.378 0:10:02.101 26,200 kbps 42,714 kbps 00:26:53.737 36,926 kbps 00:17:55.949 35,599 kbps 00:27:18.470 136,597 bytes 440,247 bytes 00:26:54.571 5 0:27:28.480 0:08:20.666 28,422 kbps 41,806 kbps 00:30:46.803 36,501 kbps 00:34:01.622 36,388 kbps 00:33:57.952 148,181 bytes 390,877 bytes 00:31:48.656 6 0:35:49.147 0:05:50.600 25,439 kbps 38,333 kbps 00:41:14.388 33,768 kbps 00:35:52.483 31,844 kbps 00:36:59.550 132,627 bytes 324,564 bytes 00:39:08.387 7 0:41:39.747 0:06:52.703 23,960 kbps 40,450 kbps 00:44:18.030 36,118 kbps 00:46:44.593 36,081 kbps 00:46:39.296 124,919 bytes 367,440 bytes 00:46:12.686 8 0:48:32.451 0:09:11.842 26,469 kbps 39,518 kbps 00:54:24.219 36,680 kbps 00:53:48.475 36,005 kbps 00:49:55.242 138,000 bytes 408,920 bytes 00:53:48.934 9 0:57:44.294 0:09:01.374 30,446 kbps 41,150 kbps 01:03:49.200 36,299 kbps 01:05:49.111 35,903 kbps 01:05:45.066 158,730 bytes 393,179 bytes 01:04:12.431 10 1:06:45.668 0:06:16.334 30,080 kbps 43,725 kbps 01:12:40.898 37,583 kbps 01:12:36.894 36,571 kbps 01:09:14.692 156,821 bytes 520,731 bytes 01:09:51.103 11 1:13:02.002 0:20:42.366 29,237 kbps 47,006 kbps 01:26:00.780 37,222 kbps 01:30:15.993 36,356 kbps 01:21:38.852 152,431 bytes 508,291 bytes 01:14:26.920 12 1:33:44.368 0:04:33.564 21,097 kbps 38,369 kbps 01:38:06.171 35,062 kbps 01:34:32.333 28,371 kbps 01:34:30.206 110,007 bytes 360,323 bytes 01:34:32.375 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00125.M2TS 4113 (0x1011) 0x1B AVC 5897.767 28,055 20,682,602,321 112,488,178 00125.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5897.767 3,903 2,877,485,576 16,557,686 00125.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 5897.767 640 471,836,160 2,764,665 00125.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 5897.767 640 471,836,160 2,764,665 00125.M2TS 4355 (0x1103) 0x81 AC3 por (Portuguese) 5897.767 640 471,836,160 2,764,665 00125.M2TS 4356 (0x1104) 0x81 AC3 zho (Chinese) 5897.767 640 471,836,160 2,764,665 00125.M2TS 4357 (0x1105) 0x81 AC3 tha (Thai) 5897.767 640 471,836,160 2,764,665 00125.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5897.767 32 23,359,296 134,627 00125.M2TS 4609 (0x1201) 0x90 PGS fra (French) 5897.767 30 21,996,845 126,641 00125.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 5897.767 27 19,945,351 115,375 00125.M2TS 4611 (0x1203) 0x90 PGS por (Portuguese) 5897.767 29 21,658,420 124,767 00125.M2TS 4612 (0x1204) 0x90 PGS zho (Chinese) 5897.767 24 17,896,103 104,441 00125.M2TS 4613 (0x1205) 0x90 PGS zho (Chinese) 5897.767 23 17,308,389 101,343 00125.M2TS 4614 (0x1206) 0x90 PGS zho (Chinese) 5897.767 27 20,069,080 116,817 00125.M2TS 4615 (0x1207) 0x90 PGS tha (Thai) 5897.767 23 17,055,562 99,906 00125.M2TS 4616 (0x1208) 0x90 PGS kor (Korean) 5897.767 19 13,683,173 81,358 00125.M2TS 4617 (0x1209) 0x90 PGS ind (Indonesian) 5897.767 31 22,585,788 129,906 00125.M2TS 4618 (0x120A) 0x90 PGS msa (Malay) 5897.767 35 25,584,372 146,452 00125.M2TS 4619 (0x120B) 0x90 PGS fra (French) 5897.767 1 638,760 3,659 00125.M2TS 4620 (0x120C) 0x90 PGS spa (Spanish) 5897.767 1 597,988 3,465 00125.M2TS 4621 (0x120D) 0x90 PGS por (Portuguese) 5897.767 1 631,134 3,638 00125.M2TS 4622 (0x120E) 0x90 PGS zho (Chinese) 5897.767 1 531,768 3,129 00125.M2TS 4623 (0x120F) 0x90 PGS tha (Thai) 5897.767 0 310,550 1,843
Total Video
00000.MPLS VC-1 1:29:27 28,442,339,328 35,414,861,702 42.39 33.36 LPCM 7.1 6144Kbps (48kHz/16-bit) DD AC3 5.1-EX 640Kbps
DISC INFO: Disc Title: 03076588_DELTA_FARCE_BD Disc Size: 35,414,861,702 bytes Protection: AACS BD-Java: No BDInfo: 0.5.2 PLAYLIST REPORT: Name: 00000.MPLS Size: 28,442,339,328 bytes Length: 1:29:27 (h:m:s) Total Bitrate: 42.39 Mbps Description: VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 33357 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio English 6144 kbps 7.1 / 48 kHz / 6144 kbps / 16-bit Dolby Digital EX Audio English 640 kbps 5.1-EX / 48 kHz / 640 kbps Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / Dolby Surround SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 43.188 kbps Presentation Graphics Spanish 47.628 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:29:27.528 28,442,339,328 42,392 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:59.270 34,141 kbps 50,071 kbps 00:06:48.783 39,140 kbps 00:05:17.692 37,639 kbps 00:03:48.770 178,963 bytes 416,971 bytes 00:07:59.270 2 0:07:59.270 0:04:05.703 35,115 kbps 45,522 kbps 00:11:24.225 39,526 kbps 00:10:39.305 37,715 kbps 00:10:34.300 183,072 bytes 456,121 bytes 00:11:55.756 3 0:12:04.974 0:07:17.478 34,787 kbps 50,330 kbps 00:14:04.426 41,120 kbps 00:12:41.719 38,419 kbps 00:12:10.938 181,363 bytes 457,130 bytes 00:15:05.112 4 0:19:22.452 0:04:59.007 35,084 kbps 44,062 kbps 00:23:19.981 39,104 kbps 00:23:16.812 37,452 kbps 00:23:29.491 182,912 bytes 456,479 bytes 00:22:41.234 5 0:24:21.460 0:05:41.674 35,018 kbps 44,422 kbps 00:29:48.119 38,940 kbps 00:29:18.506 37,537 kbps 00:29:13.877 182,570 bytes 491,618 bytes 00:28:08.770 6 0:30:03.134 0:05:06.014 35,301 kbps 48,464 kbps 00:31:41.566 39,104 kbps 00:31:37.604 37,750 kbps 00:31:34.559 184,043 bytes 496,010 bytes 00:31:11.578 7 0:35:09.148 0:07:33.244 34,377 kbps 46,296 kbps 00:37:13.898 38,969 kbps 00:35:29.669 37,495 kbps 00:37:22.990 179,227 bytes 540,814 bytes 00:36:10.126 8 0:42:42.393 0:04:29.227 31,371 kbps 43,848 kbps 00:43:05.958 39,206 kbps 00:44:33.420 37,529 kbps 00:42:47.231 163,553 bytes 455,587 bytes 00:43:11.630 9 0:47:11.620 0:06:28.721 34,557 kbps 44,525 kbps 00:47:22.506 39,711 kbps 00:47:20.462 37,697 kbps 00:47:33.892 180,166 bytes 624,316 bytes 00:53:24.117 10 0:53:40.342 0:07:18.896 35,071 kbps 47,369 kbps 00:59:33.778 40,136 kbps 01:00:35.214 37,697 kbps 00:59:15.385 182,843 bytes 502,615 bytes 00:59:11.589 11 1:00:59.238 0:07:56.517 31,536 kbps 47,617 kbps 01:03:37.813 39,625 kbps 01:03:34.101 37,660 kbps 01:08:43.911 164,416 bytes 552,647 bytes 01:02:29.954 12 1:08:55.756 0:01:34.761 33,531 kbps 40,734 kbps 01:09:17.528 38,831 kbps 01:09:16.777 37,172 kbps 01:09:16.110 174,817 bytes 352,177 bytes 01:09:30.833 13 1:10:30.517 0:03:04.142 33,794 kbps 47,478 kbps 01:11:51.265 38,672 kbps 01:12:40.981 37,269 kbps 01:10:41.654 176,184 bytes 399,104 bytes 01:11:43.841 14 1:13:34.660 0:02:35.780 29,717 kbps 42,948 kbps 01:14:13.157 40,416 kbps 01:14:09.153 33,822 kbps 01:14:05.858 154,932 bytes 404,450 bytes 01:14:13.949 15 1:16:10.440 0:03:04.976 33,980 kbps 48,797 kbps 01:17:13.712 39,756 kbps 01:18:06.098 37,450 kbps 01:17:07.414 177,156 bytes 455,531 bytes 01:18:11.061 16 1:19:15.417 0:10:12.111 28,393 kbps 47,963 kbps 01:24:44.079 39,209 kbps 01:26:20.175 37,683 kbps 01:26:20.175 148,401 bytes 434,299 bytes 01:26:52.749 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0xEA VC-1 5367.404 33,357 22,380,278,475 121,709,791 00000.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 5367.404 6,151 4,126,557,064 22,543,626 00000.M2TS 4353 (0x1101) 0x81 AC3-EX eng (English) 5367.404 640 429,404,160 2,516,040 00000.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 5367.404 192 128,821,248 838,680 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5367.404 43 28,976,659 166,272 00000.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 5367.404 48 31,955,649 182,920
