[UK] The Crazies (2010) (Additional Details)
Region Locked (B) (confirmed w/ PowerDVD set to all 3 regions)
Studio: Momentum
EAN: 5060116725728
Release Date: 2010-07-19
Aspect Ratio: 2.40:1
Identical encode to the US version, although with the addition of a French dub. The extra features playlists are in fact byte-identical to the US version, although the UK release contains two extra motion comic episodes (#3 & #4) not found on the US release. A smattering of Alliance logos here and there imply that this might be identical to the Canadian disc. No 50Hz content.
English LPCM 5.1 and DD 5.1 are main title audio, while the DD 2.0 track is a commentary. English subs are SDH.
Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
[UK] The Crazies VC-1 1:40:44 24,762,851,328 45,507,062,410 32.77 24.94 DD AC3 5.1 640Kbps LPCM 5.1 4608Kbps (48kHz/16-bit)
Code:
DISC INFO: Disc Title: THE_CRAZIES Disc Size: 45,507,062,410 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00002.MPLS Length: 1:40:44 (h:m:s) Size: 24,762,851,328 bytes Total Bitrate: 32.77 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 24944 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB LPCM Audio English 4608 kbps 5.1 / 48 kHz / 4608 kbps / 16-bit Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 39.007 kbps Presentation Graphics Spanish 29.095 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00035.M2TS 0:00:00.000 1:40:44.788 24,762,851,328 32,772 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:05:01.175 28,537 kbps 45,268 kbps 00:00:58.683 36,776 kbps 00:03:06.060 34,803 kbps 00:03:05.560 148,757 bytes 855,061 bytes 00:01:37.847 2 0:05:01.175 0:06:23.216 25,113 kbps 44,644 kbps 00:10:00.224 36,757 kbps 00:09:50.965 35,656 kbps 00:05:17.191 130,927 bytes 697,461 bytes 00:09:55.886 3 0:11:24.392 0:05:53.895 22,048 kbps 40,102 kbps 00:12:43.929 35,599 kbps 00:12:51.479 34,397 kbps 00:12:36.922 114,950 bytes 579,976 bytes 00:12:37.590 4 0:17:18.287 0:10:44.185 27,993 kbps 47,125 kbps 00:24:41.104 38,161 kbps 00:17:58.786 35,144 kbps 00:18:52.172 145,943 bytes 907,513 bytes 00:19:01.890 5 0:28:02.472 0:07:26.070 28,234 kbps 44,028 kbps 00:34:49.670 37,375 kbps 00:32:35.495 35,920 kbps 00:32:32.492 147,198 bytes 701,620 bytes 00:34:20.433 6 0:35:28.543 0:07:06.008 25,877 kbps 47,231 kbps 00:35:36.300 33,150 kbps 00:35:36.300 31,742 kbps 00:35:45.768 134,910 bytes 552,309 bytes 00:35:55.236 7 0:42:34.551 0:10:29.128 22,449 kbps 38,147 kbps 00:48:35.537 32,461 kbps 00:42:52.152 29,980 kbps 00:42:50.317 117,037 bytes 495,896 bytes 00:43:03.080 8 0:53:03.680 0:07:04.132 24,043 kbps 42,012 kbps 00:55:30.535 33,748 kbps 00:56:38.770 32,806 kbps 00:58:23.082 125,349 bytes 622,572 bytes 00:53:04.681 9 1:00:07.812 0:13:22.510 28,516 kbps 47,445 kbps 01:07:30.463 37,899 kbps 01:07:49.857 36,086 kbps 01:07:48.564 148,668 bytes 735,762 bytes 01:06:27.566 10 1:13:30.322 0:02:56.843 25,792 kbps 37,931 kbps 01:15:25.020 32,325 kbps 01:16:04.268 30,616 kbps 01:15:58.804 134,469 bytes 577,930 bytes 01:15:52.881 11 1:16:27.165 0:16:37.830 25,430 kbps 44,446 kbps 01:20:01.630 36,230 kbps 01:28:09.784 34,487 kbps 01:28:05.446 132,582 bytes 630,348 bytes 01:18:36.420 12 1:33:04.996 0:07:39.792 12,982 kbps 48,130 kbps 01:33:18.551 36,910 kbps 01:33:14.547 35,536 kbps 01:33:09.542 67,686 bytes 507,800 bytes 01:33:19.510 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00035.M2TS 4113 (0x1011) 0xEA VC-1 6044.664 24,945 18,847,700,537 102,520,876 00035.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 6044.664 640 483,584,000 2,833,500 00035.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 6044.664 640 483,584,000 2,833,500 00035.M2TS 4354 (0x1102) 0x80 LPCM eng (English) 6044.664 4,614 3,486,634,872 19,343,328 00035.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 6044.664 192 145,075,200 944,500 00035.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6044.664 39 29,473,826 168,729 00035.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 6044.664 29 21,983,864 126,203
