The Evil Dead - 1981 - Australian version
Distributed by Sony Pictures Home Entertainment Australia
Region free, confirmed with AnyDVD HD
Interesting to compare this with the US Anchor Bay version.
The US one has the movie in both 1.37:1 and 1.85:1 aspects. The Australian version has only the latter. But it does have a BonusView PIP special extra, plus a 53 minute doco, plus a 59 minute set of unedited footage not used, plus a couple of featurettes. It also has two featurettes on the disc which aren't linked through the menu system as far as I can work out. If they turn out to be easter eggs, I'll come back to report this.
Back to the movie. The encode seems to be very similar to the US 1.85:1 version. Exactly the same number of frames in both versions, and the one second bitrate graphs are very similar for the most part, although with some differences (the US version drops lower in the credits). Australian version uses DTS-HD MA rather than Dolby TrueHD.
Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
00000.MPLS AVC 1:25:26 24,540,217,344 32,896,392,236 38.30 26.90 DTS-HD Master 5.1 1952Kbps (48kHz/16-bit)
Code:
DISC INFO: Disc Title: EVIL_DEAD Disc Size: 32,896,392,236 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00000.MPLS Length: 1:25:26 (h:m:s) Size: 24,540,217,344 bytes Total Bitrate: 38.30 Mbps (*) Indicates included stream hidden by this playlist. VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 26903 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 * MPEG-4 AVC Video 1258 kbps 480p / 23.976 fps / 16:9 / High Profile 3.2 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 1952 kbps 5.1 / 48 kHz / 1952 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) DTS-HD Master Audio Italian 2187 kbps 5.1 / 48 kHz / 2187 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) DTS-HD Master Audio Spanish 2726 kbps 5.1 / 48 kHz / 2726 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / Dolby Surround * DTS Express English 192 kbps 2.0 / 48 kHz / 192 kbps / 24-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 11.493 kbps Presentation Graphics English 13.309 kbps Presentation Graphics Italian 9.847 kbps Presentation Graphics Spanish 10.825 kbps Presentation Graphics Portuguese 10.805 kbps Presentation Graphics Danish 11.142 kbps Presentation Graphics Finnish 9.788 kbps Presentation Graphics Hindi 9.197 kbps Presentation Graphics Norwegian 9.675 kbps Presentation Graphics Swedish 10.113 kbps Presentation Graphics English 91.715 kbps Presentation Graphics Italian 77.666 kbps Presentation Graphics Spanish 82.700 kbps * Presentation Graphics English 39.829 kbps * Presentation Graphics Italian 32.612 kbps * Presentation Graphics Spanish 32.341 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00011.M2TS 0:00:00.000 1:25:26.121 24,540,217,344 38,298 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:03:05.435 28,205 kbps 48,442 kbps 00:00:03.169 31,552 kbps 00:00:47.547 30,481 kbps 00:01:49.901 147,014 bytes 591,218 bytes 00:03:05.435 2 0:03:05.435 0:06:52.787 28,179 kbps 36,891 kbps 00:05:27.368 30,902 kbps 00:03:27.665 30,321 kbps 00:03:22.911 146,911 bytes 541,047 bytes 00:05:03.219 3 0:09:58.222 0:06:19.712 26,327 kbps 36,576 kbps 00:14:42.131 29,404 kbps 00:15:09.950 27,839 kbps 00:14:03.092 137,257 bytes 515,974 bytes 00:15:21.754 4 0:16:17.935 0:05:28.077 26,862 kbps 43,531 kbps 00:18:33.153 30,238 kbps 00:17:47.941 28,538 kbps 00:19:11.525 140,046 bytes 551,541 bytes 00:18:28.315 5 0:21:46.013 0:06:28.554 26,512 kbps 43,122 kbps 00:28:00.303 30,872 kbps 00:24:33.472 29,203 kbps 00:27:35.695 138,220 bytes 538,426 bytes 00:25:34.407 6 0:28:14.567 0:03:43.973 26,915 kbps 42,473 kbps 00:28:38.299 30,014 kbps 00:29:40.236 29,586 kbps 00:29:34.981 140,324 bytes 648,494 bytes 00:28:38.425 7 0:31:58.541 0:06:23.007 27,463 kbps 43,708 kbps 00:32:57.100 30,722 kbps 00:32:57.100 29,416 kbps 00:33:38.558 143,179 bytes 596,269 bytes 00:35:27.625 8 0:38:21.549 0:04:29.060 26,791 kbps 38,382 kbps 00:39:59.897 29,645 kbps 00:42:35.886 28,934 kbps 00:41:46.462 139,677 bytes 655,091 bytes 00:40:00.439 9 0:42:50.609 0:05:54.604 27,276 kbps 38,622 kbps 00:44:15.069 29,560 kbps 00:43:13.882 29,066 kbps 00:43:08.877 142,206 bytes 481,687 bytes 00:47:38.522 10 0:48:45.213 0:06:38.397 26,757 kbps 42,665 kbps 00:49:27.798 28,687 kbps 00:53:34.336 28,314 kbps 00:52:14.464 139,499 bytes 484,012 bytes 00:49:28.298 11 0:55:23.611 0:05:19.819 27,061 kbps 35,926 kbps 00:57:30.363 29,506 kbps 00:59:37.949 28,756 kbps 00:59:04.290 141,084 bytes 457,986 bytes 00:57:38.121 12 1:00:43.431 0:02:41.494 26,573 kbps 37,573 kbps 01:00:54.150 28,993 kbps 01:03:12.497 28,286 kbps 01:02:14.522 138,538 bytes 592,349 bytes 01:02:14.564 13 1:03:24.926 0:05:29.579 26,841 kbps 39,516 kbps 01:05:58.079 30,060 kbps 01:06:22.645 29,145 kbps 01:08:32.900 139,936 bytes 513,292 bytes 01:05:32.970 14 1:08:54.505 0:05:18.776 26,528 kbps 43,970 kbps 01:10:32.436 30,718 kbps 01:13:26.110 29,072 kbps 01:13:23.273 138,303 bytes 495,858 bytes 01:10:29.141 15 1:14:13.282 0:06:00.818 27,156 kbps 37,557 kbps 01:15:57.761 29,508 kbps 01:17:17.966 28,769 kbps 01:18:56.398 141,580 bytes 481,268 bytes 01:17:18.884 16 1:20:14.100 0:05:12.020 25,006 kbps 36,919 kbps 01:22:47.087 29,487 kbps 01:22:43.792 28,650 kbps 01:23:34.342 130,388 bytes 612,740 bytes 01:25:10.188 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00011.M2TS 4113 (0x1011) 0x1B AVC 5126.038 26,904 17,238,723,442 93,761,157 00011.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5126.038 1,952 1,250,737,240 7,583,668 00011.M2TS 4353 (0x1101) 0x86 DTS-HD MA ita (Italian) 5126.038 2,187 1,401,269,172 8,421,870 00011.M2TS 4354 (0x1102) 0x86 DTS-HD MA spa (Spanish) 5126.038 2,726 1,746,930,384 10,215,721 00011.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 5126.038 192 123,027,456 800,960 00011.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5126.038 11 7,364,276 42,360 00011.M2TS 4609 (0x1201) 0x90 PGS eng (English) 5126.038 13 8,527,660 50,232 00011.M2TS 4610 (0x1202) 0x90 PGS ita (Italian) 5126.038 10 6,309,730 36,620 00011.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 5126.038 11 6,936,298 40,046 00011.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 5126.038 11 6,923,207 39,975 00011.M2TS 4613 (0x1205) 0x90 PGS dan (Danish) 5126.038 11 7,139,259 41,165 00011.M2TS 4614 (0x1206) 0x90 PGS fin (Finnish) 5126.038 10 6,271,802 36,426 00011.M2TS 4615 (0x1207) 0x90 PGS hin (Hindi) 5126.038 9 5,893,072 34,384 00011.M2TS 4616 (0x1208) 0x90 PGS nor (Norwegian) 5126.038 10 6,199,256 36,025 00011.M2TS 4617 (0x1209) 0x90 PGS swe (Swedish) 5126.038 10 6,480,118 37,560 00011.M2TS 4618 (0x120A) 0x90 PGS eng (English) 5126.038 92 58,767,484 331,156 00011.M2TS 4619 (0x120B) 0x90 PGS ita (Italian) 5126.038 78 49,765,437 282,043 00011.M2TS 4620 (0x120C) 0x90 PGS spa (Spanish) 5126.038 83 52,991,101 299,688 00011.M2TS 4621 (0x120D) 0x90 PGS eng (English) 5126.038 40 25,520,880 144,413 00011.M2TS 4622 (0x120E) 0x90 PGS ita (Italian) 5126.038 33 20,896,595 118,529 00011.M2TS 4623 (0x120F) 0x90 PGS spa (Spanish) 5126.038 32 20,722,890 117,499 00011.M2TS 6656 (0x1A00) 0xA2 DTS Express eng (English) 5126.038 192 123,027,456 720,864 00011.M2TS 6912 (0x1B00) 0x1B AVC 5126.038 1,258 806,343,246 4,449,503
