The difference in running time is indeed due to the absence of the 22 sec. Fox logo at the beginning of the film. The higher audio bitrate I can't explain (the number is confirmed with my PS3's bitrate meter).
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
00001.MPLS AVC 1:36:40 28,536,926,208 47,508,277,888 39.36 35.00 LPCM 1.0 1152Kbps (48kHz/24-bit) DD AC3 1.0 192Kbps
DISC INFO: Disc Title: SWEET_SMELL_SUCCESS Disc Size: 47,508,277,888 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00001.MPLS Length: 1:36:40 (h:m:s) Size: 28,536,926,208 bytes Total Bitrate: 39.36 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 35000 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio English 1152 kbps 1.0 / 48 kHz / 1152 kbps / 24-bit Dolby Digital Audio English 192 kbps 1.0 / 48 kHz / 192 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 62.265 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00274.M2TS 0:00:00.000 1:36:40.211 28,536,926,208 39,360 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:02:12.507 34,130 kbps 37,854 kbps 00:01:54.739 36,957 kbps 00:00:51.676 36,885 kbps 00:00:46.671 177,883 bytes 309,712 bytes 00:01:47.398 2 0:02:12.507 0:05:11.060 36,531 kbps 38,286 kbps 00:02:44.914 37,105 kbps 00:02:41.744 36,928 kbps 00:02:36.865 190,455 bytes 378,028 bytes 00:02:46.749 3 0:07:23.568 0:02:27.730 32,840 kbps 37,745 kbps 00:08:30.343 36,762 kbps 00:08:17.830 36,358 kbps 00:08:17.288 171,211 bytes 284,198 bytes 00:08:46.359 4 0:09:51.299 0:03:32.378 30,866 kbps 37,195 kbps 00:10:09.650 36,357 kbps 00:10:05.271 35,283 kbps 00:10:00.141 160,921 bytes 293,603 bytes 00:09:59.307 5 0:13:23.677 0:01:47.482 32,315 kbps 37,407 kbps 00:14:58.647 36,718 kbps 00:14:55.686 36,054 kbps 00:14:55.060 168,478 bytes 278,340 bytes 00:14:41.255 6 0:15:11.160 0:03:27.582 31,842 kbps 37,778 kbps 00:15:36.852 37,010 kbps 00:17:53.489 36,910 kbps 00:17:48.484 166,012 bytes 298,789 bytes 00:18:37.783 7 0:18:38.742 0:08:05.067 35,459 kbps 38,739 kbps 00:21:15.107 37,039 kbps 00:25:35.492 36,878 kbps 00:19:17.197 184,869 bytes 313,028 bytes 00:26:43.685 8 0:26:43.810 0:04:59.382 36,545 kbps 37,608 kbps 00:28:17.570 36,953 kbps 00:27:52.045 36,878 kbps 00:27:47.040 190,531 bytes 264,631 bytes 00:27:13.798 9 0:31:43.192 0:04:36.317 36,101 kbps 37,857 kbps 00:33:57.785 37,017 kbps 00:33:24.877 36,908 kbps 00:34:12.717 188,212 bytes 298,668 bytes 00:34:12.759 10 0:36:19.510 0:02:49.127 35,699 kbps 37,869 kbps 00:38:22.174 37,004 kbps 00:38:29.265 36,910 kbps 00:38:13.040 186,119 bytes 313,996 bytes 00:38:24.844 11 0:39:08.637 0:05:34.542 35,523 kbps 37,894 kbps 00:43:11.922 37,015 kbps 00:41:28.110 36,906 kbps 00:42:49.942 185,203 bytes 295,165 bytes 00:40:04.026 12 0:44:43.180 0:01:58.034 36,292 kbps 37,493 kbps 00:44:51.313 36,959 kbps 00:45:18.090 36,878 kbps 00:45:13.085 189,209 bytes 277,582 bytes 00:46:39.254 13 0:46:41.215 0:03:23.995 36,752 kbps 37,712 kbps 00:48:57.225 37,040 kbps 00:46:57.564 36,930 kbps 00:46:52.559 191,608 bytes 309,945 bytes 00:49:21.583 14 0:50:05.210 0:03:22.118 36,313 kbps 38,224 kbps 00:51:56.488 37,084 kbps 00:51:52.484 36,917 kbps 00:51:47.437 189,320 bytes 348,869 bytes 00:51:59.449 15 0:53:27.329 0:04:48.162 36,073 kbps 38,228 kbps 00:57:51.676 37,067 kbps 00:56:48.696 36,950 kbps 00:56:43.817 188,068 bytes 349,372 bytes 00:54:02.948 16 0:58:15.492 0:03:07.186 34,498 kbps 37,784 kbps 00:58:22.874 36,828 kbps 01:00:29.417 36,588 kbps 01:00:24.412 179,854 bytes 318,751 bytes 01:00:24.829 17 1:01:22.679 0:02:54.215 34,861 kbps 38,001 kbps 01:03:53.204 37,043 kbps 01:03:46.739 36,902 kbps 01:03:46.614 181,748 bytes 356,745 bytes 01:03:56.415 18 1:04:16.894 0:07:53.556 35,270 kbps 38,109 kbps 01:06:11.801 37,023 kbps 01:09:22.116 36,914 kbps 01:09:17.111 183,880 bytes 343,177 bytes 01:06:10.216 19 1:12:10.451 0:03:48.394 35,357 kbps 37,796 kbps 01:12:49.782 37,029 kbps 01:12:39.313 36,886 kbps 01:12:52.326 184,333 bytes 316,649 bytes 01:13:27.986 20 1:15:58.845 0:03:41.804 36,682 kbps 37,955 kbps 01:19:29.306 37,004 kbps 01:16:45.601 36,898 kbps 01:16:14.111 191,243 bytes 327,033 bytes 01:16:23.912 21 1:19:40.650 0:05:45.720 35,065 kbps 38,083 kbps 01:20:29.366 36,992 kbps 01:20:04.341 36,915 kbps 01:19:59.336 182,811 bytes 287,432 bytes 01:22:26.066 22 1:25:26.371 0:04:46.828 33,634 kbps 38,630 kbps 01:25:45.557 36,958 kbps 01:25:36.339 36,881 kbps 01:25:31.334 175,353 bytes 292,846 bytes 01:29:38.039 23 1:30:13.199 0:06:27.011 33,238 kbps 39,174 kbps 01:36:34.705 37,354 kbps 01:36:30.701 37,112 kbps 01:36:25.780 173,308 bytes 322,117 bytes 01:36:35.206 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00274.M2TS 4113 (0x1011) 0x1B AVC 5800.044 35,001 25,375,924,204 137,993,716 00274.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 5800.044 2,310 1,675,102,092 9,280,344 00274.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 5800.044 192 139,205,376 906,285 00274.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5800.044 62 45,143,677 255,145
Total Video
00001.MPLS AVC 2:03:28 24,122,935,296 47,891,118,611 26.05 22.50 LPCM 1.0 1152Kbps (48kHz/24-bit)
DISC INFO: Disc Title: SENSO Disc Size: 47,891,118,611 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00001.MPLS Length: 2:03:28 (h:m:s) Size: 24,122,935,296 bytes Total Bitrate: 26.05 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 22499 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio Italian 1152 kbps 1.0 / 48 kHz / 1152 kbps / 24-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 36.402 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00274.M2TS 0:00:00.000 2:03:28.818 24,122,935,296 26,048 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:05:03.678 23,483 kbps 38,137 kbps 00:05:02.010 36,015 kbps 00:04:40.947 35,574 kbps 00:04:40.947 122,414 bytes 411,881 bytes 00:04:14.003 2 0:05:03.678 0:07:05.466 26,416 kbps 34,559 kbps 00:09:06.003 33,522 kbps 00:09:03.000 32,695 kbps 00:09:03.000 137,719 bytes 346,981 bytes 00:09:10.758 3 0:12:09.145 0:05:38.713 23,391 kbps 32,147 kbps 00:12:34.211 31,519 kbps 00:12:10.062 30,655 kbps 00:12:09.478 121,950 bytes 270,775 bytes 00:12:13.149 4 0:17:47.858 0:06:50.785 17,846 kbps 26,014 kbps 00:22:06.450 24,417 kbps 00:22:04.990 23,255 kbps 00:22:46.740 93,043 bytes 236,330 bytes 00:22:09.494 5 0:24:38.643 0:05:01.718 15,509 kbps 22,669 kbps 00:29:03.867 19,538 kbps 00:29:00.572 18,309 kbps 00:28:58.778 80,858 bytes 232,233 bytes 00:25:26.691 6 0:29:40.361 0:02:56.718 26,758 kbps 32,234 kbps 00:31:46.154 31,119 kbps 00:30:12.602 30,524 kbps 00:30:07.597 139,503 bytes 296,622 bytes 00:30:04.385 7 0:32:37.080 0:06:25.468 21,564 kbps 30,595 kbps 00:36:07.582 29,705 kbps 00:36:12.753 29,608 kbps 00:36:07.582 112,426 bytes 258,387 bytes 00:36:13.963 8 0:39:02.548 0:07:07.593 22,185 kbps 29,743 kbps 00:42:09.693 28,820 kbps 00:42:08.817 28,410 kbps 00:42:08.692 115,662 bytes 299,218 bytes 00:45:34.898 9 0:46:10.142 0:06:56.958 17,194 kbps 26,796 kbps 00:51:00.140 23,063 kbps 00:50:58.847 22,224 kbps 00:46:34.833 89,643 bytes 219,855 bytes 00:47:32.766 10 0:53:07.100 0:12:19.029 22,070 kbps 33,843 kbps 00:53:37.380 32,571 kbps 00:53:36.630 32,252 kbps 00:53:36.671 115,062 bytes 303,851 bytes 00:53:57.150 11 1:05:26.130 0:06:40.191 24,913 kbps 36,992 kbps 01:11:43.007 36,113 kbps 01:11:39.003 35,643 kbps 01:11:36.000 129,885 bytes 287,361 bytes 01:11:37.042 12 1:12:06.322 0:04:56.129 26,785 kbps 37,066 kbps 01:13:53.095 36,856 kbps 01:14:33.802 36,685 kbps 01:14:34.386 139,642 bytes 373,468 bytes 01:13:27.820 13 1:17:02.451 0:08:04.984 26,361 kbps 37,080 kbps 01:21:41.187 33,607 kbps 01:21:37.392 32,412 kbps 01:18:00.384 137,434 bytes 410,582 bytes 01:17:57.172 14 1:25:07.435 0:06:21.631 29,701 kbps 37,435 kbps 01:25:34.796 36,959 kbps 01:25:30.917 36,878 kbps 01:25:48.184 154,849 bytes 378,374 bytes 01:30:03.398 15 1:31:29.066 0:05:07.765 30,343 kbps 37,558 kbps 01:33:37.403 36,970 kbps 01:33:37.528 36,902 kbps 01:33:37.403 158,197 bytes 349,786 bytes 01:34:15.191 16 1:36:36.832 0:04:23.846 17,170 kbps 26,904 kbps 01:38:25.065 25,743 kbps 01:38:22.354 24,239 kbps 01:38:21.020 89,517 bytes 301,369 bytes 01:38:19.935 17 1:41:00.679 0:12:32.001 21,265 kbps 26,845 kbps 01:53:16.331 24,984 kbps 01:47:49.171 24,786 kbps 01:47:44.166 110,867 bytes 252,998 bytes 01:46:06.651 18 1:53:32.680 0:06:43.861 15,618 kbps 22,752 kbps 01:56:25.561 20,469 kbps 01:54:43.960 20,419 kbps 01:54:38.454 81,427 bytes 240,436 bytes 01:56:11.798 19 2:00:16.542 0:03:12.275 21,808 kbps 27,037 kbps 02:03:13.427 25,350 kbps 02:03:09.382 25,218 kbps 02:03:04.335 113,721 bytes 259,614 bytes 02:02:54.658 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00274.M2TS 4113 (0x1011) 0x1B AVC 7408.651 22,500 20,836,596,132 113,345,616 00274.M2TS 4352 (0x1100) 0x80 LPCM ita (Italian) 7408.651 2,310 2,139,667,216 11,854,112 00274.M2TS 4608 (0x1200) 0x90 PGS eng (English) 7408.651 36 33,711,760 192,356
Total Video
00701.MPLS AVC 1:34:00 9,049,042,944 47,891,118,611 12.83 12.00 DD AC3 1.0 192Kbps
DISC INFO: Disc Title: SENSO Disc Size: 47,891,118,611 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00701.MPLS Length: 1:34:00 (h:m:s) Size: 9,049,042,944 bytes Total Bitrate: 12.83 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 11999 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio English 192 kbps 1.0 / 48 kHz / 192 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00305.M2TS 0:00:00.000 1:34:00.676 9,049,042,944 12,834 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:04:55.795 14,378 kbps 24,234 kbps 00:04:21.803 21,869 kbps 00:04:34.983 21,556 kbps 00:04:33.940 74,950 bytes 247,684 bytes 00:04:03.284 2 0:04:55.795 0:02:17.637 16,901 kbps 21,678 kbps 00:05:12.729 20,776 kbps 00:05:12.687 19,353 kbps 00:05:31.205 88,116 bytes 191,057 bytes 00:07:09.762 3 0:07:13.433 0:08:59.539 9,846 kbps 16,538 kbps 00:08:31.802 15,724 kbps 00:09:10.967 15,691 kbps 00:09:11.092 51,331 bytes 142,719 bytes 00:08:58.538 4 0:16:12.972 0:02:42.162 13,052 kbps 18,475 kbps 00:16:14.473 17,628 kbps 00:16:14.473 17,090 kbps 00:16:14.473 68,046 bytes 160,451 bytes 00:16:42.126 5 0:18:55.134 0:05:19.694 13,090 kbps 19,630 kbps 00:19:11.358 18,315 kbps 00:19:10.983 17,778 kbps 00:19:10.983 68,246 bytes 151,170 bytes 00:20:40.822 6 0:24:14.828 0:05:36.169 14,302 kbps 21,080 kbps 00:29:17.797 19,357 kbps 00:29:13.877 19,210 kbps 00:29:08.872 74,564 bytes 214,224 bytes 00:29:16.921 7 0:29:50.997 0:05:14.105 11,350 kbps 16,492 kbps 00:29:50.997 15,266 kbps 00:29:59.714 15,177 kbps 00:29:58.713 59,175 bytes 158,324 bytes 00:30:01.007 8 0:35:05.103 0:14:47.094 11,380 kbps 21,612 kbps 00:35:07.271 20,315 kbps 00:35:12.235 20,184 kbps 00:35:07.271 59,330 bytes 212,032 bytes 00:35:31.129 9 0:49:52.197 0:03:34.881 12,843 kbps 16,559 kbps 00:51:13.779 15,114 kbps 00:51:13.779 14,819 kbps 00:53:10.604 66,960 bytes 158,069 bytes 00:53:20.447 10 0:53:27.078 0:02:40.702 16,260 kbps 22,733 kbps 00:54:19.255 21,686 kbps 00:54:19.256 21,483 kbps 00:54:19.256 84,770 bytes 225,581 bytes 00:54:38.525 11 0:56:07.781 0:08:11.365 15,177 kbps 22,937 kbps 01:01:55.962 20,389 kbps 00:57:17.100 19,772 kbps 00:57:15.140 79,125 bytes 234,190 bytes 00:57:16.141 12 1:04:19.146 0:05:39.881 17,293 kbps 23,108 kbps 01:04:25.611 22,403 kbps 01:04:46.632 22,240 kbps 01:04:43.504 90,159 bytes 210,272 bytes 01:07:27.710 13 1:09:59.028 0:02:59.345 9,165 kbps 20,095 kbps 01:11:50.472 19,413 kbps 01:11:50.472 18,084 kbps 01:11:46.844 47,782 bytes 209,370 bytes 01:11:45.009 14 1:12:58.374 0:12:30.750 8,345 kbps 14,039 kbps 01:20:48.552 13,169 kbps 01:20:47.259 12,576 kbps 01:20:44.381 43,509 bytes 141,998 bytes 01:20:49.928 15 1:25:29.124 0:05:28.286 9,696 kbps 15,966 kbps 01:28:21.963 13,258 kbps 01:28:21.546 13,112 kbps 01:28:21.587 50,550 bytes 145,250 bytes 01:26:48.620 16 1:30:57.410 0:03:03.266 6,678 kbps 10,557 kbps 01:31:17.054 9,726 kbps 01:31:13.759 8,835 kbps 01:31:13.259 34,823 bytes 192,868 bytes 01:33:59.759 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00305.M2TS 4113 (0x1011) 0x1B AVC 5640.510 12,000 8,460,562,955 46,060,078 00305.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 5640.510 192 135,376,896 881,360
Total Video
[FR] Weeds: Season 1: Disc 1: Episodes 1-5 AVC 2:25:31 40.279.326.720 41.694.305.228 36,90 26,09 Dolby TrueHD 5.1 3409Kbps (48kHz/24-bit)
Disc 2: Episodes 6-10 AVC 2:18:12 37.926.408.192 39.547.200.998 36,59 25,87 Dolby TrueHD 5.1 3427Kbps (48kHz/24-bit)
DISC INFO: Disc Title: WEEDS_S1_D1 Disc Size: 41.694.305.228 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.6 PLAYLIST REPORT: Name: USER.001 Length: 2:25:31 (h:m:s) Size: 40.279.326.720 bytes Total Bitrate: 36,90 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 26091 kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby TrueHD Audio English 3409 kbps 5.1 / 48 kHz / 3409 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB) Dolby TrueHD Audio French 1459 kbps 5.1 / 48 kHz / 1459 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB) Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB Dolby Digital Audio Czech 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB Dolby Digital Audio Polish 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 45,880 kbps Presentation Graphics English 34,526 kbps Presentation Graphics English 48,102 kbps Presentation Graphics Arabic 26,163 kbps Presentation Graphics Czech 38,344 kbps Presentation Graphics Danish 33,847 kbps Presentation Graphics Dutch 41,138 kbps Presentation Graphics Dutch 32,011 kbps Presentation Graphics Finnish 40,516 kbps Presentation Graphics French 36,865 kbps Presentation Graphics French 32,558 kbps Presentation Graphics Hebrew 34,449 kbps Presentation Graphics Icelandic 45,810 kbps Presentation Graphics Norwegian 41,431 kbps Presentation Graphics Polish 30,321 kbps Presentation Graphics Swedish 37,751 kbps Presentation Graphics Turkish 26,771 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00262.M2TS 0:00:00.000 0:31:40.940 8.619.411.456 36.274 00274.M2TS 0:31:40.940 0:30:11.851 8.226.613.248 36.324 00275.M2TS 1:01:52.792 0:29:54.834 8.192.114.688 36.514 00276.M2TS 1:31:47.627 0:26:43.643 7.232.397.312 36.080 00277.M2TS 1:58:31.270 0:27:00.660 8.008.790.016 39.533 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:31:40.940 25.551 kbps 29.366 kbps 00:06:48.533 26.848 kbps 00:27:28.647 26.597 kbps 00:00:59.392 133.208 bytes 664.406 bytes 00:00:19.269 2 0:31:40.940 0:30:11.851 25.514 kbps 34.558 kbps 00:32:18.102 28.037 kbps 00:32:13.973 27.168 kbps 00:32:09.010 133.019 bytes 898.797 bytes 00:32:30.281 3 1:01:52.792 0:29:54.834 25.626 kbps 30.140 kbps 01:14:29.923 27.087 kbps 01:14:25.919 26.775 kbps 01:14:20.914 133.600 bytes 759.114 bytes 01:02:32.165 4 1:31:47.627 0:26:43.643 25.552 kbps 30.204 kbps 01:32:18.240 27.047 kbps 01:32:14.195 26.705 kbps 01:47:48.003 133.214 bytes 643.236 bytes 01:32:34.298 5 1:58:31.270 0:27:00.660 28.420 kbps 33.000 kbps 01:59:36.335 29.799 kbps 02:00:08.618 29.531 kbps 02:00:03.613 148.173 bytes 612.695 bytes 01:59:37.295 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00262.M2TS 4113 (0x1011) 0x1B AVC 1900,857 25.552 6.071.340.593 33.022.896 00262.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1900,857 3.978 945.094.674 6.324.268 00262.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1900,857 2.094 497.649.564 3.582.675 00262.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1900,857 192 45.623.040 297.025 00262.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1900,857 192 45.623.040 297.025 00262.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 1900,857 192 45.623.040 297.025 00262.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1900,857 50 11.894.711 67.906 00262.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1900,857 38 8.982.709 52.322 00262.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1900,857 41 9.659.017 55.753 00262.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1900,857 42 9.894.780 57.028 00262.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1900,857 32 7.582.993 44.347 00262.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1900,857 29 6.862.929 40.604 00262.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1900,857 33 7.895.307 45.069 00262.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1900,857 44 10.569.621 60.450 00262.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1900,857 45 10.610.346 60.616 00262.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1900,857 37 8.805.903 51.121 00262.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1900,857 50 11.977.726 68.358 00262.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1900,857 45 10.578.534 60.733 00262.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1900,857 40 9.601.436 55.060 00262.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1900,857 57 13.528.477 77.145 00262.M2TS 4622 (0x120E) 0x90 PGS fra (French) 1900,857 45 10.595.902 60.892 00262.M2TS 4623 (0x120F) 0x90 PGS nld (Dutch) 1900,857 53 12.697.277 72.377 00262.M2TS 4624 (0x1210) 0x90 PGS tur (Turkish) 1900,857 42 10.095.112 58.128 00274.M2TS 4113 (0x1011) 0x1B AVC 1811,685 25.517 5.778.483.350 31.430.193 00274.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1811,685 4.108 930.218.874 6.577.864 00274.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1811,685 2.115 478.995.700 3.503.792 00274.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1811,685 192 43.484.928 283.105 00274.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1811,685 192 43.484.928 283.105 00274.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1811,685 47 10.572.899 60.483 00274.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1811,685 36 8.097.041 47.301 00274.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1811,685 37 8.480.806 49.033 00274.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1811,685 39 8.800.956 50.841 00274.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1811,685 32 7.203.923 42.086 00274.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1811,685 27 6.191.291 36.690 00274.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1811,685 38 8.676.616 49.618 00274.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1811,685 42 9.531.564 54.501 00274.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1811,685 43 9.660.174 55.214 00274.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1811,685 35 7.987.571 46.423 00274.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1811,685 48 10.836.387 61.900 00274.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1811,685 43 9.666.783 55.555 00274.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1811,685 38 8.540.004 49.040 00274.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1811,685 38 8.557.753 49.472 00275.M2TS 4113 (0x1011) 0x1B AVC 1794,668 25.628 5.749.224.014 31.270.953 00275.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1794,668 4.039 906.128.004 6.154.644 00275.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1794,668 2.100 471.023.610 3.474.764 00275.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1794,668 192 43.076.352 280.445 00275.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1794,668 192 43.076.352 280.445 00275.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 1794,668 192 43.076.352 280.445 00275.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1794,668 42 9.362.166 53.360 00275.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1794,668 30 6.831.668 39.807 00275.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1794,668 34 7.572.454 43.590 00275.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1794,668 35 7.847.515 45.173 00275.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1794,668 27 6.119.835 35.710 00275.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1794,668 24 5.343.058 31.560 00275.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1794,668 28 6.180.844 35.195 00275.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1794,668 38 8.572.376 48.936 00275.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1794,668 38 8.522.620 48.731 00275.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1794,668 31 6.966.839 40.372 00275.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1794,668 40 9.079.790 51.864 00275.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1794,668 37 8.243.384 47.309 00275.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1794,668 36 8.090.742 46.468 00275.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1794,668 69 15.386.734 87.274 00275.M2TS 4622 (0x120E) 0x90 PGS fra (French) 1794,668 57 12.825.002 73.145 00275.M2TS 4623 (0x120F) 0x90 PGS nld (Dutch) 1794,668 52 11.694.941 66.404 00275.M2TS 4624 (0x1210) 0x90 PGS tur (Turkish) 1794,668 40 8.995.151 51.394 00276.M2TS 4113 (0x1011) 0x1B AVC 1603,560 25.553 5.121.955.606 27.859.037 00276.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1603,560 4.058 813.324.058 5.626.843 00276.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1603,560 2.093 419.533.798 3.046.537 00276.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1603,560 192 38.487.552 250.570 00276.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1603,560 192 38.487.552 250.570 00276.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1603,560 43 8.635.148 49.315 00276.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1603,560 32 6.372.192 37.275 00276.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1603,560 34 6.881.949 39.845 00276.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1603,560 36 7.309.667 42.154 00276.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1603,560 29 5.829.460 34.057 00276.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1603,560 24 4.773.343 28.369 00276.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1603,560 35 7.102.946 40.487 00276.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1603,560 40 8.037.475 45.724 00276.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1603,560 40 8.043.922 45.989 00276.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1603,560 33 6.528.585 37.909 00276.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1603,560 44 8.784.472 50.176 00276.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1603,560 38 7.703.334 43.775 00276.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1603,560 38 7.526.003 43.322 00276.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1603,560 37 7.472.692 43.030 00277.M2TS 4113 (0x1011) 0x1B AVC 1620,494 28.423 5.757.416.087 31.312.829 00277.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1620,494 4.074 825.148.390 5.659.706 00277.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1620,494 2.095 424.332.940 3.098.052 00277.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1620,494 192 38.896.128 253.230 00277.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1620,494 192 38.896.128 253.230 00277.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 1620,494 192 38.896.128 253.230 00277.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1620,494 47 9.612.308 55.109 00277.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1620,494 37 7.401.440 43.454 00277.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1620,494 38 7.643.125 44.463 00277.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1620,494 39 7.998.699 46.394 00277.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1620,494 31 6.359.159 37.400 00277.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1620,494 27 5.386.244 32.210 00277.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1620,494 35 7.088.047 40.351 00277.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1620,494 40 8.191.089 47.083 00277.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1620,494 36 7.385.358 42.343 00277.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1620,494 36 7.312.227 42.682 00277.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1620,494 46 9.322.634 53.584 00277.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1620,494 45 9.029.164 51.984 00277.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1620,494 37 7.446.509 42.362 00277.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1620,494 37 7.556.748 43.978 00277.M2TS 4622 (0x120E) 0x90 PGS fra (French) 1620,494 60 12.115.393 68.890 00277.M2TS 4623 (0x120F) 0x90 PGS nld (Dutch) 1620,494 52 10.547.870 60.264 00277.M2TS 4624 (0x1210) 0x90 PGS tur (Turkish) 1620,494 50 10.129.934 58.035
DISC INFO: Disc Title: WEEDS_S1_D2 Disc Size: 39.547.200.998 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.6 PLAYLIST REPORT: Name: USER.002 Length: 2:18:12 (h:m:s) Size: 37.926.408.192 bytes Total Bitrate: 36,59 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 25866 kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby TrueHD Audio English 3427 kbps 5.1 / 48 kHz / 3427 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB) Dolby TrueHD Audio French 1416 kbps 5.1 / 48 kHz / 1416 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB) Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB Dolby Digital Audio Czech 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB Dolby Digital Audio Polish 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 39,639 kbps Presentation Graphics English 29,776 kbps Presentation Graphics English 47,544 kbps Presentation Graphics Arabic 22,076 kbps Presentation Graphics Czech 36,019 kbps Presentation Graphics Danish 32,271 kbps Presentation Graphics Dutch 34,997 kbps Presentation Graphics Dutch 26,839 kbps Presentation Graphics Finnish 35,775 kbps Presentation Graphics French 33,042 kbps Presentation Graphics French 27,795 kbps Presentation Graphics Hebrew 29,951 kbps Presentation Graphics Icelandic 39,354 kbps Presentation Graphics Norwegian 36,727 kbps Presentation Graphics Polish 27,057 kbps Presentation Graphics Swedish 35,779 kbps Presentation Graphics Turkish 21,133 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00274.M2TS 0:00:00.000 0:27:27.687 7.004.307.456 34.008 00275.M2TS 0:27:27.687 0:26:52.652 7.255.105.536 35.991 00276.M2TS 0:54:20.340 0:26:51.651 7.573.161.984 37.592 00277.M2TS 1:21:11.992 0:27:05.665 7.940.456.448 39.075 00278.M2TS 1:48:17.657 0:29:54.834 8.153.376.768 36.342 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:27:27.687 23.477 kbps 28.926 kbps 00:26:42.309 25.710 kbps 00:26:38.305 25.314 kbps 00:26:33.300 122.395 bytes 555.930 bytes 00:00:59.100 2 0:27:27.687 0:26:52.652 25.508 kbps 30.018 kbps 00:30:29.410 27.053 kbps 00:30:25.406 26.553 kbps 00:45:37.860 132.989 bytes 647.058 bytes 00:28:24.619 3 0:54:20.340 0:26:51.651 26.396 kbps 40.016 kbps 00:54:56.126 29.493 kbps 00:54:52.122 28.365 kbps 00:54:47.117 137.617 bytes 650.801 bytes 00:55:12.142 4 1:21:11.992 0:27:05.665 28.426 kbps 32.355 kbps 01:22:06.338 29.919 kbps 01:36:17.062 29.615 kbps 01:36:12.057 148.198 bytes 498.182 bytes 01:22:07.339 5 1:48:17.657 0:29:54.834 25.588 kbps 32.943 kbps 01:48:57.572 27.693 kbps 01:48:53.568 26.883 kbps 01:48:48.563 133.406 bytes 598.241 bytes 01:49:13.588 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00274.M2TS 4113 (0x1011) 0x1B AVC 1647,604 23.478 4.835.346.881 26.302.038 00274.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1647,604 4.037 831.354.906 5.653.369 00274.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1647,604 1.966 404.824.112 2.980.531 00274.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1647,604 192 39.545.088 257.455 00274.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1647,604 192 39.545.088 257.455 00274.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 1647,604 192 39.545.088 257.455 00274.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1647,604 37 7.613.884 43.465 00274.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1647,604 28 5.859.366 34.380 00274.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1647,604 30 6.175.306 35.653 00274.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1647,604 31 6.477.162 37.323 00274.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1647,604 25 5.130.808 29.901 00274.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1647,604 20 4.158.238 24.724 00274.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1647,604 31 6.288.812 35.994 00274.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1647,604 33 6.809.310 38.940 00274.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1647,604 29 5.935.368 34.007 00274.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1647,604 27 5.627.165 32.700 00274.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1647,604 37 7.697.829 43.945 00274.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1647,604 34 6.971.415 39.964 00274.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1647,604 33 6.726.378 38.619 00274.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1647,604 63 12.900.621 73.342 00274.M2TS 4622 (0x120E) 0x90 PGS fra (French) 1647,604 51 10.542.573 60.337 00274.M2TS 4623 (0x120F) 0x90 PGS nld (Dutch) 1647,604 46 9.541.473 54.199 00274.M2TS 4624 (0x1210) 0x90 PGS tur (Turkish) 1647,604 36 7.376.246 42.198 00275.M2TS 4113 (0x1011) 0x1B AVC 1612,486 25.511 5.142.026.975 27.968.416 00275.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1612,486 4.066 819.501.394 5.598.986 00275.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1612,486 2.103 423.917.388 3.155.274 00275.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1612,486 192 38.704.128 251.980 00275.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1612,486 192 38.704.128 251.980 00275.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1612,486 38 7.658.641 43.893 00275.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1612,486 29 5.766.217 33.830 00275.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1612,486 32 6.482.069 37.484 00275.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1612,486 33 6.633.428 38.328 00275.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1612,486 25 5.104.690 29.927 00275.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1612,486 21 4.245.106 25.340 00275.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1612,486 28 5.610.427 32.069 00275.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1612,486 32 6.422.824 36.818 00275.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1612,486 31 6.189.890 35.474 00275.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1612,486 28 5.633.009 32.899 00275.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1612,486 37 7.359.203 42.271 00275.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1612,486 34 6.914.579 39.860 00275.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1612,486 35 6.986.816 39.865 00275.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1612,486 33 6.619.296 38.242 00276.M2TS 4113 (0x1011) 0x1B AVC 1611,485 26.399 5.317.650.801 28.922.730 00276.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1611,485 4.137 833.368.604 5.981.174 00276.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1611,485 2.100 422.971.876 3.067.956 00276.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1611,485 192 38.680.320 251.825 00276.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1611,485 192 38.680.320 251.825 00276.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 1611,485 192 38.680.320 251.825 00276.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1611,485 36 7.193.839 41.400 00276.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1611,485 27 5.348.489 31.520 00276.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1611,485 32 6.379.938 36.977 00276.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1611,485 33 6.616.963 38.269 00276.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1611,485 24 4.879.880 28.706 00276.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1611,485 21 4.140.604 24.828 00276.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1611,485 30 6.024.668 34.749 00276.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1611,485 32 6.366.028 36.741 00276.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1611,485 35 7.057.082 40.443 00276.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1611,485 27 5.477.785 32.082 00276.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1611,485 36 7.239.751 41.654 00276.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1611,485 33 6.679.346 38.602 00276.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1611,485 34 6.833.964 39.456 00276.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1611,485 48 9.580.067 54.745 00276.M2TS 4622 (0x120E) 0x90 PGS fra (French) 1611,485 41 8.176.117 46.985 00276.M2TS 4623 (0x120F) 0x90 PGS nld (Dutch) 1611,485 37 7.511.560 43.047 00276.M2TS 4624 (0x1210) 0x90 PGS tur (Turkish) 1611,485 30 5.986.111 34.814 00277.M2TS 4113 (0x1011) 0x1B AVC 1625,499 28.429 5.776.318.205 31.415.767 00277.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1625,499 4.076 828.188.392 5.755.623 00277.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1625,499 2.055 417.560.628 3.010.031 00277.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1625,499 192 39.016.704 254.015 00277.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1625,499 192 39.016.704 254.015 00277.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1625,499 43 8.828.524 50.526 00277.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1625,499 32 6.512.126 38.209 00277.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1625,499 37 7.470.943 43.164 00277.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1625,499 41 8.375.072 48.098 00277.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1625,499 30 6.188.297 36.102 00277.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1625,499 23 4.682.513 28.018 00277.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1625,499 37 7.608.340 43.477 00277.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1625,499 42 8.627.144 49.072 00277.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1625,499 42 8.612.571 49.183 00277.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1625,499 33 6.802.711 39.552 00277.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1625,499 44 8.881.880 50.841 00277.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1625,499 42 8.611.186 49.380 00277.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1625,499 39 7.926.860 45.653 00277.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1625,499 35 7.133.349 41.333 00278.M2TS 4113 (0x1011) 0x1B AVC 1794,751 25.589 5.740.751.979 31.224.735 00278.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 1794,751 4.028 903.759.448 6.152.193 00278.M2TS 4353 (0x1101) 0x83 TrueHD fra (French) 1794,751 2.057 461.433.764 3.311.221 00278.M2TS 4354 (0x1102) 0x81 AC3 ces (Czech) 1794,751 192 43.076.352 280.445 00278.M2TS 4355 (0x1103) 0x81 AC3 pol (Polish) 1794,751 192 43.076.352 280.445 00278.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 1794,751 192 43.076.352 280.445 00278.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1794,751 44 9.792.965 56.020 00278.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1794,751 33 7.378.251 43.314 00278.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1794,751 35 7.742.263 44.794 00278.M2TS 4611 (0x1203) 0x90 PGS ces (Czech) 1794,751 41 9.233.453 52.972 00278.M2TS 4612 (0x1204) 0x90 PGS pol (Polish) 1794,751 30 6.742.516 39.445 00278.M2TS 4613 (0x1205) 0x90 PGS ara (Arabic) 1794,751 25 5.656.441 33.547 00278.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 1794,751 35 7.918.331 45.273 00278.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 1794,751 36 8.051.340 46.087 00278.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 1794,751 41 9.287.801 53.007 00278.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 1794,751 33 7.505.504 43.578 00278.M2TS 4618 (0x120A) 0x90 PGS isl (Icelandic) 1794,751 43 9.614.646 55.049 00278.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 1794,751 40 8.892.772 51.114 00278.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 1794,751 38 8.612.722 49.592 00278.M2TS 4621 (0x120D) 0x90 PGS eng (English) 1794,751 58 13.048.696 74.430 00278.M2TS 4622 (0x120E) 0x90 PGS fra (French) 1794,751 45 10.092.582 58.092 00278.M2TS 4623 (0x120F) 0x90 PGS nld (Dutch) 1794,751 48 10.767.708 61.210 00278.M2TS 4624 (0x1210) 0x90 PGS tur (Turkish) 1794,751 38 8.543.795 49.227
Total Video
[US] Away We Go VC-1 1:37:45 21,211,699,200 27,771,816,937 28.93 21.63 DTS-HD Master 5.1 3777Kbps (48kHz/24-bit)
DISC INFO: Disc Title: AWAY_WE_GO Disc Size: 27,771,816,937 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00000.MPLS Length: 1:37:45 (h:m:s) Size: 21,211,699,200 bytes Total Bitrate: 28.93 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 21633 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 3777 kbps 5.1 / 48 kHz / 3777 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS Audio Spanish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit DTS Audio French 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 46.352 kbps Presentation Graphics Spanish 37.634 kbps Presentation Graphics French 39.764 kbps Presentation Graphics Spanish 0.024 kbps Presentation Graphics French 0.023 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00010.M2TS 0:00:00.000 1:37:45.234 21,211,699,200 28,932 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:05:38.671 21,708 kbps 41,244 kbps 00:05:24.949 32,219 kbps 00:04:19.592 31,250 kbps 00:04:14.587 113,735 bytes 594,065 bytes 00:05:24.991 2 0:05:38.671 0:05:17.066 24,601 kbps 39,419 kbps 00:08:39.393 32,210 kbps 00:08:41.979 31,912 kbps 00:08:39.435 128,259 bytes 664,932 bytes 00:08:40.228 3 0:10:55.738 0:03:24.120 24,154 kbps 31,945 kbps 00:13:50.120 27,659 kbps 00:13:10.873 26,933 kbps 00:12:51.854 125,930 bytes 500,039 bytes 00:12:21.073 4 0:14:19.859 0:04:29.769 22,615 kbps 34,677 kbps 00:15:10.576 33,772 kbps 00:15:07.656 32,969 kbps 00:15:03.360 117,907 bytes 483,099 bytes 00:17:46.523 5 0:18:49.628 0:05:02.635 25,234 kbps 37,074 kbps 00:23:47.717 30,446 kbps 00:23:43.880 28,566 kbps 00:23:03.298 131,557 bytes 579,782 bytes 00:20:20.677 6 0:23:52.264 0:03:05.852 22,675 kbps 32,991 kbps 00:23:55.517 26,386 kbps 00:23:52.264 25,077 kbps 00:24:45.817 118,217 bytes 538,601 bytes 00:23:56.268 7 0:26:58.116 0:02:44.873 21,639 kbps 31,157 kbps 00:26:58.116 29,072 kbps 00:28:15.318 28,847 kbps 00:28:12.315 112,816 bytes 455,635 bytes 00:27:01.119 8 0:29:42.989 0:05:01.467 25,605 kbps 41,446 kbps 00:30:21.319 34,001 kbps 00:30:17.315 33,150 kbps 00:30:12.352 133,494 bytes 591,865 bytes 00:31:58.291 9 0:34:44.457 0:06:46.072 23,748 kbps 36,538 kbps 00:40:24.713 30,040 kbps 00:40:32.638 29,667 kbps 00:40:32.721 123,810 bytes 589,926 bytes 00:40:24.839 10 0:41:30.529 0:04:17.257 27,221 kbps 39,521 kbps 00:45:04.493 33,151 kbps 00:45:00.489 32,156 kbps 00:44:55.484 141,919 bytes 717,083 bytes 00:41:33.741 11 0:45:47.786 0:05:37.587 22,820 kbps 35,030 kbps 00:45:50.080 31,568 kbps 00:45:47.953 30,342 kbps 00:45:47.786 118,974 bytes 591,339 bytes 00:46:06.138 12 0:51:25.373 0:06:08.451 23,703 kbps 35,033 kbps 00:55:17.731 29,234 kbps 00:55:16.855 27,411 kbps 00:55:17.022 123,578 bytes 602,705 bytes 00:56:04.402 13 0:57:33.825 0:04:18.633 25,301 kbps 39,577 kbps 00:57:33.825 32,368 kbps 00:58:28.046 31,134 kbps 00:58:24.167 131,906 bytes 569,417 bytes 01:01:16.172 14 1:01:52.458 0:04:29.143 20,513 kbps 28,250 kbps 01:03:11.537 26,211 kbps 01:03:11.537 24,489 kbps 01:03:11.537 106,947 bytes 460,741 bytes 01:03:11.579 15 1:06:21.602 0:04:04.035 16,768 kbps 30,530 kbps 01:09:46.932 25,110 kbps 01:06:59.807 24,057 kbps 01:09:58.777 87,421 bytes 490,180 bytes 01:09:46.974 16 1:10:25.638 0:05:14.063 19,758 kbps 30,009 kbps 01:10:57.586 27,565 kbps 01:10:33.687 25,914 kbps 01:11:09.682 103,009 bytes 542,191 bytes 01:10:37.274 17 1:15:39.701 0:05:55.521 20,468 kbps 29,959 kbps 01:16:30.877 26,171 kbps 01:15:49.294 25,732 kbps 01:15:44.122 106,708 bytes 452,010 bytes 01:15:45.707 18 1:21:35.223 0:03:19.908 26,461 kbps 46,362 kbps 01:21:46.109 34,077 kbps 01:21:42.105 32,461 kbps 01:21:38.018 137,955 bytes 631,953 bytes 01:23:32.924 19 1:24:55.131 0:05:06.222 29,525 kbps 40,434 kbps 01:26:42.906 33,603 kbps 01:26:38.735 31,898 kbps 01:28:24.924 153,932 bytes 700,701 bytes 01:28:24.048 20 1:30:01.354 0:07:43.880 1,101 kbps 5,311 kbps 01:37:39.186 3,227 kbps 01:37:39.186 1,950 kbps 01:36:37.750 6,745 bytes 315,777 bytes 01:37:39.812 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00010.M2TS 4113 (0x1011) 0xEA VC-1 5865.109 21,634 15,860,591,162 86,284,119 00010.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5865.109 3,777 2,768,937,536 15,961,125 00010.M2TS 4353 (0x1101) 0x82 DTS spa (Spanish) 5865.109 768 563,062,784 3,299,196 00010.M2TS 4354 (0x1102) 0x82 DTS fra (French) 5865.109 768 563,062,784 3,299,196 00010.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 5865.109 192 140,765,952 916,445 00010.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5865.109 46 33,983,042 195,258 00010.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 5865.109 38 27,591,316 158,517 00010.M2TS 4610 (0x1202) 0x90 PGS fra (French) 5865.109 40 29,153,244 167,019 00010.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 5865.109 0 17,715 103 00010.M2TS 4612 (0x1204) 0x90 PGS fra (French) 5865.109 0 16,539 97
Total Video
[US] Pleasantville AVC 2:04:31 26,557,206,528 28,667,769,736 28.44 20.54 DTS-HD Master 5.1 4053Kbps (48kHz/24-bit) DD AC3 5.1 640Kbps
DISC INFO: Disc Title: PLEASANTVILLE Disc Size: 28,667,769,736 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00100.MPLS Length: 2:04:31 (h:m:s) Size: 26,557,206,528 bytes Total Bitrate: 28.44 Mbps (*) Indicates included stream hidden by this playlist. VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 20539 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4053 kbps 5.1 / 48 kHz / 4053 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio Spanish 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround Dolby Digital Audio Spanish 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround Dolby Digital Audio Portuguese 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround * Dolby Digital Audio Japanese 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- * Presentation Graphics Japanese 16.742 kbps Presentation Graphics English 31.515 kbps Presentation Graphics Spanish 26.634 kbps Presentation Graphics Chinese 25.213 kbps Presentation Graphics Spanish 25.997 kbps Presentation Graphics Portuguese 26.401 kbps Presentation Graphics Danish 26.212 kbps Presentation Graphics Finnish 21.211 kbps Presentation Graphics Greek 26.430 kbps Presentation Graphics Hebrew 19.905 kbps Presentation Graphics Norwegian 25.838 kbps Presentation Graphics Portuguese 25.872 kbps Presentation Graphics Swedish 26.076 kbps Presentation Graphics Chinese 46.762 kbps Presentation Graphics Chinese 34.387 kbps * Presentation Graphics Japanese 42.117 kbps * Presentation Graphics Japanese 25.895 kbps * Presentation Graphics Japanese 0.908 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00020.M2TS 0:00:00.000 2:04:31.130 26,557,206,528 28,437 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:00:36.369 22,691 kbps 48,922 kbps 00:00:25.275 32,004 kbps 00:00:27.277 30,454 kbps 00:00:24.691 118,164 bytes 763,874 bytes 00:00:25.859 2 0:00:36.369 0:01:24.751 26,148 kbps 44,061 kbps 00:00:54.012 32,805 kbps 00:00:45.920 31,356 kbps 00:00:45.879 136,323 bytes 634,223 bytes 00:00:44.002 3 0:02:01.121 0:03:58.237 22,282 kbps 33,088 kbps 00:03:34.964 28,029 kbps 00:03:30.877 27,405 kbps 00:03:25.705 116,167 bytes 462,725 bytes 00:02:54.299 4 0:05:59.359 0:01:52.654 22,286 kbps 28,820 kbps 00:06:12.288 24,377 kbps 00:07:04.173 23,852 kbps 00:07:01.504 116,187 bytes 429,947 bytes 00:07:29.449 5 0:07:52.013 0:02:03.206 23,874 kbps 38,766 kbps 00:09:48.129 32,353 kbps 00:09:48.129 28,271 kbps 00:09:44.792 124,468 bytes 475,092 bytes 00:09:48.170 6 0:09:55.219 0:02:45.498 23,638 kbps 38,749 kbps 00:12:18.362 32,752 kbps 00:12:08.352 29,792 kbps 00:12:05.224 123,239 bytes 461,979 bytes 00:12:18.404 7 0:12:40.718 0:04:18.257 21,397 kbps 42,602 kbps 00:12:54.857 32,070 kbps 00:13:23.677 30,545 kbps 00:13:18.714 111,553 bytes 515,417 bytes 00:12:43.929 8 0:16:58.976 0:02:47.250 20,077 kbps 28,186 kbps 00:19:24.121 22,351 kbps 00:19:22.953 21,235 kbps 00:19:23.996 104,671 bytes 387,205 bytes 00:19:41.513 9 0:19:46.226 0:03:09.647 22,187 kbps 36,218 kbps 00:22:35.729 29,677 kbps 00:22:27.721 29,236 kbps 00:22:28.055 115,672 bytes 412,914 bytes 00:22:35.771 10 0:22:55.874 0:03:39.469 20,980 kbps 36,570 kbps 00:24:01.898 33,448 kbps 00:23:57.894 28,574 kbps 00:25:14.221 109,378 bytes 320,627 bytes 00:23:59.563 11 0:26:35.343 0:01:33.384 19,513 kbps 26,940 kbps 00:27:41.660 20,869 kbps 00:27:38.740 20,378 kbps 00:26:39.431 101,732 bytes 335,641 bytes 00:26:37.804 12 0:28:08.728 0:03:59.489 21,505 kbps 33,637 kbps 00:30:45.468 29,798 kbps 00:30:58.857 29,181 kbps 00:30:50.640 112,117 bytes 383,811 bytes 00:30:51.933 13 0:32:08.217 0:02:03.748 21,999 kbps 30,815 kbps 00:33:06.567 29,251 kbps 00:33:04.482 28,782 kbps 00:33:02.397 114,693 bytes 358,424 bytes 00:32:42.502 14 0:34:11.966 0:02:15.260 21,158 kbps 31,230 kbps 00:35:17.657 28,460 kbps 00:35:09.941 27,836 kbps 00:35:17.657 110,309 bytes 340,139 bytes 00:35:29.293 15 0:36:27.226 0:01:38.473 20,785 kbps 31,449 kbps 00:36:48.831 28,697 kbps 00:36:48.831 27,744 kbps 00:36:43.951 108,366 bytes 360,420 bytes 00:36:49.665 16 0:38:05.700 0:04:47.036 20,019 kbps 24,178 kbps 00:40:51.615 21,318 kbps 00:42:47.731 20,911 kbps 00:40:42.606 104,368 bytes 299,528 bytes 00:40:18.416 17 0:42:52.736 0:03:32.045 19,928 kbps 23,226 kbps 00:43:36.113 21,083 kbps 00:44:33.170 20,897 kbps 00:44:31.794 103,894 bytes 350,667 bytes 00:45:45.409 18 0:46:24.782 0:01:57.117 23,169 kbps 31,374 kbps 00:47:10.994 29,405 kbps 00:46:52.434 28,940 kbps 00:46:46.595 120,794 bytes 337,986 bytes 00:48:21.899 19 0:48:21.899 0:02:25.395 21,356 kbps 32,358 kbps 00:48:37.831 28,940 kbps 00:48:46.006 28,587 kbps 00:48:34.494 111,340 bytes 374,901 bytes 00:49:15.911 20 0:50:47.294 0:03:12.275 20,503 kbps 24,953 kbps 00:53:27.495 21,994 kbps 00:51:27.501 21,475 kbps 00:50:57.971 106,893 bytes 348,540 bytes 00:52:07.290 21 0:53:59.569 0:01:47.190 20,268 kbps 25,673 kbps 00:54:55.583 22,006 kbps 00:54:59.087 21,382 kbps 00:54:46.992 105,667 bytes 363,278 bytes 00:54:27.097 22 0:55:46.760 0:02:10.672 20,102 kbps 23,793 kbps 00:57:35.994 20,931 kbps 00:55:51.514 20,708 kbps 00:55:46.760 104,802 bytes 290,250 bytes 00:56:38.770 23 0:57:57.432 0:02:31.901 19,827 kbps 27,132 kbps 01:00:27.749 21,793 kbps 00:59:27.230 21,228 kbps 00:59:26.813 103,371 bytes 423,688 bytes 01:00:28.583 24 1:00:29.334 0:02:29.399 20,751 kbps 26,115 kbps 01:01:38.903 22,189 kbps 01:02:13.980 21,713 kbps 01:02:13.980 108,187 bytes 395,483 bytes 01:01:52.250 25 1:02:58.733 0:02:50.170 19,943 kbps 29,284 kbps 01:04:37.874 22,354 kbps 01:04:28.447 21,743 kbps 01:04:28.865 103,975 bytes 321,268 bytes 01:03:04.530 26 1:05:48.903 0:04:46.577 20,799 kbps 33,394 kbps 01:06:24.146 28,363 kbps 01:06:22.436 26,593 kbps 01:06:24.146 108,434 bytes 465,561 bytes 01:06:32.863 27 1:10:35.481 0:02:41.160 21,117 kbps 34,441 kbps 01:11:00.881 28,907 kbps 01:11:00.881 28,454 kbps 01:11:00.881 110,096 bytes 376,678 bytes 01:12:30.512 28 1:13:16.642 0:03:33.504 23,555 kbps 40,685 kbps 01:14:42.561 33,334 kbps 01:14:38.724 31,453 kbps 01:14:37.931 122,807 bytes 472,134 bytes 01:14:37.973 29 1:16:50.147 0:04:02.200 19,801 kbps 30,422 kbps 01:17:41.198 22,314 kbps 01:20:40.585 21,251 kbps 01:18:41.425 103,235 bytes 330,303 bytes 01:18:54.438 30 1:20:52.347 0:05:23.322 20,288 kbps 35,970 kbps 01:24:43.203 30,320 kbps 01:24:35.945 29,557 kbps 01:24:35.945 105,773 bytes 546,095 bytes 01:20:58.937 31 1:26:15.670 0:05:38.463 19,827 kbps 31,225 kbps 01:31:36.532 23,103 kbps 01:30:47.775 22,232 kbps 01:30:47.608 103,368 bytes 521,717 bytes 01:30:23.042 32 1:31:54.133 0:04:06.037 18,851 kbps 25,798 kbps 01:33:32.607 21,582 kbps 01:33:36.902 20,716 kbps 01:33:36.235 98,279 bytes 365,082 bytes 01:34:50.351 33 1:36:00.171 0:06:11.204 19,311 kbps 32,257 kbps 01:40:05.916 28,253 kbps 01:40:04.748 25,373 kbps 01:39:59.743 100,677 bytes 622,389 bytes 01:38:44.627 34 1:42:11.375 0:06:59.043 20,211 kbps 29,564 kbps 01:48:42.474 22,908 kbps 01:48:40.096 22,281 kbps 01:48:58.698 105,371 bytes 470,871 bytes 01:47:56.636 35 1:49:10.418 0:04:04.035 22,387 kbps 31,902 kbps 01:53:13.453 30,123 kbps 01:52:57.896 28,083 kbps 01:52:57.812 116,714 bytes 508,888 bytes 01:49:21.137 36 1:53:14.454 0:03:27.540 21,644 kbps 36,219 kbps 01:53:15.205 28,585 kbps 01:53:15.079 28,050 kbps 01:53:15.038 112,843 bytes 416,685 bytes 01:56:13.591 37 1:56:41.995 0:07:49.135 14,298 kbps 27,433 kbps 01:59:38.880 22,692 kbps 01:58:47.078 21,548 kbps 01:58:47.370 74,558 bytes 420,709 bytes 02:03:30.319 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00020.M2TS 4113 (0x1011) 0x1B AVC 7471.047 20,539 19,180,990,690 104,349,609 00020.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 7471.047 4,053 3,785,121,524 21,733,731 00020.M2TS 4353 (0x1101) 0x81 AC3 spa (Spanish) 7471.047 192 179,307,264 1,167,365 00020.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 7471.047 192 179,307,264 1,167,365 00020.M2TS 4355 (0x1103) 0x81 AC3 por (Portuguese) 7471.047 192 179,307,264 1,167,365 00020.M2TS 4356 (0x1104) 0x81 AC3 jpn (Japanese) 7471.047 192 179,307,264 1,167,365 00020.M2TS 4357 (0x1105) 0x81 AC3 eng (English) 7471.047 192 179,307,264 1,167,365 00020.M2TS 4358 (0x1106) 0x81 AC3 eng (English) 7471.047 640 597,690,880 3,502,095 00020.M2TS 4608 (0x1200) 0x90 PGS jpn (Japanese) 7471.047 17 15,635,661 94,207 00020.M2TS 4609 (0x1201) 0x90 PGS eng (English) 7471.047 32 29,431,372 169,968 00020.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 7471.047 27 24,873,323 144,380 00020.M2TS 4611 (0x1203) 0x90 PGS zho (Chinese) 7471.047 25 23,546,030 137,227 00020.M2TS 4612 (0x1204) 0x90 PGS spa (Spanish) 7471.047 26 24,277,983 141,107 00020.M2TS 4613 (0x1205) 0x90 PGS por (Portuguese) 7471.047 26 24,655,948 143,222 00020.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 7471.047 26 24,479,283 142,141 00020.M2TS 4615 (0x1207) 0x90 PGS fin (Finnish) 7471.047 21 19,808,715 113,563 00020.M2TS 4616 (0x1208) 0x90 PGS ell (Greek) 7471.047 26 24,682,911 143,124 00020.M2TS 4617 (0x1209) 0x90 PGS heb (Hebrew) 7471.047 20 18,588,710 110,226 00020.M2TS 4618 (0x120A) 0x90 PGS nor (Norwegian) 7471.047 26 24,129,879 140,226 00020.M2TS 4619 (0x120B) 0x90 PGS por (Portuguese) 7471.047 26 24,161,705 140,344 00020.M2TS 4620 (0x120C) 0x90 PGS swe (Swedish) 7471.047 26 24,351,786 141,427 00020.M2TS 4621 (0x120D) 0x90 PGS zho (Chinese) 7471.047 47 43,670,218 250,563 00020.M2TS 4622 (0x120E) 0x90 PGS zho (Chinese) 7471.047 34 32,114,184 185,474 00020.M2TS 4623 (0x120F) 0x90 PGS jpn (Japanese) 7471.047 42 39,333,009 224,829 00020.M2TS 4624 (0x1210) 0x90 PGS jpn (Japanese) 7471.047 26 24,183,034 138,607 00020.M2TS 4625 (0x1211) 0x90 PGS jpn (Japanese) 7471.047 1 847,877 6,093
Total Video
[DE] Black Rain MPEG-2 2:05:18 30,940,237,824 35,192,838,304 32.92 27.23 DD AC3 5.1-EX 640Kbps DTS 6.1-ES 1509Kbps (48kHz/24-bit)
DISC INFO: Disc Title: LOGICAL_VOLUME_ID Disc Size: 35,192,838,304 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00002.MPLS Length: 2:05:18 (h:m:s) Size: 30,940,237,824 bytes Total Bitrate: 32.92 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-2 Video 27225 kbps 1080p / 23.976 fps / 16:9 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital EX Audio English 640 kbps 5.1-EX / 48 kHz / 640 kbps / DN -4dB DTS-ES Audio English 1509 kbps 6.1-ES / 48 kHz / 1509 kbps / 24-bit / DN -4dB Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital EX Audio German 640 kbps 5.1-EX / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 25.107 kbps Presentation Graphics English 28.715 kbps Presentation Graphics French 22.185 kbps Presentation Graphics German 25.466 kbps Presentation Graphics Dutch 24.347 kbps Presentation Graphics English 55.405 kbps Presentation Graphics French 50.123 kbps Presentation Graphics German 55.013 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00001.M2TS 0:00:00.000 1:12:05.362 17,759,539,200 32,847 00015.M2TS 1:12:05.362 0:53:12.772 13,180,698,624 33,026 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:02:45.832 24,844 kbps 33,764 kbps 00:02:33.444 31,504 kbps 00:01:59.828 30,298 kbps 00:01:37.639 129,493 bytes 603,669 bytes 00:00:52.218 2 0:02:45.832 0:02:20.473 29,374 kbps 37,077 kbps 00:04:19.008 32,920 kbps 00:04:25.223 32,330 kbps 00:04:13.795 153,144 bytes 611,590 bytes 00:04:32.689 3 0:05:06.306 0:06:04.989 27,116 kbps 36,240 kbps 00:06:49.784 32,552 kbps 00:06:45.780 31,109 kbps 00:07:25.236 141,370 bytes 615,806 bytes 00:06:45.196 4 0:11:11.295 0:03:32.879 26,474 kbps 34,390 kbps 00:12:17.820 31,776 kbps 00:11:20.429 30,926 kbps 00:11:19.095 138,022 bytes 603,745 bytes 00:11:25.976 5 0:14:44.174 0:03:23.912 28,748 kbps 34,907 kbps 00:15:09.575 31,758 kbps 00:16:20.270 31,176 kbps 00:16:15.265 149,879 bytes 611,143 bytes 00:15:14.955 6 0:18:08.087 0:02:40.493 28,248 kbps 35,341 kbps 00:18:41.787 32,386 kbps 00:18:31.276 31,859 kbps 00:18:26.313 147,273 bytes 608,495 bytes 00:18:19.765 7 0:20:48.580 0:02:21.266 26,670 kbps 34,193 kbps 00:21:16.942 31,284 kbps 00:21:34.835 30,675 kbps 00:21:34.584 139,046 bytes 597,515 bytes 00:20:57.923 8 0:23:09.846 0:08:14.452 26,823 kbps 34,651 kbps 00:25:57.931 32,244 kbps 00:25:54.970 31,446 kbps 00:25:53.718 139,842 bytes 606,790 bytes 00:26:17.367 9 0:31:24.299 0:14:38.711 27,981 kbps 35,500 kbps 00:38:01.946 33,296 kbps 00:31:42.358 32,519 kbps 00:31:39.814 145,881 bytes 610,655 bytes 00:38:49.368 10 0:46:03.010 0:03:06.019 26,582 kbps 34,436 kbps 00:48:20.772 30,167 kbps 00:46:31.330 29,888 kbps 00:46:26.283 138,586 bytes 590,652 bytes 00:48:28.030 11 0:49:09.029 0:04:39.612 27,229 kbps 33,933 kbps 00:52:09.960 32,227 kbps 00:49:25.504 31,654 kbps 00:49:20.082 141,959 bytes 596,359 bytes 00:52:51.793 12 0:53:48.642 0:01:42.477 29,497 kbps 35,529 kbps 00:54:52.914 32,237 kbps 00:54:52.956 31,566 kbps 00:54:49.244 153,783 bytes 582,540 bytes 00:54:53.039 13 0:55:31.119 0:01:54.697 26,924 kbps 33,612 kbps 00:57:16.558 30,372 kbps 00:57:12.887 29,512 kbps 00:57:14.514 140,369 bytes 545,771 bytes 00:55:39.836 14 0:57:25.817 0:04:36.275 28,304 kbps 35,206 kbps 01:00:54.776 31,993 kbps 00:59:11.130 31,231 kbps 00:59:06.751 147,562 bytes 602,067 bytes 00:58:28.505 15 1:02:02.093 0:05:31.331 22,785 kbps 33,883 kbps 01:02:42.842 29,910 kbps 01:02:42.842 29,519 kbps 01:02:42.842 118,793 bytes 576,398 bytes 01:02:24.866 16 1:07:33.424 0:04:31.938 27,106 kbps 33,475 kbps 01:10:20.549 30,864 kbps 01:08:50.584 30,112 kbps 01:08:46.247 141,318 bytes 545,803 bytes 01:11:50.931 17 1:12:05.362 0:03:09.063 26,854 kbps 32,532 kbps 01:12:40.439 29,975 kbps 01:12:37.144 28,948 kbps 01:12:32.139 140,005 bytes 564,028 bytes 01:12:23.047 18 1:15:14.426 0:04:19.384 28,181 kbps 35,863 kbps 01:16:33.463 33,600 kbps 01:19:17.919 32,920 kbps 01:19:12.914 146,924 bytes 608,599 bytes 01:18:29.913 19 1:19:33.810 0:03:57.111 24,544 kbps 33,593 kbps 01:21:21.668 30,124 kbps 01:23:19.411 29,003 kbps 01:23:20.578 127,960 bytes 495,157 bytes 01:20:34.913 20 1:23:30.922 0:03:12.775 28,480 kbps 35,612 kbps 01:26:32.937 34,340 kbps 01:26:32.854 33,461 kbps 01:26:32.854 148,483 bytes 569,573 bytes 01:26:19.507 21 1:26:43.698 0:05:59.650 27,815 kbps 36,404 kbps 01:29:33.785 32,988 kbps 01:29:29.781 32,307 kbps 01:26:47.285 145,016 bytes 601,109 bytes 01:27:15.438 22 1:32:43.349 0:03:52.023 29,432 kbps 36,014 kbps 01:33:18.009 32,869 kbps 01:33:25.641 32,561 kbps 01:33:22.388 153,444 bytes 610,521 bytes 01:35:47.700 23 1:36:35.372 0:03:57.654 25,550 kbps 35,193 kbps 01:36:53.766 33,196 kbps 01:36:48.260 32,283 kbps 01:36:44.840 133,206 bytes 583,340 bytes 01:37:19.792 24 1:40:33.026 0:06:38.231 29,141 kbps 38,900 kbps 01:44:35.811 34,359 kbps 01:44:35.811 33,171 kbps 01:44:35.894 151,928 bytes 613,956 bytes 01:43:12.269 25 1:47:11.258 0:04:19.050 28,596 kbps 35,463 kbps 01:49:38.154 32,367 kbps 01:49:37.529 31,444 kbps 01:49:32.524 149,088 bytes 612,007 bytes 01:49:23.139 26 1:51:30.308 0:05:51.142 31,283 kbps 36,553 kbps 01:52:25.572 33,949 kbps 01:52:21.609 33,273 kbps 01:53:20.418 163,096 bytes 611,932 bytes 01:53:00.482 27 1:57:21.451 0:04:11.334 28,542 kbps 35,038 kbps 02:01:02.421 31,739 kbps 02:00:58.417 31,064 kbps 02:00:53.412 148,805 bytes 593,453 bytes 02:00:55.331 28 2:01:32.785 0:03:45.350 16,458 kbps 29,583 kbps 02:05:11.921 22,534 kbps 02:05:11.921 21,926 kbps 02:04:28.502 85,823 bytes 432,657 bytes 02:05:13.464 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00001.M2TS 4113 (0x1011) 0x02 MPEG-2 4325.279 27,096 14,649,760,305 79,678,664 00001.M2TS 4352 (0x1100) 0x81 AC3-EX eng (English) 4325.279 640 346,030,080 2,027,520 00001.M2TS 4353 (0x1101) 0x82 DTS-ES eng (English) 4325.279 1,509 815,872,036 4,866,036 00001.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 4325.279 640 346,030,080 2,027,520 00001.M2TS 4355 (0x1103) 0x81 AC3-EX deu (German) 4325.279 640 346,030,080 2,027,520 00001.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 4325.279 192 103,809,024 675,840 00001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 4325.279 34 18,636,781 106,784 00001.M2TS 4609 (0x1201) 0x90 PGS eng (English) 4325.279 39 21,100,634 120,961 00001.M2TS 4610 (0x1202) 0x90 PGS fra (French) 4325.279 30 16,138,921 93,238 00001.M2TS 4611 (0x1203) 0x90 PGS deu (German) 4325.279 34 18,645,460 106,838 00001.M2TS 4612 (0x1204) 0x90 PGS nld (Dutch) 4325.279 33 17,755,871 102,019 00001.M2TS 4613 (0x1205) 0x90 PGS eng (English) 4325.279 59 31,786,653 179,624 00001.M2TS 4614 (0x1206) 0x90 PGS fra (French) 4325.279 52 28,223,978 160,294 00001.M2TS 4615 (0x1207) 0x90 PGS deu (German) 4325.279 59 31,818,862 179,805 00015.M2TS 4113 (0x1011) 0x02 MPEG-2 3192.690 27,402 10,935,672,407 59,477,524 00015.M2TS 4352 (0x1100) 0x81 AC3-EX eng (English) 3192.690 640 255,424,000 1,496,625 00015.M2TS 4353 (0x1101) 0x82 DTS-ES eng (English) 3192.690 1,509 602,237,876 3,591,876 00015.M2TS 4354 (0x1102) 0x81 AC3 fra (French) 3192.690 640 255,424,000 1,496,625 00015.M2TS 4355 (0x1103) 0x81 AC3 deu (German) 3192.690 640 255,424,000 1,496,625 00015.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 3192.690 192 76,627,200 498,875 00015.M2TS 4608 (0x1200) 0x90 PGS eng (English) 3192.690 12 4,957,749 28,698 00015.M2TS 4609 (0x1201) 0x90 PGS eng (English) 3192.690 15 5,884,531 34,055 00015.M2TS 4610 (0x1202) 0x90 PGS fra (French) 3192.690 12 4,709,998 27,373 00015.M2TS 4611 (0x1203) 0x90 PGS deu (German) 3192.690 13 5,286,425 30,493 00015.M2TS 4612 (0x1204) 0x90 PGS nld (Dutch) 3192.690 13 5,124,451 29,620 00015.M2TS 4613 (0x1205) 0x90 PGS eng (English) 3192.690 51 20,280,981 114,634 00015.M2TS 4614 (0x1206) 0x90 PGS fra (French) 3192.690 47 18,880,408 107,026 00015.M2TS 4615 (0x1207) 0x90 PGS deu (German) 3192.690 50 19,880,745 112,452
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
[DE] Collateral AVC 1:59:56 37,520,099,328 44,057,434,881 41.71 31.81 DTS-HD Master 5.1 4263Kbps (48kHz/24-bit)
DISC INFO: Disc Title: COLLATERAL Disc Size: 44,057,434,881 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00001.MPLS Length: 1:59:56 (h:m:s) Size: 37,520,099,328 bytes Total Bitrate: 41.71 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 31808 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4263 kbps 5.1 / 48 kHz / 4263 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio German 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio Italian 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio Spanish 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 32.068 kbps Presentation Graphics English 33.542 kbps Presentation Graphics French 28.021 kbps Presentation Graphics German 33.798 kbps Presentation Graphics Italian 30.930 kbps Presentation Graphics Spanish 29.515 kbps Presentation Graphics Dutch 26.812 kbps Presentation Graphics Danish 23.615 kbps Presentation Graphics Finnish 29.846 kbps Presentation Graphics Norwegian 24.896 kbps Presentation Graphics Swedish 29.412 kbps Presentation Graphics English 51.475 kbps Presentation Graphics French 49.358 kbps Presentation Graphics German 49.554 kbps Presentation Graphics Italian 49.297 kbps Presentation Graphics Spanish 47.792 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00001.M2TS 0:00:00.000 1:59:56.189 37,520,099,328 41,711 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:13:19.340 32,209 kbps 44,016 kbps 00:00:11.344 36,817 kbps 00:01:08.693 36,330 kbps 00:01:08.693 167,916 bytes 510,515 bytes 00:04:07.247 2 0:13:19.340 0:04:35.733 33,060 kbps 42,411 kbps 00:13:22.760 35,209 kbps 00:13:35.606 34,425 kbps 00:15:15.289 172,361 bytes 461,307 bytes 00:15:33.515 3 0:17:55.074 0:06:26.636 32,884 kbps 39,931 kbps 00:22:03.071 35,153 kbps 00:24:05.652 34,849 kbps 00:24:05.694 171,442 bytes 457,328 bytes 00:21:52.144 4 0:24:21.710 0:02:57.719 32,446 kbps 40,882 kbps 00:25:49.589 34,561 kbps 00:26:59.701 33,628 kbps 00:25:41.748 169,157 bytes 408,032 bytes 00:24:28.049 5 0:27:19.429 0:02:37.699 32,730 kbps 42,212 kbps 00:28:21.074 35,780 kbps 00:29:23.762 33,945 kbps 00:27:28.938 170,642 bytes 449,416 bytes 00:29:13.668 6 0:29:57.128 0:03:52.523 32,332 kbps 40,067 kbps 00:32:54.222 34,413 kbps 00:30:06.137 33,775 kbps 00:29:58.671 168,566 bytes 442,150 bytes 00:33:02.313 7 0:33:49.652 0:03:16.070 32,267 kbps 40,127 kbps 00:33:56.993 34,935 kbps 00:34:11.132 33,904 kbps 00:34:11.257 168,228 bytes 528,844 bytes 00:36:31.147 8 0:37:05.723 0:02:23.309 33,104 kbps 38,847 kbps 00:37:57.233 34,732 kbps 00:37:53.229 33,893 kbps 00:37:33.793 172,587 bytes 499,204 bytes 00:37:53.270 9 0:39:29.033 0:08:28.633 32,104 kbps 42,816 kbps 00:41:00.207 34,459 kbps 00:45:03.867 33,836 kbps 00:47:10.035 167,373 bytes 446,778 bytes 00:46:51.183 10 0:47:57.666 0:06:12.372 32,151 kbps 43,068 kbps 00:53:27.412 35,405 kbps 00:53:37.464 34,805 kbps 00:53:16.276 167,618 bytes 521,808 bytes 00:50:34.531 11 0:54:10.038 0:02:01.788 31,802 kbps 40,272 kbps 00:55:49.846 34,765 kbps 00:55:48.803 33,242 kbps 00:55:24.696 165,799 bytes 487,911 bytes 00:54:31.726 12 0:56:11.826 0:02:49.294 31,826 kbps 44,739 kbps 00:56:39.229 34,002 kbps 00:57:59.642 32,962 kbps 00:57:54.512 165,928 bytes 434,020 bytes 00:58:55.782 13 0:59:01.120 0:13:17.880 32,407 kbps 43,069 kbps 01:01:12.293 34,778 kbps 01:02:43.009 33,925 kbps 01:00:16.738 168,953 bytes 481,544 bytes 01:01:12.835 14 1:12:19.001 0:03:59.697 32,385 kbps 44,252 kbps 01:12:46.487 35,504 kbps 01:15:06.126 34,239 kbps 01:12:45.652 168,843 bytes 520,496 bytes 01:12:46.528 15 1:16:18.699 0:02:21.391 32,871 kbps 43,541 kbps 01:18:31.540 34,930 kbps 01:18:31.415 34,231 kbps 01:17:58.006 171,377 bytes 579,987 bytes 01:17:27.809 16 1:18:40.090 0:06:55.039 32,366 kbps 46,203 kbps 01:21:29.509 35,674 kbps 01:22:35.158 34,371 kbps 01:25:25.120 168,742 bytes 486,374 bytes 01:25:31.668 17 1:25:35.130 0:09:11.467 32,950 kbps 41,968 kbps 01:30:37.140 35,277 kbps 01:31:47.877 34,612 kbps 01:25:46.057 171,785 bytes 539,587 bytes 01:32:08.481 18 1:34:46.597 0:10:20.077 32,705 kbps 44,852 kbps 01:41:06.685 35,607 kbps 01:34:50.559 34,738 kbps 01:38:08.007 170,510 bytes 541,036 bytes 01:44:50.367 19 1:45:06.675 0:08:00.062 32,378 kbps 47,300 kbps 01:48:07.189 35,386 kbps 01:49:06.289 34,588 kbps 01:45:59.853 168,807 bytes 576,537 bytes 01:48:07.272 20 1:53:06.738 0:06:49.450 20,877 kbps 48,062 kbps 01:59:50.683 35,280 kbps 01:57:24.287 35,111 kbps 01:57:19.240 108,863 bytes 725,772 bytes 01:57:29.250 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00001.M2TS 4113 (0x1011) 0x1B AVC 7196.106 31,808 28,612,132,957 155,601,973 00001.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 7196.106 4,263 3,834,405,496 21,961,344 00001.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 7196.106 640 575,695,360 3,373,215 00001.M2TS 4354 (0x1102) 0x81 AC3 deu (German) 7196.106 640 575,695,360 3,373,215 00001.M2TS 4355 (0x1103) 0x81 AC3 ita (Italian) 7196.106 640 575,695,360 3,373,215 00001.M2TS 4356 (0x1104) 0x81 AC3 spa (Spanish) 7196.106 640 575,695,360 3,373,215 00001.M2TS 4357 (0x1105) 0x81 AC3 eng (English) 7196.106 224 201,493,376 1,124,405 00001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 7196.106 32 28,845,742 164,720 00001.M2TS 4609 (0x1201) 0x90 PGS eng (English) 7196.106 34 30,172,017 172,421 00001.M2TS 4610 (0x1202) 0x90 PGS fra (French) 7196.106 28 25,205,764 144,616 00001.M2TS 4611 (0x1203) 0x90 PGS deu (German) 7196.106 34 30,401,754 173,107 00001.M2TS 4612 (0x1204) 0x90 PGS ita (Italian) 7196.106 31 27,822,034 158,997 00001.M2TS 4613 (0x1205) 0x90 PGS spa (Spanish) 7196.106 30 26,549,522 152,076 00001.M2TS 4614 (0x1206) 0x90 PGS nld (Dutch) 7196.106 27 24,118,126 137,778 00001.M2TS 4615 (0x1207) 0x90 PGS dan (Danish) 7196.106 24 21,242,245 121,102 00001.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 7196.106 30 26,846,885 153,040 00001.M2TS 4617 (0x1209) 0x90 PGS nor (Norwegian) 7196.106 25 22,394,964 129,489 00001.M2TS 4618 (0x120A) 0x90 PGS swe (Swedish) 7196.106 29 26,456,398 151,496 00001.M2TS 4619 (0x120B) 0x90 PGS eng (English) 7196.106 51 46,303,419 261,688 00001.M2TS 4620 (0x120C) 0x90 PGS fra (French) 7196.106 49 44,398,283 252,875 00001.M2TS 4621 (0x120D) 0x90 PGS deu (German) 7196.106 50 44,574,944 251,817 00001.M2TS 4622 (0x120E) 0x90 PGS ita (Italian) 7196.106 49 44,344,142 250,551 00001.M2TS 4623 (0x120F) 0x90 PGS spa (Spanish) 7196.106 48 42,989,772 243,166
Total Video
[UK] Playtime AVC 2:04:13 35,143,016,448 39,344,297,342 37.72 29.00 LPCM 2.0 2304Kbps (48kHz/24-bit)
DISC INFO: Disc Title: PLAYTIME Disc Size: 39,344,297,342 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00000.MPLS Length: 2:04:13 (h:m:s) Size: 35,143,016,448 bytes Total Bitrate: 37.72 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 28999 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio French 2304 kbps 2.0 / 48 kHz / 2304 kbps / 24-bit LPCM Audio English 2304 kbps 2.0 / 48 kHz / 2304 kbps / 24-bit LPCM Audio English 2304 kbps 2.0 / 48 kHz / 2304 kbps / 24-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 8.770 kbps Presentation Graphics English 4.613 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 2:04:13.487 35,143,016,448 37,720 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:11:16.258 29,705 kbps 42,240 kbps 00:01:04.814 39,648 kbps 00:01:04.564 37,934 kbps 00:01:04.564 154,858 bytes 391,637 bytes 00:10:18.659 2 0:11:16.258 0:09:36.784 30,866 kbps 44,088 kbps 00:11:26.936 38,315 kbps 00:11:26.936 36,421 kbps 00:11:26.936 160,923 bytes 377,287 bytes 00:11:40.658 3 0:20:53.043 0:08:35.556 29,508 kbps 42,509 kbps 00:20:56.380 36,166 kbps 00:20:54.461 34,450 kbps 00:21:14.231 153,839 bytes 406,451 bytes 00:28:26.579 4 0:29:28.600 0:02:51.337 30,900 kbps 44,879 kbps 00:30:27.283 41,248 kbps 00:30:26.866 36,658 kbps 00:30:22.946 161,097 bytes 415,427 bytes 00:29:49.954 5 0:32:19.938 0:09:52.675 31,184 kbps 36,319 kbps 00:41:53.677 34,891 kbps 00:41:40.331 34,593 kbps 00:41:39.038 162,580 bytes 406,595 bytes 00:41:44.460 6 0:42:12.613 0:02:50.545 32,788 kbps 43,549 kbps 00:44:29.583 39,676 kbps 00:44:29.166 36,517 kbps 00:44:29.166 170,944 bytes 386,631 bytes 00:43:14.133 7 0:45:03.158 0:03:14.819 30,601 kbps 43,148 kbps 00:46:24.990 38,560 kbps 00:46:21.904 36,039 kbps 00:46:22.237 159,540 bytes 400,018 bytes 00:47:28.095 8 0:48:17.978 0:09:52.300 23,848 kbps 29,872 kbps 00:48:41.877 28,084 kbps 00:48:41.168 27,459 kbps 00:48:41.543 124,333 bytes 379,375 bytes 00:56:33.098 9 0:58:10.278 0:05:28.077 25,308 kbps 32,003 kbps 01:03:22.882 29,445 kbps 01:03:13.039 29,254 kbps 01:03:13.873 131,942 bytes 378,725 bytes 00:59:54.882 10 1:03:38.356 0:16:46.005 29,709 kbps 42,362 kbps 01:19:56.958 39,430 kbps 01:09:21.866 35,287 kbps 01:09:17.820 154,888 bytes 420,693 bytes 01:11:50.472 11 1:20:24.361 0:02:43.121 29,665 kbps 43,363 kbps 01:21:25.672 34,226 kbps 01:21:21.835 32,792 kbps 01:21:16.746 154,662 bytes 417,310 bytes 01:21:30.135 12 1:23:07.482 0:12:00.428 28,527 kbps 39,276 kbps 01:30:47.191 34,759 kbps 01:34:11.354 34,467 kbps 01:34:06.349 148,726 bytes 441,280 bytes 01:30:09.153 13 1:35:07.910 0:16:16.892 29,028 kbps 43,412 kbps 01:35:56.834 38,671 kbps 01:35:56.917 35,391 kbps 01:35:55.291 151,339 bytes 425,046 bytes 01:44:30.722 14 1:51:24.803 0:04:24.389 29,494 kbps 37,919 kbps 01:54:31.948 32,617 kbps 01:54:58.474 32,058 kbps 01:54:58.474 153,771 bytes 410,315 bytes 01:54:46.921 15 1:55:49.192 0:03:19.949 32,255 kbps 41,282 kbps 01:58:33.356 35,398 kbps 01:58:29.477 34,077 kbps 01:58:24.472 168,165 bytes 453,488 bytes 01:59:09.142 16 1:59:09.142 0:05:04.345 24,299 kbps 36,158 kbps 02:00:04.614 34,869 kbps 02:00:07.074 34,121 kbps 02:00:02.612 126,700 bytes 454,941 bytes 02:00:36.979 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 7453.363 28,999 27,017,502,288 146,938,401 00000.M2TS 4352 (0x1100) 0x80 LPCM fra (French) 7453.363 2,310 2,152,567,912 11,925,584 00000.M2TS 4353 (0x1101) 0x80 LPCM eng (English) 7453.363 2,310 2,152,567,912 11,925,584 00000.M2TS 4354 (0x1102) 0x80 LPCM eng (English) 7453.363 2,310 2,152,567,912 11,925,584 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 7453.363 9 8,171,246 46,963 00000.M2TS 4609 (0x1201) 0x90 PGS eng (English) 7453.363 5 4,297,945 24,724
Total Video
[US] Get Low AVC 1:43:25 24,051,419,136 31,957,833,750 31.01 24.95 DTS-HD Master 5.1 3590Kbps (48kHz/24-bit)
DISC INFO: Disc Title: GET_LOW Disc Size: 31,957,833,750 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00001.MPLS Length: 1:43:25 (h:m:s) Size: 24,051,419,136 bytes Total Bitrate: 31.01 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 24954 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 3590 kbps 5.1 / 48 kHz / 3590 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio French 192 kbps 2.0 / 48 kHz / 192 kbps / Dolby Surround Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 27.912 kbps Presentation Graphics English 24.423 kbps Presentation Graphics French 23.618 kbps Presentation Graphics Spanish 24.504 kbps Presentation Graphics English 72.369 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00011.M2TS 0:00:00.000 1:43:25.199 24,051,419,136 31,008 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:36.289 25,392 kbps 39,659 kbps 00:00:15.181 31,731 kbps 00:00:14.681 31,194 kbps 00:00:14.681 132,373 bytes 707,049 bytes 00:04:11.042 2 0:07:36.289 0:05:14.313 25,675 kbps 37,598 kbps 00:07:36.873 28,648 kbps 00:07:36.873 27,772 kbps 00:07:36.873 133,860 bytes 717,897 bytes 00:07:58.144 3 0:12:50.603 0:07:30.450 25,271 kbps 33,549 kbps 00:15:46.111 28,088 kbps 00:15:55.871 27,401 kbps 00:15:50.366 131,750 bytes 741,803 bytes 00:15:52.117 4 0:20:21.053 0:07:12.515 24,927 kbps 35,831 kbps 00:23:15.352 29,155 kbps 00:20:25.933 27,959 kbps 00:20:21.762 129,959 bytes 768,674 bytes 00:20:38.904 5 0:27:33.568 0:06:03.946 25,405 kbps 36,337 kbps 00:33:25.211 28,733 kbps 00:33:21.791 27,128 kbps 00:30:21.236 132,449 bytes 744,606 bytes 00:28:47.892 6 0:33:37.515 0:05:59.484 24,847 kbps 32,138 kbps 00:36:29.312 26,840 kbps 00:37:54.605 26,272 kbps 00:36:20.344 129,539 bytes 514,038 bytes 00:36:42.742 7 0:39:36.999 0:06:38.356 24,971 kbps 35,157 kbps 00:41:32.406 29,055 kbps 00:41:28.402 28,496 kbps 00:41:23.397 130,187 bytes 748,591 bytes 00:41:20.436 8 0:46:15.355 0:04:47.287 25,292 kbps 34,227 kbps 00:49:18.664 28,518 kbps 00:49:17.496 27,624 kbps 00:49:47.526 131,862 bytes 712,511 bytes 00:46:17.024 9 0:51:02.642 0:04:52.250 24,580 kbps 30,792 kbps 00:55:32.829 25,915 kbps 00:54:59.879 25,471 kbps 00:51:57.948 128,146 bytes 521,849 bytes 00:51:05.103 10 0:55:54.893 0:02:53.506 23,276 kbps 34,301 kbps 00:58:19.621 27,308 kbps 00:58:26.711 25,235 kbps 00:57:11.886 121,350 bytes 551,066 bytes 00:58:31.341 11 0:58:48.399 0:06:41.526 24,519 kbps 36,577 kbps 01:00:53.191 26,800 kbps 01:01:10.249 25,884 kbps 01:01:09.957 127,831 bytes 611,399 bytes 01:00:53.733 12 1:05:29.926 0:07:22.775 24,591 kbps 32,944 kbps 01:10:22.801 28,198 kbps 01:10:18.839 26,377 kbps 01:10:20.341 128,204 bytes 607,572 bytes 01:10:23.719 13 1:12:52.701 0:06:29.305 25,314 kbps 38,405 kbps 01:18:35.043 29,576 kbps 01:19:13.582 28,719 kbps 01:19:11.913 131,976 bytes 783,410 bytes 01:17:35.233 14 1:19:22.007 0:04:40.363 25,411 kbps 37,035 kbps 01:22:18.266 27,430 kbps 01:22:33.531 26,999 kbps 01:22:57.847 132,481 bytes 636,032 bytes 01:21:45.859 15 1:24:02.370 0:06:42.902 25,863 kbps 32,544 kbps 01:27:55.728 27,592 kbps 01:30:22.041 27,066 kbps 01:27:47.387 134,839 bytes 660,886 bytes 01:30:32.802 16 1:30:45.273 0:12:39.925 24,053 kbps 46,163 kbps 01:43:05.721 29,985 kbps 01:34:07.558 28,618 kbps 01:34:08.184 125,407 bytes 734,812 bytes 01:35:38.399 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00011.M2TS 4113 (0x1011) 0x1B AVC 6205.116 24,954 19,355,662,485 105,281,164 00011.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 6205.116 3,590 2,784,218,580 16,099,574 00011.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 6205.116 192 148,925,184 969,565 00011.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 6205.116 192 148,925,184 969,565 00011.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 6205.116 192 148,925,184 969,565 00011.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6205.116 28 21,649,711 124,489 00011.M2TS 4609 (0x1201) 0x90 PGS eng (English) 6205.116 24 18,943,618 110,938 00011.M2TS 4610 (0x1202) 0x90 PGS fra (French) 6205.116 24 18,319,507 106,445 00011.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 6205.116 25 19,006,415 110,302 00011.M2TS 4612 (0x1204) 0x90 PGS eng (English) 6205.116 72 56,132,745 318,299
Total Video
[US] Faster AVC 1:37:57 22,069,708,800 32,946,513,624 30.04 25.45 DTS-HD Master 5.1 2971Kbps (48kHz/24-bit)
DISC INFO: Disc Title: FASTER Disc Size: 32,946,513,624 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00001.MPLS Length: 1:37:57 (h:m:s) Size: 22,069,708,800 bytes Total Bitrate: 30.04 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 25453 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 2971 kbps 5.1 / 48 kHz / 2971 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 21.422 kbps Presentation Graphics English 17.471 kbps Presentation Graphics Spanish 21.417 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00011.M2TS 0:00:00.000 1:37:57.872 22,069,708,800 30,038 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:51.012 25,490 kbps 38,178 kbps 00:00:43.126 30,767 kbps 00:03:46.517 29,853 kbps 00:03:47.352 132,882 bytes 489,265 bytes 00:03:47.769 2 0:07:51.012 0:04:08.831 25,532 kbps 40,537 kbps 00:10:58.074 30,260 kbps 00:10:58.032 28,652 kbps 00:10:58.032 133,110 bytes 500,429 bytes 00:10:58.240 3 0:11:59.844 0:08:57.245 25,427 kbps 40,011 kbps 00:19:45.434 29,894 kbps 00:19:45.434 28,252 kbps 00:19:40.762 132,565 bytes 562,132 bytes 00:16:02.753 4 0:20:57.089 0:03:32.253 26,946 kbps 40,862 kbps 00:22:33.769 31,289 kbps 00:23:42.963 29,633 kbps 00:22:33.727 140,482 bytes 479,562 bytes 00:22:54.373 5 0:24:29.342 0:06:09.494 25,621 kbps 37,026 kbps 00:29:32.687 30,374 kbps 00:29:31.019 28,370 kbps 00:29:26.014 133,574 bytes 578,333 bytes 00:29:33.354 6 0:30:38.837 0:05:07.932 26,007 kbps 40,690 kbps 00:30:56.479 29,196 kbps 00:34:08.004 27,805 kbps 00:34:08.713 135,591 bytes 655,560 bytes 00:30:52.225 7 0:35:46.769 0:07:43.796 26,053 kbps 36,824 kbps 00:39:58.479 30,033 kbps 00:39:55.142 28,311 kbps 00:40:21.085 135,826 bytes 560,749 bytes 00:43:29.898 8 0:43:30.566 0:03:36.966 26,052 kbps 33,431 kbps 00:43:51.337 30,086 kbps 00:43:34.778 29,378 kbps 00:43:32.067 135,822 bytes 514,501 bytes 00:43:57.426 9 0:47:07.533 0:07:45.506 25,625 kbps 44,635 kbps 00:51:50.065 31,687 kbps 00:51:46.061 29,494 kbps 00:48:37.456 133,599 bytes 504,602 bytes 00:48:04.381 10 0:54:53.039 0:04:24.138 25,144 kbps 39,480 kbps 00:56:38.728 30,863 kbps 00:56:30.845 27,880 kbps 00:56:25.965 131,090 bytes 735,360 bytes 00:57:00.208 11 0:59:17.178 0:07:51.387 25,643 kbps 50,934 kbps 01:03:08.201 32,016 kbps 01:05:29.175 29,943 kbps 01:03:36.521 133,688 bytes 767,119 bytes 01:03:03.613 12 1:07:08.566 0:04:19.676 23,918 kbps 30,288 kbps 01:11:17.940 26,453 kbps 01:11:14.103 25,482 kbps 01:11:13.811 124,696 bytes 465,101 bytes 01:11:09.848 13 1:11:28.242 0:05:40.840 26,454 kbps 33,112 kbps 01:15:34.905 29,155 kbps 01:15:50.921 28,225 kbps 01:15:34.905 137,919 bytes 519,696 bytes 01:16:05.394 14 1:17:09.082 0:05:56.481 25,641 kbps 33,256 kbps 01:17:10.709 29,662 kbps 01:17:09.750 27,904 kbps 01:17:09.082 133,681 bytes 574,635 bytes 01:21:33.096 15 1:23:05.563 0:05:39.797 25,756 kbps 35,220 kbps 01:25:29.624 28,761 kbps 01:28:14.706 27,662 kbps 01:28:12.829 134,281 bytes 598,722 bytes 01:28:42.275 16 1:28:45.361 0:09:12.510 23,314 kbps 34,496 kbps 01:29:26.444 30,425 kbps 01:32:42.598 28,622 kbps 01:32:37.843 121,559 bytes 652,248 bytes 01:32:31.546 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00011.M2TS 4113 (0x1011) 0x1B AVC 5877.747 25,453 18,701,122,766 101,719,404 00011.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5877.747 2,971 2,182,876,272 12,772,365 00011.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5877.747 21 15,739,328 90,807 00011.M2TS 4609 (0x1201) 0x90 PGS eng (English) 5877.747 17 12,836,745 75,928 00011.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 5877.747 21 15,735,945 90,954
Total Video
[US] Unforgiven VC-1 2:10:40 17,973,215,232 29,401,457,918 18.34 15.95 DD AC3 5.1 640Kbps
DISC INFO: Disc Title: LOGICAL_VOLUME_ID Disc Size: 29,401,457,918 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00000.MPLS Length: 2:10:40 (h:m:s) Size: 17,973,215,232 bytes Total Bitrate: 18.34 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 15948 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio French 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround Dolby Digital Audio Spanish 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 42.888 kbps Presentation Graphics English 46.609 kbps Presentation Graphics French 39.158 kbps Presentation Graphics Spanish 41.137 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 2:10:40.624 17,973,215,232 18,339 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:01:11.863 12,097 kbps 22,808 kbps 00:00:09.217 18,600 kbps 00:00:05.130 17,244 kbps 00:00:45.420 64,071 bytes 291,043 bytes 00:00:50.133 2 0:01:11.863 0:02:42.495 17,192 kbps 30,466 kbps 00:03:02.056 24,501 kbps 00:03:00.305 22,360 kbps 00:02:56.801 89,632 bytes 329,162 bytes 00:02:08.753 3 0:03:54.359 0:03:07.020 12,400 kbps 20,659 kbps 00:07:00.253 15,690 kbps 00:03:54.400 14,819 kbps 00:03:54.400 64,650 bytes 240,563 bytes 00:04:49.122 4 0:07:01.379 0:01:16.242 16,390 kbps 28,399 kbps 00:08:03.024 23,818 kbps 00:08:02.523 20,015 kbps 00:08:01.939 85,453 bytes 441,504 bytes 00:07:21.691 5 0:08:17.622 0:05:53.186 16,920 kbps 27,817 kbps 00:08:25.254 22,767 kbps 00:08:21.250 20,805 kbps 00:13:16.420 88,212 bytes 397,209 bytes 00:08:49.862 6 0:14:10.808 0:02:43.997 19,585 kbps 30,183 kbps 00:14:43.799 24,432 kbps 00:15:21.378 23,112 kbps 00:14:36.083 102,105 bytes 430,149 bytes 00:15:48.906 7 0:16:54.805 0:07:23.776 17,232 kbps 31,601 kbps 00:24:14.244 24,528 kbps 00:18:22.810 23,846 kbps 00:21:27.286 89,841 bytes 441,505 bytes 00:21:50.142 8 0:24:18.582 0:04:34.107 18,731 kbps 29,337 kbps 00:27:53.505 23,968 kbps 00:28:32.210 22,788 kbps 00:28:31.793 97,656 bytes 489,587 bytes 00:24:21.376 9 0:28:52.689 0:02:49.669 13,768 kbps 27,876 kbps 00:29:45.074 24,020 kbps 00:29:41.279 23,543 kbps 00:29:36.274 71,782 bytes 328,841 bytes 00:29:20.008 10 0:31:42.358 0:02:52.505 21,390 kbps 30,213 kbps 00:33:59.912 25,404 kbps 00:33:46.357 24,419 kbps 00:32:12.555 111,520 bytes 324,962 bytes 00:33:14.492 11 0:34:34.864 0:04:19.259 16,701 kbps 31,319 kbps 00:35:17.114 24,742 kbps 00:34:56.803 22,813 kbps 00:34:56.302 87,072 bytes 359,092 bytes 00:35:36.050 12 0:38:54.123 0:07:30.783 21,218 kbps 30,423 kbps 00:43:16.927 25,879 kbps 00:45:15.087 24,522 kbps 00:44:43.722 110,619 bytes 452,195 bytes 00:40:56.871 13 0:46:24.907 0:07:19.439 19,614 kbps 33,219 kbps 00:52:51.042 25,698 kbps 00:47:19.419 24,558 kbps 00:52:01.159 102,257 bytes 559,320 bytes 00:52:56.590 14 0:53:44.346 0:04:20.927 19,446 kbps 27,739 kbps 00:55:06.511 25,945 kbps 00:55:04.467 24,186 kbps 00:55:04.175 101,384 bytes 320,742 bytes 00:55:57.937 15 0:58:05.273 0:02:19.639 16,452 kbps 28,075 kbps 01:00:14.068 23,616 kbps 01:00:12.942 20,511 kbps 01:00:09.439 85,774 bytes 324,613 bytes 00:58:19.162 16 1:00:24.912 0:06:24.217 20,281 kbps 27,036 kbps 01:05:11.449 23,803 kbps 01:01:39.987 22,688 kbps 01:00:28.791 105,738 bytes 368,464 bytes 01:05:34.847 17 1:06:49.130 0:02:47.166 17,300 kbps 29,991 kbps 01:09:00.344 23,667 kbps 01:09:00.177 22,221 kbps 01:08:56.257 90,193 bytes 393,402 bytes 01:08:17.176 18 1:09:36.297 0:04:12.585 17,530 kbps 27,758 kbps 01:12:42.316 24,176 kbps 01:12:40.981 22,614 kbps 01:12:41.190 91,392 bytes 369,027 bytes 01:12:42.441 19 1:13:48.882 0:07:10.930 17,742 kbps 28,976 kbps 01:14:23.167 24,110 kbps 01:16:33.088 23,563 kbps 01:13:55.097 92,497 bytes 340,350 bytes 01:14:23.792 20 1:20:59.813 0:03:47.060 10,269 kbps 21,056 kbps 01:22:08.214 16,404 kbps 01:22:05.003 14,648 kbps 01:22:03.877 53,539 bytes 339,977 bytes 01:24:46.247 21 1:24:46.873 0:04:52.125 12,630 kbps 26,356 kbps 01:26:42.322 20,557 kbps 01:25:57.610 19,565 kbps 01:25:50.937 65,845 bytes 495,180 bytes 01:26:31.853 22 1:29:38.998 0:04:48.454 15,040 kbps 30,920 kbps 01:29:41.376 23,564 kbps 01:29:39.999 22,782 kbps 01:29:39.415 78,414 bytes 428,112 bytes 01:33:51.125 23 1:34:27.453 0:01:43.436 13,522 kbps 21,000 kbps 01:36:09.305 17,102 kbps 01:36:05.301 16,558 kbps 01:34:27.870 70,499 bytes 220,073 bytes 01:35:51.412 24 1:36:10.890 0:05:00.299 12,996 kbps 24,020 kbps 01:36:31.744 18,322 kbps 01:36:28.240 17,196 kbps 01:37:26.632 67,754 bytes 382,343 bytes 01:36:36.457 25 1:41:11.190 0:02:02.622 11,674 kbps 15,946 kbps 01:42:22.052 14,615 kbps 01:42:20.342 13,601 kbps 01:42:15.254 60,861 bytes 207,092 bytes 01:43:13.228 26 1:43:13.812 0:02:36.656 14,547 kbps 27,952 kbps 01:43:59.775 25,298 kbps 01:43:59.775 22,018 kbps 01:43:57.105 75,839 bytes 347,692 bytes 01:43:57.481 27 1:45:50.469 0:03:28.875 13,256 kbps 19,101 kbps 01:49:06.706 17,405 kbps 01:49:06.206 16,432 kbps 01:49:05.872 69,112 bytes 269,968 bytes 01:47:58.805 28 1:49:19.344 0:03:55.401 12,414 kbps 22,655 kbps 01:53:11.326 20,823 kbps 01:52:59.230 20,459 kbps 01:52:59.898 64,723 bytes 232,630 bytes 01:50:29.873 29 1:53:14.746 0:01:19.579 13,030 kbps 23,499 kbps 01:53:53.451 21,015 kbps 01:53:51.115 18,940 kbps 01:53:49.030 67,932 bytes 249,498 bytes 01:53:58.414 30 1:54:34.325 0:03:47.393 11,430 kbps 19,004 kbps 01:57:36.340 15,850 kbps 01:57:34.005 15,369 kbps 01:57:32.253 59,590 bytes 274,410 bytes 01:57:36.382 31 1:58:21.719 0:03:51.397 11,706 kbps 18,902 kbps 01:58:21.761 14,472 kbps 02:00:51.035 13,666 kbps 02:00:51.035 61,031 bytes 256,284 bytes 02:02:11.657 32 2:02:13.117 0:02:19.138 11,648 kbps 17,121 kbps 02:03:54.927 16,141 kbps 02:03:53.968 13,703 kbps 02:03:49.255 60,728 bytes 255,881 bytes 02:03:54.593 33 2:04:32.256 0:06:08.368 11,242 kbps 19,222 kbps 02:10:17.768 17,514 kbps 02:10:17.768 16,765 kbps 02:10:13.680 58,728 bytes 295,474 bytes 02:10:17.810 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0xEA VC-1 7840.541 15,948 15,629,834,771 85,057,442 00000.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 7840.541 640 627,251,200 3,675,300 00000.M2TS 4353 (0x1101) 0x81 AC3 fra (French) 7840.541 192 188,175,360 1,225,100 00000.M2TS 4354 (0x1102) 0x81 AC3 spa (Spanish) 7840.541 192 188,175,360 1,225,100 00000.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 7840.541 192 188,175,360 1,225,100 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 7840.541 43 42,033,784 236,863 00000.M2TS 4609 (0x1201) 0x90 PGS eng (English) 7840.541 47 45,680,757 257,530 00000.M2TS 4610 (0x1202) 0x90 PGS fra (French) 7840.541 39 38,377,445 217,122 00000.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 7840.541 41 40,317,007 228,239
Looks decent enough though.
Total Video
00038.MPLS MPEG-2 1:57:57 31.690.997.760 34.988.591.666 35,82 19,10 LPCM 5.1 4608Kbps (48kHz/16-bit) DD AC3 5.1 640Kbps
DISC INFO: Disc Title: LOGICAL_VOLUME_ID Disc Size: 34.988.591.666 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00038.MPLS Length: 1:57:57 (h:m:s) Size: 31.690.997.760 bytes Total Bitrate: 35,82 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-2 Video 19100 kbps 1080p / 23,976 fps / 16:9 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio English 4608 kbps 5.1 / 48 kHz / 4608 kbps / 16-bit DTS Audio French 1509 kbps 5.1 / 48 kHz / 1509 kbps / 24-bit DTS Audio German 1509 kbps 5.1 / 48 kHz / 1509 kbps / 24-bit / DN -5dB DTS Audio Italian 1509 kbps 5.1 / 48 kHz / 1509 kbps / 24-bit / DN -5dB DTS Audio Spanish 1509 kbps 5.1 / 48 kHz / 1509 kbps / 24-bit Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps / DN -9dB Dolby Digital Audio German 640 kbps 5.1 / 48 kHz / 640 kbps / DN -5dB Dolby Digital Audio Italian 640 kbps 5.1 / 48 kHz / 640 kbps / DN -5dB Dolby Digital Audio Spanish 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 37,143 kbps Presentation Graphics English 40,656 kbps Presentation Graphics Danish 26,682 kbps Presentation Graphics Dutch 22,342 kbps Presentation Graphics Finnish 28,225 kbps Presentation Graphics French 24,842 kbps Presentation Graphics French 0,341 kbps Presentation Graphics German 30,645 kbps Presentation Graphics German 0,429 kbps Presentation Graphics Icelandic 25,756 kbps Presentation Graphics Italian 28,177 kbps Presentation Graphics Italian 0,368 kbps Presentation Graphics Norwegian 26,153 kbps Presentation Graphics Spanish 26,979 kbps Presentation Graphics Spanish 0,450 kbps Presentation Graphics Swedish 23,570 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00046.M2TS 0:00:00.000 0:53:02.888 14.323.685.376 36.002 00047.M2TS 0:53:02.888 0:47:04.530 12.685.111.296 35.928 00048.M2TS 1:40:07.418 0:17:49.651 4.682.201.088 35.019 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:03:25.413 19.243 kbps 28.661 kbps 00:02:25.520 25.095 kbps 00:01:23.583 24.047 kbps 00:01:18.578 100.306 bytes 425.282 bytes 00:01:40.266 2 0:03:25.413 0:05:20.653 19.259 kbps 28.635 kbps 00:06:55.415 25.072 kbps 00:04:36.901 23.602 kbps 00:04:36.109 100.405 bytes 402.651 bytes 00:06:04.781 3 0:08:46.067 0:03:09.355 19.456 kbps 26.604 kbps 00:09:13.052 24.204 kbps 00:09:13.261 23.547 kbps 00:09:13.052 101.436 bytes 447.479 bytes 00:09:09.840 4 0:11:55.423 0:04:59.757 19.122 kbps 29.460 kbps 00:12:02.304 25.555 kbps 00:11:58.718 23.923 kbps 00:11:58.426 99.693 bytes 410.563 bytes 00:12:40.926 5 0:16:55.180 0:01:48.691 19.229 kbps 25.086 kbps 00:17:21.040 21.601 kbps 00:18:19.890 20.797 kbps 00:17:11.905 100.251 bytes 463.532 bytes 00:17:02.187 6 0:18:43.872 0:04:53.459 19.197 kbps 23.605 kbps 00:22:23.342 21.244 kbps 00:21:43.844 20.860 kbps 00:21:07.140 100.082 bytes 436.929 bytes 00:21:48.598 7 0:23:37.332 0:03:13.359 19.200 kbps 24.325 kbps 00:25:08.256 21.508 kbps 00:25:04.252 20.691 kbps 00:25:00.165 100.102 bytes 439.784 bytes 00:25:56.471 8 0:26:50.692 0:05:08.558 19.119 kbps 24.089 kbps 00:26:54.029 22.085 kbps 00:26:50.900 21.132 kbps 00:26:51.484 99.680 bytes 433.948 bytes 00:28:42.762 9 0:31:59.250 0:01:38.723 19.856 kbps 28.213 kbps 00:32:43.586 22.999 kbps 00:32:56.975 21.735 kbps 00:33:09.112 103.520 bytes 367.720 bytes 00:32:47.882 10 0:33:37.974 0:02:46.457 18.692 kbps 23.187 kbps 00:35:58.406 21.783 kbps 00:35:53.693 21.100 kbps 00:35:52.650 97.454 bytes 488.368 bytes 00:35:58.447 11 0:36:24.432 0:02:18.888 19.319 kbps 24.770 kbps 00:36:37.987 20.819 kbps 00:37:18.402 20.301 kbps 00:37:17.610 100.721 bytes 471.428 bytes 00:36:28.603 12 0:38:43.321 0:00:51.384 19.269 kbps 22.328 kbps 00:38:44.697 20.950 kbps 00:38:44.405 20.394 kbps 00:38:44.613 100.462 bytes 395.549 bytes 00:39:03.758 13 0:39:34.705 0:02:37.657 19.188 kbps 27.310 kbps 00:40:35.808 23.939 kbps 00:40:32.930 21.994 kbps 00:40:31.929 100.038 bytes 438.851 bytes 00:40:35.850 14 0:42:12.363 0:02:07.502 19.625 kbps 24.252 kbps 00:42:13.280 21.943 kbps 00:43:41.869 21.076 kbps 00:43:38.157 102.317 bytes 431.822 bytes 00:43:58.552 15 0:44:19.865 0:04:23.680 18.623 kbps 24.923 kbps 00:45:24.847 22.360 kbps 00:48:13.932 21.541 kbps 00:48:08.969 97.091 bytes 432.367 bytes 00:47:25.133 16 0:48:43.545 0:04:12.961 19.556 kbps 27.582 kbps 00:52:16.883 24.215 kbps 00:50:05.627 22.202 kbps 00:52:33.900 101.953 bytes 443.352 bytes 00:51:17.991 17 0:52:56.506 0:05:48.347 19.154 kbps 27.558 kbps 00:53:49.768 23.761 kbps 00:53:47.390 21.727 kbps 00:52:58.550 99.859 bytes 471.036 bytes 00:53:08.310 18 0:58:44.854 0:07:31.033 18.923 kbps 29.971 kbps 01:05:54.909 23.984 kbps 01:01:33.231 22.470 kbps 01:01:46.285 98.657 bytes 415.000 bytes 01:04:28.614 19 1:06:15.888 0:04:52.500 18.070 kbps 23.916 kbps 01:07:13.612 21.852 kbps 01:07:16.615 20.983 kbps 01:07:13.529 94.207 bytes 454.136 bytes 01:09:22.408 20 1:11:08.389 0:02:35.780 18.955 kbps 27.074 kbps 01:12:56.955 22.562 kbps 01:12:56.955 22.279 kbps 01:12:56.955 98.824 bytes 407.872 bytes 01:11:41.046 21 1:13:44.169 0:03:46.809 17.013 kbps 22.298 kbps 01:13:48.882 21.453 kbps 01:13:48.882 20.989 kbps 01:13:44.169 88.697 bytes 371.819 bytes 01:15:15.636 22 1:17:30.979 0:02:08.545 19.085 kbps 26.850 kbps 01:18:40.674 23.002 kbps 01:18:36.795 21.878 kbps 01:18:36.420 99.498 bytes 416.003 bytes 01:18:39.589 23 1:19:39.524 0:01:45.063 17.828 kbps 23.204 kbps 01:20:20.607 21.888 kbps 01:20:16.603 20.498 kbps 01:20:15.352 92.947 bytes 396.034 bytes 01:21:24.504 24 1:21:24.588 0:05:23.531 19.255 kbps 29.096 kbps 01:23:25.333 24.522 kbps 01:25:29.207 23.046 kbps 01:25:27.205 100.388 bytes 383.437 bytes 01:24:32.942 25 1:26:48.119 0:06:05.114 20.557 kbps 28.394 kbps 01:30:15.785 23.869 kbps 01:29:01.419 23.295 kbps 01:29:00.168 107.174 bytes 432.039 bytes 01:32:16.280 26 1:32:53.234 0:01:26.419 18.536 kbps 22.734 kbps 01:33:18.843 20.578 kbps 01:33:14.880 19.693 kbps 01:33:15.840 96.638 bytes 449.714 bytes 01:34:19.403 27 1:34:19.653 0:04:09.165 21.435 kbps 28.431 kbps 01:36:56.393 24.849 kbps 01:37:09.114 24.036 kbps 01:37:09.156 111.750 bytes 440.993 bytes 01:34:23.157 28 1:38:28.819 0:01:38.598 21.478 kbps 29.447 kbps 01:39:35.135 24.596 kbps 01:39:47.231 23.626 kbps 01:39:41.558 111.977 bytes 439.801 bytes 01:39:04.438 29 1:40:07.418 0:04:06.287 19.649 kbps 25.316 kbps 01:42:59.047 23.062 kbps 01:41:30.250 22.527 kbps 01:41:25.704 102.440 bytes 431.800 bytes 01:43:47.804 30 1:44:13.705 0:04:26.557 19.530 kbps 27.263 kbps 01:47:22.602 24.258 kbps 01:47:20.016 22.617 kbps 01:47:15.220 101.819 bytes 487.924 bytes 01:47:22.644 31 1:48:40.263 0:03:08.897 18.866 kbps 27.223 kbps 01:48:43.308 25.115 kbps 01:48:53.276 24.640 kbps 01:48:48.271 98.358 bytes 485.464 bytes 01:48:43.350 32 1:51:49.160 0:06:07.909 16.664 kbps 25.393 kbps 01:56:45.498 24.789 kbps 01:56:31.025 24.648 kbps 01:56:28.773 86.890 bytes 344.307 bytes 01:52:58.104 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00046.M2TS 4113 (0x1011) 0x02 MPEG-2 3182,805 19.211 7.643.181.726 41.583.357 00046.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 3182,805 4.615 1.835.890.952 10.185.248 00046.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 3182,805 640 254.632.960 1.491.990 00046.M2TS 4354 (0x1102) 0x82 DTS fra (French) 3182,805 1.509 600.372.752 3.580.752 00046.M2TS 4355 (0x1103) 0x81 AC3 fra (French) 3182,805 640 254.632.960 1.491.990 00046.M2TS 4356 (0x1104) 0x82 DTS ita (Italian) 3182,805 1.509 600.372.752 3.580.752 00046.M2TS 4357 (0x1105) 0x81 AC3 ita (Italian) 3182,805 640 254.632.960 1.491.990 00046.M2TS 4358 (0x1106) 0x82 DTS deu (German) 3182,805 1.509 600.372.752 3.580.752 00046.M2TS 4359 (0x1107) 0x81 AC3 deu (German) 3182,805 640 254.632.960 1.491.990 00046.M2TS 4360 (0x1108) 0x82 DTS spa (Spanish) 3182,805 1.509 600.372.752 3.580.752 00046.M2TS 4361 (0x1109) 0x81 AC3 spa (Spanish) 3182,805 640 254.632.960 1.491.990 00046.M2TS 4608 (0x1200) 0x90 PGS eng (English) 3182,805 42 16.858.816 96.230 00046.M2TS 4609 (0x1201) 0x90 PGS eng (English) 3182,805 46 18.286.498 103.864 00046.M2TS 4610 (0x1202) 0x90 PGS fra (French) 3182,805 30 11.799.020 67.628 00046.M2TS 4611 (0x1203) 0x90 PGS ita (Italian) 3182,805 33 13.325.440 75.941 00046.M2TS 4612 (0x1204) 0x90 PGS deu (German) 3182,805 36 14.188.559 80.674 00046.M2TS 4613 (0x1205) 0x90 PGS spa (Spanish) 3182,805 32 12.719.997 72.626 00046.M2TS 4614 (0x1206) 0x90 PGS nld (Dutch) 3182,805 26 10.514.465 60.257 00046.M2TS 4615 (0x1207) 0x90 PGS swe (Swedish) 3182,805 28 10.941.096 62.981 00046.M2TS 4616 (0x1208) 0x90 PGS nor (Norwegian) 3182,805 31 12.223.011 69.987 00046.M2TS 4617 (0x1209) 0x90 PGS dan (Danish) 3182,805 31 12.492.101 71.462 00046.M2TS 4618 (0x120A) 0x90 PGS fin (Finnish) 3182,805 34 13.356.839 75.900 00046.M2TS 4619 (0x120B) 0x90 PGS isl (Icelandic) 3182,805 30 11.977.698 68.669 00046.M2TS 4620 (0x120C) 0x90 PGS fra (French) 3182,805 0 165.940 966 00046.M2TS 4621 (0x120D) 0x90 PGS ita (Italian) 3182,805 0 173.162 1.006 00046.M2TS 4622 (0x120E) 0x90 PGS deu (German) 3182,805 0 194.481 1.121 00046.M2TS 4623 (0x120F) 0x90 PGS spa (Spanish) 3182,805 0 195.058 1.123 00047.M2TS 4113 (0x1011) 0x02 MPEG-2 2824,447 19.221 6.786.016.324 36.919.906 00047.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 2824,447 4.615 1.629.191.788 9.038.512 00047.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 2824,447 640 225.963.520 1.324.005 00047.M2TS 4354 (0x1102) 0x82 DTS fra (French) 2824,447 1.509 532.777.600 3.177.600 00047.M2TS 4355 (0x1103) 0x81 AC3 fra (French) 2824,447 640 225.963.520 1.324.005 00047.M2TS 4356 (0x1104) 0x82 DTS ita (Italian) 2824,447 1.509 532.777.600 3.177.600 00047.M2TS 4357 (0x1105) 0x81 AC3 ita (Italian) 2824,447 640 225.963.520 1.324.005 00047.M2TS 4358 (0x1106) 0x82 DTS deu (German) 2824,447 1.509 532.777.600 3.177.600 00047.M2TS 4359 (0x1107) 0x81 AC3 deu (German) 2824,447 640 225.963.520 1.324.005 00047.M2TS 4360 (0x1108) 0x82 DTS spa (Spanish) 2824,447 1.509 532.777.600 3.177.600 00047.M2TS 4361 (0x1109) 0x81 AC3 spa (Spanish) 2824,447 640 225.963.520 1.324.005 00047.M2TS 4608 (0x1200) 0x90 PGS eng (English) 2824,447 37 12.925.291 74.009 00047.M2TS 4609 (0x1201) 0x90 PGS eng (English) 2824,447 39 13.663.549 77.849 00047.M2TS 4610 (0x1202) 0x90 PGS fra (French) 2824,447 23 8.071.575 46.466 00047.M2TS 4611 (0x1203) 0x90 PGS ita (Italian) 2824,447 26 9.219.241 52.749 00047.M2TS 4612 (0x1204) 0x90 PGS deu (German) 2824,447 29 10.208.569 58.188 00047.M2TS 4613 (0x1205) 0x90 PGS spa (Spanish) 2824,447 25 8.861.188 50.793 00047.M2TS 4614 (0x1206) 0x90 PGS nld (Dutch) 2824,447 21 7.369.464 42.372 00047.M2TS 4615 (0x1207) 0x90 PGS swe (Swedish) 2824,447 22 7.862.393 45.409 00047.M2TS 4616 (0x1208) 0x90 PGS nor (Norwegian) 2824,447 25 8.697.039 49.981 00047.M2TS 4617 (0x1209) 0x90 PGS dan (Danish) 2824,447 25 8.877.943 50.961 00047.M2TS 4618 (0x120A) 0x90 PGS fin (Finnish) 2824,447 26 9.260.366 52.815 00047.M2TS 4619 (0x120B) 0x90 PGS isl (Icelandic) 2824,447 24 8.568.674 49.265 00047.M2TS 4620 (0x120C) 0x90 PGS fra (French) 2824,447 0 135.642 796 00047.M2TS 4621 (0x120D) 0x90 PGS ita (Italian) 2824,447 0 152.016 890 00047.M2TS 4622 (0x120E) 0x90 PGS deu (German) 2824,447 1 184.711 1.068 00047.M2TS 4623 (0x120F) 0x90 PGS spa (Spanish) 2824,447 1 203.128 1.168 00048.M2TS 4113 (0x1011) 0x02 MPEG-2 1069,569 18.458 2.467.725.095 13.426.434 00048.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 1069,569 4.615 616.977.004 3.422.896 00048.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 1069,569 640 85.573.120 501.405 00048.M2TS 4354 (0x1102) 0x82 DTS fra (French) 1069,569 1.509 201.763.360 1.203.360 00048.M2TS 4355 (0x1103) 0x81 AC3 fra (French) 1069,569 640 85.573.120 501.405 00048.M2TS 4356 (0x1104) 0x82 DTS ita (Italian) 1069,569 1.509 201.763.360 1.203.360 00048.M2TS 4357 (0x1105) 0x81 AC3 ita (Italian) 1069,569 640 85.573.120 501.405 00048.M2TS 4358 (0x1106) 0x82 DTS deu (German) 1069,569 1.509 201.763.360 1.203.360 00048.M2TS 4359 (0x1107) 0x81 AC3 deu (German) 1069,569 640 85.573.120 501.405 00048.M2TS 4360 (0x1108) 0x82 DTS spa (Spanish) 1069,569 1.509 201.763.360 1.203.360 00048.M2TS 4361 (0x1109) 0x81 AC3 spa (Spanish) 1069,569 640 85.573.120 501.405 00048.M2TS 4608 (0x1200) 0x90 PGS eng (English) 1069,569 23 3.073.852 17.630 00048.M2TS 4609 (0x1201) 0x90 PGS eng (English) 1069,569 30 4.015.914 22.923 00048.M2TS 4610 (0x1202) 0x90 PGS fra (French) 1069,569 16 2.105.120 12.109 00048.M2TS 4611 (0x1203) 0x90 PGS ita (Italian) 1069,569 18 2.381.652 13.647 00048.M2TS 4612 (0x1204) 0x90 PGS deu (German) 1069,569 20 2.712.277 15.454 00048.M2TS 4613 (0x1205) 0x90 PGS spa (Spanish) 1069,569 17 2.285.260 13.113 00048.M2TS 4614 (0x1206) 0x90 PGS nld (Dutch) 1069,569 14 1.880.988 10.836 00048.M2TS 4615 (0x1207) 0x90 PGS swe (Swedish) 1069,569 15 2.047.117 11.820 00048.M2TS 4616 (0x1208) 0x90 PGS nor (Norwegian) 1069,569 17 2.216.182 12.761 00048.M2TS 4617 (0x1209) 0x90 PGS dan (Danish) 1069,569 17 2.234.170 12.852 00048.M2TS 4618 (0x120A) 0x90 PGS fin (Finnish) 1069,569 18 2.351.789 13.429 00048.M2TS 4619 (0x120B) 0x90 PGS isl (Icelandic) 1069,569 17 2.238.322 12.887 00048.M2TS 4620 (0x120C) 0x90 PGS fra (French) 1069,569 0 0 0 00048.M2TS 4621 (0x120D) 0x90 PGS ita (Italian) 1069,569 0 0 0 00048.M2TS 4622 (0x120E) 0x90 PGS deu (German) 1069,569 0 0 0 00048.M2TS 4623 (0x120F) 0x90 PGS spa (Spanish) 1069,569 0 0 0
Total Video
[FR] Alexander Revisited: Disc 1: Alexandre Revisited VC-1 3:33:12 40.874.711.040 43.735.865.048 25,56 20,48 DTS-HD Master 5.1 2027Kbps (48kHz/16-bit) DTS 2.0 1509Kbps (48kHz/16-bit)
Disc 2: Theatrical Version VC-1 2:55:25 27.188.269.056 27.741.555.666 20,66 15,00 DTS-HD Master 5.1 2142Kbps (48kHz/16-bit)
DISC INFO: Disc Title: ALEXANDRE Disc Size: 43.735.865.048 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00002.MPLS Length: 3:33:12 (h:m:s) Size: 40.874.711.040 bytes Total Bitrate: 25,56 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 20484 kbps 1080p / 23,976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 2027 kbps 5.1 / 48 kHz / 2027 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) DTS Audio English 1509 kbps 2.0 / 48 kHz / 1509 kbps / 16-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics French 28,562 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00003.M2TS 0:00:00.000 3:33:12.654 40.874.711.040 25.561 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:50.303 18.122 kbps 44.139 kbps 00:00:15.098 33.502 kbps 00:00:02.085 27.555 kbps 00:00:14.889 94.474 bytes 425.477 bytes 00:07:05.591 2 0:07:50.303 0:08:15.161 18.967 kbps 33.611 kbps 00:16:03.671 24.738 kbps 00:16:00.459 23.392 kbps 00:12:38.924 98.883 bytes 490.334 bytes 00:12:38.966 3 0:16:05.464 0:08:09.405 22.129 kbps 36.523 kbps 00:23:29.991 34.346 kbps 00:23:29.157 30.460 kbps 00:17:18.996 115.370 bytes 564.429 bytes 00:19:47.895 4 0:24:14.870 0:13:50.412 23.767 kbps 43.535 kbps 00:24:18.331 36.752 kbps 00:24:16.496 32.002 kbps 00:24:49.112 123.912 bytes 472.132 bytes 00:24:52.866 5 0:38:05.283 0:04:08.665 21.479 kbps 32.602 kbps 00:41:15.890 27.413 kbps 00:41:13.971 25.834 kbps 00:41:12.011 111.983 bytes 345.844 bytes 00:41:29.487 6 0:42:13.948 0:12:35.254 19.682 kbps 39.840 kbps 00:50:18.932 30.079 kbps 00:53:32.459 28.720 kbps 00:53:35.670 102.612 bytes 610.653 bytes 00:44:17.321 7 0:54:49.202 0:06:02.070 21.887 kbps 39.658 kbps 01:00:42.805 30.008 kbps 00:55:21.943 26.748 kbps 00:55:18.732 114.107 bytes 472.828 bytes 00:57:41.541 8 1:00:51.272 0:07:33.244 21.502 kbps 39.083 kbps 01:01:22.345 34.855 kbps 01:00:56.444 34.100 kbps 01:00:52.690 112.102 bytes 494.759 bytes 01:01:23.304 9 1:08:24.517 0:10:03.102 18.183 kbps 34.244 kbps 01:08:26.435 30.188 kbps 01:08:48.958 26.212 kbps 01:08:26.435 94.800 bytes 398.809 bytes 01:08:32.108 10 1:18:27.619 0:11:17.176 18.755 kbps 31.193 kbps 01:19:29.431 27.975 kbps 01:20:08.970 25.887 kbps 01:28:51.868 97.780 bytes 453.910 bytes 01:19:04.781 11 1:29:44.796 0:12:10.312 22.359 kbps 40.735 kbps 01:31:36.782 35.715 kbps 01:30:40.435 34.217 kbps 01:30:37.223 116.571 bytes 376.775 bytes 01:31:05.334 12 1:41:55.109 0:06:53.621 17.678 kbps 54.494 kbps 01:41:59.947 26.635 kbps 01:42:54.585 24.665 kbps 01:42:49.663 92.163 bytes 474.162 bytes 01:42:00.739 13 1:48:48.730 0:06:17.960 19.822 kbps 32.812 kbps 01:51:05.492 27.279 kbps 01:49:03.537 25.619 kbps 01:48:59.199 103.379 bytes 428.951 bytes 01:54:23.439 14 1:55:06.691 0:05:25.450 18.918 kbps 29.404 kbps 01:55:21.456 25.262 kbps 01:55:20.705 24.384 kbps 01:55:19.495 98.629 bytes 281.692 bytes 01:57:36.299 15 2:00:32.141 0:04:16.339 19.837 kbps 33.706 kbps 02:01:23.484 30.163 kbps 02:01:21.315 28.636 kbps 02:01:22.733 103.423 bytes 375.196 bytes 02:04:38.929 16 2:04:48.481 0:01:34.469 15.358 kbps 27.444 kbps 02:05:08.667 23.140 kbps 02:05:07.208 21.692 kbps 02:05:32.566 80.067 bytes 286.979 bytes 02:05:08.709 17 2:06:22.950 0:18:47.292 20.853 kbps 47.881 kbps 02:07:19.632 36.464 kbps 02:07:15.836 34.772 kbps 02:07:12.583 108.717 bytes 442.912 bytes 02:06:50.102 18 2:25:10.243 0:07:36.581 19.020 kbps 34.684 kbps 02:31:30.039 27.798 kbps 02:31:26.035 26.073 kbps 02:31:25.075 99.164 bytes 446.471 bytes 02:30:18.300 19 2:32:46.824 0:07:51.804 19.995 kbps 41.737 kbps 02:38:30.459 31.408 kbps 02:38:42.763 30.926 kbps 02:38:40.719 104.247 bytes 493.050 bytes 02:38:40.761 20 2:40:38.629 0:11:24.517 28.876 kbps 47.865 kbps 02:45:20.994 37.800 kbps 02:51:50.425 35.641 kbps 02:46:46.746 150.547 bytes 540.153 bytes 02:40:46.595 21 2:52:03.146 0:05:07.098 18.860 kbps 33.094 kbps 02:57:08.117 23.719 kbps 02:54:53.399 23.065 kbps 02:54:50.855 98.326 bytes 275.083 bytes 02:54:53.691 22 2:57:10.244 0:13:18.172 21.536 kbps 41.121 kbps 03:01:35.259 36.875 kbps 03:01:35.259 35.635 kbps 03:01:28.252 112.277 bytes 432.405 bytes 03:01:35.301 23 3:10:28.417 0:14:35.499 16.811 kbps 39.611 kbps 03:15:07.696 32.896 kbps 03:14:41.961 26.874 kbps 03:17:58.700 87.644 bytes 399.954 bytes 03:15:08.154 24 3:25:03.916 0:08:08.738 18.622 kbps 28.814 kbps 03:25:19.515 26.075 kbps 03:30:12.141 25.699 kbps 03:30:08.637 97.097 bytes 399.680 bytes 03:30:33.579 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00003.M2TS 4113 (0x1011) 0xEA VC-1 12792,530 20.484 32.755.294.968 178.202.867 00003.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 12792,530 2.027 3.240.600.808 19.601.788 00003.M2TS 4353 (0x1101) 0x82 DTS eng (English) 12792,530 1.509 2.413.015.744 14.391.744 00003.M2TS 4608 (0x1200) 0x90 PGS fra (French) 12792,530 29 45.672.287 264.144
DISC INFO: Disc Title: ALEXANDRE_V_CINEMA Disc Size: 27.741.555.666 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00002.MPLS Length: 2:55:25 (h:m:s) Size: 27.188.269.056 bytes Total Bitrate: 20,66 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 14996 kbps 1080p / 23,976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 2142 kbps 5.1 / 48 kHz / 2142 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) DTS-HD Master Audio French 2096 kbps 5.1 / 48 kHz / 2096 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics French 27,588 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00015.M2TS 0:00:00.000 2:55:25.348 27.188.269.056 20.665 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:06:58.876 13.099 kbps 27.904 kbps 00:04:20.593 18.378 kbps 00:00:07.424 17.473 kbps 00:06:05.448 68.286 bytes 332.824 bytes 00:06:48.032 2 0:06:58.876 0:10:11.944 13.583 kbps 25.390 kbps 00:13:55.960 21.965 kbps 00:14:20.150 18.883 kbps 00:14:14.812 70.814 bytes 451.668 bytes 00:13:56.001 3 0:17:10.821 0:08:58.621 13.322 kbps 28.781 kbps 00:20:53.919 23.810 kbps 00:20:53.794 19.878 kbps 00:20:53.752 69.453 bytes 373.153 bytes 00:20:37.486 4 0:26:09.442 0:11:25.893 13.353 kbps 24.599 kbps 00:26:14.864 20.084 kbps 00:36:52.168 19.304 kbps 00:36:52.251 69.617 bytes 365.365 bytes 00:36:53.461 5 0:37:35.336 0:07:17.270 12.176 kbps 26.874 kbps 00:40:23.045 18.030 kbps 00:40:02.233 16.432 kbps 00:37:52.186 63.482 bytes 346.371 bytes 00:38:01.570 6 0:44:52.606 0:12:12.857 16.748 kbps 33.795 kbps 00:47:48.615 24.991 kbps 00:46:16.315 22.692 kbps 00:46:04.344 87.318 bytes 502.436 bytes 00:48:35.579 7 0:57:05.463 0:07:01.712 14.901 kbps 26.505 kbps 00:59:14.425 20.151 kbps 00:59:14.342 18.799 kbps 00:59:12.966 77.688 bytes 313.524 bytes 00:58:26.336 8 1:04:07.176 0:10:45.436 15.805 kbps 34.169 kbps 01:05:58.913 24.424 kbps 01:04:56.601 23.277 kbps 01:05:27.048 82.402 bytes 376.416 bytes 01:09:13.149 9 1:14:52.613 0:06:45.113 12.999 kbps 29.608 kbps 01:21:10.240 20.736 kbps 01:19:38.482 19.790 kbps 01:19:38.648 67.770 bytes 354.856 bytes 01:19:39.858 10 1:21:37.726 0:08:03.191 14.834 kbps 27.413 kbps 01:21:41.730 20.658 kbps 01:29:08.343 19.229 kbps 01:27:43.758 77.336 bytes 369.693 bytes 01:29:23.649 11 1:29:40.917 0:08:08.237 11.474 kbps 29.979 kbps 01:30:15.785 16.908 kbps 01:31:58.596 14.353 kbps 01:32:24.830 59.822 bytes 400.480 bytes 01:37:49.154 12 1:37:49.154 0:03:54.359 13.007 kbps 29.156 kbps 01:40:56.133 19.726 kbps 01:39:38.722 17.356 kbps 01:39:33.759 67.813 bytes 368.776 bytes 01:40:56.175 13 1:41:43.514 0:06:45.029 17.987 kbps 32.087 kbps 01:41:44.306 25.954 kbps 01:46:32.260 24.373 kbps 01:46:20.791 93.776 bytes 504.442 bytes 01:42:15.420 14 1:48:28.543 0:08:36.557 17.182 kbps 27.711 kbps 01:56:51.629 22.310 kbps 01:55:50.401 20.680 kbps 01:55:49.901 89.581 bytes 315.037 bytes 01:49:41.491 15 1:57:05.101 0:01:36.554 16.762 kbps 26.858 kbps 01:58:18.007 22.902 kbps 01:58:16.756 19.937 kbps 01:57:30.126 87.391 bytes 266.289 bytes 01:57:44.182 16 1:58:41.656 0:19:19.199 17.007 kbps 33.918 kbps 02:10:28.320 26.006 kbps 02:16:00.652 24.737 kbps 02:16:55.665 88.666 bytes 405.132 bytes 02:18:00.855 17 2:18:00.855 0:10:40.056 19.985 kbps 35.387 kbps 02:22:42.554 26.021 kbps 02:19:31.821 24.961 kbps 02:19:26.900 104.192 bytes 413.290 bytes 02:24:46.427 18 2:28:40.912 0:09:07.338 16.577 kbps 33.100 kbps 02:30:41.615 25.809 kbps 02:31:25.242 22.807 kbps 02:31:24.325 86.422 bytes 503.821 bytes 02:31:15.274 19 2:37:48.250 0:09:35.324 14.466 kbps 34.774 kbps 02:40:37.836 25.722 kbps 02:40:37.836 21.246 kbps 02:42:09.720 75.418 bytes 436.428 bytes 02:38:21.283 20 2:47:23.575 0:08:01.772 10.090 kbps 31.306 kbps 02:55:21.427 26.178 kbps 02:51:13.554 24.291 kbps 02:51:08.841 52.655 bytes 364.144 bytes 02:55:21.761 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00015.M2TS 4113 (0x1011) 0xEA VC-1 10525,223 14.997 19.730.313.683 107.382.553 00015.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 10525,223 2.142 2.818.737.872 17.000.974 00015.M2TS 4353 (0x1101) 0x86 DTS-HD MA fra (French) 10525,223 2.097 2.758.278.928 16.658.926 00015.M2TS 4608 (0x1200) 0x90 PGS fra (French) 10525,223 28 36.296.463 210.490
Total Video
[US] The Rundown VC-1 1:44:14 19,415,924,736 23,482,222,361 24.84 17.02 DTS-HD Master 5.1 4268Kbps (48kHz/24-bit)
DISC INFO: Disc Title: THE_RUNDOWN Disc Size: 23,482,222,361 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00000.MPLS Length: 1:44:14 (h:m:s) Size: 19,415,924,736 bytes Total Bitrate: 24.84 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 17015 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4268 kbps 5.1 / 48 kHz / 4268 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS Audio Spanish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit DTS Audio French 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 35.288 kbps Presentation Graphics Spanish 29.330 kbps Presentation Graphics French 30.438 kbps Presentation Graphics Spanish 0.455 kbps Presentation Graphics French 0.407 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00010.M2TS 0:00:00.000 1:44:14.248 19,415,924,736 24,836 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:08:58.996 20,714 kbps 37,686 kbps 00:06:20.088 30,199 kbps 00:06:17.001 27,689 kbps 00:06:13.790 108,412 bytes 351,849 bytes 00:01:58.451 2 0:08:58.996 0:02:32.819 19,608 kbps 25,409 kbps 00:10:20.119 24,725 kbps 00:10:18.451 23,172 kbps 00:10:18.284 102,229 bytes 228,770 bytes 00:09:05.670 3 0:11:31.816 0:03:02.056 19,714 kbps 44,778 kbps 00:14:14.478 34,434 kbps 00:14:13.519 29,640 kbps 00:14:09.682 102,777 bytes 486,326 bytes 00:14:27.157 4 0:14:33.873 0:01:55.240 19,990 kbps 24,121 kbps 00:15:40.189 22,997 kbps 00:14:38.168 22,373 kbps 00:14:33.873 104,219 bytes 300,135 bytes 00:16:29.113 5 0:16:29.113 0:04:19.842 16,645 kbps 38,838 kbps 00:17:36.055 23,845 kbps 00:17:34.219 21,116 kbps 00:17:34.178 86,777 bytes 321,064 bytes 00:17:36.638 6 0:20:48.956 0:06:07.742 20,141 kbps 27,600 kbps 00:25:51.007 26,065 kbps 00:25:47.003 25,150 kbps 00:25:43.083 105,006 bytes 255,277 bytes 00:20:54.336 7 0:26:56.698 0:02:21.182 25,347 kbps 44,415 kbps 00:28:39.008 36,299 kbps 00:28:52.897 33,910 kbps 00:28:32.544 132,148 bytes 479,155 bytes 00:27:39.824 8 0:29:17.881 0:02:39.951 16,774 kbps 24,987 kbps 00:30:54.727 22,169 kbps 00:30:53.977 20,248 kbps 00:30:48.972 87,452 bytes 337,351 bytes 00:30:42.215 9 0:31:57.832 0:01:49.025 17,527 kbps 25,240 kbps 00:32:51.135 22,791 kbps 00:32:05.715 21,868 kbps 00:31:59.709 91,376 bytes 262,496 bytes 00:31:59.834 10 0:33:46.858 0:02:43.121 17,273 kbps 31,984 kbps 00:34:30.151 28,309 kbps 00:34:28.107 24,425 kbps 00:34:28.107 90,053 bytes 353,722 bytes 00:36:29.979 11 0:36:29.979 0:02:18.346 12,034 kbps 18,081 kbps 00:37:41.926 16,650 kbps 00:37:39.548 15,466 kbps 00:37:34.835 62,739 bytes 261,140 bytes 00:36:30.980 12 0:38:48.326 0:03:28.708 16,083 kbps 29,054 kbps 00:42:08.317 27,193 kbps 00:42:06.315 24,757 kbps 00:42:03.771 83,851 bytes 404,588 bytes 00:41:38.120 13 0:42:17.034 0:06:18.086 18,129 kbps 41,137 kbps 00:46:35.918 26,100 kbps 00:46:51.391 24,409 kbps 00:47:40.357 94,517 bytes 444,022 bytes 00:46:35.959 14 0:48:35.120 0:03:31.836 17,444 kbps 23,231 kbps 00:49:23.835 20,178 kbps 00:49:21.249 19,412 kbps 00:49:04.024 90,945 bytes 201,320 bytes 00:49:09.738 15 0:52:06.957 0:02:16.010 18,232 kbps 31,839 kbps 00:53:02.012 28,409 kbps 00:52:57.966 25,658 kbps 00:52:53.044 95,055 bytes 278,023 bytes 00:52:35.402 16 0:54:22.968 0:04:20.009 15,353 kbps 39,768 kbps 00:54:43.613 31,799 kbps 00:54:42.821 22,542 kbps 00:56:58.164 80,122 bytes 355,705 bytes 00:54:44.906 17 0:58:42.977 0:06:47.323 16,771 kbps 37,763 kbps 01:00:34.339 36,735 kbps 01:00:30.418 31,550 kbps 01:00:30.418 87,703 bytes 395,242 bytes 01:00:32.462 18 1:05:30.301 0:03:43.181 13,690 kbps 28,051 kbps 01:09:06.475 25,098 kbps 01:09:05.474 23,018 kbps 01:09:03.472 71,428 bytes 324,019 bytes 01:08:55.589 19 1:09:13.482 0:01:22.582 11,840 kbps 25,095 kbps 01:09:59.695 17,847 kbps 01:09:28.247 15,168 kbps 01:09:28.080 61,727 bytes 281,428 bytes 01:10:30.184 20 1:10:36.065 0:04:08.623 14,491 kbps 23,565 kbps 01:14:19.746 20,297 kbps 01:10:45.241 19,687 kbps 01:10:42.529 75,551 bytes 457,582 bytes 01:14:44.688 21 1:14:44.688 0:01:30.632 15,387 kbps 23,144 kbps 01:14:46.315 19,837 kbps 01:15:39.284 19,062 kbps 01:15:32.903 80,222 bytes 279,381 bytes 01:15:24.895 22 1:16:15.320 0:05:30.997 19,759 kbps 44,876 kbps 01:19:57.417 26,977 kbps 01:20:25.821 24,956 kbps 01:20:12.015 103,016 bytes 465,262 bytes 01:17:41.698 23 1:21:46.318 0:05:23.740 20,976 kbps 47,036 kbps 01:22:09.633 27,143 kbps 01:23:36.553 24,473 kbps 01:24:08.710 109,359 bytes 369,277 bytes 01:22:09.966 24 1:27:10.058 0:03:08.021 19,081 kbps 29,776 kbps 01:29:05.214 24,334 kbps 01:27:23.279 23,425 kbps 01:29:16.559 99,479 bytes 279,579 bytes 01:29:49.342 25 1:30:18.079 0:02:31.317 17,188 kbps 28,529 kbps 01:32:34.257 26,498 kbps 01:32:33.130 24,594 kbps 01:32:30.878 89,609 bytes 281,470 bytes 01:32:34.549 26 1:32:49.397 0:02:59.762 17,898 kbps 25,828 kbps 01:33:04.829 21,158 kbps 01:33:01.951 20,471 kbps 01:33:04.161 93,312 bytes 339,490 bytes 01:35:49.160 27 1:35:49.160 0:01:29.964 17,734 kbps 23,028 kbps 01:36:34.371 20,572 kbps 01:35:58.627 20,391 kbps 01:35:53.706 92,457 bytes 286,659 bytes 01:35:57.168 28 1:37:19.124 0:06:55.123 3,386 kbps 16,931 kbps 01:44:07.824 15,412 kbps 01:44:07.824 9,161 kbps 01:44:03.237 17,995 bytes 345,151 bytes 01:44:07.866 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00010.M2TS 4113 (0x1011) 0xEA VC-1 6254.123 17,016 13,302,308,334 72,385,744 00010.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 6254.123 4,268 3,336,526,504 19,108,333 00010.M2TS 4353 (0x1101) 0x82 DTS spa (Spanish) 6254.123 768 600,408,064 3,518,016 00010.M2TS 4354 (0x1102) 0x82 DTS fra (French) 6254.123 768 600,408,064 3,518,016 00010.M2TS 4355 (0x1103) 0x81 AC3 eng (English) 6254.123 192 150,102,528 977,230 00010.M2TS 4356 (0x1104) 0x81 AC3 eng (English) 6254.123 192 150,102,528 977,230 00010.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6254.123 35 27,587,828 158,926 00010.M2TS 4609 (0x1201) 0x90 PGS spa (Spanish) 6254.123 29 22,929,755 131,522 00010.M2TS 4610 (0x1202) 0x90 PGS fra (French) 6254.123 30 23,795,467 136,221 00010.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 6254.123 0 355,620 2,012 00010.M2TS 4612 (0x1204) 0x90 PGS fra (French) 6254.123 0 317,994 1,799
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
[US] Bad Lieutenant AVC 1:36:13 16,446,959,616 18,945,839,323 22.79 19.49 DTS-HD Master 2.0 1728Kbps (48kHz/16-bit)
DISC INFO: Disc Title: BAD_LIEUTENANT Disc Size: 18,945,839,323 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00004.MPLS Length: 1:36:13 (h:m:s) Size: 16,446,959,616 bytes Total Bitrate: 22.79 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 19490 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 1728 kbps 2.0 / 48 kHz / 1728 kbps / 16-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 16-bit) Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 34.823 kbps Presentation Graphics English 39.128 kbps Presentation Graphics Spanish 29.263 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00323.M2TS 0:00:00.000 1:36:13.601 16,446,959,616 22,789 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:06:34.185 18,825 kbps 27,629 kbps 00:05:43.134 26,104 kbps 00:03:36.799 25,892 kbps 00:01:51.861 98,136 bytes 355,717 bytes 00:01:47.899 2 0:06:34.185 0:08:20.291 23,725 kbps 34,643 kbps 00:08:17.747 33,651 kbps 00:08:15.369 33,070 kbps 00:08:12.492 123,689 bytes 316,376 bytes 00:14:12.351 3 0:14:54.476 0:06:54.622 23,089 kbps 38,084 kbps 00:20:09.291 36,957 kbps 00:20:08.790 35,679 kbps 00:20:07.372 120,376 bytes 281,529 bytes 00:20:12.127 4 0:21:49.099 0:05:20.862 19,896 kbps 30,910 kbps 00:26:19.744 29,913 kbps 00:25:58.390 29,661 kbps 00:26:15.991 103,727 bytes 239,051 bytes 00:26:01.393 5 0:27:09.961 0:08:14.869 13,778 kbps 21,312 kbps 00:27:40.367 20,637 kbps 00:27:39.074 20,008 kbps 00:27:34.903 71,833 bytes 193,384 bytes 00:27:36.446 6 0:35:24.831 0:04:22.345 19,468 kbps 29,202 kbps 00:39:45.841 28,700 kbps 00:39:39.960 28,497 kbps 00:39:36.582 101,497 bytes 274,084 bytes 00:38:16.836 7 0:39:47.176 0:03:23.119 17,582 kbps 24,460 kbps 00:41:45.753 23,302 kbps 00:41:42.124 22,539 kbps 00:41:38.120 91,663 bytes 216,156 bytes 00:41:40.164 8 0:43:10.296 0:08:23.169 21,313 kbps 30,047 kbps 00:46:03.260 29,612 kbps 00:46:01.967 29,410 kbps 00:46:01.967 111,114 bytes 249,299 bytes 00:43:26.395 9 0:51:33.465 0:06:18.544 19,225 kbps 24,777 kbps 00:51:42.557 23,706 kbps 00:51:39.221 23,475 kbps 00:51:36.968 100,232 bytes 224,489 bytes 00:57:52.010 10 0:57:52.010 0:03:12.192 18,959 kbps 25,612 kbps 00:58:01.644 24,921 kbps 00:57:58.850 24,486 kbps 00:57:56.097 98,842 bytes 233,476 bytes 00:57:54.762 11 1:01:04.202 0:04:44.867 18,602 kbps 27,380 kbps 01:03:05.656 26,657 kbps 01:03:02.987 25,864 kbps 01:02:57.857 96,985 bytes 189,584 bytes 01:03:04.697 12 1:05:49.070 0:04:47.537 22,155 kbps 28,100 kbps 01:10:24.053 26,705 kbps 01:10:20.257 24,412 kbps 01:10:15.252 115,505 bytes 235,343 bytes 01:10:26.013 13 1:10:36.607 0:05:19.902 18,414 kbps 20,744 kbps 01:11:25.531 20,499 kbps 01:11:52.933 20,370 kbps 01:11:22.319 96,002 bytes 168,407 bytes 01:11:35.708 14 1:15:56.510 0:04:17.548 19,230 kbps 23,532 kbps 01:20:04.549 22,243 kbps 01:20:02.589 21,264 kbps 01:20:02.422 100,256 bytes 196,264 bytes 01:20:14.059 15 1:20:14.059 0:05:02.677 17,539 kbps 26,851 kbps 01:20:14.059 26,004 kbps 01:20:49.052 25,821 kbps 01:20:43.797 91,439 bytes 223,371 bytes 01:25:16.736 16 1:25:16.736 0:10:56.864 18,755 kbps 27,784 kbps 01:28:12.328 25,665 kbps 01:25:27.080 25,300 kbps 01:25:22.617 97,786 bytes 270,274 bytes 01:31:19.474 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00323.M2TS 4113 (0x1011) 0x1B AVC 5773.434 19,491 14,066,242,649 76,527,622 00323.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5773.434 1,728 1,247,262,576 7,610,651 00323.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 5773.434 192 138,565,632 902,120 00323.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5773.434 35 25,131,886 143,575 00323.M2TS 4609 (0x1201) 0x90 PGS eng (English) 5773.434 39 28,239,004 161,000 00323.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 5773.434 29 21,119,271 122,818
Total Video
[US] 2001 Maniacs AVC 1:27:46 17,948,774,400 21,953,874,782 27.27 21.00 DTS-HD Master 5.1 4167Kbps (48kHz/24-bit)
DISC INFO: Disc Title: 2001_MANIACS Disc Size: 21,953,874,782 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00800.MPLS Length: 1:27:46 (h:m:s) Size: 17,948,774,400 bytes Total Bitrate: 27.27 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 21000 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4167 kbps 5.1 / 48 kHz / 4167 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 256 kbps 2.0 / 48 kHz / 256 kbps / DN -4dB Dolby Digital Audio English 256 kbps 2.0 / 48 kHz / 256 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 34.116 kbps Presentation Graphics English 40.316 kbps Presentation Graphics Spanish 31.910 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00004.M2TS 0:00:00.000 1:27:46.261 17,948,774,400 27,266 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:06:05.698 19,109 kbps 41,123 kbps 00:01:17.994 38,287 kbps 00:01:30.298 34,465 kbps 00:01:30.298 99,614 bytes 441,123 bytes 00:00:58.224 2 0:06:05.698 0:04:54.252 20,462 kbps 36,353 kbps 00:06:44.862 33,833 kbps 00:06:41.401 30,834 kbps 00:07:39.208 106,678 bytes 421,598 bytes 00:06:39.982 3 0:10:59.950 0:08:50.154 24,879 kbps 40,297 kbps 00:12:31.959 38,124 kbps 00:12:41.051 36,218 kbps 00:18:40.536 129,706 bytes 528,304 bytes 00:12:36.922 4 0:19:50.105 0:07:18.646 23,544 kbps 39,185 kbps 00:23:12.891 38,737 kbps 00:23:12.891 38,147 kbps 00:23:11.848 122,748 bytes 429,415 bytes 00:19:50.772 5 0:27:08.752 0:05:43.384 21,923 kbps 39,009 kbps 00:28:29.499 30,717 kbps 00:32:31.491 30,280 kbps 00:32:29.238 114,296 bytes 284,154 bytes 00:28:30.166 6 0:32:52.136 0:04:20.343 22,131 kbps 35,157 kbps 00:34:15.261 32,486 kbps 00:33:08.611 30,017 kbps 00:33:48.609 115,379 bytes 290,425 bytes 00:34:45.082 7 0:37:12.480 0:07:48.968 22,337 kbps 33,693 kbps 00:41:34.700 32,091 kbps 00:41:34.408 30,791 kbps 00:41:33.574 116,452 bytes 446,201 bytes 00:40:08.948 8 0:45:01.448 0:05:06.097 21,204 kbps 30,361 kbps 00:46:17.524 28,763 kbps 00:46:15.522 27,505 kbps 00:47:45.487 110,548 bytes 470,610 bytes 00:47:45.571 9 0:50:07.546 0:05:37.670 23,173 kbps 33,377 kbps 00:53:58.318 28,995 kbps 00:55:03.675 27,846 kbps 00:54:58.003 120,814 bytes 378,735 bytes 00:53:59.194 10 0:55:45.216 0:06:37.897 19,770 kbps 33,181 kbps 00:56:30.428 28,980 kbps 00:56:29.427 28,289 kbps 00:58:48.274 103,074 bytes 388,300 bytes 00:57:37.704 11 1:02:23.114 0:05:43.176 20,000 kbps 36,233 kbps 01:02:24.031 31,931 kbps 01:02:23.448 28,329 kbps 01:02:23.197 104,270 bytes 473,914 bytes 01:04:53.723 12 1:08:06.290 0:11:06.624 19,945 kbps 34,008 kbps 01:15:00.078 29,791 kbps 01:14:57.534 27,167 kbps 01:14:57.534 103,984 bytes 336,119 bytes 01:16:15.862 13 1:19:12.914 0:05:09.309 23,140 kbps 40,128 kbps 01:20:31.451 37,403 kbps 01:22:30.904 32,567 kbps 01:22:27.442 120,641 bytes 465,472 bytes 01:20:20.941 14 1:24:22.223 0:03:24.037 3,922 kbps 4,764 kbps 01:24:31.107 4,204 kbps 01:24:31.107 4,103 kbps 01:24:31.107 20,450 bytes 203,318 bytes 01:27:46.219 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00004.M2TS 4113 (0x1011) 0x1B AVC 5266.094 21,000 13,823,715,440 75,202,472 00004.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 5266.094 4,167 2,743,093,920 15,728,653 00004.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 5266.094 256 168,520,704 987,426 00004.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 5266.094 256 168,520,704 987,426 00004.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5266.094 34 22,457,728 128,364 00004.M2TS 4609 (0x1201) 0x90 PGS eng (English) 5266.094 40 26,539,349 151,935 00004.M2TS 4610 (0x1202) 0x90 PGS spa (Spanish) 5266.094 32 21,005,968 120,484
Total Video
The Valley: Original Ending AVC 1:45:28 28,383,498,240 39,197,453,428 35.88 31.95 LPCM 2.0 2304Kbps (48kHz/24-bit)
Restored Ending AVC 1:45:28 28,382,939,136 39,197,453,428 35.88 31.95 LPCM 2.0 2304Kbps (48kHz/24-bit)
DISC INFO: Disc Title: THE_VALLEY Disc Size: 39,197,453,428 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00000.MPLS Length: 1:45:28 (h:m:s) Size: 28,383,498,240 bytes Total Bitrate: 35.88 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 31947 kbps 1080p / 24 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio French 2304 kbps 2.0 / 48 kHz / 2304 kbps / 24-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 12.909 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:39:55.416 26,931,898,368 35,937 00002.M2TS 1:39:55.416 0:05:32.916 1,451,599,872 34,882 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:02:45.500 26,220 kbps 36,147 kbps 00:01:49.958 34,108 kbps 00:01:48.625 33,116 kbps 00:01:47.958 136,530 bytes 378,590 bytes 00:01:42.000 2 0:02:45.500 0:05:58.000 30,628 kbps 44,711 kbps 00:07:53.333 43,059 kbps 00:07:50.583 39,675 kbps 00:07:48.958 159,521 bytes 338,249 bytes 00:02:48.500 3 0:08:43.500 0:13:07.958 30,227 kbps 43,922 kbps 00:21:16.750 40,320 kbps 00:21:13.750 38,974 kbps 00:21:08.750 157,431 bytes 357,271 bytes 00:09:45.500 4 0:21:51.458 0:07:55.708 33,991 kbps 44,561 kbps 00:27:08.541 42,384 kbps 00:25:11.416 40,491 kbps 00:27:08.541 177,034 bytes 333,471 bytes 00:23:28.041 5 0:29:47.166 0:10:40.875 32,869 kbps 46,725 kbps 00:38:57.625 42,291 kbps 00:38:54.833 39,476 kbps 00:35:23.333 171,193 bytes 366,443 bytes 00:40:28.041 6 0:40:28.041 0:07:25.583 30,138 kbps 39,012 kbps 00:40:57.250 37,044 kbps 00:47:06.875 36,210 kbps 00:47:03.166 156,967 bytes 376,497 bytes 00:41:20.041 7 0:47:53.625 0:11:21.083 33,678 kbps 47,863 kbps 00:53:32.375 42,238 kbps 00:53:29.208 39,847 kbps 00:53:24.958 175,404 bytes 358,970 bytes 00:55:52.166 8 0:59:14.708 0:09:11.083 30,875 kbps 46,852 kbps 01:08:06.208 44,179 kbps 01:08:06.208 40,453 kbps 01:08:05.333 160,805 bytes 349,521 bytes 00:59:22.125 9 1:08:25.791 0:08:28.458 33,398 kbps 49,990 kbps 01:16:06.791 42,069 kbps 01:16:05.791 39,653 kbps 01:11:03.125 173,946 bytes 369,373 bytes 01:16:07.416 10 1:16:54.250 0:10:00.000 34,054 kbps 47,711 kbps 01:17:21.583 42,263 kbps 01:21:55.416 40,381 kbps 01:21:55.291 177,367 bytes 343,087 bytes 01:23:20.000 11 1:26:54.250 0:09:17.833 32,358 kbps 44,359 kbps 01:26:59.958 41,101 kbps 01:36:03.916 38,721 kbps 01:33:32.208 168,531 bytes 366,745 bytes 01:34:02.458 12 1:36:12.083 0:09:16.250 30,509 kbps 47,906 kbps 01:40:18.375 44,344 kbps 01:40:16.791 40,895 kbps 01:40:16.791 158,912 bytes 389,511 bytes 01:38:40.416 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 5995.292 32,000 23,981,393,567 130,417,886 00000.M2TS 4352 (0x1100) 0x80 LPCM fra (French) 5995.292 2,310 1,731,477,296 9,592,672 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5995.292 13 10,019,352 58,902 00002.M2TS 4113 (0x1011) 0x1B AVC 332.833 31,008 1,290,061,605 7,015,455 00002.M2TS 4352 (0x1100) 0x80 LPCM fra (French) 332.833 2,311 96,147,296 532,672 00002.M2TS 4608 (0x1200) 0x90 PGS eng (English) 332.833 5 191,981 1,154
DISC INFO: Disc Title: THE_VALLEY Disc Size: 39,197,453,428 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00001.MPLS Length: 1:45:28 (h:m:s) Size: 28,382,939,136 bytes Total Bitrate: 35.88 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 31946 kbps 1080p / 24 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio French 2304 kbps 2.0 / 48 kHz / 2304 kbps / 24-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 12.909 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:39:55.416 26,931,898,368 35,937 00001.M2TS 1:39:55.416 0:05:32.916 1,451,040,768 34,869 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:02:45.500 26,220 kbps 36,147 kbps 00:01:49.958 34,108 kbps 00:01:48.625 33,116 kbps 00:01:47.958 136,530 bytes 378,590 bytes 00:01:42.000 2 0:02:45.500 0:05:58.000 30,628 kbps 44,711 kbps 00:07:53.333 43,059 kbps 00:07:50.583 39,675 kbps 00:07:48.958 159,521 bytes 338,249 bytes 00:02:48.500 3 0:08:43.500 0:13:07.958 30,227 kbps 43,922 kbps 00:21:16.750 40,320 kbps 00:21:13.750 38,974 kbps 00:21:08.750 157,431 bytes 357,271 bytes 00:09:45.500 4 0:21:51.458 0:07:55.708 33,991 kbps 44,561 kbps 00:27:08.541 42,384 kbps 00:25:11.416 40,491 kbps 00:27:08.541 177,034 bytes 333,471 bytes 00:23:28.041 5 0:29:47.166 0:10:40.875 32,869 kbps 46,725 kbps 00:38:57.625 42,291 kbps 00:38:54.833 39,476 kbps 00:35:23.333 171,193 bytes 366,443 bytes 00:40:28.041 6 0:40:28.041 0:07:25.583 30,138 kbps 39,012 kbps 00:40:57.250 37,044 kbps 00:47:06.875 36,210 kbps 00:47:03.166 156,967 bytes 376,497 bytes 00:41:20.041 7 0:47:53.625 0:11:21.083 33,678 kbps 47,863 kbps 00:53:32.375 42,238 kbps 00:53:29.208 39,847 kbps 00:53:24.958 175,404 bytes 358,970 bytes 00:55:52.166 8 0:59:14.708 0:09:11.083 30,875 kbps 46,852 kbps 01:08:06.208 44,179 kbps 01:08:06.208 40,453 kbps 01:08:05.333 160,805 bytes 349,521 bytes 00:59:22.125 9 1:08:25.791 0:08:28.458 33,398 kbps 49,990 kbps 01:16:06.791 42,069 kbps 01:16:05.791 39,653 kbps 01:11:03.125 173,946 bytes 369,373 bytes 01:16:07.416 10 1:16:54.250 0:10:00.000 34,054 kbps 47,711 kbps 01:17:21.583 42,263 kbps 01:21:55.416 40,381 kbps 01:21:55.291 177,367 bytes 343,087 bytes 01:23:20.000 11 1:26:54.250 0:09:17.833 32,358 kbps 44,359 kbps 01:26:59.958 41,101 kbps 01:36:03.916 38,721 kbps 01:33:32.208 168,531 bytes 366,745 bytes 01:34:02.458 12 1:36:12.083 0:09:16.250 30,501 kbps 47,906 kbps 01:40:18.375 44,348 kbps 01:40:16.791 40,823 kbps 01:40:16.791 158,870 bytes 389,511 bytes 01:38:40.416 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 5995.292 32,000 23,981,393,567 130,417,886 00000.M2TS 4352 (0x1100) 0x80 LPCM fra (French) 5995.292 2,310 1,731,477,296 9,592,672 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5995.292 13 10,019,352 58,902 00001.M2TS 4113 (0x1011) 0x1B AVC 332.833 30,995 1,289,510,137 7,012,542 00001.M2TS 4352 (0x1100) 0x80 LPCM fra (French) 332.833 2,311 96,147,296 532,672 00001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 332.833 5 191,981 1,154
Total Video
00637.MPLS AVC 1:30:11 34,331,811,840 41,866,589,257 50.76 27.00 DD AC3 5.1 640Kbps
DISC INFO: Disc Title: SAWFINALCHAPTER Disc Size: 41,866,589,257 bytes Protection: AACS BD-Java: Yes Extras: Blu-ray 3D BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00637.MPLS Length: 1:30:11 (h:m:s) Size: 34,331,811,840 bytes Total Bitrate: 50.76 Mbps (*) Indicates included stream hidden by this playlist. VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 26998 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 MPEG-4 MVC Video 14004 kbps AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- * Dolby Digital Audio French 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround DTS-HD Master Audio English 5550 kbps 7.1 / 48 kHz / 5550 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 29.570 kbps Presentation Graphics English 33.648 kbps * Presentation Graphics Spanish 27.891 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00416.SSIF 0:00:00.000 1:30:11.239 34,331,811,840 50,756 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:05:13.479 25,188 kbps 33,450 kbps 00:00:43.752 30,096 kbps 00:05:04.429 29,978 kbps 00:04:59.382 131,300 bytes 385,474 bytes 00:04:39.779 2 0:05:13.479 0:07:45.173 28,127 kbps 31,883 kbps 00:10:15.156 30,141 kbps 00:10:11.152 29,970 kbps 00:08:59.914 146,641 bytes 372,942 bytes 00:07:45.214 3 0:12:58.652 0:04:18.132 29,120 kbps 32,877 kbps 00:12:59.028 30,178 kbps 00:15:35.517 30,005 kbps 00:13:48.369 151,818 bytes 392,927 bytes 00:13:58.337 4 0:17:16.785 0:04:50.957 28,497 kbps 34,808 kbps 00:17:49.234 30,339 kbps 00:17:45.230 29,960 kbps 00:21:12.854 148,571 bytes 368,846 bytes 00:19:24.955 5 0:22:07.743 0:05:21.487 24,813 kbps 33,685 kbps 00:23:07.511 30,478 kbps 00:23:03.465 29,656 kbps 00:22:58.502 129,366 bytes 315,065 bytes 00:24:52.949 6 0:27:29.230 0:08:37.725 28,875 kbps 33,198 kbps 00:32:13.473 30,644 kbps 00:32:09.469 30,034 kbps 00:32:46.756 150,540 bytes 399,875 bytes 00:29:19.924 7 0:36:06.956 0:06:57.250 25,691 kbps 34,579 kbps 00:37:33.584 30,799 kbps 00:37:29.580 29,886 kbps 00:42:50.568 133,942 bytes 355,346 bytes 00:42:39.014 8 0:43:04.206 0:04:50.206 25,816 kbps 31,941 kbps 00:46:13.020 30,201 kbps 00:44:19.698 29,991 kbps 00:45:44.950 134,590 bytes 413,979 bytes 00:46:14.021 9 0:47:54.413 0:04:06.412 29,127 kbps 31,331 kbps 00:51:31.379 30,118 kbps 00:50:53.050 29,951 kbps 00:48:38.165 151,853 bytes 338,938 bytes 00:51:23.830 10 0:52:00.826 0:05:09.100 28,739 kbps 31,612 kbps 00:53:04.389 30,149 kbps 00:53:54.981 29,987 kbps 00:55:14.352 149,834 bytes 380,670 bytes 00:54:00.695 11 0:57:09.926 0:05:59.150 29,402 kbps 34,033 kbps 01:02:02.176 30,415 kbps 01:01:27.934 30,162 kbps 01:01:22.929 153,289 bytes 391,605 bytes 01:02:41.758 12 1:03:09.076 0:07:19.814 29,219 kbps 34,996 kbps 01:08:49.542 30,734 kbps 01:08:45.538 30,333 kbps 01:08:40.533 152,334 bytes 422,579 bytes 01:07:19.201 13 1:10:28.891 0:03:44.682 29,663 kbps 33,367 kbps 01:12:16.123 30,520 kbps 01:12:12.119 30,188 kbps 01:12:07.114 154,647 bytes 386,366 bytes 01:14:00.644 14 1:14:13.574 0:04:47.578 29,233 kbps 32,284 kbps 01:18:41.091 30,244 kbps 01:15:11.757 29,965 kbps 01:17:08.749 152,405 bytes 383,308 bytes 01:15:49.378 15 1:19:01.153 0:04:46.035 27,975 kbps 35,519 kbps 01:22:53.009 30,420 kbps 01:20:55.308 30,130 kbps 01:20:50.303 145,848 bytes 451,589 bytes 01:22:53.969 16 1:23:47.188 0:06:24.050 14,647 kbps 33,784 kbps 01:24:32.567 30,648 kbps 01:24:28.563 30,301 kbps 01:24:23.558 76,369 bytes 550,799 bytes 01:23:47.230 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00416.SSIF 4114 (0x1012) 0x20 MVC 5411.156 14,004 9,472,205,406 51,566,681 00416.SSIF 4113 (0x1011) 0x1B AVC 5411.156 26,999 18,261,910,925 99,327,502 00416.SSIF 4352 (0x1100) 0x81 AC3 fra (French) 5411.156 640 432,901,120 2,536,530 00416.SSIF 4353 (0x1101) 0x81 AC3 eng (English) 5411.156 224 151,515,392 845,510 00416.SSIF 4354 (0x1102) 0x81 AC3 eng (English) 5411.156 224 151,515,392 845,510 00416.SSIF 4355 (0x1103) 0x86 DTS-HD MA eng (English) 5411.156 5,550 3,754,097,200 21,250,320 00416.SSIF 4608 (0x1200) 0x90 PGS eng (English) 5411.156 30 20,001,463 115,450 00416.SSIF 4609 (0x1201) 0x90 PGS eng (English) 5411.156 34 22,759,716 131,549 00416.SSIF 4610 (0x1202) 0x90 PGS spa (Spanish) 5411.156 28 18,865,548 109,363
Total Video
00000.MPLS AVC 1:51:09 29,742,981,120 32,601,828,686 35.68 28.02 DTS-HD Master 5.1 3999Kbps (48kHz/24-bit)
DISC INFO: Disc Title: RED Disc Size: 32,601,828,686 bytes Protection: AACS BD-Java: No BDInfo: 0.5.7 PLAYLIST REPORT: Name: 00000.MPLS Length: 1:51:09 (h:m:s) Size: 29,742,981,120 bytes Total Bitrate: 35.68 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 28024 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 MPEG-4 AVC Video 1380 kbps 480p / 23.976 fps / 16:9 / High Profile 3.2 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 3999 kbps 5.1 / 48 kHz / 3999 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) Dolby Digital Audio English 192 kbps 2.0 / 48 kHz / 192 kbps DTS Express English 192 kbps 2.0 / 48 kHz / 192 kbps / 24-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 21.309 kbps Presentation Graphics English 8.133 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:51:09.663 29,742,981,120 35,676 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:07:11.264 27,644 kbps 45,378 kbps 00:00:21.980 32,372 kbps 00:00:20.895 30,190 kbps 00:02:03.832 144,107 bytes 630,731 bytes 00:03:47.518 2 0:07:11.264 0:06:52.161 28,016 kbps 39,916 kbps 00:09:34.407 31,982 kbps 00:08:39.519 30,056 kbps 00:10:02.476 146,064 bytes 746,309 bytes 00:10:40.723 3 0:14:03.425 0:06:50.034 28,222 kbps 45,956 kbps 00:15:48.322 31,237 kbps 00:15:44.318 29,783 kbps 00:15:39.313 147,138 bytes 642,942 bytes 00:15:48.739 4 0:20:53.460 0:03:13.109 28,136 kbps 36,965 kbps 00:22:10.454 30,418 kbps 00:21:58.025 29,892 kbps 00:21:52.769 146,688 bytes 627,035 bytes 00:23:19.356 5 0:24:06.570 0:05:03.886 28,125 kbps 42,047 kbps 00:25:10.342 30,539 kbps 00:27:31.232 29,635 kbps 00:27:31.232 146,633 bytes 599,820 bytes 00:25:14.679 6 0:29:10.457 0:06:46.114 28,056 kbps 39,005 kbps 00:31:19.085 30,508 kbps 00:32:05.882 29,625 kbps 00:32:59.227 146,272 bytes 756,436 bytes 00:33:25.420 7 0:35:56.571 0:07:30.116 28,038 kbps 40,189 kbps 00:41:51.884 30,387 kbps 00:42:03.562 29,608 kbps 00:41:38.871 146,176 bytes 559,264 bytes 00:38:43.988 8 0:43:26.687 0:05:45.845 28,217 kbps 43,755 kbps 00:49:11.531 31,233 kbps 00:49:07.527 30,244 kbps 00:44:37.716 147,108 bytes 527,655 bytes 00:49:12.532 9 0:49:12.532 0:06:44.403 28,153 kbps 40,351 kbps 00:51:51.108 30,916 kbps 00:53:22.908 29,766 kbps 00:53:23.033 146,779 bytes 588,772 bytes 00:50:52.340 10 0:55:56.936 0:07:15.184 28,123 kbps 39,637 kbps 00:58:34.135 30,639 kbps 00:57:53.386 29,587 kbps 00:57:48.381 146,618 bytes 557,658 bytes 01:02:00.550 11 1:03:12.121 0:06:29.889 28,078 kbps 37,448 kbps 01:07:29.420 30,434 kbps 01:03:56.165 29,332 kbps 01:03:18.711 146,385 bytes 650,209 bytes 01:06:15.346 12 1:09:42.011 0:05:42.258 27,994 kbps 42,840 kbps 01:14:53.947 30,853 kbps 01:13:30.489 29,462 kbps 01:13:30.489 145,946 bytes 648,222 bytes 01:13:18.352 13 1:15:24.269 0:05:27.910 27,993 kbps 34,672 kbps 01:15:27.522 30,490 kbps 01:15:31.860 29,826 kbps 01:20:26.238 145,943 bytes 593,238 bytes 01:15:43.580 14 1:20:52.180 0:06:21.923 28,081 kbps 40,336 kbps 01:26:06.911 30,729 kbps 01:26:30.310 29,584 kbps 01:26:25.138 146,399 bytes 629,921 bytes 01:24:48.958 15 1:27:14.103 0:05:50.683 27,922 kbps 43,039 kbps 01:31:25.229 31,526 kbps 01:31:21.225 29,922 kbps 01:31:16.554 145,573 bytes 776,826 bytes 01:30:24.252 16 1:33:04.787 0:05:27.118 27,924 kbps 40,041 kbps 01:37:22.920 31,041 kbps 01:37:22.711 30,232 kbps 01:37:26.674 145,584 bytes 771,540 bytes 01:33:26.601 17 1:38:31.906 0:04:44.742 28,114 kbps 37,374 kbps 01:39:03.479 30,276 kbps 01:41:10.856 29,173 kbps 01:41:05.768 146,574 bytes 689,831 bytes 01:39:03.687 18 1:43:16.648 0:07:53.014 27,751 kbps 46,605 kbps 01:45:46.006 31,809 kbps 01:45:19.730 31,041 kbps 01:45:14.641 144,706 bytes 757,576 bytes 01:45:11.013 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 6669.580 28,024 23,363,536,378 127,069,863 00000.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 6669.580 3,999 3,333,979,368 19,159,506 00000.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 6669.580 192 160,120,320 1,042,450 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6669.580 21 17,765,468 106,268 00000.M2TS 4609 (0x1201) 0x90 PGS eng (English) 6669.580 8 6,780,220 37,427 00000.M2TS 6656 (0x1A00) 0xA2 DTS Express eng (English) 6669.580 192 160,120,832 938,208 00000.M2TS 6912 (0x1B00) 0x1B AVC 6669.580 1,380 1,150,749,853 6,334,104
Total Video
00001.MPLS AVC 1:26:26 17.370.765.312 23.014.371.424 26,79 20,95 DTS-HD Master 5.1 1927Kbps (48kHz/16-bit)
DISC INFO: Disc Title: KABOOM Disc Size: 23.014.371.424 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00001.MPLS Length: 1:26:26 (h:m:s) Size: 17.370.765.312 bytes Total Bitrate: 26,79 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 20948 kbps 1080p / 23,976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 1927 kbps 5.1 / 48 kHz / 1927 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) DTS-HD Master Audio French 2228 kbps 5.1 / 48 kHz / 2228 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics French 0,019 kbps Presentation Graphics French 36,874 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00002.M2TS 0:00:00.000 1:26:26.556 17.370.765.312 26.794 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:09:03.209 21.093 kbps 43.006 kbps 00:07:03.214 28.455 kbps 00:07:03.214 25.539 kbps 00:07:03.214 109.963 bytes 686.378 bytes 00:05:06.597 2 0:09:03.209 0:06:34.310 20.925 kbps 29.197 kbps 00:15:00.983 23.624 kbps 00:12:36.046 22.118 kbps 00:12:07.059 109.093 bytes 425.360 bytes 00:10:38.429 3 0:15:37.519 0:07:08.261 20.831 kbps 43.531 kbps 00:21:01.969 23.920 kbps 00:20:01.783 23.045 kbps 00:16:00.709 108.605 bytes 761.796 bytes 00:22:23.300 4 0:22:45.781 0:08:57.745 21.081 kbps 38.705 kbps 00:27:03.246 26.013 kbps 00:27:03.246 23.223 kbps 00:27:03.246 109.905 bytes 650.203 bytes 00:23:48.427 5 0:31:43.526 0:05:59.442 21.324 kbps 37.323 kbps 00:37:01.928 28.429 kbps 00:36:57.924 25.366 kbps 00:36:54.795 111.176 bytes 551.804 bytes 00:34:27.482 6 0:37:42.969 0:06:35.770 21.293 kbps 30.459 kbps 00:42:52.361 23.621 kbps 00:42:49.775 22.522 kbps 00:42:44.853 111.012 bytes 420.485 bytes 00:39:26.906 7 0:44:18.739 0:08:41.229 21.156 kbps 35.667 kbps 00:49:51.571 26.367 kbps 00:44:35.297 23.985 kbps 00:44:34.922 110.298 bytes 714.128 bytes 00:46:58.148 8 0:52:59.968 0:06:56.457 20.722 kbps 27.230 kbps 00:57:31.823 22.150 kbps 00:54:05.158 21.870 kbps 00:54:03.573 108.035 bytes 441.924 bytes 00:59:55.675 9 0:59:56.426 0:08:30.301 20.873 kbps 29.762 kbps 01:01:30.186 24.231 kbps 01:01:29.143 23.709 kbps 01:01:30.186 108.822 bytes 615.670 bytes 01:01:15.296 10 1:08:26.727 0:07:49.469 20.708 kbps 29.916 kbps 01:09:32.960 24.798 kbps 01:09:29.290 23.607 kbps 01:09:29.665 107.964 bytes 430.917 bytes 01:16:01.974 11 1:16:16.196 0:08:03.149 20.459 kbps 40.239 kbps 01:19:41.651 29.236 kbps 01:19:01.445 25.041 kbps 01:18:56.606 106.662 bytes 758.977 bytes 01:21:08.488 12 1:24:19.345 0:02:07.210 21.044 kbps 39.359 kbps 01:25:59.237 27.511 kbps 01:25:42.720 26.411 kbps 01:25:42.387 109.786 bytes 636.297 bytes 01:24:27.395 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00002.M2TS 4113 (0x1011) 0x1B AVC 5186,473 20.949 13.581.309.655 73.884.570 00002.M2TS 4352 (0x1100) 0x86 DTS-HD MA fra (French) 5186,473 2.228 1.444.286.440 8.677.814 00002.M2TS 4353 (0x1101) 0x86 DTS-HD MA eng (English) 5186,473 1.927 1.249.124.640 7.598.463 00002.M2TS 4608 (0x1200) 0x90 PGS fra (French) 5186,473 0 12.000 72 00002.M2TS 4609 (0x1201) 0x90 PGS fra (French) 5186,473 37 23.906.107 138.037
Total Video
00001.MPLS AVC 2:03:58 23,625,467,904 23,923,528,257 25.41 22.48 LPCM 2.0 1536Kbps (48kHz/16-bit)
DISC INFO: Disc Title: MATCH_POINT Disc Size: 23,923,528,257 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00001.MPLS Length: 2:03:58 (h:m:s) Size: 23,625,467,904 bytes Total Bitrate: 25.41 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 22476 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- LPCM Audio English 1536 kbps 2.0 / 48 kHz / 1536 kbps / 16-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics Chinese 35.167 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00003.M2TS 0:00:00.000 2:03:58.722 23,625,467,904 25,408 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:10:12.820 21,279 kbps 43,778 kbps 00:08:37.266 38,246 kbps 00:08:33.262 33,484 kbps 00:07:41.169 110,929 bytes 496,550 bytes 00:01:08.276 2 0:10:12.820 0:09:15.221 21,395 kbps 40,298 kbps 00:16:09.134 32,094 kbps 00:16:07.591 29,934 kbps 00:14:16.397 111,546 bytes 434,303 bytes 00:10:13.821 3 0:19:28.041 0:09:37.201 22,851 kbps 34,542 kbps 00:27:41.910 28,586 kbps 00:26:32.173 27,427 kbps 00:27:33.401 119,137 bytes 362,511 bytes 00:22:04.281 4 0:29:05.243 0:11:02.411 24,019 kbps 41,459 kbps 00:39:34.372 36,666 kbps 00:39:32.286 36,311 kbps 00:39:32.995 125,225 bytes 445,039 bytes 00:38:17.795 5 0:40:07.655 0:09:20.726 22,461 kbps 41,945 kbps 00:49:01.855 33,521 kbps 00:49:22.834 31,961 kbps 00:48:12.931 117,102 bytes 403,650 bytes 00:45:43.490 6 0:49:28.382 0:10:14.280 22,365 kbps 40,745 kbps 00:52:39.698 35,717 kbps 00:52:58.174 31,730 kbps 00:52:58.133 116,602 bytes 327,896 bytes 00:52:44.786 7 0:59:42.662 0:09:12.218 24,811 kbps 44,149 kbps 01:00:26.664 37,253 kbps 01:03:41.818 35,620 kbps 01:03:40.817 129,351 bytes 473,797 bytes 01:07:18.075 8 1:08:54.880 0:10:48.189 21,299 kbps 39,463 kbps 01:10:48.410 30,660 kbps 01:10:46.992 26,483 kbps 01:10:45.366 111,041 bytes 509,086 bytes 01:14:07.025 9 1:19:43.069 0:09:42.206 22,358 kbps 42,629 kbps 01:21:22.544 39,855 kbps 01:20:30.408 33,579 kbps 01:20:28.823 116,564 bytes 389,061 bytes 01:23:38.888 10 1:29:25.276 0:09:11.259 24,542 kbps 44,369 kbps 01:37:44.358 36,500 kbps 01:37:54.785 34,572 kbps 01:37:49.947 127,948 bytes 431,148 bytes 01:34:58.317 11 1:38:36.535 0:09:01.082 24,926 kbps 42,839 kbps 01:42:14.294 40,619 kbps 01:42:13.752 33,510 kbps 01:42:09.748 129,952 bytes 387,745 bytes 01:39:18.744 12 1:47:37.617 0:16:21.105 19,671 kbps 37,234 kbps 01:47:43.665 32,232 kbps 01:53:54.786 29,437 kbps 01:53:53.535 102,558 bytes 331,818 bytes 01:47:55.635 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00003.M2TS 4113 (0x1011) 0x1B AVC 7438.640 22,476 20,898,798,560 113,684,453 00003.M2TS 4352 (0x1100) 0x80 LPCM eng (English) 7438.640 1,542 1,434,193,892 8,926,518 00003.M2TS 4608 (0x1200) 0x90 PGS zho (Chinese) 7438.640 35 32,699,403 189,146
Total Video
00801.MPLS VC-1 2:08:19 38,817,189,888 39,462,592,868 40.33 28.57 DTS-HD Master 5.1 4264Kbps (48kHz/24-bit)
DISC INFO: Disc Title: INTERPRETER_G51 Disc Size: 39,462,592,868 bytes Protection: AACS BD-Java: Yes BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00801.MPLS Length: 2:08:19 (h:m:s) Size: 38,817,189,888 bytes Total Bitrate: 40.33 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 28574 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio English 4264 kbps 5.1 / 48 kHz / 4264 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) DTS Audio German 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit DTS Audio Japanese 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit DTS Audio Portuguese 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit DTS Audio Russian 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit DTS Audio Spanish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit DTS Audio Spanish 768 kbps 5.1 / 48 kHz / 768 kbps / 24-bit SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 35.048 kbps Presentation Graphics English 0.328 kbps Presentation Graphics Chinese 24.851 kbps Presentation Graphics Danish 25.572 kbps Presentation Graphics Dutch 26.523 kbps Presentation Graphics Finnish 30.970 kbps Presentation Graphics German 30.094 kbps Presentation Graphics German 0.666 kbps Presentation Graphics Greek 33.202 kbps Presentation Graphics Japanese 20.258 kbps Presentation Graphics Japanese 0.817 kbps Presentation Graphics Korean 18.805 kbps Presentation Graphics Norwegian 27.807 kbps Presentation Graphics Polish 28.243 kbps Presentation Graphics Portuguese 27.364 kbps Presentation Graphics Portuguese 28.219 kbps Presentation Graphics Portuguese 0.411 kbps Presentation Graphics Russian 0.140 kbps Presentation Graphics Spanish 28.800 kbps Presentation Graphics Spanish 31.485 kbps Presentation Graphics Spanish 0.923 kbps Presentation Graphics Spanish 0.606 kbps Presentation Graphics Swedish 24.573 kbps Presentation Graphics Thai 22.065 kbps Presentation Graphics Turkish 29.383 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00800.M2TS 0:00:00.000 2:08:19.692 38,817,189,888 40,331 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 2:08:19.692 28,574 kbps 47,499 kbps 01:33:13.254 36,761 kbps 00:02:29.649 34,620 kbps 01:20:40.126 149,051 bytes 672,442 bytes 01:14:30.507 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00800.M2TS 4113 (0x1011) 0xEA VC-1 7699.609 28,574 27,500,962,534 149,573,005 00800.M2TS 4352 (0x1100) 0x82 DTS jpn (Japanese) 7699.609 768 739,171,328 4,331,082 00800.M2TS 4353 (0x1101) 0x86 DTS-HD MA eng (English) 7699.609 4,264 4,103,484,884 23,500,612 00800.M2TS 4354 (0x1102) 0x82 DTS deu (German) 7699.609 768 739,171,328 4,331,082 00800.M2TS 4355 (0x1103) 0x82 DTS spa (Spanish) 7699.609 768 739,171,328 4,331,082 00800.M2TS 4356 (0x1104) 0x82 DTS por (Portuguese) 7699.609 768 739,171,328 4,331,082 00800.M2TS 4357 (0x1105) 0x82 DTS spa (Spanish) 7699.609 768 739,171,328 4,331,082 00800.M2TS 4358 (0x1106) 0x82 DTS rus (Russian) 7699.609 768 739,171,328 4,331,082 00800.M2TS 4608 (0x1200) 0x90 PGS jpn (Japanese) 7699.609 20 19,497,969 114,802 00800.M2TS 4609 (0x1201) 0x90 PGS eng (English) 7699.609 35 33,731,949 194,219 00800.M2TS 4610 (0x1202) 0x90 PGS deu (German) 7699.609 30 28,964,274 167,011 00800.M2TS 4611 (0x1203) 0x90 PGS spa (Spanish) 7699.609 29 27,719,053 160,215 00800.M2TS 4612 (0x1204) 0x90 PGS por (Portuguese) 7699.609 27 26,337,054 152,422 00800.M2TS 4613 (0x1205) 0x90 PGS spa (Spanish) 7699.609 31 30,303,512 174,401 00800.M2TS 4614 (0x1206) 0x90 PGS dan (Danish) 7699.609 26 24,611,597 143,002 00800.M2TS 4615 (0x1207) 0x90 PGS nld (Dutch) 7699.609 27 25,527,327 148,004 00800.M2TS 4616 (0x1208) 0x90 PGS fin (Finnish) 7699.609 31 29,807,333 170,006 00800.M2TS 4617 (0x1209) 0x90 PGS ell (Greek) 7699.609 33 31,955,196 183,526 00800.M2TS 4618 (0x120A) 0x90 PGS kor (Korean) 7699.609 19 18,098,750 108,301 00800.M2TS 4619 (0x120B) 0x90 PGS nor (Norwegian) 7699.609 28 26,763,540 154,299 00800.M2TS 4620 (0x120C) 0x90 PGS pol (Polish) 7699.609 28 27,182,868 157,300 00800.M2TS 4621 (0x120D) 0x90 PGS por (Portuguese) 7699.609 28 27,160,168 157,181 00800.M2TS 4622 (0x120E) 0x90 PGS swe (Swedish) 7699.609 25 23,650,963 137,860 00800.M2TS 4623 (0x120F) 0x90 PGS tha (Thai) 7699.609 22 21,236,300 125,557 00800.M2TS 4624 (0x1210) 0x90 PGS tur (Turkish) 7699.609 29 28,280,485 163,359 00800.M2TS 4625 (0x1211) 0x90 PGS zho (Chinese) 7699.609 25 23,918,395 139,407 00800.M2TS 4626 (0x1212) 0x90 PGS jpn (Japanese) 7699.609 1 785,861 4,682 00800.M2TS 4627 (0x1213) 0x90 PGS eng (English) 7699.609 0 316,096 1,871 00800.M2TS 4628 (0x1214) 0x90 PGS deu (German) 7699.609 1 641,167 3,737 00800.M2TS 4629 (0x1215) 0x90 PGS spa (Spanish) 7699.609 1 887,996 5,157 00800.M2TS 4630 (0x1216) 0x90 PGS por (Portuguese) 7699.609 0 396,029 2,328 00800.M2TS 4631 (0x1217) 0x90 PGS spa (Spanish) 7699.609 1 583,268 3,421 00800.M2TS 4632 (0x1218) 0x90 PGS rus (Russian) 7699.609 0 134,772 786
Total Video
00000.MPLS VC-1 1:31:57 17,116,403,712 22,914,430,768 24.82 22.97 DD AC3 5.1 640Kbps
DISC INFO: Disc Title: 3DALEEARNHARDTSTORY Disc Size: 22,914,430,768 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00000.MPLS Length: 1:31:57 (h:m:s) Size: 17,116,403,712 bytes Total Bitrate: 24.82 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- VC-1 Video 22967 kbps 1080p / 23.976 fps / 16:9 / Advanced Profile 3 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby Digital Audio English 640 kbps 5.1 / 48 kHz / 640 kbps / DN -4dB SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 55.064 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:31:57.136 17,116,403,712 24,819 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:06:25.968 23,823 kbps 52,784 kbps 00:00:20.478 33,711 kbps 00:01:09.652 31,651 kbps 00:01:05.982 124,191 bytes 565,650 bytes 00:00:58.183 2 0:06:25.968 0:04:03.451 21,777 kbps 31,555 kbps 00:08:58.329 27,421 kbps 00:06:31.391 26,697 kbps 00:06:31.474 113,536 bytes 280,907 bytes 00:10:18.075 3 0:10:29.420 0:13:53.833 22,315 kbps 34,691 kbps 00:12:02.763 29,618 kbps 00:10:49.273 29,085 kbps 00:10:49.273 116,342 bytes 325,192 bytes 00:12:02.805 4 0:24:23.253 0:06:58.543 22,656 kbps 32,888 kbps 00:25:33.657 30,373 kbps 00:29:07.704 30,312 kbps 00:29:07.787 118,120 bytes 496,137 bytes 00:29:04.993 5 0:31:21.796 0:11:47.581 23,595 kbps 49,032 kbps 00:42:16.367 32,667 kbps 00:42:14.448 30,712 kbps 00:32:46.214 123,012 bytes 411,893 bytes 00:42:08.609 6 0:43:09.378 0:06:57.416 21,382 kbps 28,340 kbps 00:44:37.549 25,810 kbps 00:43:47.333 24,649 kbps 00:43:47.249 111,478 bytes 302,208 bytes 00:44:40.010 7 0:50:06.795 0:11:10.294 22,837 kbps 40,399 kbps 00:53:53.605 31,411 kbps 00:54:06.326 30,534 kbps 00:53:59.986 119,064 bytes 330,937 bytes 00:53:54.230 8 1:01:17.090 0:08:27.507 23,024 kbps 39,038 kbps 01:07:38.012 31,167 kbps 01:07:34.550 30,154 kbps 01:06:34.740 120,038 bytes 378,890 bytes 01:01:34.482 9 1:09:44.597 0:07:03.965 20,606 kbps 33,351 kbps 01:11:15.938 30,874 kbps 01:11:14.687 28,978 kbps 01:11:14.144 107,431 bytes 271,728 bytes 01:13:45.879 10 1:16:48.562 0:05:04.721 27,166 kbps 41,413 kbps 01:20:09.221 33,363 kbps 01:20:21.525 30,978 kbps 01:20:16.603 141,633 bytes 375,063 bytes 01:21:24.212 11 1:21:53.283 0:03:58.488 21,513 kbps 27,012 kbps 01:22:17.515 25,958 kbps 01:22:13.345 25,580 kbps 01:22:10.425 112,160 bytes 318,718 bytes 01:25:50.270 12 1:25:51.771 0:06:05.364 25,634 kbps 52,787 kbps 01:28:47.363 34,351 kbps 01:29:42.126 30,708 kbps 01:30:42.103 133,659 bytes 553,564 bytes 01:28:48.239 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0xEA VC-1 5517.012 22,967 15,838,873,684 86,160,546 00000.M2TS 4352 (0x1100) 0x81 AC3 eng (English) 5517.012 640 441,372,160 2,586,165 00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5517.012 55 37,974,109 216,374
Total Video
00000.MPLS AVC 1:22:53 17,930,305,536 19,855,566,428 28.84 23.99 Dolby TrueHD 5.1 1629Kbps (48kHz/16-bit)
DISC INFO: Disc Title: DIAGNOSIS_DEATH Disc Size: 19,855,566,428 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00000.MPLS Length: 1:22:53 (h:m:s) Size: 17,930,305,536 bytes Total Bitrate: 28.84 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 23991 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- Dolby TrueHD Audio English 1629 kbps 5.1 / 48 kHz / 1629 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps) Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00000.M2TS 0:00:00.000 1:22:53.218 17,930,305,536 28,843 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:04:11.793 24,094 kbps 32,468 kbps 00:01:09.194 31,076 kbps 00:01:05.565 29,309 kbps 00:01:05.565 125,596 bytes 275,627 bytes 00:01:14.824 2 0:04:11.793 0:07:26.404 23,693 kbps 27,925 kbps 00:04:12.710 26,508 kbps 00:05:33.082 26,014 kbps 00:09:45.376 123,525 bytes 355,224 bytes 00:04:15.338 3 0:11:38.197 0:07:16.394 24,637 kbps 31,820 kbps 00:15:23.631 28,349 kbps 00:15:20.336 27,716 kbps 00:12:11.355 128,445 bytes 314,796 bytes 00:14:40.796 4 0:18:54.591 0:08:52.657 24,483 kbps 30,718 kbps 00:26:46.688 30,039 kbps 00:26:46.688 29,928 kbps 00:26:46.688 127,642 bytes 308,087 bytes 00:27:47.123 5 0:27:47.248 0:10:31.005 24,224 kbps 33,130 kbps 00:29:28.933 28,352 kbps 00:32:29.197 27,824 kbps 00:32:24.859 126,295 bytes 317,796 bytes 00:27:48.124 6 0:38:18.254 0:07:37.665 25,145 kbps 33,361 kbps 00:41:39.163 31,436 kbps 00:39:57.269 30,794 kbps 00:39:57.186 131,095 bytes 398,001 bytes 00:39:58.312 7 0:45:55.919 0:08:30.843 24,067 kbps 33,288 kbps 00:54:18.505 32,891 kbps 00:54:17.754 32,375 kbps 00:54:16.711 125,472 bytes 361,643 bytes 00:51:54.986 8 0:54:26.763 0:10:07.189 24,704 kbps 33,565 kbps 01:04:19.689 33,033 kbps 01:04:15.893 32,887 kbps 01:04:11.389 128,794 bytes 305,193 bytes 01:03:38.064 9 1:04:33.953 0:06:05.531 24,447 kbps 33,527 kbps 01:10:14.960 32,987 kbps 01:10:14.960 32,901 kbps 01:10:15.044 127,456 bytes 313,648 bytes 01:07:53.903 10 1:10:39.485 0:06:32.642 26,250 kbps 33,709 kbps 01:14:48.484 32,972 kbps 01:14:44.938 32,895 kbps 01:14:44.062 136,856 bytes 271,962 bytes 01:13:23.732 11 1:17:12.127 0:01:51.444 24,893 kbps 28,931 kbps 01:18:42.092 27,498 kbps 01:18:41.049 27,174 kbps 01:18:41.049 129,782 bytes 338,937 bytes 01:18:44.052 12 1:19:03.572 0:03:49.646 12,075 kbps 30,579 kbps 01:22:41.706 28,988 kbps 01:22:38.161 28,441 kbps 01:22:35.116 62,966 bytes 317,073 bytes 01:22:39.245 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00000.M2TS 4113 (0x1011) 0x1B AVC 4973.051 23,992 14,914,250,645 81,125,193 00000.M2TS 4352 (0x1100) 0x83 TrueHD eng (English) 4973.051 2,269 1,410,530,732 10,541,029 00000.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 4973.051 224 139,250,944 777,070 00000.M2TS 4354 (0x1102) 0x81 AC3 eng (English) 4973.051 224 139,250,944 777,070
Total Video
00002.MPLS AVC 1:36:07 25,573,797,888 43,324,057,008 35.47 29.84 DTS-HD Master 5.1 3831Kbps (48kHz/24-bit)
DISC INFO: Disc Title: HAPPY TOGETHER Disc Size: 43,324,057,008 bytes Protection: AACS BD-Java: No BDInfo: 0.5.6 PLAYLIST REPORT: Name: 00002.MPLS Length: 1:36:07 (h:m:s) Size: 25,573,797,888 bytes Total Bitrate: 35.47 Mbps VIDEO: Codec Bitrate Description ----- ------- ----------- MPEG-4 AVC Video 29841 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1 AUDIO: Codec Language Bitrate Description ----- -------- ------- ----------- DTS-HD Master Audio Chinese 3831 kbps 5.1 / 48 kHz / 3831 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit) SUBTITLES: Codec Language Bitrate Description ----- -------- ------- ----------- Presentation Graphics English 20.158 kbps FILES: Name Time In Length Size Total Bitrate ---- ------- ------ ---- ------------- 00028.M2TS 0:00:00.000 0:00:11.010 3,735,552 2,714 00027.M2TS 0:00:11.010 1:35:56.792 25,570,062,336 35,534 CHAPTERS: Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time ------ ------- ------ -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- -------------- 1 0:00:00.000 0:02:36.364 21,544 kbps 43,157 kbps 00:01:57.242 37,331 kbps 00:01:53.780 35,151 kbps 00:01:51.236 112,291 bytes 413,165 bytes 00:00:40.582 2 0:02:36.364 0:03:36.841 31,886 kbps 42,238 kbps 00:04:57.797 35,710 kbps 00:04:31.396 35,585 kbps 00:04:26.057 166,238 bytes 358,740 bytes 00:04:26.140 3 0:06:13.206 0:01:25.293 29,423 kbps 32,806 kbps 00:07:36.956 30,507 kbps 00:06:32.350 30,357 kbps 00:06:28.429 153,396 bytes 469,168 bytes 00:07:37.915 4 0:07:38.499 0:05:34.667 31,815 kbps 43,842 kbps 00:07:42.545 39,942 kbps 00:07:42.378 37,591 kbps 00:07:42.378 165,867 bytes 383,596 bytes 00:11:53.003 5 0:13:13.167 0:02:50.587 30,772 kbps 41,250 kbps 00:14:14.395 37,098 kbps 00:14:14.395 35,580 kbps 00:14:14.395 160,430 bytes 420,900 bytes 00:13:20.674 6 0:16:03.754 0:04:43.783 30,268 kbps 44,102 kbps 00:20:07.873 40,265 kbps 00:20:04.203 37,249 kbps 00:19:59.198 157,806 bytes 363,000 bytes 00:20:05.078 7 0:20:47.537 0:04:47.704 27,060 kbps 45,005 kbps 00:24:20.208 36,359 kbps 00:24:19.833 35,278 kbps 00:20:48.038 141,076 bytes 459,418 bytes 00:24:31.928 8 0:25:35.242 0:06:47.031 31,812 kbps 44,362 kbps 00:27:00.327 40,253 kbps 00:26:57.866 36,984 kbps 00:26:57.866 165,852 bytes 443,362 bytes 00:25:36.243 9 0:32:22.273 0:02:36.072 33,020 kbps 36,869 kbps 00:32:59.268 34,831 kbps 00:32:55.264 34,518 kbps 00:32:50.259 172,153 bytes 390,502 bytes 00:33:34.971 10 0:34:58.346 0:03:13.318 33,007 kbps 37,531 kbps 00:37:02.762 36,143 kbps 00:37:33.960 35,616 kbps 00:37:33.668 172,082 bytes 453,436 bytes 00:36:34.525 11 0:38:11.664 0:01:07.734 23,541 kbps 37,586 kbps 00:38:54.290 35,682 kbps 00:38:50.286 34,546 kbps 00:38:45.948 122,733 bytes 420,098 bytes 00:38:55.291 12 0:39:19.398 0:04:29.227 32,616 kbps 42,594 kbps 00:39:25.863 38,077 kbps 00:39:25.863 36,572 kbps 00:39:20.066 170,045 bytes 394,900 bytes 00:39:23.944 13 0:43:48.625 0:05:32.540 32,830 kbps 41,169 kbps 00:48:57.059 35,386 kbps 00:48:53.388 34,348 kbps 00:48:01.587 171,159 bytes 348,860 bytes 00:48:57.142 14 0:49:21.166 0:05:06.931 30,740 kbps 43,916 kbps 00:53:33.251 38,174 kbps 00:53:39.382 36,041 kbps 00:53:39.382 160,264 bytes 444,458 bytes 00:50:39.953 15 0:54:28.098 0:05:04.470 30,290 kbps 45,190 kbps 00:59:06.543 38,460 kbps 00:59:04.958 36,056 kbps 00:55:19.149 157,916 bytes 442,458 bytes 00:58:01.227 16 0:59:32.569 0:04:54.002 29,735 kbps 44,208 kbps 01:02:50.391 39,163 kbps 01:02:48.848 36,070 kbps 01:02:48.848 155,025 bytes 446,763 bytes 01:01:55.920 17 1:04:26.571 0:06:52.787 28,422 kbps 44,785 kbps 01:04:52.263 40,495 kbps 01:05:48.778 37,270 kbps 01:05:48.527 148,178 bytes 504,675 bytes 01:10:23.052 18 1:11:19.358 0:03:07.478 30,099 kbps 43,397 kbps 01:13:47.631 38,946 kbps 01:13:47.089 36,026 kbps 01:13:47.089 156,924 bytes 456,098 bytes 01:14:23.125 19 1:14:26.837 0:02:10.046 32,567 kbps 38,198 kbps 01:16:27.791 36,049 kbps 01:16:26.707 35,747 kbps 01:16:21.660 169,788 bytes 456,535 bytes 01:16:22.160 20 1:16:36.883 0:03:56.277 31,900 kbps 45,116 kbps 01:17:13.420 38,433 kbps 01:17:13.253 36,021 kbps 01:17:05.871 166,312 bytes 440,693 bytes 01:20:03.673 21 1:20:33.161 0:05:23.281 30,941 kbps 43,826 kbps 01:23:08.066 37,991 kbps 01:23:06.022 35,248 kbps 01:23:14.572 161,313 bytes 456,060 bytes 01:22:28.276 22 1:25:56.442 0:02:31.442 28,561 kbps 36,431 kbps 01:25:58.444 35,675 kbps 01:25:57.402 35,070 kbps 01:25:58.153 148,905 bytes 423,336 bytes 01:27:47.136 23 1:28:27.885 0:01:58.034 28,622 kbps 46,216 kbps 01:29:45.963 39,093 kbps 01:28:31.514 35,920 kbps 01:28:30.388 149,221 bytes 469,598 bytes 01:29:45.463 24 1:30:25.920 0:05:41.883 20,543 kbps 41,943 kbps 01:30:49.068 37,567 kbps 01:30:45.064 36,374 kbps 01:30:45.064 107,117 bytes 451,114 bytes 01:30:37.098 STREAM DIAGNOSTICS: File PID Type Codec Language Seconds Bitrate Bytes Packets ---- --- ---- ----- -------- -------------- -------------- ------------- ----- 00028.M2TS 4113 (0x1011) 0x1B AVC 10.886 739 1,005,736 5,601 00028.M2TS 4352 (0x1100) 0x86 DTS-HD MA zho (Chinese) 10.886 1,579 2,148,640 13,429 00028.M2TS 4608 (0x1200) 0x90 PGS eng (English) 10.886 1 1,702 17 00027.M2TS 4113 (0x1011) 0x1B AVC 5756.626 29,897 21,513,548,018 117,002,392 00027.M2TS 4352 (0x1100) 0x86 DTS-HD MA zho (Chinese) 5756.626 3,836 2,760,220,120 15,898,929 00027.M2TS 4608 (0x1200) 0x90 PGS eng (English) 5756.626 20 14,531,682 83,236
