Originally Posted by
edfowler
interesting.
Glad I'm going to build four boxes to test with.
With the four at mid wall I will have to deal with the gain from the floor boundry because the front sub will have to be underneath the screen. I could move the other three to the center of each wall however. Would this help or just screw things up?
An acoustically transparent screen is not an option because I am certainly more of a videophile than audiophile.
I will also see what it sounds like to place each sub half way up the wall in each corner.
The problem with one out of four on the floor is you canceled the height modes with the three halfway up, then bring it right back with the one on the floor - just not as strong as with four on the floor.
The four in the corner I don't like - kills of the odd modes, seriously boosts the even modes. You will have very strong nulls 1/4th from each wall constraining your seating. The thing to remember about Harman's patterns is they assumed parametric EQ to notch out the remaining modes - they are just making spatially symmetric patterns so this EQ can work over a broad area.
No more plots though - Dennis is trying to Tom Sawyer me into doing HIS rooms - I got garden weeds to attend to!
