AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 4310CI vs 5308CI
post #1 of 19
Considering the impressive feature set and expansive connectivity of the
4310, I wanted to give it a go against my present receiver, the 5308.
My first 4310 fell victim, first day, to the infamous firmware upgrade blunder.
But my seller, OneCall, took care of business and sent a new unit out same day.
I was going to go into a lengthy explaination why I'm doing this but nobody really cares why
I actually have 3 new members of the family present this week, the 4310, the new OPPO Bluray player BDP-83 (WOW) and the Mark Seaton SubMersive subwoofer (bigger WOW)
Since the 5308 has no cons (unless Denon doesn't provide the promised upgrades for the 5308 like DenonLink4, I don't think DPLIIz will be something I'll be utilizing anyway, never know though) compared to the 4310, I'll go right into the Cons of the 4310 vs the 5308... as I see them.
1 - No onscreen volume display if you turn off video convert... ie video processing bypass, which I do on sources such as BluRay, HDDVD or other 1080p/24 sources. Useful feature for some, a welcome omission for others who don't want anything in the way of their pristine video signal
The 5308 can overlay onscreen volume all the time regardless of video convert mode.
2 - Lack of ability to tweak levels per surround mode. The 5308 provides a way (with remote) to adjust the levels of all active speakers per surround mode or 2 channel mode, 4310 doesn't have this feature that I can find.
Not a big deal, for me, but something I've grown use to using occassionally.
3 - No audio input switching, (auto, digital, analog), on 4310 remote.
5308's remote has this button and it works on the 4310, not sure why Denon left this button off Or maybe it's there I just haven't found it yet. But again not a big deal since I use a univeral remote anyway and can program that button from the 5308's remote.
4 - Onscreen (GUI) overlay. Again if you turn off the Video Convert mode, bypassing Video Processing, and go into the onscreen display the 4310 blacks out the current video source to get to the onscreen menu. Again the 5308 overlays on top even when video convert is turned off. Kind of a cool/useful feature of the 5308, something I'm use to but.... not a deal breaker.
Once I have the 4310 dialed in I doubt I'll be referring to the onscreen menu all the much anyway.
5 - Cheap speaker binding post compared to the 5308. 5308 has nice heavy duty post, 4310 not so much.
6 - "Only" 5 HDMI inputs on back of the 4310, 5308 has 6, but the 4310 provides a 6th input on front. Would rather have 6 on back but that's just me and again not a deal breaker.
So as you can see no deal breakers thus far. The sound of the 4310 is excellent even compared to the 5308. The 4310 drives my speakers with no issues thus far. The 4310 also runs much cooler than the 5308, granted the 5308 doesn't get hot but the 4310 doesn't even get warm
I figure this is a comparsion I'll be involved with for at least a month maybe longer. After a time I'll switch to the 5308 for awhile, then switch back to the 4310 and so on.
Could the 4310 be a giant killer..........
dc
post #2 of 19
ALL Denon receivers can tweak channel level by surround mode. See pg 81 of your manual, "Adjust the Volume of the Speakers".
I am not familiar with the touchscreen Denon remotes, but I would also imagine there is an "Input Mode" button somewhere... I could be wrong though. If you need that IR code for your universal though it's out there.
Also, in terms of video processing, I'm pretty sure that when you have CONVERT on but the i/p scaler off you are bypassing the processing. I'm also not sure how you can deduce that the 5308CI is keeping things "pristine" when overlaying the volume bar -- isn't it by necessity doing some processing to the video signal if it's overlaying graphics?
Anyway, that's minor stuff, thanks for the review.... now, let's get to the good stuff!! How does it SOUND vs the 5308CI, and how is the video processing of the ABT-2010 vs the HQV processing in the 5308CI???
post #3 of 19
Yes there it is, channel level tweaking, thanks. I'm use to hitting the enter button on the remote to access this.
I wouldn't, and didn't, say the 5308 was keeping things "pristine" when overlaying volume. If this is in fact having a negative effect on the video signal I can't see it
Not sure why one would turn off the i/p scaler if they have the Video Convert turned ON..... I'll have to try it and/or read the manual a bit
Video processing and sound quality are all things I'll be looking and listening for during the course of this semi-shootout....
dc
post #4 of 19
Conversion = changing format, e.g. component video input > HDMI output
Scaling = changing resolution
So, if you would like to have analog video be converted to HDMI, but do not want to alter the resolution, you can have Convert = ON and i/p scaler = OFF. This will allow cross-conversion of format but disable the scaler.
I believe if you have i/p scaler set to OFF or Analog then it won't touch the HDMI signal at all.
post #5 of 19
Yes but I can't think of a situation were you would want to do this.
Unless of course you have a better VP laying around, in that case
I don't think you'd buy the 4310 in the first place.
But people, me, have done crazier things....
post #6 of 19
in that case I don't think you'd buy the 4310 in the first place.
well, the point I was making was a general one, it's the way all Denons with HDMI video conversion work. Not 4310-specific...
there are people who prefer to have the display or an external VP handle the video processing... and you are right that they probably don't feel the need to upgrade to the 4310
post #7 of 19
dc
No doubt the 4310 is great value but it is not THX certified (I thought this would not make a difference but it does, I had the 4308 and I was surprised when I got the 5308 and it sounded much better), does not have as many options for zones, etc. I think you are comparing apples to oranges. Denon is aiming at Yamaha and Pioneer, not shooting itself in the foot. I'm really impressed with the 5308, there is not one thing to complain and this is rare, even the input layout is superb.
post #8 of 19
If you think that THX certification automatically guarantees better sound, you are shooting yourself in a foot
post #9 of 19
wow that's ..er.r... surprising to say the least....."giant killer" hmmm like Oppo....
post #10 of 19
Hai,
I think its great the 4310 is holding up against the 5308, its called progress. We have to keep in mind that its always the last 10% at this level that cost you more and its '2' version newer so...
having the same core values but a missing some features left and right (like zones) is the best you can expect from a good brand if you step down a range.
The differenced between the 5308 and the avp on the pre-amp are also small for some giving you more options to pick what you want without the loss of what a platform can bring.
Looking forward to your next review step, also going to test the 4810 ?
Daniel.
post #11 of 19
I said I was surprised, didn't I?
Anyway, can you increase the level of each input individually on the 4310?
post #12 of 19
Yes, digital and analog
post #13 of 19
One very cool feature of the 4310 not on the 5308 is the "source select" feature on the remote. Pushing this button brings up an onscreen display of all available sources. You scroll to the one you want, push enter and you're there! Pretty cool....... Also with the 5308 I was having issues with it's VP and scrolling video across bottom of my Plasma screen (Panasonic 9U) getting some blurring of scrolling info, not an issue with my projector (Panny 3000). The VP of the 4310 doesn't display this blurring issue.
I'm still on the fence about the sound quality and video processing of the 4310 compared to the 5308. I'll have to do a lot more listening and viewing to both units before crowning the 4310 up to the challenge of being in the same ballpark as the 5308.
dc
post #14 of 19
Thanks for doing this comparison, DreamCatcher! If things will continue in this direction, 4310ci will be perfect receiver for me.
post #15 of 19
Hi! I myself, is going to combine a 4310 with my denon video processsor and get the ultimate picture. I don`t thinkt anything out there beats the realta noise reduction.
Also I like PreP, detail enhancement and edge enhancement, wich I presume will be availible via the abt 2010 chip in the 4310ci.
Has anyone compared the PQ from the 4310ci against the Oppo-bdp83 or the dvdo edge?!
post #16 of 19
Dreamcatcher,
Now that you've had both units for a while, please give us an update.
post #17 of 19
Originally Posted by JimP View Post
Dreamcatcher,
I've sold the 5308 and kept the 4310.
I was able to sell my year old plus 5308 for nearly as much as I paid for it,
so with the 4310 performing beyond expectations, I decided I could live without it.
Reasons........
I like the updated GUI of the 4310, easier to navigate and a few extra features.
I wanted to experiment with Audyssey DSX and DPLIIz, should be getting the front wide speakers setup this week.
Video processing was a toss up between the 5308 and 4310, both are excellent.
And the amps of the 4310 have held their own, I don't feel like I'm missing anything in the power department.
And of course the grand or so in my pocket
The 5308 is probably still the best receiver out there but even their own lesser models are catching up quickly.
dc
post #18 of 19
And if you need more power, there is always power amps that go well with the denon recievers so...
post #19 of 19
dc,
Are you using the Sierras in your HT system or in a seperate 2 CH audio system?
Bill
