AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official: Denon DBP-2010CI Blu-ray Player
Official: Denon DBP-2010CI Blu-ray Player - Page 3
post #61 of 912
Originally Posted by JJaret View Post
I will give the player a more comprehensive workout over the next few days and report back.
Could you check some layer-change times for DVD's?
post #62 of 912
Finally got to mess with it a little this morning after returning. Everything was a piece of cake to set up.
Here's my quandry with upscaling DVD's. When selecting 1080p/24 with the resolution button (which is on the front of the unit not on the remote.... stupid), my projector reports receiving 1080p/60. BD is fine displays 1080p/24. So, does it really scale to 1080p/24?
S~
post #63 of 912
couple quick questions:
can it force 24fps on sd dvds?
if you press eject when turned off, how long does it take for the drive to open?
does it have a zoom feature? will it work on bds?
post #64 of 912
1. It is supposed to scale SDDVD's to 1080p/24; however, as I said in my previous post my projector says it is receiving 60. I'm going to call Denon.
2. 15 seconds from power button to tray all the way open. Not nearly as fast as the 3600 which is immediate.
3. There is a zoom button on the remote; however, I have yet to try it.
S~
post #65 of 912
S~
Thanks S. Quantitatively, it sounds very similar to the 1800. If you have a chance to compare some load times (click on my signature to see the BD titles I used), I think it will help us potential buyers get a feel for its speed. The 15 second eject time sounds nearly indentical to 1800 (1800 is actually 14 seconds).
Zoom on the 1800 only works on dvds and has three settings. It's been my impression it does distory the image to some degree.
Thanks for your input!
post #66 of 912
Originally Posted by electric turd View Post
The ABT2010 is also found in the high end denon DVD-A1UDCI
Originally Posted by darthpaul View Post
ABT is for Analog out only..(On the A1)
This incorrect info is still being propogated by a typo on the German Denon website for the A1. I can assure you that ABT cannot be found in the player as it was never mentioned in the press release and no ABT logo can be found anywhere. The A1 only has the Silicon Optix Realta, just like the 3800.
post #67 of 912
Originally Posted by tn001d View Post
Any first hand [IMG]http://www.****************/img/i/P.jpg[/IMG]user experience ? Screen Shots ?[IMG]http://***************/9/P/i.jpg[/IMG]
Thats what I am looking for too..would be nice to hear some experiences/ see some pics
post #68 of 912
Per the crutchfield website, the 2010 has the "Anchor Bay ABT1030 upscaler for superior DVD video upconversion"
post #69 of 912
you are right ,i like players that are built like a tank "like my 3930" and i think i ll go for the 2500 but i dont want to spend my money on a player that can maybe not play some of my blu rays ,thats the reason why i am considering the 2010ci i dont think it will a big difference between the anchorbay and terranex chip.i have an onkyo tx-sr805 that can decode all the hd formats so i hope the price of the 2500 will drop here in spain it still costs 900 euros
thank you very much JOHN BARLOW for your replay i thought no one will answer my questions
post #70 of 912
If you reread my post, I was responding to quotes that the $4500 A1UDCI universal player has the ABT chip in addition to HQV Realta. I was correcting electric turd and darthpaul that this is simply not true.
Getting back on topic, it is a crying shame that the 2010 player doesn't have the same chip as the Oppo player. How can you name your BD player the 2010 model and yet not have the ABT 2010 chip (it would have been very fitting indeed)?!! I'm sure many would have loved to do a side by side comparison. Any idea if the ABT 2010/1030 parallels HQV's Realta/Reon (ie. reference quality/mass market chip)?
post #71 of 912
After a couple of days here is some more information and thoughts.
Standard DVD Playback
Picture quality is excellent. As compared to my Denon DVD-2930 w/its Reon processor, black levels and color are richer. Definitely a step above what I always felt was a washed out look of standard DVDs on a 1080p panel. Sharpness and clarity of picture are the same or better.
Start & Load Times
DBP-2010CI/Panasonic DMP-BD55
Power-on tray eject 18 sec/20 sec
DVD Loading 19 sec/22 sec
BR w/o Java 36 sec/24 sec
BR w/Java 65 sec/65 sec
BR w/BD Live 90 sec/90 sec (w/SD card installed, w/o SD card times the same as BR w/Java disc)
1080p/24 for DVDs
I have played with all the video settings. 1080p/24 appears to only work for Blu-ray 1080p/24 discs. My panel (Pioneer Kuro PDP-5010FD) won't inidicate 1080p/24 on the screen, but the player and my AVR (Denon AVR-3808CI)indicate only 1080p output on standard DVDs, while they show 1080p/24 for Blu-rays.
DVD Layer Change
I was somewhat shocked when someone asked about this. With my DVD-2930 I never even noticed layer change delays. However, DVD layer change delays evidently are back with Blu-ray players. The player indicates layer and bit rate information on one of its DVD display modes, so I was able to find the layer changes to comment. There is a fraction of a second delay on layer changes, I would say less than a half of a second. I did check the delay on my Panasonic player and the DBP-2010 performed better.
Zoom Feature
Only works for DVD, DIVX or Picture Viewing, not on Blu-ray
Picture Adjustments
I was incorrect in my initial observation, the player has picture adjustments with 5 memory settings. The adjustments are for contrast, brightness, sharpness, black level, gamma correction and color.
HQV Benchmark Tests
I ran both the DVD and HD discs and as far as I can see the player passed all the tests.
I hope this covers most of the questions asked. I guess it is now time to watch some Blu-rays.
post #72 of 912
Start & Load Times
1080p/24 for DVDs
DVD Layer Change
Zoom Feature
Picture Adjustments
HQV Benchmark Tests
Do you have the Spears and Munsil disc for benchmarking? We may be able to find better separation b/w ABT 1030 and 2010 from that disc.
post #73 of 912
You are very welcome sir. I can say this about the 2500. Anytime there have been discs that wouldn't play, and there really haven't been that many. Maybe half a dozen give or take, Denon always has a firmware update for the 2500 to correct the issue.
I heard a rumor that Denon is going to release a new 4010 player built more like the 2500 with SACD capability and Denonlink 4
post #74 of 912
Unfortunately no.
post #75 of 912
I don't think anyone considers it a rumor anymore as reports all point to an Oct release for the 4010. While great news for audiophiles (it will do DVD-A in addition to SACD so it's a true universal player), videophiles are no doubt disappointed by the lack of a named post processor.
post #76 of 912
Start & Load Times
1080p/24 for DVDs
DVD Layer Change
Zoom Feature
Picture Adjustments
HQV Benchmark Tests
Great information. Thanks for your efforts
post #77 of 912
It will be using the ABT 2010, but this really isn't the place to discuss it.
S~
post #78 of 912
S~
Good to know. Thanks for the heads up!
post #79 of 912
The only players that could actually output 1080/24 for sd-dvd was the toshiba HD-DVD players. I know because i own two. From what i remember it was a fluke in the implementation of the chip. While it made DVD's look phenomenal, in this day and age dvd is falling out of favor for Bluray.
This player sounds like a winner.
post #80 of 912
Not quite true. The Panasonic 35/55/60/80, Oppo all scale SDDVD to 1080p/24. Toshiba just implemented it poorly. I had a few, also. I will still be talking to Denon next week since it was supposed to deliver 1080p/24 with SDDVD and neither jjarret nor I can get it correctly.
S~
post #81 of 912
S~
so can the $60 TOshiba xde upconverter
post #82 of 912
Nice preliminary review, but would really like to know more about it's blu-ray capabilities, mainly in regards to PQ & AQ.
Have you used the analog connections on this player at all?
How is the blu-ray PQ compared to some of the other blu-ray players you have used?
post #83 of 912
Blu-ray Picture
Blu-ray playback is excellent. I can't say it performs any better or worse than my Panasonic DMP-BD55. Both players do an excellent job with Blu-ray discs.
Blu-ray Audio
I'm sorry but I use HDMI for my audio. My receiver is HDMI 1.3 and is capable to decoding all of the new codecs. I don't have enough spare audio cables to do any analog audio testing. As I said previously, the player appears to decode Dolby TrueHD and DTS-MA and output over LPCM. My receiver indicates 8 channels received on 7.1 discs.
post #84 of 912
Blu-ray Picture
Blu-ray Audio
Thanks JJaret for your reply.
I'm not surprised by the PQ results of the Denon compared to your Panny 55.
My Panny BD80 also has great PQ with blu-ray as well.
I am most interested to hear some feedback on the 7.1 analog performance of the Denon 2010.
The 7.1 analog section of the Denon is one of the reasons why I'm interested in the 2010.
I would seriously hope that Denon will produce better sound quality than my Panasonic's analog section.
So far I have been extremely happy with the sound quality of all my Denon components (AVR5803 - 3930CI - 2930CI )
post #85 of 912
What is a dvd layer change. I just watched a standerd dvd on the denon 2010 and i got some flicker on the screen. I had none when i watched a BD. I also just watched inkhart on BD was to be in DTS 5.1 HD it show up on my denon 5308 avr as doby.
post #86 of 912
great information. Thanks for your efforts
+1
post #87 of 912
Ok the layer change was on some standard dvd. But over all the standard dvd looked clean and sharp very little grain and great quality. The load time were alot better than my 2500ci transport player. This player is alot smaller than the other Denon players. It is not the tank that i am use to. It is now like the other blu-ray players out there. I think Denon needs to computerize on build. I would of payed more for better build quality. Something like the 3800ci but with link 4 and Ethernet ports. Overall this is a good player not great standard and blu-ray PQ is on. Sound well i let my avr do the talking with HDMI cables. Build Denon let me down on build. Looks great with my 5308ci avr.
post #88 of 912
When the player switches layers on a multi-layer DVD, there is a momentary pause.
Make sure your audio settings on the player are as follows:
BD Audio Mode = HD Audio Output
HDMI Audio Out = HDMI Multi(Normal)
This will ensure bitstream to your AVR-5308
post #89 of 912
how does bs and sd dvd compare to your 2500?
post #90 of 912
2010 BS is as good as the 2500. But i can see a big plus on the standard Dvd. The 2010 has alot less grain the color stands out cleaner better black, red. And the load times WOW FAST FAST FAST beat the 2500 by a long shot. The player is still $200 to high . But i think it looks better than the OPPO player. Looks great with my 5308
