Originally Posted by walford
I certainly do not think the Hill is the cause of your problem since you are getting all of the UHF channels from the Empire State building and UHF channels are more subject to line of sight problems then VHF.
The problem is that many users who apparenty received analog channels without serious problems are having problems with digital VHF on the same RF channels as you found from the "better or worse" thread( aslthough many of them do not have a VUHF capable antennas such as your 4" rabbit ears). If you can make a simple 300 ohm dipole and suspend it above the railing or move the rabbit ears away from the railing I think you may be able to receive your UVHF channels.
The wide swings on channel 13 are very indicative of multpath reception as the tuner switches between the direct path to the antenna and a signal received from another reflective object.
How about lining the rail with lead - I.E., the shielding jacket they put on you at hospital when they take your x-ray?? LOL! Just supposing.
So I must be doing SOMEthings right - only ABC7 "absolutely refuses" to come in.
