Originally Posted by
peeteebee
At stock speeds you are right, it doesn't work, I know. But this doesn't mean it will definetly not, like stated by blaubart.
You don't have to believe me, but I know what I had and saw using this HW, even if it contradicts to the experience of every HD 3200/HT 1000MHz user you are aware of. You have to update you list because now you do know of a user that had VA on an hd3200.
can't reproduce since I have replaced my 5050e by an 240e. Its not just changing cpu, my system is Passively cooled, so I have to take it apart.
To be honest, I was surprised to have all options available in CCC (bob, weave, va and others)
I deselected auto and selected VA. Using the test pattern .ts (cheese thing) I found my system was using VA, but since I don't like to overclock I put it all back to stock speeds and ordered a better (read HT3) cpu.
my system specs during that test:
gigabyte ga-ma78gm-s2h, rev 2
ams 5050e (at 2900+, clock 225 * default multiplier 13)
cpu at 1000 (also tried 800 and 900, they both work too)
win7 (had good results using vista too)
settings:
aero was off (and when it was on, I got a popup that it was switched off
during playback)
cnq was on
1920*1080 via hdmi
software/drivers:
ccc used: can't remember, have used 9.7 .. 9.11. Last tests were with 9.8
because newer versions had problems
7mc, mediaplayer, powerdvd 9
with new cpu and everything and stock speeds, I also have VA on my HD3200 integrated gpu.
Here is my attempt of reproducing your results. Unfortunately they were not reproducible. My conclusion is,
Extreme overclocking + Unpractical assumption (Aero off) + Non-reproducible performance = Your claim of "not true" is totally meaningless. (I am not sure where you came from, but remember that this forum is not for overclocking competitions.)
HyperTransport 2.0
Test setup:
- GIGABYTE GA-MA78GM-S2H
- Athlon X2 4850
- Windows 7 32-bit, Aero off
- Catalyst 9.8 & 9.11
- HD 3200 @1000MHz, HT @1125MHz (225MHz x 5), C'n'Q off, Memory @400MHz (DDR2-800).
The best deinterlacing method available is
Adaptive.
(If you are able to post a similar screenshot of your claimed CCC along with Cheese Slices, I will believe you.
HyperTransport 3.0
Test setup:
- Athlon II X2 240
- Windows 7 32-bit, Aero on
- MPC HomeCinema 1.3.1378.0 with the internal MPEG TS souce filter, CyberLink Video/SP Decoder (PDVD9) & Microsoft DTV-DVD Video Decoder for MPEG-2, ArcSoft Video Decoder for VC-1, EVR.
- HD 3200 @500MHz, HT @2000MHz (200MHz x 10), C'n'Q on, Memory @400MHz (DDR2-800). That is, everything is at default.
Now Vector Adaptive is available in CCC, but this is
deceptive,
only Motion Adaptive is actually working!! Here are screenshots of Cheese Slices and HD HQV Benchmark:
Cheese Slices MPEG-2 1080i
HD HQV Video Resolution Loss Test (compare with
these pictures)
In summary, my previous statements are perfectly correct!Quote:
renethx
To be precise,
- HD 3200/3300 with a HT 2.0 processor: Only Bob and Weave work. (Update: Adaptive may work under certain extreme conditions [deinterlacing is still crappy])
- HD 3200/3300 with a HT 3.0 processor: Motion adaptive works up to 1920x1080; only Bob and Weave work beyond that (i.e. under dual monitor).
