Still working on it got the old polarizing film removed from glass slide, Im not sure if I need to cut vermillion film and apply to slide or just cut polarizing film to shape and and not use glass slide at all. I bought a can of denaturalized alcohol for 5 bucks at walmart. Seems like its working the rest of the glue off. I'm almost curious if the glue itself is the problem. Seems like the heat made glue bubble between film abit. Sounds like a good idea to not glue it on slide and just cut to exact shape of slide and place in holder.
post #91 of 207
10/1/10 at 11:32pm
Hello ShilohG. Well my daughters boyfriend took the tv apart today, cleaned it reallly good and then proceeded to take everything apart. Everything went very smoothly. Found the burnt filter and replaced it then put the tv back together. Yellow is gone but the red is really red and the blue is really blue. Tried to adjust everything but had no luck. Do u have any suggestions on what maybe causing this? Thanks for all your help. Will be waiting to hear from u! Thanks Again!!
Thanks and good luck to everyone!!
