Originally Posted by
mdavej
One of the strangest things on the remote is volume lock. Although this is totally customizable in activities, for some reason several soft buttons and config screens on the remote are dedicated to some global volume lock that operates outside of activities. This totally unnecessary holdover from other one-for-alls makes no sense on this remote. It gets overridden by activities anyway. Go figure.
Programming and learning takes lots of planning:
- If you learn a button on a particular page, it's on that page forever.
- You can't create another page until all the previous pages are full.
- All soft buttons are created last to first. So you have to work backwards to avoid moving buttons around. This is especially frustrating when making favorites lists.
- If you don't upload before downloading, your learns are wiped out. And you have to exit the software completely and start again to even see the option to upload.
- You can move soft buttons around on a page, but to move them to another page, you have to delete them add them back. Each of these movements takes a LONG time. And if you edit the button text too fast, it crashes and you lose all your edits.
- If you don't have discrete on/off for all your devices you're out of luck. This remote does no device state tracking.
On the plus side, they actually do a few things better than harmony:
- You control exactly what goes on in your activities, not what the wizard thinks should go on.
- You have customizable delays for each step in a macro and can have more than 5
steps.
- The Help (Assistant) function presents you with a list of all the steps in your activity so you can choose which step to repeat.
- The software actually shows a picture of the remote so you can see the buttons and click the ones you want to edit.
- You can mostly bypass the setup wizard when you want to make changes.
If you come from harmony there are some things you have to do differently:
- If you leave an activity screen, the only way to get back is to run the activity again. I find myself blocking the IR with my hand a lot to avoid problems.
- Learns have to be initiated on the remote, not the software, and you have to remember to upload them when you're done.
The problem with harmony and xsight is the stupid web based software. Give me drag and drop, and a few menus on a real, standalone application that runs fast. (I know harmony has standalone, but it runs as slow as the web config). Don't make me wait 15 seconds every time I click a button and require several confirmation clicks for one simple operation. My guess is the worst guy on the harmony software team probably got fired, and one-for-all hired him to design their software. In any case, whoever designed it has no earthly idea how a remote is used or is supposed to work. I wish harmony and one-for-all would hire developers who have at least seen and used a remote before.
Bottom line is if you have a simple setup and don't do much customizing, you may actually like this remote. Otherwise, harmony is a much more functional, better designed and mature product over all.
For now, I'll stick with harmony. If anyone wants a really good deal on an xsight color, PM me. My loss is your gain.
