http://www.solidsignal.com/prod_display.asp?PROD=PVDP2
5-860 Mhz on the TV port
950-2150 Mhz on the Sat port that I will use for MoCA.
A little over $20 with shipping for three of them to replace the three splitters on the head-end and the two remote nodes.
I'll report back when they come in and I get them installed.
When purchasing these, make sure they will pass all the way down to 5 Mhz for use with Cable TV, some of the cheaper ones are made for OTA antennas only and only pass down to 40 Mhz.
