Originally Posted by glangford
Seems to be a systemic problem with all LG. I have the 47LH90 and it has lip sync problems using hdmi with a scientific atlanta 8300 HD cable box as well. Just fine on cable with component feeds. DVD or blu ray on hdmi is just fine.
They are supposed to send me a usb device to upload a firmware update.
I love the TV and am not worrying about it. You are not loosing anything on cable with component feeds, which maxes out at 1080i anyway. I may just leave it that way.
Verizon is going to send you an update via usb?
Can you please keep us posted on how that goes for you as I have fios as well and would like this problem resolved.
Also does it really look the same using component as HDMI? I thought HDMI was digital and component was analog. Wouldn't that make a difference in PQ? I know that currently the max broadcast for HD is 1080i but still analog vs digital?
Any more posts on this topic would be steller!
