Originally Posted by mmeister
Mike,
Test top looks great. Did you get a lot of bubbles to come to the top with the mallet, or did you use the ol' sawzall? The 91" top will be two pieces or are you building two 91" tops? If so you may want to break it down to two pieces because a 91" top will be in the 350lbs range. I calculate four 80lbs concrete and one bag of sand for a 91" top. Doable but hard to move and may crack.
Mike,
I totally forgot to add sand to this top... oops. Although it's so small it won't matter. I haven't even begun to think about how to do the actual counters. I'm thinking three pieces for the lower counter since there's a sink involved. The upper bar top will only be about 15-18" wide which worries me since it'll be long and skinny.
I beat on the form for a solid 10 minutes with the mallet, I guess we'll know in three days how well that worked. The sad part is I had a broken orbital sander that I was going to screw into the form and let run for 30 minutes. I guess I tossed it at one point, figures I finally throw something away then lo and behold I need it. I need to come up with plan b now, I'm not going to beat on an 8' form to remove the bubbles.
