Originally Posted by A L Wong
deepstang, thank you for the constructive comments. Really helpful.
I have the Audyssey MultiEqXT in a Denon 3808.
After calibrating the AntiMode, I ran Audyssey calibration.
I then did REW with Bypass mode on, Audyssey On and Audyssey Off.
It did not show significant differences at all.
So, using ByPass mode is not a fair comparison between Audyssey XT and Anti-Mode in it's eq capabilities.
I will need to do Just Audyssey, without the 8033 in the chain and do a REW graph.
Then add the 8033 to the chain, and see if the anti-mode improves on AudysseyXT.
But it is academic and a moot point really, as I truly like what I am hearing now.
I won't be running without the anti-mode anyway.
Am I making any sense?
Ah, VERY true. I should have thought to ask that. To do a fair comparison, the proper sequence to run the calibrations is to:
1: connect the AM-8033 in line from the sub out from the receiver (just as you have it now)
2: run the AM-8033 sub setup
3: make sure the AM-8033 is set to flat (no 25 or 35Hz boost), than run Audyssey
4: after all Audyssey calibration is done, you can change the AM settings to include the boost.
Regardless of the comparison and the graphs, the above sequence is the proper way to incorporate the 8033 along with Audyssey. This allows more effective control of the optional boost feature on the 8033 as well.
**EDIT** above sequence was edited thans to a1bert reminder. THANKS!!
