AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Antimode 8033
Antimode 8033 - Page 10
post #271 of 554
Originally Posted by bsoko2 View Post
I was in the first 100 to order and still am waiting.
Gotcha, I figured they were In the hands of the masses by now. I hope to hear some input on it when you receive it. I'm looking to get my hsu vtf15s setup correctly with my Yamaha. Thanks
post #272 of 554
Originally Posted by Venomous View Post
So has anyone received their dual core yet?
I spoke to a US rep at the NY Audio/AV Show. He said that shipment has been delayed because of problems with the casework and that they should be on their way soon. Functional development is done.
post #273 of 554
Thanks Kal!
post #274 of 554
Looking forward to a review of this one.
post #275 of 554
My Duo Core is on the way. Shpped from Finland today the 23rd and will be delivered by UPS at end of day on the 25th. Now that is a quick delivery from Finland to Olympia, WA.
post #276 of 554
Duo Core Manual for those that wonder what it does http://www.dspeaker.com/fileadmin/da...lCoreEng09.pdf
post #277 of 554
I just took delivery of a Rhythmik F12SE to add to my dual ported SVS PC12NSD
I am running a triple subs set up in a 5.1 system. The AVR is the Denon 3808 with Audyssey XT. The single LFE pre-out is connected to a AM8033c.
I have the two ported subs in front, with both subs' phase set to 0 and connected via a Y connector to the 0 phase output of the AM8033C.
I have the sealed Rhythmik at the rear left of my sofa. I am using the LFE input and set the phase to 180. This sub is connected to the 180 deg phase output of the AM8033 as recommended by AntiMode.
I read some where here, that if connected to the LFE input, this bypass the phase and cross-over in the F12SE.
Will this interfere with the AM8033C 's calibration, which recommended the phase to be set to 180?
Should I instead use the line input of the F12, which enables the phase control?
Thank you and sorry for the long post.
post #278 of 554
There is now a 8033SII and the 8033 Cinema. Anyone know th real difference between the two other than the brief table on the DSPeaker site?
post #279 of 554
So?
J
post #280 of 554
Hardware: S-II has blue LEDs, dual inputs (for stereo systems without LFE out), normal and inverted output (balanced output possible), cinema has yellow LEDs, one input, one output.
Firmware: S-II has wider pass-band and correction range, more Anti-Mode filters, additional lift and lowpass-filter modes. (See the manual.)
post #281 of 554
Info I got from them -
S-II has two inputs that are actively summed (so you can connect stereo systems etc. see the connection examples), and corrects upto 250Hz. S-II also has additional lowpass filters modes. You can see the differences from the comparison chart http://www.dspeaker.com/en/products/anti-mode-8033.shtml and CinemaSII manual: http://www.dspeaker.com/fileadmin/datasheets/dspeaker/antimode8033CinemaSIIen.pdf .
S-II is not yet available, but all remaining 8033S units are programmed with the latest firmware, so they are identical to S-II, except for the LED color (yellow instead of blue)
post #282 of 554
I am contemplating getting Antimode 8033 to use with my Velo SMS-1. I am guessing it will be best of both worlds with 8033 correcting things in time domain also with SMS-1 providing more control over 8033. Has anybody used this combo?
post #283 of 554
What is your reciever? Best not to mix them, one is as good as the other and I prefer the Anti Mode 8033.
post #284 of 554
My receiver does not have EQ. I figured I can run 8033 first & use SMS-1 just to change presets & final tweaking with its manual EQ.
post #285 of 554
I have a pioneer receiver it does not eq the sub. I thought maybe I should get an antimode.
I'm not really sure which of the two antimodes to get. I would get the cinema because its cheaper but read through the post. Some of you said there is a pop sound when it turns off.
Is the SII worth it over the cinema?
post #286 of 554
The one with "pop" is 8033c, not the 8033cinema.
post #287 of 554
Good! I should go for the cinema.
thanks
post #288 of 554
Nice, when you get it, tell us how you like it, im gonna order the CInima version on Friday.
post #289 of 554
oh you'll have to wait... I'm not in a hurry to get it, maybe by the end of the year.
post #290 of 554
Well i should be ordering the CInima version tomarrow.
post #291 of 554
Can I borrow yours after you're done?
post #292 of 554
NO. LOL, BTW, how the F do you order one of these?, every time i try, it says payment declined.
post #293 of 554
Nevermind i just used paypal, and it worked, so i should be getting the Cinima version soooon, YAY.
post #294 of 554
Nice Josh! I hope it works well!
post #295 of 554
Where are you dudes ordering these from anyway? Somewhat hard to find a vendor...
post #296 of 554
I'm in the US and I ordered mine from here. http://www.creativesound.ca/index.html
post #297 of 554
I ordered mine from here. http://www.tweekgeek.com
post #298 of 554
I ordered mine from Db speakers.
post #299 of 554
Thanks for the links!
It looks like the 8033S has stereo in/outs... does that mean I can use it with 2 subwoofers? I've got 2 low level sub outputs on my AVR, and am thinking about purchasing 2x Hsu ULS-15's.
post #300 of 554
You can use it with two subs but it will treat them as one summed unit. If you want independent dual sub calibration you have to upgrade to the 2.0 dual core version.
