AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Antimode 8033
Antimode 8033 - Page 2
post #31 of 542
Originally Posted by deepstang View Post
Are there any USA based companies that sell this? The 2 sites I have seen selling this item have the price in Euros
As mentioned several times, the manf. is who we've purchased our units from (as covered in the main thread). You can google "currency converter" to find out a close ballpark for today's conversion.
post #32 of 542
Go to this site for coversion table of EURO to US $: http://finance.yahoo.com/currency-co...to=USD;amt=205.
Bill
post #33 of 542
If sufficient time is given would a BFD and REW work as well as an antimode 8033 to save money or is the antimode a vastly superior product
post #34 of 542
If you have the tools and time then 8033 is not better and not vastly superior.I have owned the 8033, it did its job well but there is limited flexibility with it. I like to set specific curves.
post #35 of 542
Do I just need REW, the cables, a PC and SPl meter to go with the BFD??
Does setting up a desired curve also help with resonances and other issues that the Antimode is supposed to help with?? Sorry for the hijack.
post #36 of 542
Originally Posted by allredp View Post
Cool--thanks for that advice. Glad to hear you like the AntiMode in your system! What are you running?
Seaton Submersive It really does a great job of setting the SubMersive up for some great bass.
post #37 of 542
Any Canadians on here buy one of these? Just wondering if there was any surprise costs added to it... brokerage, duties, etc??
post #38 of 542
Yeah, is there a thread outlining this data? Sorry for the ignorance, but what is REW and BFD.
Also, I am sure this can be answered on the main Antimode thread, but does it do a great job (if it can) on dialing in 2 subs to 1 room?
post #39 of 542
I've used my Anti-Mode with both a single sub and a dual sub setups. On duals you still have to know the basic's on how to set them up (gain/level match, phase, location, location, location ). The Anti-mode works with the summed output of the two subs as a single entity, but it does do so very well. Mismatched subs may present more of a challenge as the EQ is not differentiating the signal it sends between them, but if they are a matched pair and set up properly you should be fine. Many people have run multiples (including some who run a sub/MBM set up) and reported good results.
REW is Room EQ Wizard, a freeware app that can be downloaded from another forum, just google it and you should be able to find it easily. A BFD is a Behringer Feedback Destroyer, a pro-audio piece of equipment that is frequently utilized for its parametric EQ features and relatively low price. They are plentiful online or through retail stores such as Guitar Center. The same forum that hosts REW has a dedicated section to each of these items, with FAQ's, set up walk throughs and many knowledgeable posters who can assist setting up, running and then understanding the results given by REW.
post #40 of 542
Yeah, baby!
I'm in the que for the black-oak SubMersive, so I'll know how cool Seaton's masterpiece is for myself very soon--can't wait!
post #41 of 542
Originally Posted by Kal Rubinson View Post
3- That way Audyssey will compensate for the time delay in the AntiMode.
Did you mean #2- calibrate with the 8033-then with audyssey?
If 3, what else?
Joel
post #42 of 542
Originally Posted by spyboy View Post
There is exactly one place to buy the 8033 and the price in dollars depends on the the exchange rate at the time of purchase. Last I heard the price in $$ is $350.
I bought mine from here:
http://www.simplifiaudio.com/room_co.../dspeaker.html
I believe they are the official USA dealer for the Anti-Mode. Great to deal with and shipped fast as well.
There is one for sale right now in the classified section here I believe for a great price.
post #43 of 542
Umm. Yes. How did I and another get the wrong number? Did the OP change the post.
post #44 of 542
If I am running dual subs in opposite corners of my room, would I be better off with the Anti-mode or the SVS ASQ-1?
post #45 of 542
For dual sub, I would get SVS AS-EQ1. It had the ability to adjust the level and phase independently but EQ as a same group. Another plus is EQ1 had more filter than Anti Mode.
post #46 of 542
Could you qualify that statement?
You are comparing apples and bananas here, as EQ1 uses FIR's (finite impulse response) and Anti-Mode uses IIR's (Infinite impulse response). You can argue which is better as long as you want, but that is just an implementation detail and you can get crap and excellent from both.
So, that is not a plus. Still, both products produce great results, so either way you go, you should be satisfied with the improvement.
post #47 of 542
Well, Which one will let me boost frequencies in the 15hz range or really dial in the low end? I know the 8033 is a set it and forget it piece, but does it do a better job and getting the ultra low bass up to par with the rest of the system?
post #48 of 542
It has some low bass boost options that may appeal to you.
post #49 of 542
Snowmanik, I am glad you had success with using the Antimode for duals...but as you said, it is best applied on "matched" subs. As most may know, my dual Epik set-up is NON-Equidistant to the listener and the room. It can be debated how important delay is; however, in my situation I think applying individual delay to each sub would help to create more accuracy. I currently have a BFD dsp1124p and use it for one cut and one boost. In my situation, the subs are [unfortunately] calibrated as one, with no individual delay to each sub. I have yet to come to a conclusion if applying individual filters to each sub, or as one unit is best in my situation.
I just had a light bulb go off in my head....
Would it be a good idea to have this set-up: Reciever --> Antimode --> BFD --> dual subs. This would allow a delay to be set from the BFD to each sub, and than allow the Antimode to calibrate the system as a whole.
**The hardest part would be figuring out what the proper delay should be to each uneven positioned sub.
post #50 of 542
I just received my Dual Submersive HP's (awesome!) and I am wondering if I can use the Antimode to tune them both, even though they are on opposite sides of the room. Will it work?
post #51 of 542
I am also in somewhat similar situation. I have 2 different makes of subs(both sealed) in different locations. One is in left front between the lt & center speaker and the second one is diagonally opposite in right rear behind second row of seats. I am planning to connect both to 8033 but before EQing them I will try to level match them individually. They are at different distances(back sub closer than front) but I am hoping it won't matter as much for subwoofers if I set the delay based on front sub. Any suggestions are welcome. My room has a nasty dip at 40hz at the main seating position. I am limited by where I can place the subs. Can I use BFD just to set the different delay for each sub?
post #52 of 542
Because Anti-Mode will measure the combined response and correct that, it will work. It will work best, if the subs are positioned symmetrically in the room and the listening position.
post #53 of 542
I dont have that option... They are placed on opposite sides of the room with one being about 5 ft closer to the listening position. What is my best bet?
post #54 of 542
Buy two, one for each!
post #55 of 542
I have similar problem with front at 13ft & back one at 7ft because of the room dimensions. I am thinking of setting the delay at 10ft for the subs & calibrating/EQ'ing them together.
post #56 of 542
You might check here instead:
http://www.creativesound.ca/details....l=ANTIMODE8033
post #57 of 542
all Antimode owners,
Just to check with you guys, it was written in the manual to add 90 cm to the subwoofer distance to compensate for the processing lag.
Please correct me if i'm wrong, if there's a processing lag in the signal, should we not decrease the distance by the said amount instead of adding?
But does this makes any difference at all?
Have read reviews in avguide where they have mention reducing the distance of 90 cm instead of adding?
So which is which? Adding or reducing?
post #58 of 542
Anyone running two Antimodes with two subs?
Wouldn't calibrating each sub independently from each other produce better results?
Thanks for any input.
MrJulius
post #59 of 542
No, you add distance b/c it is taking the signal LONGER to travel through the Antimode. It basically delays the signal getting to the subwoofer, thus you have to add distance to compensate.
MrJulius
Good question. I am in a situation similar to Jrunr, but have yet to pull the trigger on something like the AS-EQ1 or Antimode.
Calibrating each independently is good, but it is often thought that the best results would happen if the subs are calibrated together AFTER calibrated individually so that their interaction in the room can be taken into consideration. Yes, you can eq them flat individually; however, it is not taking into account how they will interact with each other when operating at the same time. Some people may argue that FLAT + FLAT = FLAT response; however, that is not always true.
post #60 of 542
Your reciever or prepro will do that when setting up the sub during speaker setup and calibration. If you notice in the menu that the sub distance is probably set to more distance than what it actually is.
