AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Antimode 8033
Antimode 8033 - Page 12
post #331 of 533
Originally Posted by Joshjp View Post
If you use 2 subs with the Anti Mode does 1 need to be at 180 PHASE?. THANKS
No! You can use a "Y" splitter on the "0" out to go to 2 subs. I do it all the time. Once had quad subs in a room and using 3 Y splitters to 2 groups of 2 subs and it worked just fine.
post #332 of 533
Originally Posted by A L Wong View Post
These are the DECAY of RAW without any calibration and with AM8033.
The difference is audible with reduced ringing. My ceiling rattles are no longer audible.
Thanks. Nice improvement. I'm wondering is Antimode boosting the lower amplitudes by 5dB or they rises up automatically due to reduction of peaks?
post #333 of 533
Does anyone know if the AM8033 corrects for differences in distance in a dual subs system where one sub is near field, about 1.5 feet away whilst the other sub is about 9 feet away?
The near field sub ( phase set at 180) is connected to the 180deg phase output and the further one ( phase set to 0 deg) is to the 0 deg phase output.
Is it essential to set the phase to 180 and 0 deg corresponding with the respective outputs on the AM8033 the subs are connected to?
A friend suggested to vary the phase of the near field sub so as to obtain the same distance as the further sub by using the AudysseyXT on my AVR.
Then to run AM8033 followed by AudysseyXT with this phase setting.
Will this method correct for the time domain difference or is it done automatically by AM8033 regardless of the phase setting?
I hope I am not confusing you guys.
post #334 of 533
Antimode 8033 treats the whole bass as mono bass. It does not know if you have single or dual subs. Antimode cannot individually time-align each subs, unlike Audyssey Sub EQ HT.
When plugging in Sub A (with 0 phase) to the 0 output, and plugging in Sub B (with 180 phase) to the 180 output, both subs are finally at the same phase, ie 0.
post #335 of 533
I run 3 Submersives off the "0" output on my 8033 with "Y" splitters. Awesome output and the room and seat shake.
post #336 of 533
I have 4 subs connected to 8033. Front 2 are 14 ft away & connected to 0 output whereas back 2 are 8ft away connected to 180 output with SMS1 in the chain before 8033 to visualize/tweak the response/EQ further. With rear subs out of phase in my room the response is much smoother without rattling/booming & seems like inverting the phase on the rear subs has time-aligned them to some extent. Response is also much smoother around the crossover region.
post #337 of 533
Vinodk,
Please may I ask how the rear subs are out of phase?
Do you mean the rear subs' phase knobs are set to 0 phase but connected to the 180 deg phase output on the AM8033?
If not how did you set them to be out of phase with the front subs?
post #338 of 533
Thats correct, I left the phase knobs on the subs at 0 & connected the subs to 180 output on 8033.
post #339 of 533
Thank you for the clarification.
I think I will try this when I have the time.
The distance mismatch in my case is rather significant and I wonder if adjusting the phase will ameliorate the time alignment issue.
The other alternative would be to use a digital delay between the rear sub and the 8033.
post #340 of 533
Originally Posted by Brady84 View Post
When you combined the XT and the 8033 did you run the XT first and then the 8033 second or did you just combine the independent calibrations? Running them in order would have a much different (likely better) effect than just combining their independent calibrations where they may be doubly trying to fix the same frequency causing a worse response than without them.
Originally Posted by globalgreg View Post
Calibrate the Antimode first, then run Audyssey.
Yes, that is exactly what I did as the last step to obtain the 'combined' REW FR of the XT and AM8033.
A L,
I think you miss what these guys are saying. You calibrated each of them separately (i.e. with the other off) and then combined them by turning them both on.
The best way to get the combined result is to first calibrate with the 8033, leave it active, and then run the Audyssey calibration with the 8033 in the chain.
Would you be willing to do this and post the graph? It would add to your already very helpful post above.
post #341 of 533
Originally Posted by nlpearman View Post
A L,
nlpearman
I have tried to make myself clear that I have done exactly as what you have suggested.
Maybe my labeling of the combined AM8033 with XT is misleading, but I did the 8033 calibration first, then left it active, and proceeded to do the XT calibration.
In to tal I did three calibration.
1. Just AM8033 self calibration.
2. Just Audyssey XT 3 position calibration
3. With AM8033 active, did a 6 position audyssey XT Calibration for the combined graph.
post #342 of 533
nlpearman
And re-reading the posts, you're absolutely right. My mistake.
Thank again for your informative comparison graphs. Good stuff.
post #343 of 533
It's time to get a new toy to play with and the "DSPeaker Anti-Mode 8033C" seems like the right toy to get. From research, my understanding, unless one has stereo sub pre-out capability, there's no benefit purchasing the more expensive 8033S. If there's benefit, I'm happy to get the more expensive 8033S II.
For general information purposes, we're currently running a pair of subs attached to a Marantz, SR5007 which has two separate (mono) sub pre-outs and Audyssey XT. In the near future we definitely will be upgrading the subs but do not have plans on upgrading to XT32. My question, do I get the 8033C or do I get the 8033S II? Will I be shortchanging my efforts getting the 8033C and will there be benefit getting the more expensive 8033S II?
post #344 of 533
I have the 8033C and I believe the main benefit to the S model (apart from its stereo capability) is that it will EQ to a higher frequency cutoff than the C model. However, unless you have a high xover setting (say 120hz or higher), I don't believe it makes much difference.
post #345 of 533
Thanks Ovation. Our settings are 120Hz with what ever the Audyssey crossover settings are set at. The 8033C can be had at TweekGeek. Do you or anybody else have any dealing with them as at $350.00 USD, they have the best price I've found. I just need to make sure I'm not shortchanging the purchase over a hundred dollar difference.
Edited by BeeMan458 - 11/22/12 at 12:15pm
post #346 of 533
(scroll down to comparison sheet)
Fifty percent more filters, greater frequency capability, an additional lift mode, capable of stereo in/out and upgraded firmware.
I purchased from Bob at Creative Sound Solution, delivered, for $450.00.
post #347 of 533
I just upgraded from the original to the 8033Cinema and also bought from creative sound solution. enjoy your new toy.
post #348 of 533
It's the waiting that kills ya.
Now I want an Omnimic setup so I can see what's what with what.
post #349 of 533
Dbl post. D'oh!
post #350 of 533
I read that both UPS and Fedex are going on strike today.
post #351 of 533
What ever happens, the 8033S II that was ordered will be delivered via USPS.
post #352 of 533
Curses, foiled again.
post #353 of 533
After reading through this thread I'm going to have to get one. Something to play with.
post #354 of 533
Okay, fine, I'll call them up and ask them to change the shipper.
............(Not!)...................
post #355 of 533
Boys and their toys!
post #356 of 533
And the party's at your house.
post #357 of 533
Enjoy. I would likely spring for the S-II if I were looking for one right now (the extra filters are the biggest selling point for me) but I'm quite happy with my current model. If I ever add a sub to the living room system, I'll likely move my current 8033 up there too and get the S-II for the HT (or whatever they have at the time).
post #358 of 533
I might be interested in selling my 8033S and upgrading. Anyone know the best place to sell one? They seem to be few and far between on eBay.
post #359 of 533
I'd be happy to do a short review but I haven't picked up an OmniMic yet and other than Audyssey, MultEQ XT, which I'll layer on top of the Anti-Mode, I have nothing else to compare it to.
Have you picked up a room analyzing program like OmniMic?
post #360 of 533
PM sent about your antimode.
