AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Antimode 8033
Antimode 8033 - Page 19
post #541 of 554
Originally Posted by Brian Fineberg View Post
Ill find out soon. I just bought an 818. Ill let you know. If so there will be an antimode for sale soon smile.gif
Might want to check a few searches here because I think I've read the XT32 implementation in the 818 is "crippled" as in it does not include the full sub EQ component? I could be wrong on this. Just a friendly heads up.
FWIW, I've used an onkyo 905 (with XT) with the antimode S-II and it does not sound as good as my 5009 with XT32 alone. I haven't run any graphs, just my opinion.
I will most likely sell mine soon.
post #542 of 554
Put up my 8033S in the classifieds.
post #543 of 554
Originally Posted by BeeMan458 View Post
Hint, hint, you can download REW for free:cool: But the rest of it is going cost's ya.tongue.gif (Something to be considered.)
Difficult to use with a Mac!
post #544 of 554
Why? Upgrading? Not useful? Over promised?
post #545 of 554
Upgraded to an AVR with Audyssey XT32. Bass is so good with justt XT32 that I figured I don't need it. Too lazy to see how it is with both the Antimode and XT32. biggrin.gif
post #546 of 554
Originally Posted by globalgreg View PostUpgraded to an AVR with Audyssey XT32. Bass is so good with justt XT32 that I figured I don't need it. Too lazy to see how it is with both the Antimode and XT32. biggrin.gif
Ah that make sense I heard the XT 32 is very goo, which AVR
post #547 of 554
The Denon AVR-X4000. I like it a lot.
post #548 of 554
I have a SC-61 pioneer elite on the way, and was considering grabbing a 8033Cinema for my VTF15H.
Couple of questions:
  1. I understand I run the 8033 cal before proceeding with MCACC, but what about sub gain control which wont be tweaked until you see MCACC results? Does that have no bearing on the Anti Mode Cal.
  2. Is there anything in MCACC I should have OFF when using the anti mode?
The manual just makes it like you hook it up, let it do it's thing for 10 mins or so, and then it'll apply that room correction to the sub channel coming in going forward. I get that the signal runs through the Anti Mode and it applies the filters (same principal as a calibrated video processor before the display), but I guess the gain setting is what I do not get. Or does the sub gain setting have no bearing on the room response, meaning the sub will report the same response in a room whether the gain knob is a 25% or 50%?
post #549 of 554
Gain or level match the subs first. Run Anti-Mode in front of MCACC and then run MCACC.
Once turned on, Anti-Mode runs through about eight iterations and then automatically turns off. If you have REW, put REW in RTA mode and you can watch Anti-Mode go through each of it's sweep cycles.
post #550 of 554
OK. I only have one sub, so it may be best to run MCACC, determine what is a good volume setting on the sub by where MCACC sets the trim level, then I can go back and run the 8033 setup, then MCACC?
Thanks. My current sub volume was set with an iteration of Audyssey, so it is probably fine where it is.
post #551 of 554
I'm reading the manual for the antimode and I'm a little confused about the lift settings.
Do they boost frequencies, cut them, or both? I see the part where it says it boosts frequencies by 8db. But there's also another section saying it cuts them by -3db. Is that only when both LED's are on?
Also, if anyone knows any sites I can get the 80333S2 cheaper than dspeaker that would be great.
Edited by saprano - 12/13/13 at 11:14am
post #552 of 554
Brian - did you ever try this? What is your opinion on 818 vs. Antimode?
post #553 of 554
Got my 2.0 from here. Very good service. And the DSpeaker is very fast to answer emails if you have any questions..
http://www.simplifiaudio.com/
post #554 of 554
Ok, thanks.
Anybody can answer my other questions?
