Originally Posted by
ratso1
sorry i guess i am confused. i have dual full range stereo outputs on my preamp. i would be running one preamp output to my power amp/main speakers and one preamp output (with some kind of Y cable) to the antimode/subs.
OK
so if i use the antimode cable, the subs would be stereo and if i use a summed Y cable the subs would be mono, if i read you correctly? the mains would still be recieving a full range stereo signal from the other preamp output? or are you saying that both outputs would be affected? sorry i'm not picking up on this, kal - it takes me some time
I do not know what the AntiMode cable is, so I can only comment on the use of a standard Y-cable or one with series resistors in it. The issue is whether your two output sets are independent, each with its own buffer/driver circuitry. In general, they are not in most preamps. In fact, the two sets are usually wired from a common buffer/driver with the equivalent of internal Y-cables.
If this is so with your preamp, then attaching a standard Y-cable between the two you use for the subs/antimode will also shunt together the two main outputs you connect to your amps. The result is that everything(!) is mono. That is why there are Y-cables with resistors in them. They serve to provide a mono signal for whatever use while still maintaining (almost all) separation between the channels on the main chassis.
