I read over both the Denon manual (for various AVRs) and batpig's informative "Denon to English" document, but I'm still unclear on one point: Can you manually adjust the EQ after using the Audessey setup and still use all the Audessey "Dynamic EQ" and "Dynamic Volume" features? I'd like to be able to tweak the EQ a bit on my parents' system in order to compensate for some hearing loss in the upper mid range, but I can't tell if I can do this and still use the Audessey's Dynamic Volume feature.
The Denon manuals and batpig's document both seem to imply that you can do this with the 9 band "Manual EQ" feature, but I've been unable to confirm this. Am I correct that the best approach would be to use the "Base Curve Copy" function to first copy the Audessey's "Flat" auto-calibration curve to the 9 band EQ, and then make adjustments to it manually and select "Manual" for the Audessey's "Multi EQ" setting?
Is there a better way to do this? I'd like to simply make some coarse adjustments to the mid and upper-mid range frequencies while still using the Dynamic EQ and Dynamic Volume features.
Thanks for any clarification on this,
Larry
Larry
