Originally Posted by
batpig
I'm confused -- the Cinema and Music buttons are what you are looking for but apparently you already know about them. Can you explain more clearly what it is you want to do that the Std/Cinema/Music buttons don't let you?
Trust me, you're not as confused as I am.
OK, I'll try to clear it up.
For 2-channel input: if I go into the MENU > ... > Surround Parameter, I can toggle among the various modes: ProLogic, Cinema, Music, Games. Leaving the setting on ProLogic and exiting MENU, the front display will read "Dolby Pro Logic". Hitting the STD button will toggle between Dolby Pro Logic and NEO 6 Cinema/Music. If I hit the Cinema (or Music) button, the display now reads Dolby PL II Cinema (or Music), and hitting it repeatedly toggles between that and Neo 6. Going back to the STD button doesn't give me simply Pro Logic any longer; I'm still toggling between Dolby PL II Cinema (or Music) and Neo 6.
So my question is: how does one choose simply Dolby Pro Logic again without going back in the MENU and selecting it from the Surround Parameter settings? (As a side note, it appears the only way to select Games is to also go into the MENU.)
