For all you audiophiles, a question about SACD playback:
With the input via HDMI (PCM), should Audyssey MultEq be ON or OFF? With it enabled, the sound is very clear, but almost too crisp and a little too much from the surrounds. Turning it OFF, the sound is fuller, more like that from the EXT analogs. It would seem as if that would be the logical way to listen to SACDs (without any processing), but, not being an audiophile, I don't always trust my own judgment.
And for you guys with media PCs:
I'm not sure what the correct setting for HDMI setup --> RBG Range should be: Normal or Enhanced. The CCC for my ATI card allows setting pixel format to:
YCbCr - 4:4:4
YCbCr - 4:2:2
RGB - 4:4:4 Studio (Limited RGB)
RGB - 4:4:4 Standard (Full RGB)
I would think if I have the 2310 set to "Normal", then the ATI card should be set to "Studio." Or "Enhanced" on the 2310 should be paired "Standard." If this is correct, which would be the preferred pairing?
Or should I be sending YCbCr 4:4:4 to the 2310, as my display is native 4:4:4, or so I'm told.
YCbCr - 4:4:4
YCbCr - 4:2:2
Of course, otoh, that just makes it work like all the other receivers that don't have a gui...
Ok, I will turn it off. So much for HDMI-CEC making things easier for consumers...
