what do you mean by "output over HDMI" -- do you mean decoding and then sending OUT multich PCM audio to another device? then the answer is no.
Both can of course decode and PLAY and type of audio. But they can't send decoded audio out via the HDMI -- if the HDMI audio is set to TV it will simply pass the audio through to the sink (e.g. display).
you will not find any receiver that can do what you want, the point is to decode the audio and then PLAY IT, not send it to another device for more processing. I would imagine it could only be done with a fancy (expensive) professional surround decoder/processor.
you may want to mute it
