well, you can do what you feel is best. we keep trying to tell you that there no "right" solution, you have to set it up to meet your needs. but, yes, you generally have it correct:
1 - to use the TV scaler, let the source send NATIVE output and turn i/p scaler on the Denon OFF
2 - to use the DVR scaler, set the DVR to 1080i output and turn i/p scaler on the Denon OFF (but note that the TV will still be involved as it has to do a 1080i > 1080p deinterlace)
3 - to use the Denon scaler, let the source send NATIVE and set Denon to AUTO (or 1080p).
you are still confused about several things:
you don't "set the TV" to anything! The TV can ONLY display its NATIVE RESOLUTION. Always. I assume you have a 1080p display? Then the ONLY thing it can display is EXACTLY 1920x1080 pixels. So, regardless of what you give it, the TV has to display at 1080p. So, the TV will always be doing some scaling unless you feed it a 1080p signal.
So, the question then becomes how you set up your source devices -- do you want them to scale to 1080p first (so the TV doesn't do anything) or do you want them to pass the resolution through (so the TV does all the processing). So, if you want the Denon to scale to 1080p before it ever gets to the TV, set the scaler on the Denon and just input the native resolution from your sources. If you want the TV do the scaling, turn the scaler off on the Denon and let everything pass through.
hugs all around!
