AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread
*OFFICIAL* Denon AVR 2310CI / 890 Owner's Thread - Page 124
post #3691 of 7011
That did it. Thanks!
post #3692 of 7011
Should a Dolby TrueHD bd movies show as such on my 2310? Mine says multi channel.
post #3693 of 7011
It doesn't matter whether the BDP or the 2310 does the decoding of the Dolby TrueHD audio track to PCM. When the BDP does it, the 2310 will display MULT CH IN and you won't get the "blue" HD Audio light. If you want the 2310 to do it, you would set your BDP to "bitstream" and then you will see Dolby TrueHD and the "blue" light.
post #3694 of 7011
Hi - tiny bit off topic. But, I'm looking for a blue ray player with wireless that will stream from Netflix. LG BD390 looks good, but there seems to be some issues with LG and the Denon 2310CI (I have not done the firmware upgrade yet - just got it)
Any other recommendations that work well?
post #3695 of 7011
unfortunately, the netflix streaming players are all the ones that cause the "bug"! LG, Samsung, and the Sony 460 are the major netflix streamers and they all have the bitstream problem. If you are willing to update your firmware, then you can buy any of them with no issue.
Since you mentioned you want wireless, the LG 390 and the Samsung 3600 are (I think) your only options among standalone players. The PS3 has wireless and can also stream netflix if you want to consider that as well.
post #3696 of 7011
Hi, please read the Audio section of my FAQ:
http://batpigworld.com/fadq.html#audio
post #3697 of 7011
Originally Posted by EJ View Post
Contrary to popular belief, DVD=480i
exactly. this is why the advent of the "progressive scan" DVD player was such a big deal, and why the 480i deinterlacing is the critical step of any DVD "upscaling".
even though film is progressive (24 fps) it is stored on disc as telecined 480i/60 (since when DVD standard was developed there were no progressive displays). Being able to properly reconstruct those progressive frames is the most important step in upscaling. Properly done, upscaled SD DVD can look really outstanding on an HDTV (unlike SD cable channels which are garbage analog feeds at heart).
This is a great article if people want to understand more about this:
http://www.hometheaterhifi.com/volum...e-10-2000.html
post #3698 of 7011
Are you saying if I've updated my 2310 firmware to .69 I won't have the bug? I have the Sony 460.
post #3699 of 7011
This was discussed earlier this week here.
This was what I was looking for. I read the poster's question but did not see this reply. Thanks
post #3700 of 7011
I received my 2310 last Friday from Electronics Expo and I was very happy with it until it started acting up. The issue first started Saturday morning when I went to turn it on and no video was shown on my TV (Samsung LN52A750 connected via HDMI) and no audio was heard (I also noticed that nothing showed up on the left hand side of the receiver display where it shows the audio input signal). I switched HDMI cables, disconnected all speaker cables, etc. and even reset the microprocessor.
I eventually moved the receiver into my sons room and connected it to his 360 and Samsung TV and it worked fine, moved it back to my room and it worked for awhile and then eventually after a couple of power cycles stopped working again (I could also get it to stop working on my sons TV). I eventually got it working and it stayed working until today where it started the same behavior all over again (when it does act up, even the radio tuner audio doesn't work). I checked and it currently has firmware update 0079. Is there a bug where it doesn't like Saturday's ;-)
Since the issue is not consistent I am worried about returning it to Electronics Expo since their return policy states that if they can't duplicate the issue then they charge a 20% restocking fee. Has anyone experienced similar issues or have any ideas on what to the check? Any issues returning items to Electronics Expo?
post #3701 of 7011
I am awaiting arrival on my Denon 890 and have a quick question. I currently have a Yamaha 2500 the has the visual set up menu everything in my system now is HDMI and the Yamaha is not. When I tried to run a speaker scan on my system I could not get the OSD to come up. I did fiqure it out by running a cable from the Yamaha monitor to the tv monitor then set the TV to video that brought up the OSD. What do I have to do on the denon to have the OSD come up on my TV? or do follow what I did with my Yamaha?
Dale
post #3702 of 7011
Dale
Its easy after all your components are connected. Turn on Tv, receiver and one of the source. Then press MENU and thats it.
post #3703 of 7011
Thanks for the quick reply what do you mean by source since I do not have the denon yet I just want to make sure I understand.
Thanks again.
post #3704 of 7011
Thanks again.
Source = whatever is connected to the Denon (Sat cable, bluray player, Xbox360, PS3, etc...)
Also if you haven't already, read BATPIG'S "DENON-TO-ENGLISH DICTIONARY" SETUP GUIDE AND FAQ
post #3705 of 7011
Correct.
post #3706 of 7011
The latest firmware version should be 00.69 vice 00.79. Give EE a call and explain your issue. Most likely they'll let you return the unit for a replacement.
post #3707 of 7011
Thanks. I called EE and had no issues getting a RA for an exchange and they are even paying for the return shipping (I had assumed I would have to pay this). My receiver does have the Main Ver = 00.69 and Sub Ver = 00.30 firmware, I thought I had seen it referenced as the 0079 update.
post #3708 of 7011
The firmware update # itself is 79, but the Main Ver that the AVR get's updated to is 69.
post #3709 of 7011
I'm looking for some help regarding the OPT-2 DVR Output and getting signal over it. I don't think I'm doing something right, and I've submitted another thread here:
AVR-890/2310CI DVR/Bluetooth Headphones Setup, OPT-2 Out not sending audio
Could owners try to check this out?
post #3710 of 7011
To get OPT-2 (DVR) OUT to work connect source to OPT-2 (DVR) IN
post #3711 of 7011
Does the source have to be live or can I just plug a dead TOSLink cable in?
Will OPT-2 OUT only send signals from OPT-2 IN or will it send signals from HDMI inputs as well?
post #3712 of 7011
I have try this and it only works with OPT-2 IN. No signals is transfer to OPT-2 OUT from other connections beside OPT-2 IN.
post #3713 of 7011
So how can I hook up wireless headphones to a Denon AVR890?
post #3714 of 7011
Well I had a friend that came over with a Turtle Beach X41 wireless headset. And the only way was to set it up running optical cable from Xbox 360 to OPT-2 IN and then OPT-2 OUT to X41 receiver.
post #3715 of 7011
But you only were able to get sound from the Xbox, correct? No audio from other sources still?
I am trying to find a solution where I can get output from all sources.
post #3716 of 7011
Thats correct, only the Xbox.
post #3717 of 7011
So does a method exist to get output from all sources?
post #3718 of 7011
Sorry ngordon, I'm not sure about that. Maybe jdsmoothie, batpig, SoM or others can chime in with a solution.
post #3719 of 7011
You can connect your components to an optical switch first, then connect the switch to the OPT2 IN jack.
post #3720 of 7011
If I were to use an optical switch, I'd have to rely on it to change inputs and it would only have a single output to my Denon. I'd lose all the ability to set "per input" settings on the Denon, not to mention it would be ridiculously expensive!
Could someone just confirm or deny that there's a way to get line level audio output from all sources on this receiver?
