AVS › AVS Forum › A/V Control & Automation › Remote Control Area › NHT COntroller -- Discrete on and off Commands
post #1 of 4
Can anyone help with discrete on and off power commands for the NHT Controller? Thank you!!!!
post #2 of 4
The NHT codes for UEI/JP1 are HERE. The discretes are in there. Not sure exactly what you need, but you can convert those to pronto if necessary.
post #3 of 4
This might be helpful:
http://nhthifi.com/current/manuals/c...mote_codes.pdf
What format do you need the codes in? If you need them in long form Pronto hex code, it will be a bit of a problem since the ir code uses RC5 which has a toggle bit. If your remote can accept the Pronto short form, I think it will be able to do toggle bits correctly.
post #4 of 4
Thank you!
The problem is that when switching say from blu ray player to cable, the controller shuts off (because it is already on and we apparently have a toggle on/off command rather then just an on command).
  Back to Forum: Remote Control Area
