Since there is some info coming out on this Receiver I wanted to start a thread specifically for it.
On the Denon website-
http://usa.denon.com/ProductDetails/5118.asp
Owners Manual-
http://usa.denon.com/AVR-4810CI-OM-E_007.pdf
Specs-
- Like the new Look GUI to.
Shaping up to be another great Denon Receiver.
More info here-
http://www.avclubhouse.com/?p=1084&preview=true
Owners Manual-
Specs-
AVR-4810 October $3,000
Next Generation 9.3 A/V Multi-Source/Zone, Network Streaming Receiver • All new DDSC-HD • Dolby TrueHD and DD+ • dts-HD Master Audio Audio decoding • Dolby PLIIz matrix decoding for Front Height effects • Audyssey DSX (Dynamic Surround Expansion) decoding for Front Height and/or Front Width channels • HDCD decoding • Features latest 32-bit Floating Analog Devices SHARC Processors • 9 channels equal power amplifier section, Multi Mono-block construction • 140 watts per channel (8 ohms, 20 – 20kHz, <0.05% THD) • Burr-Brown 24-bit, 192-kHz, PCM-1791A DACs on all 8 channels configured in differential mode • 3 Source/Zone capable, including 2 with video • 1080p Compatible HDMI 1.3a Deep Color (6/2) Repeaters, Dual outputs • Front Panel HDMI input • Fully assignable channels for biamping, Surround channels or Multi-Zone applications • Assignable +12v, 150mA triggers (2) • Assignable Ultra-Wideband (100 MHz) Component inputs (3) • Analog/HDMI Video to HDMI Scaling (1080p) featuring Anchor Bay Technologies processing (ABT-2010), with GUI overlay • Vertical Stretch for CinemaScope Screens • Digital to Analog conversion for Multi-Zone connection flexibility • Rear panel RS-232C and Ethernet ports for Crestron/AMX control communication • Ethernet port with built-in Multi-Media Command and Control functionality • Web Browser Control • Windows Vista Certified, and Windows 7 compatible • Dedicated iPod™ control port (for use with optional ASD-11R Dock, with on-screen display and remote control • DLNA Certified • Remote Access and Firmware Update/Upgrade via Internet • Internet Radio, Rhapsody and Napster • Audyssey MultEQ XT and Audyssey Pro Installer Ready, calibration microphone included • 4 Assignable digital inputs • Denon Link 4th, featuring Clock Control with HDMI • Front Panel USB Port • iPod Digital Direct USB Connectivity (Audio only) • AM/FM HD Radio tuner with auto preset FM memory (56 stations) • XM and Sirius Radio Ready • New GUI for Main Zone, with independent On Screen Display for Zone 2 • New EL learning/pre-programmed Remote Control • Detachable Power Cord • Serial IR ports • Second, Multi-Zone Remote included • Sleep Timer
More info here-
