How will 4810 compare to 4310?
I think it's pretty much analogous to 3808 vs 4308 last year: you get a bigger chassis, beefier amps, wifi, component video output to Zone 2, and greater overall flexibility and settings options. Video processing and general features / functionality are the same.
this year though, the biggest difference is that the 4810 has 9 amps and 12 channels of processing (11.1) with a huge amount of flexibility in how you distribute those amps/channels. The 4310CI is just a 7.1 receiver (so if you use DSX or want to power Zone 2, you would have to sacrifice the rear surrounds in 7.1 to add heights/wides or Zone 2 speakers); the 4810CI can do a full 11.1 DSX setup, or run a 7.1 setup with powered multizone, or a 5.1 setup with two powered zones, etc. If you have external amps for Main Zone you can dedicate even more amps to MultiZone.
