Originally Posted by scolumbo
Gapless playback means no pauses between tracks. Think of Dark Side of the Moon, Abbey Road, or other recordings where one track transitions to another without a gap, or pause. Playing from a HDD, the Oppo will introduce a pause of about a second between the tracks. I have also tried many different DLNA servers, and all have pauses between tracks when streamed to the Oppo.
It's the biggest disadvantage to playing music from a HDD or streaming music via DLNA to the Oppo, IMO. Foobar and other media players can play gapless from a pc or htpc. I'm curious if other media streamers offer gapless playback.
A workaround is to rip a single full-disc FLAC with a cuesheet but even then, the Oppo won't play gapless if played from the cuesheet. You can get gapless playback by playing the full-disc FLAC directly, but then you don't get track info, or navigation control (selecting tracks, Stop, Pause, etc.) when playing directly from the full-disc FLAC file.
If I can get true gapless playback with a WDLive NAS, then it would be time to retire my WD MyBook World Edition NAS. Can you verify that you get no gaps by playing Dark Side of the Moon, if you have that recording?
BTW, I use the same process for ripping FLACs from DVD-A discs, although I've settled on DVD Audio Extractor as my preferred ripping software vs. DVD-A Extractor.
In between hammer blows on the media room remodel/expansion I was able to get in there and test the "gapless" on the -93. You are correct: When streaming it will add about a 1 sec gap on the playback - I tried my LOVE DVD-A and it misses a beat or two at the start of each track. Never noticed this before or paid any attention..........
Sorry if I got your hopes up; However, can't you just merge/join the album side flacs into 2 files - one file for each album side? They will be big files but I think the -93 can handle them.
I use a freeware program called HJSPLIT which shows on the console that it will both join and split files. I have only used it to split files so I don't know about its effectiveness on merging/joining but I am sure there are plenty of programs that will do that if HJSPLIT doesn't. If you try it, please let me know how it works as I may do that also. I only have about 5 discs that would require this so it wouldn't be too big a task to handle.
