OK, it is 2009 and in a month or so it will nearly be time for football. I will soon be in the market for a new bedroom TV. Size will probably be 32", but 37" could be a possibility. Since plasma does not come in these sizes, LCD is my only option.
Since I will be watching cable, including SD and HD programming (football), I am leary about motion and LCD.
Which set should I be considering. Have read through thread after thread and am confused. Need some straightforward, knowledgeable answers: Which LCD should I get for the bedroom for HD football? AND some movies on DVD?
Distance from my eyes to the TV would be in the range of 12-14 feet.
Mike
Mike
37 inch would be better, but a 40-42 would be the minimum I would suggest. I realize you probably have to consider price, space and WAF, but go bigger if you can. Just my 2 cents...
). It looks just like the pic posted above by yuhang.
However, most are in agreement that a 32 inch set is way too small at a 12-14 foot viewing distance. TVs have evolved like everthing else in the last 25 years. People used to drive cars without power steering or air conditioning, too. As for aesthetics, I have seen 50 inch sets installed in bedroom armoires, 60 inch sets wall hung over large dressers and so on. Just because it is big does not necessarily mean it cannot tastefully be placed in a room.
