AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Have You Ever Seen A Modern Plasma TV With BURN IN?
post #1 of 45
Please vote YES
If you have personally seen a modern plasma display (> 3 years old) with real, actual, permanent, burn in. These burnt in images should not fade, or change in any way, even after repeated attempts to clear them.
Do not count temporary image retention, or persistent image retention that does fade and then returns quickly.
For the sake of accuracy please don't count hearsay accounts of others.
Please vote NO
If you haven't.
If you vote yes, please include model, brand, actions taken to remove the burn in, and if the manufacturer covered this under warranty. Thanks to all.
post #2 of 45
If yes, what did they do to cause it. what was viewed and how long over all/how new was the tv/etc.
post #3 of 45
Good points.
post #4 of 45
hmmm one guy said yes put didn't care to share. A guy from the lcd section maybe
post #5 of 45
My uncle recently upgraded a LG50pc5d which did have a minor burn in problem. For some reason, all cable channels from their cable box gave a small grey line along the top of the image (i know it sounds stupid, but we have a similar problem with our comcast service) I say burn in, because I know they tried running only movies for an entire weekend to mix it up, but I saw the set and the 2 straight days of video did nothing or at least nothing noticeable to the line.
I think its hard to fault the plasma, b/c i know that tv spent alot of time on for normal viewing and cant imagine how many hours that bar just sat on screen constantly..
I only bring it up as a warning to anyone who may have bad cable service like us, and get those lines along the edge of the screen.
*edit: and to be fair, I don't think any break in or anything was done to the set, aka not treated that well..
post #6 of 45
Yes but qualified: I work for a bank that bought several Panny plasmas and the branches, rather than keeping them tuned to the HDMI ports running the ads that they were bought for, left them on CNN or whatever, so lots of image retention, at least. And I have friends who own plasmas that complain of "burn in" using PS3's and the like but, after banning the games from their TV's, that seems to clear up. I haven't actually seen permanant damage on a plasma yet, although most people I know own LCD's. (I own a 8G Kuro and mix up the content, so no issues here.)
post #7 of 45
Never seen it. I have seen some bad IR at best buy though. TV was stuck on the Prirates of Caribbean Blu Ray menu all day. I turned it off to see and it was all over the screen. Came back the following day and it was gone. It was an LG plasma.
post #8 of 45
my father-in-law has a 3 year old samsung 42" plasma. he watches a lot of old 4:3 movies and both sides of the screen have major burn-in. however: he has not tried using the built-in un-burner setting in the menu, nor anything else to get rid of it.
post #9 of 45
Thanks for the info. Is this line clearly visible through the full screen video?
post #10 of 45
No, I have not, it must be quite an event with all the ruckus around here about it.
post #11 of 45
Our office has 65" Panasonic's that are left on a static website screen (with no animation or change) for 12 hours a day on average with the screen saver defeated. They are only occasionally used for other images. And still they have not had burn in after almost 2.5 years of that. Ironically, we had a few NEC 40" LCD's setup to the exact same webpage and they DID experience permanent burn-in, which I didn't even know was possible with LCD until it happened to us.
post #12 of 45
Part of the secret LCD dis-information squad.
post #13 of 45
I just became aware of LCD "burn in" recently. Apparently it has something to do with the liquid crystals retaining their state.
post #14 of 45
LCD's don't burn-in. Burn-in something akin to you looking straight at a total solar eclipse. What LCD's have is ghosting, something like looking at a bright light and then closing your eyes while looking away to see a fading image of it.
post #15 of 45
I hear that the actual term is image persistence, but I believe it is a different phenomenon than ghosting. I'm also sure that it is highly unlikely in any normal use of an lcd. The way I understand it, it is the twisted liquid crystals getting used to a state, and not returning to their static twisted state.
It is reversible or reducible in most cases to my limited understanding.
post #16 of 45
You probably just provoked a bunch more to vote yes.
post #17 of 45
Yup, the 151fd at the store had burn in lines from widescreen movies. That's all they played was widescreen and on a all black screen you could easily see the lines and they did not go away, maybe with a all white screen displayed for hours they would of went away, but who knows.
It takes alot of abuse to burn in a pioneer and probably panasonic.
Other brands like samsung-lg-vizio etc you REALLY have to watch out because they are nowhere near as image retention resistant as pio-panny.
post #18 of 45
I have an Insignia NS-PDP50HD-09 with mild burn-in in the lower left and lower right corners from playing too much Gran Turismo 5: Prologue without a break. The digits from the HUD speedometer on the bottom left and the HUD gear position indicator from the bottom right are burned in and look like "088" and "8" respectively.
Once I noticed it, I started running full screen break-in images (saved to the hard drive on the PS3 for quick and easy access) for at least five minutes after each gaming session, and I have not seen any further burn-in.
Have not attempted a warranty replacement because:
1) I'm very happy with the TV considering what I paid for it.
2) It is only noticeable under specific conditions.
3) It's my own damn fault.
post #19 of 45
Just a joke guys.
Everyone knows that the LCD dis-information squad is no secret.
post #20 of 45
Are these only visible on a black screen?
Have you ever tried running full screen video or a break in series overnight for a while to clear them?
post #21 of 45
They are most noticeable on any light or dark image with little color differentiation, and almost unnoticeable (unless you get up very close to the screen) otherwise.
When I first noticed them I ran the break-in images for over 24 hours but that had no effect.
post #22 of 45
Are you still playing this game daily?
post #23 of 45
Call it what you want, but what we got on these LCD's was a PERMANENT retained image. The AV company that provided them tried to address it with NEC and ended up having to replace them.
post #24 of 45
No. I've played it all the way through twice and am now waiting for the full version to be released.
post #25 of 45
Is this section of your screen, with the image, typically black for normal tv watching? Like in the 4:3 border, if you watch that way.
post #26 of 45
I don't have cable or satellite; I only watch a little broadcast HD and a lot of Netflix, probably 80-90% of which has no black bars.
I know you're trying to find a reason for this to be IR and not burn-in, but I've been through everything the last few months and it will not go away. The image is burned in.
But again, I don't blame the set. I got cocky and thought the set was immune to burn-in, and tortured it, and paid the price. With just a slight amount of care, I believe the burn-in would not have happened.
post #27 of 45
It just seems that a few hundred hours of gaming should not be able to cause that under any circumstances that I'm aware of. Thanks for all the info.
post #28 of 45
If I had to make a semi-educated guess, I'd say that it's because the digits are pure white numbers on a black background, and that the bright white pixels wore just slightly more than the black ones surrounding them. That would explain why it is only visible (from a distance anyway) in light or dark scenes with uniform color.
It is my hope that someday, the pixels around the numbers will wear enough to make the burn-in go away.
And if I ever buy another plasma (and I would, over LCD, without question) I won't be so dumb.
post #29 of 45
If it's any consolation, I don't think your usage is the cause of this. It's more extreme than most peoples, but I don't think in other circumstances (another brand or even another unit of the same model) that you would get the same result.
post #30 of 45
I ahd an old computer crt that had burn in, but it was more like parts of the screen did not burn in, they just did not "burn" as much as much due to bar type issues---I was using it primarily for photos and photoshop---and where the area was almost always very dark, it seemed not to have "faded" as much, so i could see the difference when viewing certain things
on the 63b550, i sometimes see some ghosting like with Costners' wyatt earp in the dark bar scenes, but it is more a brief smear when there is movement, then it is gone
