AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Open Range (FRN) comparison *PIX*
post #1 of 111
The PQ is decent. Some ringing here and there. No obvious DNR or waxy look. I may have to agree with others here the contrast and color timing is a bit too "harsh" for my taste. I hope they use the transfer closer to the "look" of the DVD when it get released in the US. The cinematography of this western movie is gorgeous and the initial BD transfer does not do it justice.
Now I know some of you is thinking "Who cares? How is the lossless sound?"
The climactic shootout is the Audio demo scene. Perfect for "breakin' in" your subwoofer. My twin Velodynes handled it quite well
post #2 of 111
post #3 of 111
post #4 of 111
post #5 of 111
post #6 of 111
reserved for future use
post #7 of 111
Blu-ray File size: 17.00> GB
Bitrate: 17.56 mbps
Blu-ray File size: 30.10 GB
Bitrate: 24.97 mbps
Code:
        Total   Video
00001.MPLS                                                      VC-1    2:18:53 32,412,223,488  40,576,227,412  31.11   24.97   DTS-HD Master 5.1 2002Kbps (48kHz/16-bit) DTS 2.0 256Kbps (48kHz/16-bit)
DISC INFO:
Disc Title:     OPEN_RANGE
Disc Size:      40,576,227,412 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.1
PLAYLIST REPORT:
Length:                 2:18:53 (h:m:s)
Total Bitrate:          31.11 Mbps
Description:
VIDEO:
VC-1 Video              24969 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         2002 kbps       5.1 / 48 kHz / 2002 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Audio                    French          2046 kbps       5.1 / 48 kHz / 2046 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS Audio                       English         256 kbps        2.0 / 48 kHz / 256 kbps / 16-bit
SUBTITLES:
Presentation Graphics           French          21.661 kbps
Presentation Graphics           French          36.190 kbps
FILES:
00002.M2TS      0:00:00.000     2:18:53.950     32,412,223,488  31,113
CHAPTERS:
1               0:00:00.000     0:07:54.474     25,157 kbps     42,038 kbps     00:05:26.034    36,318 kbps     00:05:22.071    33,245 kbps     00:03:12.692    131,275 bytes   366,143 bytes   00:06:11.996
2               0:07:54.474     0:08:08.279     26,412 kbps     41,712 kbps     00:13:36.148    35,951 kbps     00:13:32.978    33,323 kbps     00:13:27.973    137,698 bytes   474,944 bytes   00:13:43.322
3               0:16:02.753     0:10:31.631     23,697 kbps     37,605 kbps     00:16:25.067    33,746 kbps     00:16:25.067    32,245 kbps     00:16:22.564    123,543 bytes   363,524 bytes   00:16:25.693
4               0:26:34.384     0:07:22.442     24,117 kbps     44,048 kbps     00:31:32.140    34,295 kbps     00:28:04.891    32,985 kbps     00:27:59.886    125,854 bytes   378,803 bytes   00:31:19.878
5               0:33:56.826     0:07:25.820     27,786 kbps     40,535 kbps     00:39:09.305    34,814 kbps     00:39:05.343    33,012 kbps     00:36:44.160    144,861 bytes   349,587 bytes   00:34:51.464
6               0:41:22.646     0:11:41.158     24,358 kbps     45,766 kbps     00:43:16.927    33,704 kbps     00:47:42.276    32,599 kbps     00:47:27.886    126,990 bytes   479,017 bytes   00:43:16.969
7               0:53:03.805     0:08:49.529     28,033 kbps     44,609 kbps     00:54:09.120    35,076 kbps     00:53:27.579    33,334 kbps     00:54:57.669    146,153 bytes   388,430 bytes   00:56:04.402
8               1:01:53.334     0:09:07.797     27,423 kbps     43,120 kbps     01:06:31.946    35,464 kbps     01:08:15.007    33,363 kbps     01:08:09.919    142,971 bytes   366,174 bytes   01:06:32.405
9               1:11:01.131     0:10:01.726     27,758 kbps     44,597 kbps     01:11:17.564    33,840 kbps     01:11:15.521    32,465 kbps     01:18:37.504    144,716 bytes   347,845 bytes   01:18:46.471
10              1:21:02.858     0:09:23.896     24,392 kbps     32,523 kbps     01:27:34.958    29,855 kbps     01:21:55.827    29,484 kbps     01:21:55.660    127,167 bytes   320,546 bytes   01:23:31.589
11              1:30:26.754     0:09:15.263     22,969 kbps     38,344 kbps     01:35:24.844    33,114 kbps     01:37:05.569    31,796 kbps     01:35:34.520    119,751 bytes   376,844 bytes   01:35:42.153
12              1:39:42.017     0:10:36.385     26,426 kbps     44,295 kbps     01:43:29.453    35,120 kbps     01:47:27.774    33,481 kbps     01:42:10.499    137,773 bytes   455,566 bytes   01:49:04.162
13              1:50:18.403     0:09:14.345     25,089 kbps     39,600 kbps     01:56:22.183    34,043 kbps     01:56:38.074    33,770 kbps     01:56:14.342    130,802 bytes   387,901 bytes   01:56:03.373
14              1:59:32.748     0:08:22.251     23,077 kbps     37,257 kbps     02:07:53.791    34,633 kbps     02:00:39.982    32,256 kbps     02:00:39.982    120,315 bytes   398,814 bytes   02:07:50.704
15              2:07:55.000     0:06:20.046     25,112 kbps     41,373 kbps     02:08:58.772    33,735 kbps     02:08:13.268    32,446 kbps     02:08:09.181    131,095 bytes   438,402 bytes   02:08:25.864
16              2:14:15.047     0:04:38.903     11,546 kbps     28,005 kbps     02:14:59.299    26,861 kbps     02:14:57.047    26,473 kbps     02:14:58.173    60,451 bytes    324,160 bytes   02:15:08.767
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0xEA            VC-1                                    8333.826                24,970                  26,011,761,579  141,488,707
00002.M2TS      4352 (0x1100)   0x85            DTS-HD HR       fra (French)            8333.826                2,046                   2,131,408,224   12,500,928
00002.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           8333.826                2,002                   2,085,127,124   12,637,350
00002.M2TS      4354 (0x1102)   0x82            DTS             eng (English)           8333.826                255                     265,644,720     1,562,616
00002.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            8333.826                22                      22,564,732      131,094
00002.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            8333.826                36                      37,700,778      213,759
post #8 of 111
I prefer the HDnet captures. The blu-ray's color looks too warm and artificial looking.
post #9 of 111
The BD also has blown highlights and is mushier than the HDNet broadcast.
post #10 of 111
Holy cow. That is, well, shocking.
post #11 of 111
What the hell. If it is not one thing it has to be another?
Clouds play a big role in the cinematography and is meant to be seen which is evident in the DVD and the broadcast version; considering how prominently the skyline is featured in shots.
Look how an overcast day has now become a scorching dusk shot instead. This changes the tone of cinematography and it wasn't meant to be a Leone film, I do love his films though.
Now the grain structure really stands out more than it normally would. I actually remember the look of this film from the theater and it didn't appear like this.
HDNET, looks superior. Man, I love this movie.
(FRN)? Is that for French release?
Oh, please don't let it be this bad in the US.
Best Regards
KvE
If this is release by Sony they are schizophrenic, Run Lola Run suffers from ganked contrast along with the recent Ghostbusters.
post #12 of 111
Ouch.. I agree the HDnet broadcast looks the best..
The Blu-Ray looks off...
post #13 of 111
I thought the HDNET version looked better at first, too, but now I don't know; upon further analysis, it looks like grain has been improperly minimized and as for detail, look at the background trees and mountain terrain in post #2...there's much more texture, detail and color variation shown in the Blu-ray.
post #14 of 111
I love this movie, the EE on the dvd is pretty bad and the BRD is odd.
Looks like I will have to keep waiting to watch it at home
post #15 of 111
Yes, only color and brightness seem to be better on the broadcast version, compression and detail are much better on the BD, even though it's a far cry from a real, unmolested, unfiletered presentation from a good source.
Too bad, the movie is just fantastic!
post #16 of 111
I agree, the HDNET version looks over worked and robbed of the rich color I remember from the DVD version.
post #17 of 111
The HDnet version and the dvd are from the same transfer though.
post #18 of 111
HDNet version is heavily DNR'd in the latest shot posted. But the BD seems to be in color torch mode. Who knows what color timing is right? Only a direct comparison to a print will reveal the truth.
We can certainly see that the color is way different in the BD compared to the HDNet and DVD versions. We can also see the HDNet version has been filtered to hell and back.
Oh well. I'll just rent this one.
post #19 of 111
Oh, so this is where they misplaced Do The Right Thing's yellow filter.
"It's the hottest day of the summer on the open range..."
This is a great movie and I look forward to the NA release (with a great transfer).
post #20 of 111
If they intended to make it look realistic, I'd guess the greenish tint of the Blu-ray isn't right. Weathered wood looks gray. To make it worse they cranked up the saturation to the point where there are strange colors. I've never seen pink and green colors in the sky as in the shot of the two guys on the hill.
post #21 of 111
The Blu-ray disc version color balance is off, it is yellow (someone removed too much blue in the process). As for detail, look at the green lamp shades in the bar scene. There is much more detail in the HDNet version.
post #22 of 111
I got this BD and in actual viewing, it looks pretty darn good. I prefer it over the HDNet version, which I also have. The latter looks a tad washed out to me, but I agree the French BD is a tad warm. As for detail, the BD has more, easily noticeable, again in actual viewing. I'm using a 120" 2.35:1 Dalite HP screen w/a Panny AE3000U PJ.
post #23 of 111
BD: contrast boosted
post #24 of 111
Hmm...you're right...not to mention, the HDNET version makes it more clear that the sign behind the counter reads "No Varmits or Vagrants"...but I stand behind the town establishing shot having a more detailed background on the BD, so we appear to have two transfers that dance back and forth throughout on which offers the better overall experience (the compression artifacting alone in the HDNET shots is horrifying). Can we all agree that none of these transfers is up to the par we'll hopefully find one day when there's a U.S. BD release?
post #25 of 111
sheesh, look at the forcefield around Costner, even in the BD....
post #26 of 111
Look at: the balcony railing on the Haidin & Regan store, the window on the side of the General Store, all show better detail on the HDNet version.
post #27 of 111
post #28 of 111
I had this disc - for 3 days and sold it. Audio was f'ed up - voices all sounds like they took a small hit of helium. Directly compared it to the DVD audio - very much noticeable to me. The French Dances With Wolves was worse. Regardless of the DNR, the HDnet version looks much better to me - did not like the colors at all on the BD.
How long ago was this on HDnet? I've had it for a while and do not recall seeing it in the listings.
post #29 of 111
Holy amber, Batman! Great movie, but I'll be sticking with the DVD.
post #30 of 111
How's the audio on this BD? The gun shots on the DVD version was one of my reference scenes.
  Back to Forum: Blu-ray Software
