| Originally posted by jotter Hi, The SwapDV application allows you to manage your own digital video library, based on content backed up from from your replay TV. It combines the functionality of a replay client (Yet Another Replay Client), a replay server (Yet Another Replay Server) and a replay guide editor :) The application is for all platforms. A small feature list: * connect to a replay TV and browse its contents * download mpegs (raw/modified) * save and edit guides (raw/header stripped) * import digital video into your local server, either from your replay TV or from your disk * edit, add, remove shows and channels * emulate a replayTV box on your local network * "real" replay TVs can play back videos from your server SwapDV 0.5 and source code released. Go to http://swapdv.sourceforge.net to download the new version and/or sources |
ReplayTV doesn't subscribe to the Canadian TV listings (even though their supplier, Tribune, does have them available. But if I could somehow reassign the Buffalo or Niagara Falls cable stations to the channels they are received on for the Toronto cable system, I'd have all but a few stray channels accessible with up-to-date program guides! So what I'm hoping to be able to do is regularly download a neighbor-town's listings, edit the guide to reassign the channel numbers as they occur locally in Canada, and then send the edited guide back to the ReplayTV. Would I be able to use SwapDV to do that? I know it's not your primary goal, but if it works as a side effect you can make many people happy!
